--- ray/src/common/tmapcolrs.c 1998/10/08 16:31:02 3.5 +++ ray/src/common/tmapcolrs.c 1998/10/27 09:32:54 3.8 @@ -39,7 +39,7 @@ static BYTE photofact[BMESUPPER-BMESLOWER]; int -tmCvColrs(ls, cs, scan, len) /* tone map RGBE/XYZE colors */ +tmCvColrs(ls, cs, scan, len) /* convert RGBE/XYZE colors */ TMbright *ls; BYTE *cs; COLR *scan; @@ -63,7 +63,7 @@ int len; colr_color(newscan[i], scan[i]); return(tmCvColors(ls, cs, newscan, len)); } - if (colrReg == -1) { /* build tables if necessary */ + if (colrReg < 0) { /* build tables if necessary */ colrReg = tmRegPkg(&colrPkg); if (colrReg < 0) returnErr(TM_E_CODERR1); @@ -93,20 +93,22 @@ int len; ls[i] = bi; if (cs == TM_NOCHROM) /* no color? */ continue; - if (tmTop->flags & TM_F_BW) - cmon[RED] = cmon[GRN] = cmon[BLU] = li; /* mesopic adj. */ if (tmTop->flags & TM_F_MESOPIC && bi < BMESUPPER) { register int pf, sli = normscot(cmon); if (bi < BMESLOWER) cmon[RED] = cmon[GRN] = cmon[BLU] = sli; else { + if (tmTop->flags & TM_F_BW) + cmon[RED] = cmon[GRN] = cmon[BLU] = li; pf = photofact[bi-BMESLOWER]; sli *= 256 - pf; cmon[RED] = ( sli + pf*cmon[RED] ) >> 8; cmon[GRN] = ( sli + pf*cmon[GRN] ) >> 8; cmon[BLU] = ( sli + pf*cmon[BLU] ) >> 8; } + } else if (tmTop->flags & TM_F_BW) { + cmon[RED] = cmon[GRN] = cmon[BLU] = li; } bi = ( (int4)GAMTSZ*cd->clfb[RED]*cmon[RED]/li ) >> 8; cs[3*i ] = bi>=GAMTSZ ? 255 : cd->gamb[bi]; @@ -146,17 +148,18 @@ register struct radhead *rh; rh->format = FMTCIE; else rh->format = FMTBAD; - return; + return(0); } if (isexpos(s)) { rh->expos *= exposval(s); - return; + return(0); } if (isprims(s)) { primsval(rh->mypri, s); rh->primp = rh->mypri; - return; + return(0); } + return(0); } @@ -183,8 +186,10 @@ FILE *fp; *xp = *yp = 0; /* error precaution */ if ((inpf = fp) == TM_GETFILE && (inpf = fopen(fname, "r")) == NULL) returnErr(TM_E_BADFILE); + *lpp = NULL; + if (cpp != TM_NOCHROMP) *cpp = NULL; info = rhdefault; /* get our header */ - getheader(inpf, headline, (char *)&info); + getheader(inpf, headline, (MEM_PTR)&info); if (info.format == FMTBAD | info.expos <= 0. || fgetresolu(xp, yp, inpf) < 0) { err = TM_E_BADFILE; goto done; @@ -225,9 +230,14 @@ done: /* clean up */ if (fp == NULL) fclose(inpf); if (scanin != NULL) - free((char *)scanin); - if (err != TM_E_OK) + free((MEM_PTR)scanin); + if (err != TM_E_OK) { + if (*lpp != NULL) + free((MEM_PTR)*lpp); + if (cpp != TM_NOCHROMP && *cpp != NULL) + free((MEM_PTR)*cpp); returnErr(err); + } returnOK; } @@ -295,8 +305,8 @@ char *fname; for (y = 0; y < *yp; y++) { if (freadcolrs(scan, *xp, infp) < 0) { pclose(infp); - free((char *)scan); - free((char *)*psp); + free((MEM_PTR)scan); + free((MEM_PTR)*psp); *psp = NULL; returnErr(TM_E_BADFILE); } @@ -311,7 +321,7 @@ char *fname; *rp++ = scan[x][BLU]; } } - free((char *)scan); + free((MEM_PTR)scan); pclose(infp); returnOK; } @@ -328,7 +338,6 @@ char *fname; FILE *fp; { char *funcName = fname==NULL ? "tmMapPicture" : fname; - FILE *inpf; BYTE *cp; TMbright *lp; int err; @@ -359,7 +368,7 @@ FILE *fp; if (flags & TM_F_BW) { *psp = (BYTE *)malloc(sizeof(BYTE) * *xp * *yp); if (*psp == NULL) { - free((char *)lp); + free((MEM_PTR)lp); tmDone(NULL); returnErr(TM_E_NOMEM); } @@ -377,10 +386,10 @@ FILE *fp; err = tmMapPixels(*psp, lp, cp, *xp * *yp); done: /* clean up */ - free((char *)lp); + free((MEM_PTR)lp); tmDone(NULL); if (err != TM_E_OK) { /* free memory on error */ - free((char *)*psp); + free((MEM_PTR)*psp); *psp = NULL; returnErr(err); }
