root/radiance/ray/src/common/tmapcolrs.c
Fri Jan 2 11:36:26 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 3.14: +9 -10 lines
Diff to previous 3.14 , to selected 3.6
Changes since 3.13: +8 -8 lines
Diff to previous 3.13 , to selected 3.6
Diff to previous 3.12 , to selected 3.6
Changes since 3.11: +4 -4 lines
Diff to previous 3.11 , to selected 3.6
Changes since 3.10: +1 -56 lines
Diff to previous 3.10 , to selected 3.6
Changes since 3.9: +83 -21 lines
Diff to previous 3.9 , to selected 3.6
Wed Oct 28 09:26:03 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.8: +18 -14 lines
Diff to previous 3.8 , to selected 3.6
made pcond calling optional
Tue Oct 27 09:32:54 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.7: +4 -2 lines
Diff to previous 3.7 , to selected 3.6
fixed tone mapping for TM_F_BW back the way it was in 3.4
Tue Oct 27 09:16:53 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.6: +4 -3 lines
Diff to previous 3.6
Revision 3.6 - (view) (download) (annotate) - [selected]
Thu Oct 22 13:53:19 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.5: +18 -12 lines
Diff to previous 3.5
minor fixes
Thu Oct 8 16:31:02 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.4: +2 -4 lines
Diff to previous 3.4 , to selected 3.6
minor adjustment in tmCvColrs() when TM_F_BW is set
Mon Aug 17 17:58:46 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.3: +3 -3 lines
Diff to previous 3.3 , to selected 3.6
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Fri Apr 18 13:59:46 1997 UTC (27 years ago) by greg
Changes since 3.2: +71 -12 lines
Diff to previous 3.2 , to selected 3.6
added notion of conversion packages with private data
Wed Apr 16 20:28:05 1997 UTC (27 years ago) by greg
Changes since 3.1: +8 -2 lines
Diff to previous 3.1 , to selected 3.6
minor bug fixes and added tmDup()
Tue Apr 15 16:53:02 1997 UTC (27 years ago) by greg
Diff to selected 3.6
