root/Development/ray/src/common/tmap16bit.c
Fri May 20 02:06:38 2011 UTC (14 years, 5 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 1.9
Mon Mar 7 20:49:19 2011 UTC (14 years, 7 months ago) by greg
Diff to previous 1.8
Minor improvement in round-off method
Thu May 15 22:15:16 2008 UTC (17 years, 5 months ago) by greg
Diff to previous 1.7
Fixed bug for 48-bit RGB conversion with gamma=1.0
Mon Oct 8 18:07:55 2007 UTC (18 years ago) by greg
Diff to previous 1.6
Fri Jan 7 21:41:06 2005 UTC (20 years, 9 months ago) by greg
Changes since 1.5: +3 -3 lines
Diff to previous 1.5
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (20 years, 9 months ago) by greg
Changes since 1.4: +28 -27 lines
Diff to previous 1.4
Sun Jul 27 22:12:01 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 1.3
Tue Jul 15 07:28:09 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.2: +71 -36 lines
Diff to previous 1.2
Improved speed of 48-bit RGB pixel conversion in tmCvRGB48()
Tue Jul 15 00:23:36 2003 UTC (22 years, 3 months ago) by greg
Changes since 1.1: +25 -6 lines
Diff to previous 1.1
Bug fix for linear 16-bit and zero valued pixels
Mon Jul 14 18:21:07 2003 UTC (22 years, 3 months ago) by greg
