root/Development/ray/src/common/tmapcolrs.c
Wed Feb 23 00:08:08 2005 UTC (20 years, 8 months ago) by greg
Diff to previous 3.19
Made it so tmLoadPicture() opens files as binary under Windows
Fri Jan 7 22:05:30 2005 UTC (20 years, 10 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18
Added client data pointer to tmSetSpace() call
Fri Jan 7 21:41:06 2005 UTC (20 years, 10 months ago) by greg
Diff to previous 3.17
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (20 years, 10 months ago) by greg
Changes since 3.16: +42 -35 lines
Diff to previous 3.16
Sat Oct 23 18:55:52 2004 UTC (21 years ago) by schorsch
CVS Tags: rad3R6P1
Changes since 3.15: +3 -1 lines
Diff to previous 3.15
Fri Jan 2 11:36:26 2004 UTC (21 years, 10 months ago) by schorsch
Changes since 3.14: +9 -10 lines
Diff to previous 3.14
Sun Jul 27 22:12:01 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.13: +8 -8 lines
Diff to previous 3.13
Thu Jul 17 09:21:29 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 3.12
Fri Jun 20 00:25:49 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.11: +4 -4 lines
Diff to previous 3.11
Tue Feb 25 02:47:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.10: +1 -56 lines
Diff to previous 3.10
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.9: +83 -21 lines
Diff to previous 3.9
Wed Oct 28 09:26:03 1998 UTC (27 years ago) by gwlarson
Changes since 3.8: +18 -14 lines
Diff to previous 3.8
made pcond calling optional
Tue Oct 27 09:32:54 1998 UTC (27 years ago) by gwlarson
Changes since 3.7: +4 -2 lines
Diff to previous 3.7
fixed tone mapping for TM_F_BW back the way it was in 3.4
Tue Oct 27 09:16:53 1998 UTC (27 years ago) by gwlarson
Changes since 3.6: +4 -3 lines
Diff to previous 3.6
Thu Oct 22 13:53:19 1998 UTC (27 years ago) by gwlarson
Changes since 3.5: +18 -12 lines
Diff to previous 3.5
minor fixes
Thu Oct 8 16:31:02 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.4: +2 -4 lines
Diff to previous 3.4
minor adjustment in tmCvColrs() when TM_F_BW is set
Mon Aug 17 17:58:46 1998 UTC (27 years, 3 months ago) by gwlarson
Changes since 3.3: +3 -3 lines
Diff to previous 3.3
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Fri Apr 18 13:59:46 1997 UTC (28 years, 7 months ago) by greg
Changes since 3.2: +71 -12 lines
Diff to previous 3.2
added notion of conversion packages with private data
Wed Apr 16 20:28:05 1997 UTC (28 years, 7 months ago) by greg
Changes since 3.1: +8 -2 lines
minor bug fixes and added tmDup()
Tue Apr 15 16:53:02 1997 UTC (28 years, 7 months ago) by greg
