root/Development/ray/src/common/tmap16bit.c
Fri Jan 7 21:41:06 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.5: +3 -3 lines
Diff to previous 1.5
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (20 years, 11 months ago) by greg
Changes since 1.4: +28 -27 lines
Diff to previous 1.4
Sun Jul 27 22:12:01 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 1.3
Tue Jul 15 07:28:09 2003 UTC (22 years, 5 months ago) by greg
Changes since 1.2: +71 -36 lines
Diff to previous 1.2
Improved speed of 48-bit RGB pixel conversion in tmCvRGB48()
Tue Jul 15 00:23:36 2003 UTC (22 years, 5 months ago) by greg
Changes since 1.1: +25 -6 lines
Diff to previous 1.1
Bug fix for linear 16-bit and zero valued pixels
Mon Jul 14 18:21:07 2003 UTC (22 years, 5 months ago) by greg
