| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: tmap16bit.c,v 1.5 2005/01/07 20:33:02 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines for tone-mapping 16-bit/primary pixels
| 6 |
| 7 |
* Externals declared in tonemap.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include <stdio.h>
| 13 |
#include <math.h>
| 14 |
#include "tmprivat.h"
| 15 |
| 16 |
#define LOGTABBITS 11 /* log table is 1<<LOGTABBITS long */
| 17 |
#define GAMTABBITS 9 /* gamma table is 1<<GAMTABBITS long */
| 18 |
#define MONGAMTSZ 1024 /* monitor gamma table length */
| 19 |
| 20 |
static float logtab[1<<LOGTABBITS];
| 21 |
static float gamtab[1<<GAMTABBITS];
| 22 |
static float gammul[16];
| 23 |
static double cur_gam = 0.;
| 24 |
static BYTE mongamtab[MONGAMTSZ];
| 25 |
static double cur_mongam = 0.;
| 26 |
| 27 |
#define imultpow2(i,s) ((s)>=0 ? (i)<<(s) : (i)>>-(s))
| 28 |
| 29 |
| 30 |
/* Fill our log table */
| 31 |
static void
| 32 |
mkLogTable()
| 33 |
| 34 |
int i;
| 35 |
| 36 |
if (logtab[0] != 0.f)
| 37 |
return;
| 38 |
for (i = 1<<LOGTABBITS; i--; )
| 39 |
logtab[i] = log(imultpow2(i,15-LOGTABBITS)*(1./(1L<<16))
| 40 |
+ .5);
| 41 |
| 42 |
| 43 |
| 44 |
/* Fill our input gamma table */
| 45 |
static void
| 46 |
mkGamTable(double gv)
| 47 |
| 48 |
int i;
| 49 |
| 50 |
if (gv == cur_gam)
| 51 |
return;
| 52 |
for (i = 1<<GAMTABBITS; i--; )
| 53 |
gamtab[i] = pow((i+.5)*(1./(1<<GAMTABBITS)), gv);
| 54 |
for (i = 16; i--; )
| 55 |
gammul[i] = pow((double)(1L<<i), -gv);
| 56 |
cur_gam = gv;
| 57 |
| 58 |
| 59 |
| 60 |
/* Fill our monitor gamma table */
| 61 |
static void
| 62 |
mkMonGamTable(TMstruct *tms)
| 63 |
| 64 |
int i;
| 65 |
| 66 |
if (tms->mongam == cur_mongam)
| 67 |
return;
| 68 |
for (i = MONGAMTSZ; i--; )
| 69 |
mongamtab[i] = 256.*pow((i+.5)*(1./MONGAMTSZ), 1./tms->mongam);
| 70 |
cur_mongam = tms->mongam;
| 71 |
| 72 |
| 73 |
| 74 |
/* Find normalizing shift value for a 2-byte unsigned integer */
| 75 |
static int
| 76 |
normShift16(int i)
| 77 |
| 78 |
int s = 0;
| 79 |
| 80 |
if (!i)
| 81 |
return(-1);
| 82 |
while (!(i & 0x8000)) {
| 83 |
i <<= 1;
| 84 |
++s;
| 85 |
| 86 |
return(s);
| 87 |
| 88 |
| 89 |
| 90 |
/* Find common normalizing shift for 3 2-byte unsigned integers */
| 91 |
static int
| 92 |
normShift48(uint16 clr48[3])
| 93 |
| 94 |
int imax = (clr48[1] > clr48[0] ? clr48[1] : clr48[0]);
| 95 |
if (clr48[2] > imax)
| 96 |
imax = clr48[2];
| 97 |
return(normShift16(imax));
| 98 |
| 99 |
| 100 |
| 101 |
/* convert at 48-bit tristimulus value to a COLOR */
| 102 |
static void
| 103 |
rgb48_color(COLOR col, uint16 clr48[3], double gv)
| 104 |
| 105 |
int nshft;
| 106 |
| 107 |
if (gv == 1.) { /* linear case */
| 108 |
col[0] = clr48[0]*(1./(1L<<16));
| 109 |
col[1] = clr48[1]*(1./(1L<<16));
| 110 |
col[2] = clr48[2]*(1./(1L<<16));
| 111 |
return;
| 112 |
| 113 |
/* non-linear case */
| 114 |
/* XXX Uncomment if this routine is made public
| 115 |
if (gv != cur_gam)
| 116 |
mkGamTable(gv);
| 117 |
| 118 |
nshft = normShift48(clr48);
| 119 |
if (nshft < 0) {
| 120 |
col[0] = col[1] = col[2] = .0f;
| 121 |
return;
| 122 |
| 123 |
col[0] = gamtab[imultpow2(clr48[0],GAMTABBITS-16+nshft)] *
| 124 |
gammul[nshft];
| 125 |
col[1] = gamtab[imultpow2(clr48[1],GAMTABBITS-16+nshft)] *
| 126 |
gammul[nshft];
| 127 |
col[2] = gamtab[imultpow2(clr48[2],GAMTABBITS-16+nshft)] *
| 128 |
gammul[nshft];
| 129 |
| 130 |
| 131 |
| 132 |
/* Convert 16-bit gray scanline to encoded luminance */
| 133 |
int
| 134 |
tmCvGray16(TMstruct *tms, TMbright *ls, uint16 *scan, int len, double gv)
| 135 |
| 136 |
static const char funcName[] = "tmCvGray16";
| 137 |
static double cur_inpsf = 1.;
| 138 |
static double log_inpsf = 0.;
| 139 |
int nshft;
| 140 |
double d;
| 141 |
| 142 |
if (tms == NULL)
| 143 |
returnErr(TM_E_TMINVAL);
| 144 |
if ((ls == NULL) | (scan == NULL) | (len < 0))
| 145 |
returnErr(TM_E_ILLEGAL);
| 146 |
if (gv <= 0.)
| 147 |
gv = DEFGAM;
| 148 |
/* initialize log table */
| 149 |
if (logtab[0] == 0.f)
| 150 |
mkLogTable();
| 151 |
if (cur_inpsf != tms->inpsf)
| 152 |
log_inpsf = log(cur_inpsf = tms->inpsf);
| 153 |
/* convert 16-bit grays */
| 154 |
while (len--) {
| 155 |
nshft = normShift16(*scan);
| 156 |
if (nshft < 0) { /* bogus value */
| 157 |
*ls++ = TM_NOBRT;
| 158 |
scan++;
| 159 |
continue;
| 160 |
| 161 |
d = logtab[ imultpow2(*scan,LOGTABBITS-15+nshft) &
| 162 |
((1L<<LOGTABBITS)-1) ];
| 163 |
d -= M_LN2*nshft;
| 164 |
d = (double)TM_BRTSCALE * (gv*d + log_inpsf);
| 165 |
*ls++ = (d>0. ? d+.5 : d-.5);
| 166 |
scan++;
| 167 |
| 168 |
returnOK;
| 169 |
| 170 |
| 171 |
/* Convert a 48-bit RGB scanline to encoded luminance/chrominance */
| 172 |
int
| 173 |
tmCvRGB48(TMstruct *tms, TMbright *ls, BYTE *cs,
| 174 |
uint16 (*scan)[3], int len, double gv)
| 175 |
| 176 |
static const char funcName[] = "tmCvRGB48";
| 177 |
| 178 |
| 179 |
int i;
| 180 |
| 181 |
if (tms == NULL)
| 182 |
| 183 |
| 184 |
| 185 |
if (gv <= 0.)
| 186 |
gv = DEFGAM;
| 187 |
/* sync input gamma table */
| 188 |
if ((gv != 1.) & (gv != cur_gam))
| 189 |
mkGamTable(gv);
| 190 |
if (tmNeedMatrix(tms)) { /* need floating point */
| 191 |
COLOR *newscan;
| 192 |
newscan = (COLOR *)tempbuffer(len*sizeof(COLOR));
| 193 |
if (newscan == NULL)
| 194 |
returnErr(TM_E_NOMEM);
| 195 |
for (i = len; i--; )
| 196 |
rgb48_color(newscan[i], scan[i], gv);
| 197 |
return(tmCvColors(tms, ls, cs, newscan, len));
| 198 |
| 199 |
/* sync monitor gamma table */
| 200 |
if (cs != TM_NOCHROM && tms->mongam != cur_mongam)
| 201 |
mkMonGamTable(tms);
| 202 |
| 203 |
| 204 |
mkLogTable();
| 205 |
| 206 |
| 207 |
if (tms->flags & TM_F_MESOPIC)
| 208 |
tmMkMesofact();
| 209 |
/* convert scanline */
| 210 |
for (i = len; i--; ) {
| 211 |
int nshft = normShift48(scan[i]);
| 212 |
COLOR cmon;
| 213 |
double lum;
| 214 |
int bi;
| 215 |
| 216 |
if (nshft < 0) {
| 217 |
bi = TM_NOBRT; /* bogus value */
| 218 |
lum = 1.;
| 219 |
} else {
| 220 |
int j = GAMTABBITS-16+nshft;
| 221 |
int nshft2;
| 222 |
double d;
| 223 |
/* normalized linear */
| 224 |
setcolor(cmon, gamtab[imultpow2(scan[i][0],j)],
| 225 |
gamtab[imultpow2(scan[i][1],j)],
| 226 |
gamtab[imultpow2(scan[i][2],j)] );
| 227 |
lum = tms->clf[RED]*cmon[RED];
| 228 |
lum += tms->clf[GRN]*cmon[GRN];
| 229 |
lum += tms->clf[BLU]*cmon[BLU];
| 230 |
/* convert to log Y */
| 231 |
j = lum * (double)(1L<<16);
| 232 |
nshft2 = normShift16(j);
| 233 |
d = logtab[ imultpow2(j,LOGTABBITS-15+nshft2) &
| 234 |
| 235 |
d -= M_LN2*(gv*nshft + nshft2);
| 236 |
d = (double)TM_BRTSCALE*(d + log_inpsf);
| 237 |
bi = (int)(d>0. ? d+.5 : d-.5);
| 238 |
| 239 |
/* world luminance */
| 240 |
ls[i] = bi;
| 241 |
if (cs == TM_NOCHROM) /* no color? */
| 242 |
continue;
| 243 |
/* mesopic adj. */
| 244 |
if (tms->flags & TM_F_MESOPIC && bi < BMESUPPER) {
| 245 |
double slum = scotlum(cmon);
| 246 |
if (bi < BMESLOWER)
| 247 |
setcolor(cmon, slum, slum, slum);
| 248 |
else {
| 249 |
double pf;
| 250 |
pf = (1./256.)*tmMesofact[bi-BMESLOWER];
| 251 |
if (tms->flags & TM_F_BW)
| 252 |
cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
| 253 |
slum *= 1. - pf;
| 254 |
cmon[RED] = slum + pf*cmon[RED];
| 255 |
cmon[GRN] = slum + pf*cmon[GRN];
| 256 |
cmon[BLU] = slum + pf*cmon[BLU];
| 257 |
| 258 |
} else if (tms->flags & TM_F_BW) {
| 259 |
| 260 |
| 261 |
bi = (double)MONGAMTSZ*tms->clf[RED]*cmon[RED]/lum;
| 262 |
cs[3*i ] = bi>=MONGAMTSZ ? 255 : mongamtab[bi];
| 263 |
bi = (double)MONGAMTSZ*tms->clf[GRN]*cmon[GRN]/lum;
| 264 |
cs[3*i+1] = bi>=MONGAMTSZ ? 255 : mongamtab[bi];
| 265 |
bi = (double)MONGAMTSZ*tms->clf[BLU]*cmon[BLU]/lum;
| 266 |
cs[3*i+2] = bi>=MONGAMTSZ ? 255 : mongamtab[bi];
| 267 |
| 268 |
returnOK;
| 269 |
