root/Development/ray/src/common/tiffio.h
Revision: 3.8
Committed: Mon Jul 21 22:30:17 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 3.7: +0 -0 lines
1 /* $Header: /cvsroot/osrs/libtiff/libtiff/tiffio.h,v 1.8 2001/02/17 03:03:52 warmerda Exp $ */
2
3 /*
4 * Copyright (c) 1988-1997 Sam Leffler
5 * Copyright (c) 1991-1997 Silicon Graphics, Inc.
6 *
7 * Permission to use, copy, modify, distribute, and sell this software and
8 * its documentation for any purpose is hereby granted without fee, provided
9 * that (i) the above copyright notices and this permission notice appear in
10 * all copies of the software and related documentation, and (ii) the names of
11 * Sam Leffler and Silicon Graphics may not be used in any advertising or
12 * publicity relating to the software without the specific, prior written
13 * permission of Sam Leffler and Silicon Graphics.
14 *
15 * THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
16 * EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
17 * WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
18 *
19 * IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
20 * ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
21 * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
22 * WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
23 * LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
24 * OF THIS SOFTWARE.
25 */
26
27 #ifndef _TIFFIO_
28 #define _TIFFIO_
29
30 /*
31 * TIFF I/O Library Definitions.
32 */
33 #include "tiff.h"
34 #include "tiffvers.h"
35
36 /*
37 * TIFF is defined as an incomplete type to hide the
38 * library's internal data structures from clients.
39 */
40 typedef struct tiff TIFF;
41
42 /*
43 * The following typedefs define the intrinsic size of
44 * data types used in the *exported* interfaces. These
45 * definitions depend on the proper definition of types
46 * in tiff.h. Note also that the varargs interface used
47 * to pass tag types and values uses the types defined in
48 * tiff.h directly.
49 *
50 * NB: ttag_t is unsigned int and not unsigned short because
51 * ANSI C requires that the type before the ellipsis be a
52 * promoted type (i.e. one of int, unsigned int, pointer,
53 * or double) and because we defined pseudo-tags that are
54 * outside the range of legal Aldus-assigned tags.
55 * NB: tsize_t is int32 and not uint32 because some functions
56 * return -1.
57 * NB: toff_t is not off_t for many reasons; TIFFs max out at
58 * 32-bit file offsets being the most important, and to ensure
59 * that it is unsigned, rather than signed.
60 */
61 typedef uint32 ttag_t; /* directory tag */
62 typedef uint16 tdir_t; /* directory index */
63 typedef uint16 tsample_t; /* sample number */
64 typedef uint32 tstrip_t; /* strip number */
65 typedef uint32 ttile_t; /* tile number */
66 typedef int32 tsize_t; /* i/o size in bytes */
67 typedef void* tdata_t; /* image data ref */
68 typedef uint32 toff_t; /* file offset */
69
70 #if !defined(__WIN32__) && (defined(_WIN32) || defined(WIN32))
71 #define __WIN32__
72 #endif
73
74 /*
75 * On windows you should define USE_WIN32_FILEIO if you are using tif_win32.c
76 * or AVOID_WIN32_FILEIO if you are using something else (like tif_unix.c).
77 *
78 * By default tif_win32.c is assumed on windows if not using the cygwin
79 * environment.
80 */
81
82 #if defined(_WINDOWS) || defined(__WIN32__) || defined(_Windows)
83 # if !defined(__CYGWIN) && !defined(AVOID_WIN32_FILEIO) && !defined(USE_WIN32_FILIO)
84 # define USE_WIN32_FILEIO
85 # endif
86 #endif
87
88 #if defined(USE_WIN32_FILEIO)
89 #include <windows.h>
90 #ifdef __WIN32__
91 DECLARE_HANDLE(thandle_t); /* Win32 file handle */
92 #else
93 typedef HFILE thandle_t; /* client data handle */
94 #endif
95 #else
96 typedef void* thandle_t; /* client data handle */
97 #endif
98
99 #ifndef NULL
100 #define NULL 0
101 #endif
102
103 /*
104 * Flags to pass to TIFFPrintDirectory to control
105 * printing of data structures that are potentially
106 * very large. Bit-or these flags to enable printing
107 * multiple items.
108 */
109 #define TIFFPRINT_NONE 0x0 /* no extra info */
110 #define TIFFPRINT_STRIPS 0x1 /* strips/tiles info */
111 #define TIFFPRINT_CURVES 0x2 /* color/gray response curves */
112 #define TIFFPRINT_COLORMAP 0x4 /* colormap */
113 #define TIFFPRINT_JPEGQTABLES 0x100 /* JPEG Q matrices */
114 #define TIFFPRINT_JPEGACTABLES 0x200 /* JPEG AC tables */
115 #define TIFFPRINT_JPEGDCTABLES 0x200 /* JPEG DC tables */
116
117 /*
118 * RGBA-style image support.
119 */
120 typedef unsigned char TIFFRGBValue; /* 8-bit samples */
121 typedef struct _TIFFRGBAImage TIFFRGBAImage;
122 /*
123 * The image reading and conversion routines invoke
124 * ``put routines'' to copy/image/whatever tiles of
125 * raw image data. A default set of routines are
126 * provided to convert/copy raw image data to 8-bit
127 * packed ABGR format rasters. Applications can supply
128 * alternate routines that unpack the data into a
129 * different format or, for example, unpack the data
130 * and draw the unpacked raster on the display.
131 */
132 typedef void (*tileContigRoutine)
133 (TIFFRGBAImage*, uint32*, uint32, uint32, uint32, uint32, int32, int32,
134 unsigned char*);
135 typedef void (*tileSeparateRoutine)
136 (TIFFRGBAImage*, uint32*, uint32, uint32, uint32, uint32, int32, int32,
137 unsigned char*, unsigned char*, unsigned char*, unsigned char*);
138 /*
139 * RGBA-reader state.
140 */
141 typedef struct { /* YCbCr->RGB support */
142 TIFFRGBValue* clamptab; /* range clamping table */
143 int* Cr_r_tab;
144 int* Cb_b_tab;
145 int32* Cr_g_tab;
146 int32* Cb_g_tab;
147 float coeffs[3]; /* cached for repeated use */
148 } TIFFYCbCrToRGB;
149
150 struct _TIFFRGBAImage {
151 TIFF* tif; /* image handle */
152 int stoponerr; /* stop on read error */
153 int isContig; /* data is packed/separate */
154 int alpha; /* type of alpha data present */
155 uint32 width; /* image width */
156 uint32 height; /* image height */
157 uint16 bitspersample; /* image bits/sample */
158 uint16 samplesperpixel; /* image samples/pixel */
159 uint16 orientation; /* image orientation */
160 uint16 photometric; /* image photometric interp */
161 uint16* redcmap; /* colormap pallete */
162 uint16* greencmap;
163 uint16* bluecmap;
164 /* get image data routine */
165 int (*get)(TIFFRGBAImage*, uint32*, uint32, uint32);
166 union {
167 void (*any)(TIFFRGBAImage*);
168 tileContigRoutine contig;
169 tileSeparateRoutine separate;
170 } put; /* put decoded strip/tile */
171 TIFFRGBValue* Map; /* sample mapping array */
172 uint32** BWmap; /* black&white map */
173 uint32** PALmap; /* palette image map */
174 TIFFYCbCrToRGB* ycbcr; /* YCbCr conversion state */
175
176 int row_offset;
177 int col_offset;
178 };
179
180 /*
181 * Macros for extracting components from the
182 * packed ABGR form returned by TIFFReadRGBAImage.
183 */
184 #define TIFFGetR(abgr) ((abgr) & 0xff)
185 #define TIFFGetG(abgr) (((abgr) >> 8) & 0xff)
186 #define TIFFGetB(abgr) (((abgr) >> 16) & 0xff)
187 #define TIFFGetA(abgr) (((abgr) >> 24) & 0xff)
188
189 /*
190 * A CODEC is a software package that implements decoding,
191 * encoding, or decoding+encoding of a compression algorithm.
192 * The library provides a collection of builtin codecs.
193 * More codecs may be registered through calls to the library
194 * and/or the builtin implementations may be overridden.
195 */
196 typedef int (*TIFFInitMethod)(TIFF*, int);
197 typedef struct {
198 char* name;
199 uint16 scheme;
200 TIFFInitMethod init;
201 } TIFFCodec;
202
203 #include <stdio.h>
204 #include <stdarg.h>
205
206 /* share internal LogLuv conversion routines */
207 #ifndef LOGLUV_PUBLIC
208 #define LOGLUV_PUBLIC 1
209 #endif
210
211 #if defined(__cplusplus)
212 extern "C" {
213 #endif
214 typedef void (*TIFFErrorHandler)(const char*, const char*, va_list);
215 typedef tsize_t (*TIFFReadWriteProc)(thandle_t, tdata_t, tsize_t);
216 typedef toff_t (*TIFFSeekProc)(thandle_t, toff_t, int);
217 typedef int (*TIFFCloseProc)(thandle_t);
218 typedef toff_t (*TIFFSizeProc)(thandle_t);
219 typedef int (*TIFFMapFileProc)(thandle_t, tdata_t*, toff_t*);
220 typedef void (*TIFFUnmapFileProc)(thandle_t, tdata_t, toff_t);
221 typedef void (*TIFFExtendProc)(TIFF*);
222
223 extern const char* TIFFGetVersion(void);
224
225 extern const TIFFCodec* TIFFFindCODEC(uint16);
226 extern TIFFCodec* TIFFRegisterCODEC(uint16, const char*, TIFFInitMethod);
227 extern void TIFFUnRegisterCODEC(TIFFCodec*);
228
229 extern tdata_t _TIFFmalloc(tsize_t);
230 extern tdata_t _TIFFrealloc(tdata_t, tsize_t);
231 extern void _TIFFmemset(tdata_t, int, tsize_t);
232 extern void _TIFFmemcpy(tdata_t, const tdata_t, tsize_t);
233 extern int _TIFFmemcmp(const tdata_t, const tdata_t, tsize_t);
234 extern void _TIFFfree(tdata_t);
235
236 extern void TIFFClose(TIFF*);
237 extern int TIFFFlush(TIFF*);
238 extern int TIFFFlushData(TIFF*);
239 extern int TIFFGetField(TIFF*, ttag_t, ...);
240 extern int TIFFVGetField(TIFF*, ttag_t, va_list);
241 extern int TIFFGetFieldDefaulted(TIFF*, ttag_t, ...);
242 extern int TIFFVGetFieldDefaulted(TIFF*, ttag_t, va_list);
243 extern int TIFFReadDirectory(TIFF*);
244 extern tsize_t TIFFScanlineSize(TIFF*);
245 extern tsize_t TIFFRasterScanlineSize(TIFF*);
246 extern tsize_t TIFFStripSize(TIFF*);
247 extern tsize_t TIFFVStripSize(TIFF*, uint32);
248 extern tsize_t TIFFTileRowSize(TIFF*);
249 extern tsize_t TIFFTileSize(TIFF*);
250 extern tsize_t TIFFVTileSize(TIFF*, uint32);
251 extern uint32 TIFFDefaultStripSize(TIFF*, uint32);
252 extern void TIFFDefaultTileSize(TIFF*, uint32*, uint32*);
253 extern int TIFFFileno(TIFF*);
254 extern int TIFFGetMode(TIFF*);
255 extern int TIFFIsTiled(TIFF*);
256 extern int TIFFIsByteSwapped(TIFF*);
257 extern int TIFFIsUpSampled(TIFF*);
258 extern int TIFFIsMSB2LSB(TIFF*);
259 extern uint32 TIFFCurrentRow(TIFF*);
260 extern tdir_t TIFFCurrentDirectory(TIFF*);
261 extern tdir_t TIFFNumberOfDirectories(TIFF*);
262 extern uint32 TIFFCurrentDirOffset(TIFF*);
263 extern tstrip_t TIFFCurrentStrip(TIFF*);
264 extern ttile_t TIFFCurrentTile(TIFF*);
265 extern int TIFFReadBufferSetup(TIFF*, tdata_t, tsize_t);
266 extern int TIFFWriteBufferSetup(TIFF*, tdata_t, tsize_t);
267 extern int TIFFWriteCheck(TIFF*, int, const char *);
268 extern int TIFFCreateDirectory(TIFF*);
269 extern int TIFFLastDirectory(TIFF*);
270 extern int TIFFSetDirectory(TIFF*, tdir_t);
271 extern int TIFFSetSubDirectory(TIFF*, uint32);
272 extern int TIFFUnlinkDirectory(TIFF*, tdir_t);
273 extern int TIFFSetField(TIFF*, ttag_t, ...);
274 extern int TIFFVSetField(TIFF*, ttag_t, va_list);
275 extern int TIFFWriteDirectory(TIFF *);
276 extern int TIFFReassignTagToIgnore(enum TIFFIgnoreSense, int);
277
278 #if defined(c_plusplus) || defined(__cplusplus)
279 extern void TIFFPrintDirectory(TIFF*, FILE*, long = 0);
280 extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t = 0);
281 extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t = 0);
282 extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int = 0);
283 #else
284 extern void TIFFPrintDirectory(TIFF*, FILE*, long);
285 extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t);
286 extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t);
287 extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int);
288 #endif
289
290 extern int TIFFReadRGBAStrip(TIFF*, tstrip_t, uint32 * );
291 extern int TIFFReadRGBATile(TIFF*, uint32, uint32, uint32 * );
292 extern int TIFFRGBAImageOK(TIFF*, char [1024]);
293 extern int TIFFRGBAImageBegin(TIFFRGBAImage*, TIFF*, int, char [1024]);
294 extern int TIFFRGBAImageGet(TIFFRGBAImage*, uint32*, uint32, uint32);
295 extern void TIFFRGBAImageEnd(TIFFRGBAImage*);
296 extern TIFF* TIFFOpen(const char*, const char*);
297 extern TIFF* TIFFFdOpen(int, const char*, const char*);
298 extern TIFF* TIFFClientOpen(const char*, const char*,
299 thandle_t,
300 TIFFReadWriteProc, TIFFReadWriteProc,
301 TIFFSeekProc, TIFFCloseProc,
302 TIFFSizeProc,
303 TIFFMapFileProc, TIFFUnmapFileProc);
304 extern const char* TIFFFileName(TIFF*);
305 extern void TIFFError(const char*, const char*, ...);
306 extern void TIFFWarning(const char*, const char*, ...);
307 extern TIFFErrorHandler TIFFSetErrorHandler(TIFFErrorHandler);
308 extern TIFFErrorHandler TIFFSetWarningHandler(TIFFErrorHandler);
309 extern TIFFExtendProc TIFFSetTagExtender(TIFFExtendProc);
310 extern ttile_t TIFFComputeTile(TIFF*, uint32, uint32, uint32, tsample_t);
311 extern int TIFFCheckTile(TIFF*, uint32, uint32, uint32, tsample_t);
312 extern ttile_t TIFFNumberOfTiles(TIFF*);
313 extern tsize_t TIFFReadTile(TIFF*,
314 tdata_t, uint32, uint32, uint32, tsample_t);
315 extern tsize_t TIFFWriteTile(TIFF*,
316 tdata_t, uint32, uint32, uint32, tsample_t);
317 extern tstrip_t TIFFComputeStrip(TIFF*, uint32, tsample_t);
318 extern tstrip_t TIFFNumberOfStrips(TIFF*);
319 extern tsize_t TIFFReadEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
320 extern tsize_t TIFFReadRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
321 extern tsize_t TIFFReadEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t);
322 extern tsize_t TIFFReadRawTile(TIFF*, ttile_t, tdata_t, tsize_t);
323 extern tsize_t TIFFWriteEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
324 extern tsize_t TIFFWriteRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
325 extern tsize_t TIFFWriteEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t);
326 extern tsize_t TIFFWriteRawTile(TIFF*, ttile_t, tdata_t, tsize_t);
327 extern void TIFFSetWriteOffset(TIFF*, toff_t);
328 extern void TIFFSwabShort(uint16*);
329 extern void TIFFSwabLong(uint32*);
330 extern void TIFFSwabDouble(double*);
331 extern void TIFFSwabArrayOfShort(uint16*, unsigned long);
332 extern void TIFFSwabArrayOfLong(uint32*, unsigned long);
333 extern void TIFFSwabArrayOfDouble(double*, unsigned long);
334 extern void TIFFReverseBits(unsigned char *, unsigned long);
335 extern const unsigned char* TIFFGetBitRevTable(int);
336
337 #if LOGLUV_PUBLIC
338 #define U_NEU 0.210526316
339 #define V_NEU 0.473684211
340 #define UVSCALE 410.
341 extern double LogL16toY(int);
342 extern double LogL10toY(int);
343 extern void XYZtoRGB24(float*, uint8*);
344 extern int uv_decode(double*, double*, int);
345 extern void LogLuv24toXYZ(uint32, float*);
346 extern void LogLuv32toXYZ(uint32, float*);
347 #if defined(c_plusplus) || defined(__cplusplus)
348 extern int LogL16fromY(double, int = SGILOGENCODE_NODITHER);
349 extern int LogL10fromY(double, int = SGILOGENCODE_NODITHER);
350 extern int uv_encode(double, double, int = SGILOGENCODE_NODITHER);
351 extern uint32 LogLuv24fromXYZ(float*, int = SGILOGENCODE_NODITHER);
352 extern uint32 LogLuv32fromXYZ(float*, int = SGILOGENCODE_NODITHER);
353 #else
354 extern int LogL16fromY(double, int);
355 extern int LogL10fromY(double, int);
356 extern int uv_encode(double, double, int);
357 extern uint32 LogLuv24fromXYZ(float*, int);
358 extern uint32 LogLuv32fromXYZ(float*, int);
359 #endif
360 #endif /* LOGLUV_PUBLIC */
361 #if defined(__cplusplus)
362 }
363 #endif
364 #endif /* _TIFFIO_ */
