--- ray/src/common/tmapcolrs.c 2003/06/20 00:25:49 3.12 +++ ray/src/common/tmapcolrs.c 2003/07/27 22:12:01 3.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tmapcolrs.c,v 3.12 2003/06/20 00:25:49 greg Exp $"; +static const char RCSid[] = "$Id: tmapcolrs.c,v 3.14 2003/07/27 22:12:01 schorsch Exp $"; #endif /* * Routines for tone mapping on Radiance RGBE and XYZE pictures. @@ -58,7 +58,7 @@ int len; if (tmTop == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | scan == NULL | len < 0) + if ((ls == NULL) | (scan == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); #if TM_PIC_CTRANS if (tmNeedMatrix(tmTop)) { /* need floating point */ @@ -187,8 +187,8 @@ FILE *fp; /* check arguments */ if (tmTop == NULL) returnErr(TM_E_TMINVAL); - if (lpp == NULL | xp == NULL | yp == NULL | - (fname == NULL & fp == TM_GETFILE)) + if ((lpp == NULL) | (xp == NULL) | (yp == NULL) | + ((fname == NULL) & (fp == TM_GETFILE))) returnErr(TM_E_ILLEGAL); *xp = *yp = 0; /* error precaution */ if ((inpf = fp) == TM_GETFILE && (inpf = fopen(fname, "r")) == NULL) @@ -197,7 +197,7 @@ FILE *fp; if (cpp != TM_NOCHROMP) *cpp = NULL; info = rhdefault; /* get our header */ getheader(inpf, headline, (char *)&info); - if (info.format == FMTBAD | info.expos <= 0. || + if ((info.format == FMTBAD) | (info.expos <= 0.) || fgetresolu(xp, yp, inpf) < 0) { err = TM_E_BADFILE; goto done; } @@ -250,7 +250,7 @@ done: /* clean up */ #ifdef PCOND -int /* run pcond to map picture */ +static int /* run pcond to map picture */ dopcond(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname) BYTE **psp; int *xp, *yp; @@ -305,7 +305,7 @@ char *fname; rp = (BYTE *)malloc(sizeof(BYTE) * *xp * *yp); else rp = (BYTE *)malloc(3*sizeof(BYTE) * *xp * *yp); - if ((*psp = rp) == NULL | scan == NULL) { + if (((*psp = rp) == NULL) | (scan == NULL)) { pclose(infp); returnErr(TM_E_NOMEM); } @@ -351,8 +351,8 @@ FILE *fp; TMbright *lp; int err; /* check arguments */ - if (psp == NULL | xp == NULL | yp == NULL | monpri == NULL | - (fname == NULL & fp == TM_GETFILE)) + if ((psp == NULL) | (xp == NULL) | (yp == NULL) | (monpri == NULL) | + ((fname == NULL) & (fp == TM_GETFILE))) returnErr(TM_E_ILLEGAL); /* set defaults */ if (gamval < MINGAM) gamval = DEFGAM;
