root/radiance/ray/src/common/tmapcolrs.c
Changes since 3.10: +1 -56 lines
Diff to previous 3.10 , to selected 3.2
Changes since 3.9: +83 -21 lines
Diff to previous 3.9 , to selected 3.2
Wed Oct 28 09:26:03 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.8: +18 -14 lines
Diff to previous 3.8 , to selected 3.2
made pcond calling optional
Tue Oct 27 09:32:54 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.7: +4 -2 lines
Diff to previous 3.7 , to selected 3.2
fixed tone mapping for TM_F_BW back the way it was in 3.4
Tue Oct 27 09:16:53 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.6: +4 -3 lines
Diff to previous 3.6 , to selected 3.2
Thu Oct 22 13:53:19 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.5: +18 -12 lines
Diff to previous 3.5 , to selected 3.2
minor fixes
Thu Oct 8 16:31:02 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.4: +2 -4 lines
Diff to previous 3.4 , to selected 3.2
minor adjustment in tmCvColrs() when TM_F_BW is set
Mon Aug 17 17:58:46 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.3: +3 -3 lines
Diff to previous 3.3 , to selected 3.2
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Fri Apr 18 13:59:46 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.2: +71 -12 lines
Diff to previous 3.2
added notion of conversion packages with private data
Revision 3.2 - (view) (download) (annotate) - [selected]
Wed Apr 16 20:28:05 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.1: +8 -2 lines
minor bug fixes and added tmDup()
Tue Apr 15 16:53:02 1997 UTC (27 years, 1 month ago) by greg
Diff to selected 3.2
