root/radiance/ray/src/common/tmapcolrs.c
Thu Nov 21 17:15:54 2024 UTC (8 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.38: +2 -2 lines
Diff to previous 3.38 , to selected 3.24
refactor: Removed unused client data parametr from tmSetSpace() call
Tue Sep 10 20:24:42 2024 UTC (10 months, 4 weeks ago) by greg
Changes since 3.37: +29 -9 lines
Diff to previous 3.37 , to selected 3.24
feat(ra_bmp,ra_rgbe,ximage): Added quick conversion of spectral inputs to RGB
Sat Jan 15 16:57:46 2022 UTC (3 years, 6 months ago) by greg
Changes since 3.36: +14 -14 lines
Diff to previous 3.36 , to selected 3.24
refactor: eliminated use of MEM_PTR and (char *) for untyped memory
Fri Jan 7 23:01:01 2022 UTC (3 years, 7 months ago) by greg
Changes since 3.35: +4 -2 lines
Diff to previous 3.35 , to selected 3.24
perf: minor performance improvement in grayscale mode to 24-bit output
Tue Oct 13 00:08:46 2020 UTC (4 years, 9 months ago) by greg
Changes since 3.34: +12 -4 lines
Diff to previous 3.34 , to selected 3.24
fix: Corrected overflow of some color primaries during tone-mapping
Sat Dec 28 18:05:14 2019 UTC (5 years, 7 months ago) by greg
Changes since 3.33: +1 -4 lines
Diff to previous 3.33 , to selected 3.24
Fri Jul 19 17:37:56 2019 UTC (6 years ago) by greg
Changes since 3.32: +2 -1 lines
Diff to previous 3.32 , to selected 3.24
Thu Aug 2 18:33:42 2018 UTC (7 years ago) by greg
Changes since 3.31: +2 -2 lines
Diff to previous 3.31 , to selected 3.24
Tue Feb 2 18:02:32 2016 UTC (9 years, 6 months ago) by greg
Changes since 3.30: +2 -2 lines
Diff to previous 3.30 , to selected 3.24
Tue Jun 28 21:11:04 2011 UTC (14 years, 1 month ago) by greg
Changes since 3.29: +2 -2 lines
Diff to previous 3.29 , to selected 3.24
Minor compile fixes
Fri May 20 02:06:38 2011 UTC (14 years, 2 months ago) by greg
Changes since 3.28: +12 -12 lines
Diff to previous 3.28 , to selected 3.24
Fri Apr 22 17:06:26 2011 UTC (14 years, 3 months ago) by greg
Changes since 3.27: +23 -26 lines
Diff to previous 3.27 , to selected 3.24
Improved accuracy of color for wide-gamut monitor spaces
Thu Dec 2 18:10:40 2010 UTC (14 years, 8 months ago) by greg
Changes since 3.26: +3 -3 lines
Diff to previous 3.26 , to selected 3.24
Changed ordering of header inclusion to avoid compile issue
Mon Feb 9 20:48:08 2009 UTC (16 years, 6 months ago) by greg
Changes since 3.25: +2 -1 lines
Diff to previous 3.25 , to selected 3.24
Eliminated redefinition of malloc(3)
Wed May 31 19:27:42 2006 UTC (19 years, 2 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.24: +1 -2 lines
Diff to previous 3.24
Removed forgotten debug statement
Revision 3.24 - (view) (download) (annotate) - [selected]
Thu May 18 01:58:18 2006 UTC (19 years, 2 months ago) by greg
Changes since 3.23: +8 -7 lines
Diff to previous 3.23
Minor improvements to luminance accuracy
Tue Nov 15 06:53:00 2005 UTC (19 years, 8 months ago) by greg
Changes since 3.22: +2 -3 lines
Diff to previous 3.22 , to selected 3.24
Added tmCvLuminance() call
Mon Oct 24 04:25:01 2005 UTC (19 years, 9 months ago) by greg
Changes since 3.21: +7 -7 lines
Diff to previous 3.21 , to selected 3.24
Minor fix to avoid generating black pixels at gamut extremes
Sat Sep 24 20:15:54 2005 UTC (19 years, 10 months ago) by greg
Changes since 3.20: +44 -35 lines
Diff to previous 3.20 , to selected 3.24
Eliminated TM_PIC_CTRANS macro and made color transforms work in integer
Wed Feb 23 00:08:08 2005 UTC (20 years, 5 months ago) by greg
Diff to previous 3.19 , to selected 3.24
Made it so tmLoadPicture() opens files as binary under Windows
Fri Jan 7 22:05:30 2005 UTC (20 years, 7 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.24
Added client data pointer to tmSetSpace() call
Fri Jan 7 21:41:06 2005 UTC (20 years, 7 months ago) by greg
Diff to previous 3.17 , to selected 3.24
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (20 years, 7 months ago) by greg
Changes since 3.16: +42 -35 lines
Diff to previous 3.16 , to selected 3.24
Sat Oct 23 18:55:52 2004 UTC (20 years, 9 months ago) by schorsch
CVS Tags: rad3R6P1
Changes since 3.15: +3 -1 lines
Diff to previous 3.15 , to selected 3.24
Fri Jan 2 11:36:26 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 3.14: +9 -10 lines
Diff to previous 3.14 , to selected 3.24
Sun Jul 27 22:12:01 2003 UTC (22 years ago) by schorsch
Changes since 3.13: +8 -8 lines
Diff to previous 3.13 , to selected 3.24
Thu Jul 17 09:21:29 2003 UTC (22 years ago) by schorsch
Diff to previous 3.12 , to selected 3.24
Fri Jun 20 00:25:49 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.11: +4 -4 lines
Diff to previous 3.11 , to selected 3.24
Tue Feb 25 02:47:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.10: +1 -56 lines
Diff to previous 3.10 , to selected 3.24
Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.9: +83 -21 lines
Diff to previous 3.9 , to selected 3.24
Wed Oct 28 09:26:03 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.8: +18 -14 lines
Diff to previous 3.8 , to selected 3.24
made pcond calling optional
Tue Oct 27 09:32:54 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.7: +4 -2 lines
Diff to previous 3.7 , to selected 3.24
fixed tone mapping for TM_F_BW back the way it was in 3.4
Tue Oct 27 09:16:53 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.6: +4 -3 lines
Diff to previous 3.6 , to selected 3.24
Thu Oct 22 13:53:19 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.5: +18 -12 lines
Diff to previous 3.5 , to selected 3.24
minor fixes
Thu Oct 8 16:31:02 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.4: +2 -4 lines
Diff to previous 3.4 , to selected 3.24
minor adjustment in tmCvColrs() when TM_F_BW is set
Mon Aug 17 17:58:46 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.3: +3 -3 lines
Diff to previous 3.3 , to selected 3.24
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Fri Apr 18 13:59:46 1997 UTC (28 years, 3 months ago) by greg
Changes since 3.2: +71 -12 lines
Diff to previous 3.2 , to selected 3.24
added notion of conversion packages with private data
Wed Apr 16 20:28:05 1997 UTC (28 years, 3 months ago) by greg
Changes since 3.1: +8 -2 lines
Diff to previous 3.1 , to selected 3.24
minor bug fixes and added tmDup()
Tue Apr 15 16:53:02 1997 UTC (28 years, 4 months ago) by greg
Diff to selected 3.24
