1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: tmap16bit.c,v 1.4 2003/07/27 22:12:01 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Routines for tone-mapping 16-bit/primary pixels |
6 |
7 |
* Externals declared in tonemap.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <stdio.h> |
13 |
#include <math.h> |
14 |
#include "tmprivat.h" |
15 |
16 |
#define LOGTABBITS 11 /* log table is 1<<LOGTABBITS long */ |
17 |
#define GAMTABBITS 9 /* gamma table is 1<<GAMTABBITS long */ |
18 |
#define MONGAMTSZ 1024 /* monitor gamma table length */ |
19 |
20 |
static float logtab[1<<LOGTABBITS]; |
21 |
static float gamtab[1<<GAMTABBITS]; |
22 |
static float gammul[16]; |
23 |
static double cur_gam = 0.; |
24 |
static BYTE mongamtab[MONGAMTSZ]; |
25 |
static double cur_mongam = 0.; |
26 |
27 |
#define imultpow2(i,s) ((s)>=0 ? (i)<<(s) : (i)>>-(s)) |
28 |
29 |
30 |
/* Fill our log table */ |
31 |
static void |
32 |
mkLogTable() |
33 |
34 |
int i; |
35 |
36 |
if (logtab[0] != 0.f) |
37 |
return; |
38 |
for (i = 1<<LOGTABBITS; i--; ) |
39 |
logtab[i] = log(imultpow2(i,15-LOGTABBITS)*(1./(1L<<16)) |
40 |
+ .5); |
41 |
42 |
43 |
44 |
/* Fill our input gamma table */ |
45 |
static void |
46 |
mkGamTable(double gv) |
47 |
48 |
int i; |
49 |
50 |
if (gv == cur_gam) |
51 |
return; |
52 |
for (i = 1<<GAMTABBITS; i--; ) |
53 |
gamtab[i] = pow((i+.5)*(1./(1<<GAMTABBITS)), gv); |
54 |
for (i = 16; i--; ) |
55 |
gammul[i] = pow((double)(1L<<i), -gv); |
56 |
cur_gam = gv; |
57 |
58 |
59 |
60 |
/* Fill our monitor gamma table */ |
61 |
static void |
62 |
mkMonGamTable(TMstruct *tms) |
63 |
64 |
int i; |
65 |
66 |
if (tms->mongam == cur_mongam) |
67 |
return; |
68 |
for (i = MONGAMTSZ; i--; ) |
69 |
mongamtab[i] = 256.*pow((i+.5)*(1./MONGAMTSZ), 1./tms->mongam); |
70 |
cur_mongam = tms->mongam; |
71 |
72 |
73 |
74 |
/* Find normalizing shift value for a 2-byte unsigned integer */ |
75 |
static int |
76 |
normShift16(int i) |
77 |
78 |
int s = 0; |
79 |
80 |
if (!i) |
81 |
return(-1); |
82 |
while (!(i & 0x8000)) { |
83 |
i <<= 1; |
84 |
++s; |
85 |
86 |
return(s); |
87 |
88 |
89 |
90 |
/* Find common normalizing shift for 3 2-byte unsigned integers */ |
91 |
static int |
92 |
normShift48(uint16 clr48[3]) |
93 |
94 |
int imax = (clr48[1] > clr48[0] ? clr48[1] : clr48[0]); |
95 |
if (clr48[2] > imax) |
96 |
imax = clr48[2]; |
97 |
return(normShift16(imax)); |
98 |
99 |
100 |
101 |
/* convert at 48-bit tristimulus value to a COLOR */ |
102 |
static void |
103 |
rgb48_color(COLOR col, uint16 clr48[3], double gv) |
104 |
105 |
int nshft; |
106 |
107 |
if (gv == 1.) { /* linear case */ |
108 |
col[0] = clr48[0]*(1./(1L<<16)); |
109 |
col[1] = clr48[1]*(1./(1L<<16)); |
110 |
col[2] = clr48[2]*(1./(1L<<16)); |
111 |
return; |
112 |
113 |
/* non-linear case */ |
114 |
/* XXX Uncomment if this routine is made public |
115 |
if (gv != cur_gam) |
116 |
mkGamTable(gv); |
117 |
118 |
nshft = normShift48(clr48); |
119 |
if (nshft < 0) { |
120 |
col[0] = col[1] = col[2] = .0f; |
121 |
return; |
122 |
123 |
col[0] = gamtab[imultpow2(clr48[0],GAMTABBITS-16+nshft)] * |
124 |
gammul[nshft]; |
125 |
col[1] = gamtab[imultpow2(clr48[1],GAMTABBITS-16+nshft)] * |
126 |
gammul[nshft]; |
127 |
col[2] = gamtab[imultpow2(clr48[2],GAMTABBITS-16+nshft)] * |
128 |
gammul[nshft]; |
129 |
130 |
131 |
132 |
/* Convert 16-bit gray scanline to encoded luminance */ |
133 |
int |
134 |
tmCvGray16(TMstruct *tms, TMbright *ls, uint16 *scan, int len, double gv) |
135 |
136 |
static char funcName[] = "tmCvGray16"; |
137 |
static double cur_inpsf = 1.; |
138 |
static double log_inpsf = 0.; |
139 |
int nshft; |
140 |
double d; |
141 |
142 |
if (tms == NULL) |
143 |
returnErr(TM_E_TMINVAL); |
144 |
if ((ls == NULL) | (scan == NULL) | (len < 0)) |
145 |
returnErr(TM_E_ILLEGAL); |
146 |
if (gv <= 0.) |
147 |
gv = DEFGAM; |
148 |
/* initialize log table */ |
149 |
if (logtab[0] == 0.f) |
150 |
mkLogTable(); |
151 |
if (cur_inpsf != tms->inpsf) |
152 |
log_inpsf = log(cur_inpsf = tms->inpsf); |
153 |
/* convert 16-bit grays */ |
154 |
while (len--) { |
155 |
nshft = normShift16(*scan); |
156 |
if (nshft < 0) { /* bogus value */ |
157 |
*ls++ = TM_NOBRT; |
158 |
scan++; |
159 |
continue; |
160 |
161 |
d = logtab[ imultpow2(*scan,LOGTABBITS-15+nshft) & |
162 |
((1L<<LOGTABBITS)-1) ]; |
163 |
d -= M_LN2*nshft; |
164 |
d = (double)TM_BRTSCALE * (gv*d + log_inpsf); |
165 |
*ls++ = (d>0. ? d+.5 : d-.5); |
166 |
scan++; |
167 |
168 |
returnOK; |
169 |
170 |
171 |
/* Convert a 48-bit RGB scanline to encoded luminance/chrominance */ |
172 |
int |
173 |
tmCvRGB48(TMstruct *tms, TMbright *ls, BYTE *cs, |
174 |
uint16 (*scan)[3], int len, double gv) |
175 |
176 |
static char funcName[] = "tmCvRGB48"; |
177 |
178 |
179 |
int i; |
180 |
181 |
if (tms == NULL) |
182 |
183 |
184 |
185 |
if (gv <= 0.) |
186 |
gv = DEFGAM; |
187 |
/* sync input gamma table */ |
188 |
if ((gv != 1.) & (gv != cur_gam)) |
189 |
mkGamTable(gv); |
190 |
if (tmNeedMatrix(tms)) { /* need floating point */ |
191 |
COLOR *newscan; |
192 |
newscan = (COLOR *)tempbuffer(len*sizeof(COLOR)); |
193 |
if (newscan == NULL) |
194 |
returnErr(TM_E_NOMEM); |
195 |
for (i = len; i--; ) |
196 |
rgb48_color(newscan[i], scan[i], gv); |
197 |
return(tmCvColors(tms, ls, cs, newscan, len)); |
198 |
199 |
/* sync monitor gamma table */ |
200 |
if (cs != TM_NOCHROM && tms->mongam != cur_mongam) |
201 |
mkMonGamTable(tms); |
202 |
203 |
204 |
mkLogTable(); |
205 |
206 |
207 |
if (tms->flags & TM_F_MESOPIC) |
208 |
tmMkMesofact(); |
209 |
/* convert scanline */ |
210 |
for (i = len; i--; ) { |
211 |
int nshft = normShift48(scan[i]); |
212 |
COLOR cmon; |
213 |
double lum; |
214 |
int bi; |
215 |
216 |
if (nshft < 0) { |
217 |
bi = TM_NOBRT; /* bogus value */ |
218 |
lum = 1.; |
219 |
} else { |
220 |
int j = GAMTABBITS-16+nshft; |
221 |
int nshft2; |
222 |
double d; |
223 |
/* normalized linear */ |
224 |
setcolor(cmon, gamtab[imultpow2(scan[i][0],j)], |
225 |
gamtab[imultpow2(scan[i][1],j)], |
226 |
gamtab[imultpow2(scan[i][2],j)] ); |
227 |
lum = tms->clf[RED]*cmon[RED]; |
228 |
lum += tms->clf[GRN]*cmon[GRN]; |
229 |
lum += tms->clf[BLU]*cmon[BLU]; |
230 |
/* convert to log Y */ |
231 |
j = lum * (double)(1L<<16); |
232 |
nshft2 = normShift16(j); |
233 |
d = logtab[ imultpow2(j,LOGTABBITS-15+nshft2) & |
234 |
235 |
d -= M_LN2*(gv*nshft + nshft2); |
236 |
d = (double)TM_BRTSCALE*(d + log_inpsf); |
237 |
bi = (int)(d>0. ? d+.5 : d-.5); |
238 |
239 |
/* world luminance */ |
240 |
ls[i] = bi; |
241 |
if (cs == TM_NOCHROM) /* no color? */ |
242 |
continue; |
243 |
/* mesopic adj. */ |
244 |
if (tms->flags & TM_F_MESOPIC && bi < BMESUPPER) { |
245 |
double slum = scotlum(cmon); |
246 |
if (bi < BMESLOWER) |
247 |
setcolor(cmon, slum, slum, slum); |
248 |
else { |
249 |
double pf; |
250 |
pf = (1./256.)*tmMesofact[bi-BMESLOWER]; |
251 |
if (tms->flags & TM_F_BW) |
252 |
cmon[RED] = cmon[GRN] = cmon[BLU] = lum; |
253 |
slum *= 1. - pf; |
254 |
cmon[RED] = slum + pf*cmon[RED]; |
255 |
cmon[GRN] = slum + pf*cmon[GRN]; |
256 |
cmon[BLU] = slum + pf*cmon[BLU]; |
257 |
258 |
} else if (tms->flags & TM_F_BW) { |
259 |
260 |
261 |
bi = (double)MONGAMTSZ*tms->clf[RED]*cmon[RED]/lum; |
262 |
cs[3*i ] = bi>=MONGAMTSZ ? 255 : mongamtab[bi]; |
263 |
bi = (double)MONGAMTSZ*tms->clf[GRN]*cmon[GRN]/lum; |
264 |
cs[3*i+1] = bi>=MONGAMTSZ ? 255 : mongamtab[bi]; |
265 |
bi = (double)MONGAMTSZ*tms->clf[BLU]*cmon[BLU]/lum; |
266 |
cs[3*i+2] = bi>=MONGAMTSZ ? 255 : mongamtab[bi]; |
267 |
268 |
returnOK; |
269 |
