root/Development/ray/src/common/tifftypes.h
Revision: 3.2
Committed: Wed Oct 27 23:23:47 2004 UTC (21 years ago) by greg
CVS Tags: rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1
Changes since 3.1: +2 -2 lines
1 /* RCSid $Id: tifftypes.h,v 3.1 2003/06/20 00:25:49 greg Exp $ */
2 /* The following is lifted straight out of tiff.h */
3 #ifndef _TIFF_DATA_TYPEDEFS_
4 #define _TIFF_DATA_TYPEDEFS_
5 /*
6 * Intrinsic data types required by the file format:
7 *
8 * 8-bit quantities int8/uint8
9 * 16-bit quantities int16/uint16
10 * 32-bit quantities int32/uint32
11 */
12 #ifdef __STDC__
13 typedef signed char int8; /* NB: non-ANSI compilers may not grok */
14 #else
15 typedef char int8;
16 #endif
17 typedef unsigned char uint8;
18 typedef short int16;
19 typedef unsigned short uint16; /* sizeof (uint16) must == 2 */
20 #if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) || defined(__LP64__) || defined(__x86_64)
21 typedef int int32;
22 typedef unsigned int uint32; /* sizeof (uint32) must == 4 */
23 #else
24 typedef long int32;
25 typedef unsigned long uint32; /* sizeof (uint32) must == 4 */
26 #endif
27 #endif /* _TIFF_DATA_TYPEDEFS_ */
