Made it so tmLoadPicture() opens files as binary under Windows
Added client data pointer to tmSetSpace() call
Moved error codes inside passed TMstruct
Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
made pcond calling optional
fixed tone mapping for TM_F_BW back the way it was in 3.4
minor fixes
minor adjustment in tmCvColrs() when TM_F_BW is set
took "color.h" include out of tonemap.h and put in tmprivat.h changed routines so zero-length arrays don't return error
added notion of conversion packages with private data
minor bug fixes and added tmDup()
