root/radiance/ray/src/common/tmapcolrs.c
Tue Jun 28 21:11:04 2011 UTC (12 years, 10 months ago) by greg
Changes since 3.29: +2 -2 lines
Diff to previous 3.29 , to selected 3.17
Minor compile fixes
Fri May 20 02:06:38 2011 UTC (12 years, 11 months ago) by greg
Changes since 3.28: +12 -12 lines
Diff to previous 3.28 , to selected 3.17
Fri Apr 22 17:06:26 2011 UTC (13 years ago) by greg
Changes since 3.27: +23 -26 lines
Diff to previous 3.27 , to selected 3.17
Improved accuracy of color for wide-gamut monitor spaces
Thu Dec 2 18:10:40 2010 UTC (13 years, 5 months ago) by greg
Changes since 3.26: +3 -3 lines
Diff to previous 3.26 , to selected 3.17
Changed ordering of header inclusion to avoid compile issue
Mon Feb 9 20:48:08 2009 UTC (15 years, 3 months ago) by greg
Changes since 3.25: +2 -1 lines
Diff to previous 3.25 , to selected 3.17
Eliminated redefinition of malloc(3)
Wed May 31 19:27:42 2006 UTC (17 years, 11 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.24: +1 -2 lines
Diff to previous 3.24 , to selected 3.17
Removed forgotten debug statement
Thu May 18 01:58:18 2006 UTC (18 years ago) by greg
Changes since 3.23: +8 -7 lines
Diff to previous 3.23 , to selected 3.17
Minor improvements to luminance accuracy
Tue Nov 15 06:53:00 2005 UTC (18 years, 6 months ago) by greg
Changes since 3.22: +2 -3 lines
Diff to previous 3.22 , to selected 3.17
Added tmCvLuminance() call
Mon Oct 24 04:25:01 2005 UTC (18 years, 6 months ago) by greg
Changes since 3.21: +7 -7 lines
Diff to previous 3.21 , to selected 3.17
Minor fix to avoid generating black pixels at gamut extremes
Sat Sep 24 20:15:54 2005 UTC (18 years, 7 months ago) by greg
Changes since 3.20: +44 -35 lines
Diff to previous 3.20 , to selected 3.17
Eliminated TM_PIC_CTRANS macro and made color transforms work in integer
Wed Feb 23 00:08:08 2005 UTC (19 years, 2 months ago) by greg
Diff to previous 3.19 , to selected 3.17
Made it so tmLoadPicture() opens files as binary under Windows
Fri Jan 7 22:05:30 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.17
Added client data pointer to tmSetSpace() call
Fri Jan 7 21:41:06 2005 UTC (19 years, 4 months ago) by greg
Diff to previous 3.17
Moved error codes inside passed TMstruct
Revision 3.17 - (view) (download) (annotate) - [selected]
Fri Jan 7 20:33:02 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.16: +42 -35 lines
Diff to previous 3.16
Sat Oct 23 18:55:52 2004 UTC (19 years, 6 months ago) by schorsch
CVS Tags: rad3R6P1
Changes since 3.15: +3 -1 lines
Diff to previous 3.15 , to selected 3.17
Fri Jan 2 11:36:26 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 3.14: +9 -10 lines
Diff to previous 3.14 , to selected 3.17
Changes since 3.13: +8 -8 lines
Diff to previous 3.13 , to selected 3.17
Diff to previous 3.12 , to selected 3.17
Changes since 3.11: +4 -4 lines
Diff to previous 3.11 , to selected 3.17
Changes since 3.10: +1 -56 lines
Diff to previous 3.10 , to selected 3.17
Changes since 3.9: +83 -21 lines
Diff to previous 3.9 , to selected 3.17
Wed Oct 28 09:26:03 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.8: +18 -14 lines
Diff to previous 3.8 , to selected 3.17
made pcond calling optional
Tue Oct 27 09:32:54 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.7: +4 -2 lines
Diff to previous 3.7 , to selected 3.17
fixed tone mapping for TM_F_BW back the way it was in 3.4
Tue Oct 27 09:16:53 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.6: +4 -3 lines
Diff to previous 3.6 , to selected 3.17
Thu Oct 22 13:53:19 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.5: +18 -12 lines
Diff to previous 3.5 , to selected 3.17
minor fixes
Thu Oct 8 16:31:02 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.4: +2 -4 lines
Diff to previous 3.4 , to selected 3.17
minor adjustment in tmCvColrs() when TM_F_BW is set
Mon Aug 17 17:58:46 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.3: +3 -3 lines
Diff to previous 3.3 , to selected 3.17
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Fri Apr 18 13:59:46 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.2: +71 -12 lines
Diff to previous 3.2 , to selected 3.17
added notion of conversion packages with private data
Wed Apr 16 20:28:05 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.1: +8 -2 lines
Diff to previous 3.1 , to selected 3.17
minor bug fixes and added tmDup()
Tue Apr 15 16:53:02 1997 UTC (27 years, 1 month ago) by greg
Diff to selected 3.17
