1 |
/* Copyright (c) 1997 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for tone mapping on Radiance RGBE and XYZE pictures. |
9 |
* See tonemap.h for detailed function descriptions. |
10 |
11 |
12 |
#include <stdio.h> |
13 |
#include <math.h> |
14 |
#include "tmprivat.h" |
15 |
#include "resolu.h" |
16 |
17 |
18 |
extern char *tempbuffer(); |
19 |
20 |
#define LOGISZ 260 |
21 |
static TMbright logi[LOGISZ]; |
22 |
static BYTE photofact[BMESUPPER-BMESLOWER]; |
23 |
24 |
25 |
int |
26 |
tmCvColrs(ls, cs, scan, len) /* tone map RGBE/XYZE colors */ |
27 |
TMbright *ls; |
28 |
BYTE *cs; |
29 |
COLR *scan; |
30 |
int len; |
31 |
32 |
static char funcName[] = "tmCvColrs"; |
33 |
COLR cmon; |
34 |
register int i, bi, li; |
35 |
36 |
if (tmTop == NULL) |
37 |
returnErr(TM_E_TMINVAL); |
38 |
if (ls == NULL | scan == NULL | len <= 0) |
39 |
returnErr(TM_E_ILLEGAL); |
40 |
if (tmTop->flags & TM_F_NEEDMAT) { /* need floating point */ |
41 |
register COLOR *newscan; |
42 |
newscan = (COLOR *)tempbuffer(len*sizeof(COLOR)); |
43 |
if (newscan == NULL) |
44 |
returnErr(TM_E_NOMEM); |
45 |
for (i = len; i--; ) |
46 |
colr_color(newscan[i], scan[i]); |
47 |
return(tmCvColors(ls, cs, newscan, len)); |
48 |
49 |
if (logi[0] == 0) { /* build tables if necessary */ |
50 |
for (i = 256; i--; ) |
51 |
logi[i] = TM_BRTSCALE*log((i+.5)/256.) - .5; |
52 |
for (i = 256; i < LOGISZ; i++) |
53 |
logi[i] = logi[255]; |
54 |
for (i = BMESLOWER; i < BMESUPPER; i++) |
55 |
photofact[i-BMESLOWER] = 256. * |
56 |
(tmLuminance(i) - LMESLOWER) / |
57 |
(LMESUPPER - LMESLOWER); |
58 |
59 |
for (i = len; i--; ) { |
60 |
copycolr(cmon, scan[i]); |
61 |
/* world luminance */ |
62 |
li = ( tmTop->clfb[RED]*cmon[RED] + |
63 |
tmTop->clfb[GRN]*cmon[GRN] + |
64 |
tmTop->clfb[BLU]*cmon[BLU] ) >> 8; |
65 |
bi = BRT2SCALE*(cmon[EXP]-COLXS) + |
66 |
logi[li] + tmTop->inpsfb; |
67 |
if (bi < MINBRT) { |
68 |
bi = MINBRT-1; /* bogus value */ |
69 |
li++; /* avoid li==0 */ |
70 |
71 |
ls[i] = bi; |
72 |
if (cs == TM_NOCHROM) /* no color? */ |
73 |
continue; |
74 |
/* mesopic adj. */ |
75 |
if (tmTop->flags & TM_F_MESOPIC && bi < BMESUPPER) { |
76 |
register int pf, sli = normscot(cmon); |
77 |
if (bi < BMESLOWER) |
78 |
cmon[RED] = cmon[GRN] = cmon[BLU] = sli; |
79 |
else { |
80 |
if (tmTop->flags & TM_F_BW) |
81 |
cmon[RED] = cmon[GRN] = cmon[BLU] = li; |
82 |
pf = photofact[bi-BMESLOWER]; |
83 |
sli *= 256 - pf; |
84 |
cmon[RED] = ( sli + pf*cmon[RED] ) >> 8; |
85 |
cmon[GRN] = ( sli + pf*cmon[GRN] ) >> 8; |
86 |
cmon[BLU] = ( sli + pf*cmon[BLU] ) >> 8; |
87 |
88 |
} else if (tmTop->flags & TM_F_BW) { |
89 |
90 |
91 |
bi = ( (int4)TM_GAMTSZ*tmTop->clfb[RED]*cmon[RED]/li ) >> 8; |
92 |
cs[3*i ] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; |
93 |
bi = ( (int4)TM_GAMTSZ*tmTop->clfb[GRN]*cmon[GRN]/li ) >> 8; |
94 |
cs[3*i+1] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; |
95 |
bi = ( (int4)TM_GAMTSZ*tmTop->clfb[BLU]*cmon[BLU]/li ) >> 8; |
96 |
cs[3*i+2] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; |
97 |
98 |
returnOK; |
99 |
100 |
101 |
102 |
#define FMTRGB 1 /* Input is RGBE */ |
103 |
#define FMTCIE 2 /* Input is CIE XYZE */ |
104 |
#define FMTUNK 3 /* Input format is unspecified */ |
105 |
#define FMTBAD 4 /* Input is not a recognized format */ |
106 |
107 |
static struct radhead { |
108 |
int format; /* FMTRGB, FMTCIE, FMTUNK, FMTBAD */ |
109 |
double expos; /* input exposure value */ |
110 |
RGBPRIMP primp; /* input primaries */ |
111 |
RGBPRIMS mypri; /* custom primaries */ |
112 |
} rhdefault = {FMTUNK, 1., stdprims, STDPRIMS}; |
113 |
114 |
115 |
static int |
116 |
headline(s, rh) /* grok a header line */ |
117 |
register char *s; |
118 |
register struct radhead *rh; |
119 |
120 |
char fmt[32]; |
121 |
122 |
if (formatval(fmt, s)) { |
123 |
if (!strcmp(fmt, COLRFMT)) |
124 |
rh->format = FMTRGB; |
125 |
else if (!strcmp(fmt, CIEFMT)) |
126 |
rh->format = FMTCIE; |
127 |
else |
128 |
rh->format = FMTBAD; |
129 |
return; |
130 |
131 |
if (isexpos(s)) { |
132 |
rh->expos *= exposval(s); |
133 |
return; |
134 |
135 |
if (isprims(s)) { |
136 |
primsval(rh->mypri, s); |
137 |
rh->primp = rh->mypri; |
138 |
return; |
139 |
140 |
141 |
142 |
143 |
int |
144 |
tmLoadPicture(lpp, cpp, xp, yp, fname, fp) /* convert Radiance picture */ |
145 |
TMbright **lpp; |
146 |
BYTE **cpp; |
147 |
int *xp, *yp; |
148 |
char *fname; |
149 |
FILE *fp; |
150 |
151 |
char *funcName = fname==NULL ? "tmLoadPicture" : fname; |
152 |
FILE *inpf; |
153 |
struct radhead info; |
154 |
int err; |
155 |
COLR *scanin = NULL; |
156 |
int i; |
157 |
/* check arguments */ |
158 |
159 |
160 |
if (lpp == NULL | xp == NULL | yp == NULL | |
161 |
(fname == NULL & fp == TM_GETFILE)) |
162 |
163 |
*xp = *yp = 0; /* error precaution */ |
164 |
if ((inpf = fp) == TM_GETFILE && (inpf = fopen(fname, "r")) == NULL) |
165 |
returnErr(TM_E_BADFILE); |
166 |
info = rhdefault; /* get our header */ |
167 |
getheader(inpf, headline, (char *)&info); |
168 |
if (info.format == FMTBAD | info.expos <= 0. || |
169 |
fgetresolu(xp, yp, inpf) < 0) { |
170 |
err = TM_E_BADFILE; goto done; |
171 |
172 |
if (info.format == FMTUNK) /* assume RGBE format */ |
173 |
info.format = FMTRGB; |
174 |
if (info.format == FMTRGB) |
175 |
info.expos /= WHTEFFICACY; |
176 |
else if (info.format == FMTCIE) |
177 |
info.primp = TM_XYZPRIM; |
178 |
/* prepare library */ |
179 |
if ((err = tmSetSpace(info.primp, 1./info.expos)) != TM_E_OK) |
180 |
goto done; |
181 |
err = TM_E_NOMEM; /* allocate arrays */ |
182 |
*lpp = (TMbright *)malloc(sizeof(TMbright) * *xp * *yp); |
183 |
if (*lpp == NULL) |
184 |
goto done; |
185 |
if (cpp != TM_NOCHROMP) { |
186 |
*cpp = (BYTE *)malloc(3*sizeof(BYTE) * *xp * *yp); |
187 |
if (*cpp == NULL) |
188 |
goto done; |
189 |
190 |
scanin = (COLR *)malloc(sizeof(COLR) * *xp); |
191 |
if (scanin == NULL) |
192 |
goto done; |
193 |
err = TM_E_BADFILE; /* read & convert scanlines */ |
194 |
for (i = 0; i < *yp; i++) { |
195 |
if (freadcolrs(scanin, *xp, inpf) < 0) { |
196 |
err = TM_E_BADFILE; break; |
197 |
198 |
err = tmCvColrs(*lpp + (i * *xp), |
199 |
cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp + (i * 3 * *xp), |
200 |
scanin, *xp); |
201 |
if (err != TM_E_OK) |
202 |
break; |
203 |
204 |
done: /* clean up */ |
205 |
if (fp == NULL) |
206 |
fclose(inpf); |
207 |
if (scanin != NULL) |
208 |
free((char *)scanin); |
209 |
210 |
returnErr(err); |
211 |
returnOK; |
212 |
213 |
214 |
215 |
int /* run pcond to map picture */ |
216 |
dopcond(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname) |
217 |
BYTE **psp; |
218 |
int *xp, *yp; |
219 |
int flags; |
220 |
RGBPRIMP monpri; |
221 |
double gamval, Lddyn, Ldmax; |
222 |
char *fname; |
223 |
224 |
char *funcName = fname; |
225 |
char cmdbuf[512]; |
226 |
FILE *infp; |
227 |
register COLR *scan; |
228 |
register BYTE *rp; |
229 |
int y; |
230 |
register int x; |
231 |
/* set up gamma correction */ |
232 |
if (setcolrcor(pow, 1./gamval) < 0) |
233 |
234 |
/* create command */ |
235 |
strcpy(cmdbuf, "pcond "); |
236 |
if (flags & TM_F_HCONTR) |
237 |
strcat(cmdbuf, "-s "); |
238 |
if (flags & TM_F_MESOPIC) |
239 |
strcat(cmdbuf, "-c "); |
240 |
if (flags & TM_F_LINEAR) |
241 |
strcat(cmdbuf, "-l "); |
242 |
if (flags & TM_F_ACUITY) |
243 |
strcat(cmdbuf, "-a "); |
244 |
if (flags & TM_F_VEIL) |
245 |
strcat(cmdbuf, "-v "); |
246 |
if (flags & TM_F_CWEIGHT) |
247 |
strcat(cmdbuf, "-w "); |
248 |
sprintf(cmdbuf+strlen(cmdbuf), |
249 |
"-p %f %f %f %f %f %f %f %f -d %f -u %f %s", |
250 |
monpri[RED][CIEX], monpri[RED][CIEY], |
251 |
monpri[GRN][CIEX], monpri[GRN][CIEY], |
252 |
monpri[BLU][CIEX], monpri[BLU][CIEY], |
253 |
monpri[WHT][CIEX], monpri[WHT][CIEY], |
254 |
Lddyn, Ldmax, fname); |
255 |
/* start pcond */ |
256 |
if ((infp = popen(cmdbuf, "r")) == NULL) |
257 |
258 |
/* check picture format and size */ |
259 |
if (checkheader(infp, COLRFMT, NULL) < 0 || |
260 |
fgetresolu(xp, yp, infp) < 0) { |
261 |
pclose(infp); |
262 |
263 |
264 |
265 |
scan = (COLR *)malloc(sizeof(COLR) * *xp); |
266 |
if (flags & TM_F_BW) |
267 |
rp = (BYTE *)malloc(sizeof(BYTE) * *xp * *yp); |
268 |
else |
269 |
rp = (BYTE *)malloc(3*sizeof(BYTE) * *xp * *yp); |
270 |
if ((*psp = rp) == NULL | scan == NULL) { |
271 |
pclose(infp); |
272 |
273 |
274 |
/* read and gamma map file */ |
275 |
for (y = 0; y < *yp; y++) { |
276 |
if (freadcolrs(scan, *xp, infp) < 0) { |
277 |
pclose(infp); |
278 |
free((char *)scan); |
279 |
free((char *)*psp); |
280 |
*psp = NULL; |
281 |
282 |
283 |
colrs_gambs(scan, *xp); |
284 |
285 |
for (x = 0; x < *xp; x++) |
286 |
*rp++ = normbright(scan[x]); |
287 |
else |
288 |
for (x = 0; x < *xp; x++) { |
289 |
*rp++ = scan[x][RED]; |
290 |
*rp++ = scan[x][GRN]; |
291 |
*rp++ = scan[x][BLU]; |
292 |
293 |
294 |
295 |
pclose(infp); |
296 |
returnOK; |
297 |
298 |
299 |
300 |
int /* map a Radiance picture */ |
301 |
tmMapPicture(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname, fp) |
302 |
BYTE **psp; |
303 |
int *xp, *yp; |
304 |
int flags; |
305 |
RGBPRIMP monpri; |
306 |
307 |
char *fname; |
308 |
FILE *fp; |
309 |
310 |
char *funcName = fname==NULL ? "tmMapPicture" : fname; |
311 |
FILE *inpf; |
312 |
BYTE *cp; |
313 |
TMbright *lp; |
314 |
int err; |
315 |
316 |
if (psp == NULL | xp == NULL | yp == NULL | monpri == NULL | |
317 |
318 |
319 |
/* set defaults */ |
320 |
if (gamval < MINGAM) gamval = DEFGAM; |
321 |
if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; |
322 |
if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; |
323 |
if (flags & TM_F_BW) monpri = stdprims; |
324 |
/* check for pcond run */ |
325 |
if (fp == TM_GETFILE && flags & TM_F_UNIMPL) |
326 |
return( dopcond(psp, xp, yp, flags, |
327 |
monpri, gamval, Lddyn, Ldmax, fname) ); |
328 |
/* initialize tone mapping */ |
329 |
if (tmInit(flags, monpri, gamval) == NULL) |
330 |
331 |
/* load & convert picture */ |
332 |
err = tmLoadPicture(&lp, (flags&TM_F_BW) ? TM_NOCHROMP : &cp, |
333 |
xp, yp, fname, fp); |
334 |
if (err != TM_E_OK) { |
335 |
tmDone(NULL); |
336 |
return(err); |
337 |
338 |
/* allocate space for result */ |
339 |
if (flags & TM_F_BW) { |
340 |
*psp = (BYTE *)malloc(sizeof(BYTE) * *xp * *yp); |
341 |
if (*psp == NULL) { |
342 |
free((char *)lp); |
343 |
tmDone(NULL); |
344 |
345 |
346 |
cp = TM_NOCHROM; |
347 |
} else |
348 |
*psp = cp; |
349 |
/* compute color mapping */ |
350 |
err = tmAddHisto(lp, *xp * *yp, 1); |
351 |
352 |
goto done; |
353 |
err = tmComputeMapping(gamval, Lddyn, Ldmax); |
354 |
355 |
goto done; |
356 |
/* map colors */ |
357 |
err = tmMapPixels(*psp, lp, cp, *xp * *yp); |
358 |
359 |
360 |
free((char *)lp); |
361 |
tmDone(NULL); |
362 |
if (err != TM_E_OK) { /* free memory on error */ |
363 |
364 |
*psp = NULL; |
365 |
returnErr(err); |
366 |
367 |
returnOK; |
368 |
