--- ray/src/common/tmapcolrs.c 1997/04/15 16:53:02 3.1 +++ ray/src/common/tmapcolrs.c 2003/07/17 09:21:29 3.13 @@ -1,29 +1,51 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: tmapcolrs.c,v 3.13 2003/07/17 09:21:29 schorsch Exp $"; #endif - /* * Routines for tone mapping on Radiance RGBE and XYZE pictures. - * See tonemap.h for detailed function descriptions. + * + * Externals declared in tonemap.h */ +#include "copyright.h" + #include +#include #include +#include #include "tmprivat.h" #include "resolu.h" +#ifndef TM_PIC_CTRANS +#define TM_PIC_CTRANS 1 /* transform colors? (expensive) */ +#endif -extern char *tempbuffer(); +#define GAMTSZ 1024 +typedef struct { + BYTE gamb[GAMTSZ]; /* gamma lookup table */ + COLR clfb; /* encoded tm->clf */ + TMbright inpsfb; /* encoded tm->inpsf */ +} COLRDATA; + +#ifdef NOPROTO +static MEM_PTR colrInit(); +static void colrNewSpace(); +#else +static MEM_PTR colrInit(struct tmStruct *); +static void colrNewSpace(struct tmStruct *); +#endif +static struct tmPackage colrPkg = { /* our package functions */ + colrInit, colrNewSpace, free +}; +static int colrReg = -1; /* our package registration number */ + #define LOGISZ 260 static TMbright logi[LOGISZ]; -static BYTE photofact[BMESUPPER-BMESLOWER]; int -tmCvColrs(ls, cs, scan, len) /* tone map RGBE/XYZE colors */ +tmCvColrs(ls, cs, scan, len) /* convert RGBE/XYZE colors */ TMbright *ls; BYTE *cs; COLR *scan; @@ -31,13 +53,18 @@ int len; { static char funcName[] = "tmCvColrs"; COLR cmon; + register COLRDATA *cd; register int i, bi, li; if (tmTop == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | scan == NULL | len <= 0) + if (ls == NULL | scan == NULL | len < 0) returnErr(TM_E_ILLEGAL); - if (tmTop->flags & TM_F_NEEDMAT) { /* need floating point */ +#if TM_PIC_CTRANS + if (tmNeedMatrix(tmTop)) { /* need floating point */ +#else + if (tmTop->inppri == TM_XYZPRIM) { /* no way around this */ +#endif register COLOR *newscan; newscan = (COLOR *)tempbuffer(len*sizeof(COLOR)); if (newscan == NULL) @@ -46,27 +73,29 @@ int len; colr_color(newscan[i], scan[i]); return(tmCvColors(ls, cs, newscan, len)); } - if (logi[0] == 0) { /* build tables if necessary */ + if (colrReg < 0) { /* build tables if necessary */ + colrReg = tmRegPkg(&colrPkg); + if (colrReg < 0) + returnErr(TM_E_CODERR1); for (i = 256; i--; ) logi[i] = TM_BRTSCALE*log((i+.5)/256.) - .5; for (i = 256; i < LOGISZ; i++) - logi[i] = logi[255]; - for (i = BMESLOWER; i < BMESUPPER; i++) - photofact[i-BMESLOWER] = 256. * - (tmLuminance(i) - LMESLOWER) / - (LMESUPPER - LMESLOWER); + logi[i] = 0; + tmMkMesofact(); } + if ((cd = (COLRDATA *)tmPkgData(tmTop,colrReg)) == NULL) + returnErr(TM_E_NOMEM); for (i = len; i--; ) { copycolr(cmon, scan[i]); /* world luminance */ - li = ( tmTop->clfb[RED]*cmon[RED] + - tmTop->clfb[GRN]*cmon[GRN] + - tmTop->clfb[BLU]*cmon[BLU] ) >> 8; - bi = BRT2SCALE*(cmon[EXP]-COLXS) + - logi[li] + tmTop->inpsfb; - if (bi < MINBRT) { - bi = MINBRT-1; /* bogus value */ - li++; /* avoid li==0 */ + li = ( cd->clfb[RED]*cmon[RED] + + cd->clfb[GRN]*cmon[GRN] + + cd->clfb[BLU]*cmon[BLU] ) >> 8; + bi = BRT2SCALE(cmon[EXP]-COLXS) + + logi[li] + cd->inpsfb; + if (li <= 0) { + bi = TM_NOBRT; /* bogus value */ + li = 1; /* avoid li==0 */ } ls[i] = bi; if (cs == TM_NOCHROM) /* no color? */ @@ -79,7 +108,7 @@ int len; else { if (tmTop->flags & TM_F_BW) cmon[RED] = cmon[GRN] = cmon[BLU] = li; - pf = photofact[bi-BMESLOWER]; + pf = tmMesofact[bi-BMESLOWER]; sli *= 256 - pf; cmon[RED] = ( sli + pf*cmon[RED] ) >> 8; cmon[GRN] = ( sli + pf*cmon[GRN] ) >> 8; @@ -88,12 +117,12 @@ int len; } else if (tmTop->flags & TM_F_BW) { cmon[RED] = cmon[GRN] = cmon[BLU] = li; } - bi = ( (int4)TM_GAMTSZ*tmTop->clfb[RED]*cmon[RED]/li ) >> 8; - cs[3*i ] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; - bi = ( (int4)TM_GAMTSZ*tmTop->clfb[GRN]*cmon[GRN]/li ) >> 8; - cs[3*i+1] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; - bi = ( (int4)TM_GAMTSZ*tmTop->clfb[BLU]*cmon[BLU]/li ) >> 8; - cs[3*i+2] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; + bi = ( (int32)GAMTSZ*cd->clfb[RED]*cmon[RED]/li ) >> 8; + cs[3*i ] = bi>=GAMTSZ ? 255 : cd->gamb[bi]; + bi = ( (int32)GAMTSZ*cd->clfb[GRN]*cmon[GRN]/li ) >> 8; + cs[3*i+1] = bi>=GAMTSZ ? 255 : cd->gamb[bi]; + bi = ( (int32)GAMTSZ*cd->clfb[BLU]*cmon[BLU]/li ) >> 8; + cs[3*i+2] = bi>=GAMTSZ ? 255 : cd->gamb[bi]; } returnOK; } @@ -126,17 +155,18 @@ register struct radhead *rh; rh->format = FMTCIE; else rh->format = FMTBAD; - return; + return(0); } if (isexpos(s)) { rh->expos *= exposval(s); - return; + return(0); } if (isprims(s)) { primsval(rh->mypri, s); rh->primp = rh->mypri; - return; + return(0); } + return(0); } @@ -163,6 +193,8 @@ FILE *fp; *xp = *yp = 0; /* error precaution */ if ((inpf = fp) == TM_GETFILE && (inpf = fopen(fname, "r")) == NULL) returnErr(TM_E_BADFILE); + *lpp = NULL; + if (cpp != TM_NOCHROMP) *cpp = NULL; info = rhdefault; /* get our header */ getheader(inpf, headline, (char *)&info); if (info.format == FMTBAD | info.expos <= 0. || @@ -205,14 +237,20 @@ done: /* clean up */ if (fp == NULL) fclose(inpf); if (scanin != NULL) - free((char *)scanin); - if (err != TM_E_OK) + free((MEM_PTR)scanin); + if (err != TM_E_OK) { + if (*lpp != NULL) + free((MEM_PTR)*lpp); + if (cpp != TM_NOCHROMP && *cpp != NULL) + free((MEM_PTR)*cpp); returnErr(err); + } returnOK; } -int /* run pcond to map picture */ +#ifdef PCOND +static int /* run pcond to map picture */ dopcond(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname) BYTE **psp; int *xp, *yp; @@ -222,7 +260,7 @@ double gamval, Lddyn, Ldmax; char *fname; { char *funcName = fname; - char cmdbuf[512]; + char cmdbuf[1024]; FILE *infp; register COLR *scan; register BYTE *rp; @@ -232,26 +270,26 @@ char *fname; if (setcolrcor(pow, 1./gamval) < 0) returnErr(TM_E_NOMEM); /* create command */ - strcpy(cmdbuf, "pcond "); + strcpy(cmdbuf, PCOND); if (flags & TM_F_HCONTR) - strcat(cmdbuf, "-s "); + strcat(cmdbuf, " -s"); if (flags & TM_F_MESOPIC) - strcat(cmdbuf, "-c "); + strcat(cmdbuf, " -c"); if (flags & TM_F_LINEAR) - strcat(cmdbuf, "-l "); + strcat(cmdbuf, " -l"); if (flags & TM_F_ACUITY) - strcat(cmdbuf, "-a "); + strcat(cmdbuf, " -a"); if (flags & TM_F_VEIL) - strcat(cmdbuf, "-v "); + strcat(cmdbuf, " -v"); if (flags & TM_F_CWEIGHT) - strcat(cmdbuf, "-w "); - sprintf(cmdbuf+strlen(cmdbuf), - "-p %f %f %f %f %f %f %f %f -d %f -u %f %s", - monpri[RED][CIEX], monpri[RED][CIEY], - monpri[GRN][CIEX], monpri[GRN][CIEY], - monpri[BLU][CIEX], monpri[BLU][CIEY], - monpri[WHT][CIEX], monpri[WHT][CIEY], - Lddyn, Ldmax, fname); + strcat(cmdbuf, " -w"); + if (monpri != stdprims) + sprintf(cmdbuf+strlen(cmdbuf), " -p %f %f %f %f %f %f %f %f", + monpri[RED][CIEX], monpri[RED][CIEY], + monpri[GRN][CIEX], monpri[GRN][CIEY], + monpri[BLU][CIEX], monpri[BLU][CIEY], + monpri[WHT][CIEX], monpri[WHT][CIEY]); + sprintf(cmdbuf+strlen(cmdbuf), " -d %f -u %f %s", Lddyn, Ldmax, fname); /* start pcond */ if ((infp = popen(cmdbuf, "r")) == NULL) returnErr(TM_E_BADFILE); @@ -262,11 +300,11 @@ char *fname; returnErr(TM_E_BADFILE); } /* allocate arrays */ + scan = (COLR *)malloc(sizeof(COLR) * *xp); if (flags & TM_F_BW) rp = (BYTE *)malloc(sizeof(BYTE) * *xp * *yp); else rp = (BYTE *)malloc(3*sizeof(BYTE) * *xp * *yp); - scan = (COLR *)malloc(sizeof(COLR) * *xp); if ((*psp = rp) == NULL | scan == NULL) { pclose(infp); returnErr(TM_E_NOMEM); @@ -275,6 +313,9 @@ char *fname; for (y = 0; y < *yp; y++) { if (freadcolrs(scan, *xp, infp) < 0) { pclose(infp); + free((MEM_PTR)scan); + free((MEM_PTR)*psp); + *psp = NULL; returnErr(TM_E_BADFILE); } colrs_gambs(scan, *xp); @@ -288,10 +329,11 @@ char *fname; *rp++ = scan[x][BLU]; } } - free((char *)scan); + free((MEM_PTR)scan); pclose(infp); returnOK; } +#endif int /* map a Radiance picture */ @@ -305,7 +347,6 @@ char *fname; FILE *fp; { char *funcName = fname==NULL ? "tmMapPicture" : fname; - FILE *inpf; BYTE *cp; TMbright *lp; int err; @@ -318,10 +359,12 @@ FILE *fp; if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; if (flags & TM_F_BW) monpri = stdprims; +#ifdef PCOND /* check for pcond run */ if (fp == TM_GETFILE && flags & TM_F_UNIMPL) return( dopcond(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname) ); +#endif /* initialize tone mapping */ if (tmInit(flags, monpri, gamval) == NULL) returnErr(TM_E_NOMEM); @@ -335,8 +378,11 @@ FILE *fp; /* allocate space for result */ if (flags & TM_F_BW) { *psp = (BYTE *)malloc(sizeof(BYTE) * *xp * *yp); - if (*psp == NULL) + if (*psp == NULL) { + free((MEM_PTR)lp); + tmDone(NULL); returnErr(TM_E_NOMEM); + } cp = TM_NOCHROM; } else *psp = cp; @@ -351,12 +397,49 @@ FILE *fp; err = tmMapPixels(*psp, lp, cp, *xp * *yp); done: /* clean up */ - free((char *)lp); + free((MEM_PTR)lp); tmDone(NULL); if (err != TM_E_OK) { /* free memory on error */ - free((char *)*psp); + free((MEM_PTR)*psp); *psp = NULL; returnErr(err); } returnOK; +} + + +static void +colrNewSpace(tms) /* color space changed for tone mapping */ +register struct tmStruct *tms; +{ + register COLRDATA *cd; + double d; + + cd = (COLRDATA *)tms->pd[colrReg]; + cd->clfb[RED] = 256.*tms->clf[RED] + .5; + cd->clfb[GRN] = 256.*tms->clf[GRN] + .5; + cd->clfb[BLU] = 256.*tms->clf[BLU] + .5; + cd->clfb[EXP] = COLXS; + d = TM_BRTSCALE*log(tms->inpsf); + cd->inpsfb = d<0. ? d-.5 : d+.5; +} + + +static MEM_PTR +colrInit(tms) /* initialize private data for tone mapping */ +register struct tmStruct *tms; +{ + register COLRDATA *cd; + register int i; + /* allocate our data */ + cd = (COLRDATA *)malloc(sizeof(COLRDATA)); + if (cd == NULL) + return(NULL); + tms->pd[colrReg] = (MEM_PTR)cd; + /* compute gamma table */ + for (i = GAMTSZ; i--; ) + cd->gamb[i] = 256.*pow((i+.5)/GAMTSZ, 1./tms->mongam); + /* compute color and scale factors */ + colrNewSpace(tms); + return((MEM_PTR)cd); }
