1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Routines for tone-mapping 16-bit/primary pixels |
6 |
7 |
* Externals declared in tonemap.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <stdio.h> |
13 |
#include <math.h> |
14 |
#include "tmprivat.h" |
15 |
16 |
#define LOGTABBITS 11 /* log table is 1<<LOGTABBITS long */ |
17 |
#define GAMTABBITS 9 /* gamma table is 1<<GAMTABBITS long */ |
18 |
19 |
static float logtab[1<<LOGTABBITS]; |
20 |
static float gamtab[1<<GAMTABBITS]; |
21 |
static float gammul[16]; |
22 |
static double cur_gam = 0.; |
23 |
24 |
#define imultpow2(i,s) ((s)>=0 ? (i)<<(s) : (i)>>-(s)) |
25 |
26 |
27 |
/* Fill our log table */ |
28 |
static void |
29 |
mkLogTable() |
30 |
31 |
int i; |
32 |
33 |
if (logtab[0] != 0.f) |
34 |
return; |
35 |
for (i = 1<<LOGTABBITS; i--; ) |
36 |
logtab[i] = log(imultpow2(i,15-LOGTABBITS)*(1./(1L<<16)) |
37 |
+ .5); |
38 |
39 |
40 |
41 |
/* Fill our gamma table */ |
42 |
static void |
43 |
mkGamTable(double gv) |
44 |
45 |
int i; |
46 |
47 |
if (gv == cur_gam) |
48 |
return; |
49 |
for (i = 1<<GAMTABBITS; i--; ) |
50 |
gamtab[i] = pow((i+.5)*(1./(1<<GAMTABBITS)), gv); |
51 |
for (i = 16; i--; ) |
52 |
gammul[i] = pow((double)(1L<<i), -gv); |
53 |
cur_gam = gv; |
54 |
55 |
56 |
57 |
/* Find normalizing shift value for a 2-byte unsigned integer */ |
58 |
static int |
59 |
normShift16(int i) |
60 |
61 |
int s = 0; |
62 |
63 |
while (!(i & 0x8000)) { |
64 |
i <<= 1; |
65 |
++s; |
66 |
67 |
return(s); |
68 |
69 |
70 |
71 |
/* Find common normalizing shift for 3 2-byte unsigned integers */ |
72 |
static int |
73 |
normShift48(uint16 clr48[3]) |
74 |
75 |
int imax = (clr48[1] > clr48[0] ? clr48[1] : clr48[0]); |
76 |
if (clr48[2] > imax) |
77 |
imax = clr48[2]; |
78 |
return(normShift16(imax)); |
79 |
80 |
81 |
82 |
/* convert at 48-bit tristimulus value to a COLOR */ |
83 |
static void |
84 |
rgb48_color(COLOR col, uint16 clr48[3]) |
85 |
86 |
int nshft; |
87 |
88 |
if (cur_gam == 1.) { /* linear case */ |
89 |
col[0] = clr48[0]*(1./(1L<<16)); |
90 |
col[1] = clr48[1]*(1./(1L<<16)); |
91 |
col[2] = clr48[2]*(1./(1L<<16)); |
92 |
return; |
93 |
94 |
/* non-linear case */ |
95 |
nshft = normShift48(clr48); |
96 |
col[0] = gamtab[imultpow2(clr48[0],GAMTABBITS-16+nshft)] * |
97 |
gammul[nshft]; |
98 |
col[1] = gamtab[imultpow2(clr48[1],GAMTABBITS-16+nshft)] * |
99 |
gammul[nshft]; |
100 |
col[2] = gamtab[imultpow2(clr48[2],GAMTABBITS-16+nshft)] * |
101 |
gammul[nshft]; |
102 |
103 |
104 |
105 |
/* Convert 16-bit gray scanline to encoded luminance */ |
106 |
int |
107 |
tmCvGray16(TMbright *ls, uint16 *scan, int len, double gv) |
108 |
109 |
static char funcName[] = "tmCvGray16"; |
110 |
static double cur_inpsf = 1.; |
111 |
static double log_inpsf = 0.; |
112 |
int nshft; |
113 |
double d; |
114 |
115 |
if (tmTop == NULL) |
116 |
returnErr(TM_E_TMINVAL); |
117 |
if (ls == NULL | scan == NULL | len < 0 | gv <= MINGAM) |
118 |
returnErr(TM_E_ILLEGAL); |
119 |
/* initialize log table */ |
120 |
if (logtab[0] == 0.f) |
121 |
mkLogTable(); |
122 |
if (cur_inpsf != tmTop->inpsf) |
123 |
log_inpsf = log(cur_inpsf = tmTop->inpsf); |
124 |
/* convert 16-bit grays */ |
125 |
while (len--) { |
126 |
nshft = normShift16(*scan); |
127 |
d = logtab[ imultpow2(*scan,LOGTABBITS-15+nshft) & |
128 |
((1L<<LOGTABBITS)-1) ] |
129 |
- M_LN2*nshft; |
130 |
d = (double)TM_BRTSCALE * (gv*d + log_inpsf); |
131 |
*ls++ = (d>0. ? d+.5 : d-.5); |
132 |
scan++; |
133 |
134 |
returnOK; |
135 |
136 |
137 |
/* Convert a 48-bit RGB scanline to encoded luminance/chrominance */ |
138 |
int |
139 |
tmCvRGB48(TMbright *ls, BYTE *cs, uint16 (*scan)[3], int len, double gv) |
140 |
141 |
static char funcName[] = "tmCvRGB48"; |
142 |
143 |
144 |
int i; |
145 |
146 |
147 |
148 |
149 |
150 |
/* update gamma table */ |
151 |
if (gv != 1. & gv != cur_gam) |
152 |
mkGamTable(gv); |
153 |
#if 0 |
154 |
if (tmNeedMatrix(tmTop)) { /* need floating point */ |
155 |
#else |
156 |
157 |
#endif |
158 |
COLOR *newscan; |
159 |
newscan = (COLOR *)tempbuffer(len*sizeof(COLOR)); |
160 |
if (newscan == NULL) |
161 |
returnErr(TM_E_NOMEM); |
162 |
for (i = len; i--; ) |
163 |
rgb48_color(newscan[i], scan[i]); |
164 |
return(tmCvColors(ls, cs, newscan, len)); |
165 |
166 |
#if 0 |
167 |
168 |
169 |
mkLogTable(); |
170 |
171 |
172 |
/* convert scanline */ |
173 |
for (i = len; i--; ) { |
174 |
copycolr(cmon, scan[i]); |
175 |
/* world luminance */ |
176 |
li = ( cd->clfb[RED]*cmon[RED] + |
177 |
cd->clfb[GRN]*cmon[GRN] + |
178 |
cd->clfb[BLU]*cmon[BLU] ) >> 8; |
179 |
bi = BRT2SCALE(cmon[EXP]-COLXS) + |
180 |
logi[li] + cd->inpsfb; |
181 |
if (li <= 0) { |
182 |
bi = TM_NOBRT; /* bogus value */ |
183 |
li = 1; /* avoid li==0 */ |
184 |
185 |
ls[i] = bi; |
186 |
if (cs == TM_NOCHROM) /* no color? */ |
187 |
continue; |
188 |
/* mesopic adj. */ |
189 |
if (tmTop->flags & TM_F_MESOPIC && bi < BMESUPPER) { |
190 |
int pf, sli = normscot(cmon); |
191 |
if (bi < BMESLOWER) |
192 |
cmon[RED] = cmon[GRN] = cmon[BLU] = sli; |
193 |
else { |
194 |
if (tmTop->flags & TM_F_BW) |
195 |
cmon[RED] = cmon[GRN] = cmon[BLU] = li; |
196 |
pf = tmMesofact[bi-BMESLOWER]; |
197 |
sli *= 256 - pf; |
198 |
cmon[RED] = ( sli + pf*cmon[RED] ) >> 8; |
199 |
cmon[GRN] = ( sli + pf*cmon[GRN] ) >> 8; |
200 |
cmon[BLU] = ( sli + pf*cmon[BLU] ) >> 8; |
201 |
202 |
} else if (tmTop->flags & TM_F_BW) { |
203 |
204 |
205 |
bi = ( (int32)GAMTSZ*cd->clfb[RED]*cmon[RED]/li ) >> 8; |
206 |
cs[3*i ] = bi>=GAMTSZ ? 255 : cd->gamb[bi]; |
207 |
bi = ( (int32)GAMTSZ*cd->clfb[GRN]*cmon[GRN]/li ) >> 8; |
208 |
cs[3*i+1] = bi>=GAMTSZ ? 255 : cd->gamb[bi]; |
209 |
bi = ( (int32)GAMTSZ*cd->clfb[BLU]*cmon[BLU]/li ) >> 8; |
210 |
cs[3*i+2] = bi>=GAMTSZ ? 255 : cd->gamb[bi]; |
211 |
212 |
returnOK; |
213 |
#endif |
214 |
