1 |
/* $Id: tiffio.h,v 1.43 2005/04/13 14:06:21 dron Exp $ */ |
2 |
3 |
4 |
* Copyright (c) 1988-1997 Sam Leffler |
5 |
* Copyright (c) 1991-1997 Silicon Graphics, Inc. |
6 |
7 |
* Permission to use, copy, modify, distribute, and sell this software and |
8 |
* its documentation for any purpose is hereby granted without fee, provided |
9 |
* that (i) the above copyright notices and this permission notice appear in |
10 |
* all copies of the software and related documentation, and (ii) the names of |
11 |
* Sam Leffler and Silicon Graphics may not be used in any advertising or |
12 |
* publicity relating to the software without the specific, prior written |
13 |
* permission of Sam Leffler and Silicon Graphics. |
14 |
15 |
* THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND, |
16 |
* EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY |
17 |
* WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. |
18 |
19 |
* IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR |
20 |
* ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND, |
21 |
* OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, |
22 |
* WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF |
23 |
* LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE |
24 |
* OF THIS SOFTWARE. |
25 |
26 |
27 |
#ifndef _TIFFIO_ |
28 |
#define _TIFFIO_ |
29 |
30 |
31 |
* TIFF I/O Library Definitions. |
32 |
33 |
#include "tiff.h" |
34 |
#include "tiffvers.h" |
35 |
36 |
37 |
* TIFF is defined as an incomplete type to hide the |
38 |
* library's internal data structures from clients. |
39 |
40 |
typedef struct tiff TIFF; |
41 |
42 |
43 |
* The following typedefs define the intrinsic size of |
44 |
* data types used in the *exported* interfaces. These |
45 |
* definitions depend on the proper definition of types |
46 |
* in tiff.h. Note also that the varargs interface used |
47 |
* to pass tag types and values uses the types defined in |
48 |
* tiff.h directly. |
49 |
50 |
* NB: ttag_t is unsigned int and not unsigned short because |
51 |
* ANSI C requires that the type before the ellipsis be a |
52 |
* promoted type (i.e. one of int, unsigned int, pointer, |
53 |
* or double) and because we defined pseudo-tags that are |
54 |
* outside the range of legal Aldus-assigned tags. |
55 |
* NB: tsize_t is int32 and not uint32 because some functions |
56 |
* return -1. |
57 |
* NB: toff_t is not off_t for many reasons; TIFFs max out at |
58 |
* 32-bit file offsets being the most important, and to ensure |
59 |
* that it is unsigned, rather than signed. |
60 |
61 |
typedef uint32 ttag_t; /* directory tag */ |
62 |
typedef uint16 tdir_t; /* directory index */ |
63 |
typedef uint16 tsample_t; /* sample number */ |
64 |
typedef uint32 tstrip_t; /* strip number */ |
65 |
typedef uint32 ttile_t; /* tile number */ |
66 |
typedef int32 tsize_t; /* i/o size in bytes */ |
67 |
typedef void* tdata_t; /* image data ref */ |
68 |
typedef uint32 toff_t; /* file offset */ |
69 |
70 |
#if !defined(__WIN32__) && (defined(_WIN32) || defined(WIN32)) |
71 |
#define __WIN32__ |
72 |
#endif |
73 |
74 |
75 |
* On windows you should define USE_WIN32_FILEIO if you are using tif_win32.c |
76 |
* or AVOID_WIN32_FILEIO if you are using something else (like tif_unix.c). |
77 |
78 |
* By default tif_win32.c is assumed on windows if not using the cygwin |
79 |
* environment. |
80 |
81 |
82 |
#if defined(_WINDOWS) || defined(__WIN32__) || defined(_Windows) |
83 |
# if !defined(__CYGWIN) && !defined(AVOID_WIN32_FILEIO) && !defined(USE_WIN32_FILIO) |
84 |
# define USE_WIN32_FILEIO |
85 |
# endif |
86 |
#endif |
87 |
88 |
#if defined(USE_WIN32_FILEIO) |
89 |
# include <windows.h> |
90 |
# ifdef __WIN32__ |
91 |
DECLARE_HANDLE(thandle_t); /* Win32 file handle */ |
92 |
# else |
93 |
typedef HFILE thandle_t; /* client data handle */ |
94 |
# endif /* __WIN32__ */ |
95 |
#else |
96 |
typedef void* thandle_t; /* client data handle */ |
97 |
#endif /* USE_WIN32_FILEIO */ |
98 |
99 |
#ifndef NULL |
100 |
# define NULL (void *)0 |
101 |
#endif |
102 |
103 |
104 |
* Flags to pass to TIFFPrintDirectory to control |
105 |
* printing of data structures that are potentially |
106 |
* very large. Bit-or these flags to enable printing |
107 |
* multiple items. |
108 |
109 |
#define TIFFPRINT_NONE 0x0 /* no extra info */ |
110 |
#define TIFFPRINT_STRIPS 0x1 /* strips/tiles info */ |
111 |
#define TIFFPRINT_CURVES 0x2 /* color/gray response curves */ |
112 |
#define TIFFPRINT_COLORMAP 0x4 /* colormap */ |
113 |
#define TIFFPRINT_JPEGQTABLES 0x100 /* JPEG Q matrices */ |
114 |
#define TIFFPRINT_JPEGACTABLES 0x200 /* JPEG AC tables */ |
115 |
#define TIFFPRINT_JPEGDCTABLES 0x200 /* JPEG DC tables */ |
116 |
117 |
118 |
* Colour conversion stuff |
119 |
120 |
121 |
/* reference white */ |
122 |
#define D65_X0 (95.0470F) |
123 |
#define D65_Y0 (100.0F) |
124 |
#define D65_Z0 (108.8827F) |
125 |
126 |
#define D50_X0 (96.4250F) |
127 |
#define D50_Y0 (100.0F) |
128 |
#define D50_Z0 (82.4680F) |
129 |
130 |
/* Structure for holding information about a display device. */ |
131 |
132 |
typedef unsigned char TIFFRGBValue; /* 8-bit samples */ |
133 |
134 |
typedef struct { |
135 |
float d_mat[3][3]; /* XYZ -> luminance matrix */ |
136 |
float d_YCR; /* Light o/p for reference white */ |
137 |
float d_YCG; |
138 |
float d_YCB; |
139 |
uint32 d_Vrwr; /* Pixel values for ref. white */ |
140 |
uint32 d_Vrwg; |
141 |
uint32 d_Vrwb; |
142 |
float d_Y0R; /* Residual light for black pixel */ |
143 |
float d_Y0G; |
144 |
float d_Y0B; |
145 |
float d_gammaR; /* Gamma values for the three guns */ |
146 |
float d_gammaG; |
147 |
float d_gammaB; |
148 |
} TIFFDisplay; |
149 |
150 |
typedef struct { /* YCbCr->RGB support */ |
151 |
TIFFRGBValue* clamptab; /* range clamping table */ |
152 |
int* Cr_r_tab; |
153 |
int* Cb_b_tab; |
154 |
int32* Cr_g_tab; |
155 |
int32* Cb_g_tab; |
156 |
int32* Y_tab; |
157 |
} TIFFYCbCrToRGB; |
158 |
159 |
typedef struct { /* CIE Lab 1976->RGB support */ |
160 |
int range; /* Size of conversion table */ |
161 |
#define CIELABTORGB_TABLE_RANGE 1500 |
162 |
float rstep, gstep, bstep; |
163 |
float X0, Y0, Z0; /* Reference white point */ |
164 |
TIFFDisplay display; |
165 |
float Yr2r[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yr to r */ |
166 |
float Yg2g[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yg to g */ |
167 |
float Yb2b[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yb to b */ |
168 |
} TIFFCIELabToRGB; |
169 |
170 |
171 |
* RGBA-style image support. |
172 |
173 |
typedef struct _TIFFRGBAImage TIFFRGBAImage; |
174 |
175 |
* The image reading and conversion routines invoke |
176 |
* ``put routines'' to copy/image/whatever tiles of |
177 |
* raw image data. A default set of routines are |
178 |
* provided to convert/copy raw image data to 8-bit |
179 |
* packed ABGR format rasters. Applications can supply |
180 |
* alternate routines that unpack the data into a |
181 |
* different format or, for example, unpack the data |
182 |
* and draw the unpacked raster on the display. |
183 |
184 |
typedef void (*tileContigRoutine) |
185 |
(TIFFRGBAImage*, uint32*, uint32, uint32, uint32, uint32, int32, int32, |
186 |
unsigned char*); |
187 |
typedef void (*tileSeparateRoutine) |
188 |
189 |
unsigned char*, unsigned char*, unsigned char*, unsigned char*); |
190 |
191 |
* RGBA-reader state. |
192 |
193 |
struct _TIFFRGBAImage { |
194 |
TIFF* tif; /* image handle */ |
195 |
int stoponerr; /* stop on read error */ |
196 |
int isContig; /* data is packed/separate */ |
197 |
int alpha; /* type of alpha data present */ |
198 |
uint32 width; /* image width */ |
199 |
uint32 height; /* image height */ |
200 |
uint16 bitspersample; /* image bits/sample */ |
201 |
uint16 samplesperpixel; /* image samples/pixel */ |
202 |
uint16 orientation; /* image orientation */ |
203 |
uint16 req_orientation; /* requested orientation */ |
204 |
uint16 photometric; /* image photometric interp */ |
205 |
uint16* redcmap; /* colormap pallete */ |
206 |
uint16* greencmap; |
207 |
uint16* bluecmap; |
208 |
/* get image data routine */ |
209 |
int (*get)(TIFFRGBAImage*, uint32*, uint32, uint32); |
210 |
union { |
211 |
void (*any)(TIFFRGBAImage*); |
212 |
tileContigRoutine contig; |
213 |
tileSeparateRoutine separate; |
214 |
} put; /* put decoded strip/tile */ |
215 |
TIFFRGBValue* Map; /* sample mapping array */ |
216 |
uint32** BWmap; /* black&white map */ |
217 |
uint32** PALmap; /* palette image map */ |
218 |
TIFFYCbCrToRGB* ycbcr; /* YCbCr conversion state */ |
219 |
TIFFCIELabToRGB* cielab; /* CIE L*a*b conversion state */ |
220 |
221 |
int row_offset; |
222 |
int col_offset; |
223 |
224 |
225 |
226 |
* Macros for extracting components from the |
227 |
* packed ABGR form returned by TIFFReadRGBAImage. |
228 |
229 |
#define TIFFGetR(abgr) ((abgr) & 0xff) |
230 |
#define TIFFGetG(abgr) (((abgr) >> 8) & 0xff) |
231 |
#define TIFFGetB(abgr) (((abgr) >> 16) & 0xff) |
232 |
#define TIFFGetA(abgr) (((abgr) >> 24) & 0xff) |
233 |
234 |
235 |
* A CODEC is a software package that implements decoding, |
236 |
* encoding, or decoding+encoding of a compression algorithm. |
237 |
* The library provides a collection of builtin codecs. |
238 |
* More codecs may be registered through calls to the library |
239 |
* and/or the builtin implementations may be overridden. |
240 |
241 |
typedef int (*TIFFInitMethod)(TIFF*, int); |
242 |
typedef struct { |
243 |
char* name; |
244 |
uint16 scheme; |
245 |
TIFFInitMethod init; |
246 |
} TIFFCodec; |
247 |
248 |
#include <stdio.h> |
249 |
#include <stdarg.h> |
250 |
251 |
/* share internal LogLuv conversion routines? */ |
252 |
#ifndef LOGLUV_PUBLIC |
253 |
#define LOGLUV_PUBLIC 1 |
254 |
#endif |
255 |
256 |
#if defined(c_plusplus) || defined(__cplusplus) |
257 |
extern "C" { |
258 |
#endif |
259 |
typedef void (*TIFFErrorHandler)(const char*, const char*, va_list); |
260 |
typedef tsize_t (*TIFFReadWriteProc)(thandle_t, tdata_t, tsize_t); |
261 |
typedef toff_t (*TIFFSeekProc)(thandle_t, toff_t, int); |
262 |
typedef int (*TIFFCloseProc)(thandle_t); |
263 |
typedef toff_t (*TIFFSizeProc)(thandle_t); |
264 |
typedef int (*TIFFMapFileProc)(thandle_t, tdata_t*, toff_t*); |
265 |
typedef void (*TIFFUnmapFileProc)(thandle_t, tdata_t, toff_t); |
266 |
typedef void (*TIFFExtendProc)(TIFF*); |
267 |
268 |
extern const char* TIFFGetVersion(void); |
269 |
270 |
extern const TIFFCodec* TIFFFindCODEC(uint16); |
271 |
extern TIFFCodec* TIFFRegisterCODEC(uint16, const char*, TIFFInitMethod); |
272 |
extern void TIFFUnRegisterCODEC(TIFFCodec*); |
273 |
extern int TIFFIsCODECConfigured(uint16); |
274 |
extern TIFFCodec* TIFFGetConfiguredCODECs(); |
275 |
276 |
extern tdata_t _TIFFmalloc(tsize_t); |
277 |
extern tdata_t _TIFFrealloc(tdata_t, tsize_t); |
278 |
extern void _TIFFmemset(tdata_t, int, tsize_t); |
279 |
extern void _TIFFmemcpy(tdata_t, const tdata_t, tsize_t); |
280 |
extern int _TIFFmemcmp(const tdata_t, const tdata_t, tsize_t); |
281 |
extern void _TIFFfree(tdata_t); |
282 |
283 |
extern void TIFFCleanup(TIFF*); |
284 |
extern void TIFFClose(TIFF*); |
285 |
extern int TIFFFlush(TIFF*); |
286 |
extern int TIFFFlushData(TIFF*); |
287 |
extern int TIFFGetField(TIFF*, ttag_t, ...); |
288 |
extern int TIFFVGetField(TIFF*, ttag_t, va_list); |
289 |
extern int TIFFGetFieldDefaulted(TIFF*, ttag_t, ...); |
290 |
extern int TIFFVGetFieldDefaulted(TIFF*, ttag_t, va_list); |
291 |
extern int TIFFReadDirectory(TIFF*); |
292 |
extern tsize_t TIFFScanlineSize(TIFF*); |
293 |
extern tsize_t TIFFRasterScanlineSize(TIFF*); |
294 |
extern tsize_t TIFFStripSize(TIFF*); |
295 |
extern tsize_t TIFFRawStripSize(TIFF*, tstrip_t); |
296 |
extern tsize_t TIFFVStripSize(TIFF*, uint32); |
297 |
extern tsize_t TIFFTileRowSize(TIFF*); |
298 |
extern tsize_t TIFFTileSize(TIFF*); |
299 |
extern tsize_t TIFFVTileSize(TIFF*, uint32); |
300 |
extern uint32 TIFFDefaultStripSize(TIFF*, uint32); |
301 |
extern void TIFFDefaultTileSize(TIFF*, uint32*, uint32*); |
302 |
extern int TIFFFileno(TIFF*); |
303 |
extern int TIFFSetFileno(TIFF*, int); |
304 |
extern thandle_t TIFFClientdata(TIFF*); |
305 |
extern thandle_t TIFFSetClientdata(TIFF*, thandle_t); |
306 |
extern int TIFFGetMode(TIFF*); |
307 |
extern int TIFFSetMode(TIFF*, int); |
308 |
extern int TIFFIsTiled(TIFF*); |
309 |
extern int TIFFIsByteSwapped(TIFF*); |
310 |
extern int TIFFIsUpSampled(TIFF*); |
311 |
extern int TIFFIsMSB2LSB(TIFF*); |
312 |
extern int TIFFIsBigEndian(TIFF*); |
313 |
extern TIFFReadWriteProc TIFFGetReadProc(TIFF*); |
314 |
extern TIFFReadWriteProc TIFFGetWriteProc(TIFF*); |
315 |
extern TIFFSeekProc TIFFGetSeekProc(TIFF*); |
316 |
extern TIFFCloseProc TIFFGetCloseProc(TIFF*); |
317 |
extern TIFFSizeProc TIFFGetSizeProc(TIFF*); |
318 |
extern TIFFMapFileProc TIFFGetMapFileProc(TIFF*); |
319 |
extern TIFFUnmapFileProc TIFFGetUnmapFileProc(TIFF*); |
320 |
extern uint32 TIFFCurrentRow(TIFF*); |
321 |
extern tdir_t TIFFCurrentDirectory(TIFF*); |
322 |
extern tdir_t TIFFNumberOfDirectories(TIFF*); |
323 |
extern uint32 TIFFCurrentDirOffset(TIFF*); |
324 |
extern tstrip_t TIFFCurrentStrip(TIFF*); |
325 |
extern ttile_t TIFFCurrentTile(TIFF*); |
326 |
extern int TIFFReadBufferSetup(TIFF*, tdata_t, tsize_t); |
327 |
extern int TIFFWriteBufferSetup(TIFF*, tdata_t, tsize_t); |
328 |
extern int TIFFSetupStrips(TIFF *); |
329 |
extern int TIFFWriteCheck(TIFF*, int, const char *); |
330 |
extern int TIFFCreateDirectory(TIFF*); |
331 |
extern int TIFFLastDirectory(TIFF*); |
332 |
extern int TIFFSetDirectory(TIFF*, tdir_t); |
333 |
extern int TIFFSetSubDirectory(TIFF*, uint32); |
334 |
extern int TIFFUnlinkDirectory(TIFF*, tdir_t); |
335 |
extern int TIFFSetField(TIFF*, ttag_t, ...); |
336 |
extern int TIFFVSetField(TIFF*, ttag_t, va_list); |
337 |
extern int TIFFWriteDirectory(TIFF *); |
338 |
extern int TIFFCheckpointDirectory(TIFF *); |
339 |
extern int TIFFRewriteDirectory(TIFF *); |
340 |
extern int TIFFReassignTagToIgnore(enum TIFFIgnoreSense, int); |
341 |
342 |
343 |
extern void TIFFPrintDirectory(TIFF*, FILE*, long = 0); |
344 |
extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t = 0); |
345 |
extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t = 0); |
346 |
extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int = 0); |
347 |
extern int TIFFReadRGBAImageOriented(TIFF*, uint32, uint32, uint32*, |
348 |
int = ORIENTATION_BOTLEFT, int = 0); |
349 |
#else |
350 |
extern void TIFFPrintDirectory(TIFF*, FILE*, long); |
351 |
extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t); |
352 |
extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t); |
353 |
extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int); |
354 |
extern int TIFFReadRGBAImageOriented(TIFF*, uint32, uint32, uint32*, int, int); |
355 |
#endif |
356 |
357 |
extern int TIFFReadRGBAStrip(TIFF*, tstrip_t, uint32 * ); |
358 |
extern int TIFFReadRGBATile(TIFF*, uint32, uint32, uint32 * ); |
359 |
extern int TIFFRGBAImageOK(TIFF*, char [1024]); |
360 |
extern int TIFFRGBAImageBegin(TIFFRGBAImage*, TIFF*, int, char [1024]); |
361 |
extern int TIFFRGBAImageGet(TIFFRGBAImage*, uint32*, uint32, uint32); |
362 |
extern void TIFFRGBAImageEnd(TIFFRGBAImage*); |
363 |
extern TIFF* TIFFOpen(const char*, const char*); |
364 |
# ifdef __WIN32__ |
365 |
extern TIFF* TIFFOpenW(const wchar_t*, const char*); |
366 |
367 |
extern TIFF* TIFFFdOpen(int, const char*, const char*); |
368 |
extern TIFF* TIFFClientOpen(const char*, const char*, |
369 |
thandle_t, |
370 |
TIFFReadWriteProc, TIFFReadWriteProc, |
371 |
TIFFSeekProc, TIFFCloseProc, |
372 |
TIFFSizeProc, |
373 |
TIFFMapFileProc, TIFFUnmapFileProc); |
374 |
extern const char* TIFFFileName(TIFF*); |
375 |
extern const char* TIFFSetFileName(TIFF*, const char *); |
376 |
extern void TIFFError(const char*, const char*, ...); |
377 |
extern void TIFFWarning(const char*, const char*, ...); |
378 |
extern TIFFErrorHandler TIFFSetErrorHandler(TIFFErrorHandler); |
379 |
extern TIFFErrorHandler TIFFSetWarningHandler(TIFFErrorHandler); |
380 |
extern TIFFExtendProc TIFFSetTagExtender(TIFFExtendProc); |
381 |
extern ttile_t TIFFComputeTile(TIFF*, uint32, uint32, uint32, tsample_t); |
382 |
extern int TIFFCheckTile(TIFF*, uint32, uint32, uint32, tsample_t); |
383 |
extern ttile_t TIFFNumberOfTiles(TIFF*); |
384 |
extern tsize_t TIFFReadTile(TIFF*, |
385 |
tdata_t, uint32, uint32, uint32, tsample_t); |
386 |
extern tsize_t TIFFWriteTile(TIFF*, |
387 |
388 |
extern tstrip_t TIFFComputeStrip(TIFF*, uint32, tsample_t); |
389 |
extern tstrip_t TIFFNumberOfStrips(TIFF*); |
390 |
extern tsize_t TIFFReadEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t); |
391 |
extern tsize_t TIFFReadRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t); |
392 |
extern tsize_t TIFFReadEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t); |
393 |
extern tsize_t TIFFReadRawTile(TIFF*, ttile_t, tdata_t, tsize_t); |
394 |
extern tsize_t TIFFWriteEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t); |
395 |
extern tsize_t TIFFWriteRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t); |
396 |
extern tsize_t TIFFWriteEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t); |
397 |
extern tsize_t TIFFWriteRawTile(TIFF*, ttile_t, tdata_t, tsize_t); |
398 |
extern int TIFFDataWidth(TIFFDataType); /* table of tag datatype widths */ |
399 |
extern void TIFFSetWriteOffset(TIFF*, toff_t); |
400 |
extern void TIFFSwabShort(uint16*); |
401 |
extern void TIFFSwabLong(uint32*); |
402 |
extern void TIFFSwabDouble(double*); |
403 |
extern void TIFFSwabArrayOfShort(uint16*, unsigned long); |
404 |
extern void TIFFSwabArrayOfTriples(uint8*, unsigned long); |
405 |
extern void TIFFSwabArrayOfLong(uint32*, unsigned long); |
406 |
extern void TIFFSwabArrayOfDouble(double*, unsigned long); |
407 |
extern void TIFFReverseBits(unsigned char *, unsigned long); |
408 |
extern const unsigned char* TIFFGetBitRevTable(int); |
409 |
410 |
#ifdef LOGLUV_PUBLIC |
411 |
#define U_NEU 0.210526316 |
412 |
#define V_NEU 0.473684211 |
413 |
#define UVSCALE 410. |
414 |
extern double LogL16toY(int); |
415 |
extern double LogL10toY(int); |
416 |
extern void XYZtoRGB24(float*, uint8*); |
417 |
extern int uv_decode(double*, double*, int); |
418 |
extern void LogLuv24toXYZ(uint32, float*); |
419 |
extern void LogLuv32toXYZ(uint32, float*); |
420 |
421 |
extern int LogL16fromY(double, int = SGILOGENCODE_NODITHER); |
422 |
extern int LogL10fromY(double, int = SGILOGENCODE_NODITHER); |
423 |
extern int uv_encode(double, double, int = SGILOGENCODE_NODITHER); |
424 |
extern uint32 LogLuv24fromXYZ(float*, int = SGILOGENCODE_NODITHER); |
425 |
extern uint32 LogLuv32fromXYZ(float*, int = SGILOGENCODE_NODITHER); |
426 |
#else |
427 |
extern int LogL16fromY(double, int); |
428 |
extern int LogL10fromY(double, int); |
429 |
extern int uv_encode(double, double, int); |
430 |
extern uint32 LogLuv24fromXYZ(float*, int); |
431 |
extern uint32 LogLuv32fromXYZ(float*, int); |
432 |
#endif |
433 |
#endif /* LOGLUV_PUBLIC */ |
434 |
435 |
436 |
** Stuff, related to tag handling and creating custom tags. |
437 |
438 |
extern int TIFFGetTagListCount( TIFF * ); |
439 |
extern ttag_t TIFFGetTagListEntry( TIFF *, int tag_index ); |
440 |
441 |
#define TIFF_ANY TIFF_NOTYPE /* for field descriptor searching */ |
442 |
#define TIFF_VARIABLE -1 /* marker for variable length tags */ |
443 |
#define TIFF_SPP -2 /* marker for SamplesPerPixel tags */ |
444 |
#define TIFF_VARIABLE2 -3 /* marker for uint32 var-length tags */ |
445 |
446 |
#define FIELD_CUSTOM 65 |
447 |
448 |
typedef struct { |
449 |
ttag_t field_tag; /* field's tag */ |
450 |
short field_readcount; /* read count/TIFF_VARIABLE/TIFF_SPP */ |
451 |
short field_writecount; /* write count/TIFF_VARIABLE */ |
452 |
TIFFDataType field_type; /* type of associated data */ |
453 |
unsigned short field_bit; /* bit in fieldsset bit vector */ |
454 |
unsigned char field_oktochange; /* if true, can change while writing */ |
455 |
unsigned char field_passcount; /* if true, pass dir count on set */ |
456 |
char *field_name; /* ASCII name */ |
457 |
} TIFFFieldInfo; |
458 |
459 |
typedef struct _TIFFTagValue { |
460 |
const TIFFFieldInfo *info; |
461 |
int count; |
462 |
void *value; |
463 |
} TIFFTagValue; |
464 |
465 |
extern void TIFFMergeFieldInfo(TIFF*, const TIFFFieldInfo[], int); |
466 |
extern const TIFFFieldInfo* TIFFFindFieldInfo(TIFF*, ttag_t, TIFFDataType); |
467 |
extern const TIFFFieldInfo* TIFFFindFieldInfoByName(TIFF* , const char *, |
468 |
TIFFDataType); |
469 |
extern const TIFFFieldInfo* TIFFFieldWithTag(TIFF*, ttag_t); |
470 |
extern const TIFFFieldInfo* TIFFFieldWithName(TIFF*, const char *); |
471 |
472 |
typedef int (*TIFFVSetMethod)(TIFF*, ttag_t, va_list); |
473 |
typedef int (*TIFFVGetMethod)(TIFF*, ttag_t, va_list); |
474 |
typedef void (*TIFFPrintMethod)(TIFF*, FILE*, long); |
475 |
476 |
typedef struct { |
477 |
TIFFVSetMethod vsetfield; /* tag set routine */ |
478 |
TIFFVGetMethod vgetfield; /* tag get routine */ |
479 |
TIFFPrintMethod printdir; /* directory print routine */ |
480 |
} TIFFTagMethods; |
481 |
482 |
extern TIFFTagMethods *TIFFAccessTagMethods( TIFF * ); |
483 |
extern void *TIFFGetClientInfo( TIFF *, const char * ); |
484 |
extern void TIFFSetClientInfo( TIFF *, void *, const char * ); |
485 |
486 |
extern int TIFFCIELabToRGBInit(TIFFCIELabToRGB*, TIFFDisplay *, float*); |
487 |
extern void TIFFCIELabToXYZ(TIFFCIELabToRGB *, uint32, int32, int32, |
488 |
float *, float *, float *); |
489 |
extern void TIFFXYZToRGB(TIFFCIELabToRGB *, float, float, float, |
490 |
uint32 *, uint32 *, uint32 *); |
491 |
492 |
extern int TIFFYCbCrToRGBInit(TIFFYCbCrToRGB*, float*, float*); |
493 |
extern void TIFFYCbCrtoRGB(TIFFYCbCrToRGB *, uint32, int32, int32, |
494 |
495 |
496 |
497 |
498 |
#endif |
499 |
500 |
#endif /* _TIFFIO_ */ |
501 |
502 |
/* vim: set ts=8 sts=8 sw=8 noet: */ |
