| 1 |
/* $Id: tiffio.h,v 1.43 2005/04/13 14:06:21 dron Exp $ */
| 2 |
| 3 |
| 4 |
* Copyright (c) 1988-1997 Sam Leffler
| 5 |
* Copyright (c) 1991-1997 Silicon Graphics, Inc.
| 6 |
| 7 |
* Permission to use, copy, modify, distribute, and sell this software and
| 8 |
* its documentation for any purpose is hereby granted without fee, provided
| 9 |
* that (i) the above copyright notices and this permission notice appear in
| 10 |
* all copies of the software and related documentation, and (ii) the names of
| 11 |
* Sam Leffler and Silicon Graphics may not be used in any advertising or
| 12 |
* publicity relating to the software without the specific, prior written
| 13 |
* permission of Sam Leffler and Silicon Graphics.
| 14 |
| 15 |
* THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
| 16 |
* EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
| 17 |
* WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
| 18 |
| 19 |
* IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
| 20 |
* ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
| 21 |
* OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
| 22 |
* WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
| 23 |
* LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
| 24 |
* OF THIS SOFTWARE.
| 25 |
| 26 |
| 27 |
#ifndef _TIFFIO_
| 28 |
#define _TIFFIO_
| 29 |
| 30 |
| 31 |
* TIFF I/O Library Definitions.
| 32 |
| 33 |
#include "tiff.h"
| 34 |
#include "tiffvers.h"
| 35 |
| 36 |
| 37 |
* TIFF is defined as an incomplete type to hide the
| 38 |
* library's internal data structures from clients.
| 39 |
| 40 |
typedef struct tiff TIFF;
| 41 |
| 42 |
| 43 |
* The following typedefs define the intrinsic size of
| 44 |
* data types used in the *exported* interfaces. These
| 45 |
* definitions depend on the proper definition of types
| 46 |
* in tiff.h. Note also that the varargs interface used
| 47 |
* to pass tag types and values uses the types defined in
| 48 |
* tiff.h directly.
| 49 |
| 50 |
* NB: ttag_t is unsigned int and not unsigned short because
| 51 |
* ANSI C requires that the type before the ellipsis be a
| 52 |
* promoted type (i.e. one of int, unsigned int, pointer,
| 53 |
* or double) and because we defined pseudo-tags that are
| 54 |
* outside the range of legal Aldus-assigned tags.
| 55 |
* NB: tsize_t is int32 and not uint32 because some functions
| 56 |
* return -1.
| 57 |
* NB: toff_t is not off_t for many reasons; TIFFs max out at
| 58 |
* 32-bit file offsets being the most important, and to ensure
| 59 |
* that it is unsigned, rather than signed.
| 60 |
| 61 |
typedef uint32 ttag_t; /* directory tag */
| 62 |
typedef uint16 tdir_t; /* directory index */
| 63 |
typedef uint16 tsample_t; /* sample number */
| 64 |
typedef uint32 tstrip_t; /* strip number */
| 65 |
typedef uint32 ttile_t; /* tile number */
| 66 |
typedef int32 tsize_t; /* i/o size in bytes */
| 67 |
typedef void* tdata_t; /* image data ref */
| 68 |
typedef uint32 toff_t; /* file offset */
| 69 |
| 70 |
#if !defined(__WIN32__) && (defined(_WIN32) || defined(WIN32))
| 71 |
#define __WIN32__
| 72 |
#endif
| 73 |
| 74 |
| 75 |
* On windows you should define USE_WIN32_FILEIO if you are using tif_win32.c
| 76 |
* or AVOID_WIN32_FILEIO if you are using something else (like tif_unix.c).
| 77 |
| 78 |
* By default tif_win32.c is assumed on windows if not using the cygwin
| 79 |
* environment.
| 80 |
| 81 |
| 82 |
#if defined(_WINDOWS) || defined(__WIN32__) || defined(_Windows)
| 83 |
# if !defined(__CYGWIN) && !defined(AVOID_WIN32_FILEIO) && !defined(USE_WIN32_FILIO)
| 84 |
# define USE_WIN32_FILEIO
| 85 |
# endif
| 86 |
#endif
| 87 |
| 88 |
#if defined(USE_WIN32_FILEIO)
| 89 |
# include <windows.h>
| 90 |
# ifdef __WIN32__
| 91 |
DECLARE_HANDLE(thandle_t); /* Win32 file handle */
| 92 |
# else
| 93 |
typedef HFILE thandle_t; /* client data handle */
| 94 |
# endif /* __WIN32__ */
| 95 |
#else
| 96 |
typedef void* thandle_t; /* client data handle */
| 97 |
#endif /* USE_WIN32_FILEIO */
| 98 |
| 99 |
#ifndef NULL
| 100 |
# define NULL (void *)0
| 101 |
#endif
| 102 |
| 103 |
| 104 |
* Flags to pass to TIFFPrintDirectory to control
| 105 |
* printing of data structures that are potentially
| 106 |
* very large. Bit-or these flags to enable printing
| 107 |
* multiple items.
| 108 |
| 109 |
#define TIFFPRINT_NONE 0x0 /* no extra info */
| 110 |
#define TIFFPRINT_STRIPS 0x1 /* strips/tiles info */
| 111 |
#define TIFFPRINT_CURVES 0x2 /* color/gray response curves */
| 112 |
#define TIFFPRINT_COLORMAP 0x4 /* colormap */
| 113 |
#define TIFFPRINT_JPEGQTABLES 0x100 /* JPEG Q matrices */
| 114 |
#define TIFFPRINT_JPEGACTABLES 0x200 /* JPEG AC tables */
| 115 |
#define TIFFPRINT_JPEGDCTABLES 0x200 /* JPEG DC tables */
| 116 |
| 117 |
| 118 |
* Colour conversion stuff
| 119 |
| 120 |
| 121 |
/* reference white */
| 122 |
#define D65_X0 (95.0470F)
| 123 |
#define D65_Y0 (100.0F)
| 124 |
#define D65_Z0 (108.8827F)
| 125 |
| 126 |
#define D50_X0 (96.4250F)
| 127 |
#define D50_Y0 (100.0F)
| 128 |
#define D50_Z0 (82.4680F)
| 129 |
| 130 |
/* Structure for holding information about a display device. */
| 131 |
| 132 |
typedef unsigned char TIFFRGBValue; /* 8-bit samples */
| 133 |
| 134 |
typedef struct {
| 135 |
float d_mat[3][3]; /* XYZ -> luminance matrix */
| 136 |
float d_YCR; /* Light o/p for reference white */
| 137 |
float d_YCG;
| 138 |
float d_YCB;
| 139 |
uint32 d_Vrwr; /* Pixel values for ref. white */
| 140 |
uint32 d_Vrwg;
| 141 |
uint32 d_Vrwb;
| 142 |
float d_Y0R; /* Residual light for black pixel */
| 143 |
float d_Y0G;
| 144 |
float d_Y0B;
| 145 |
float d_gammaR; /* Gamma values for the three guns */
| 146 |
float d_gammaG;
| 147 |
float d_gammaB;
| 148 |
} TIFFDisplay;
| 149 |
| 150 |
typedef struct { /* YCbCr->RGB support */
| 151 |
TIFFRGBValue* clamptab; /* range clamping table */
| 152 |
int* Cr_r_tab;
| 153 |
int* Cb_b_tab;
| 154 |
int32* Cr_g_tab;
| 155 |
int32* Cb_g_tab;
| 156 |
int32* Y_tab;
| 157 |
} TIFFYCbCrToRGB;
| 158 |
| 159 |
typedef struct { /* CIE Lab 1976->RGB support */
| 160 |
int range; /* Size of conversion table */
| 161 |
#define CIELABTORGB_TABLE_RANGE 1500
| 162 |
float rstep, gstep, bstep;
| 163 |
float X0, Y0, Z0; /* Reference white point */
| 164 |
TIFFDisplay display;
| 165 |
float Yr2r[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yr to r */
| 166 |
float Yg2g[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yg to g */
| 167 |
float Yb2b[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yb to b */
| 168 |
} TIFFCIELabToRGB;
| 169 |
| 170 |
| 171 |
* RGBA-style image support.
| 172 |
| 173 |
typedef struct _TIFFRGBAImage TIFFRGBAImage;
| 174 |
| 175 |
* The image reading and conversion routines invoke
| 176 |
* ``put routines'' to copy/image/whatever tiles of
| 177 |
* raw image data. A default set of routines are
| 178 |
* provided to convert/copy raw image data to 8-bit
| 179 |
* packed ABGR format rasters. Applications can supply
| 180 |
* alternate routines that unpack the data into a
| 181 |
* different format or, for example, unpack the data
| 182 |
* and draw the unpacked raster on the display.
| 183 |
| 184 |
typedef void (*tileContigRoutine)
| 185 |
(TIFFRGBAImage*, uint32*, uint32, uint32, uint32, uint32, int32, int32,
| 186 |
unsigned char*);
| 187 |
typedef void (*tileSeparateRoutine)
| 188 |
| 189 |
unsigned char*, unsigned char*, unsigned char*, unsigned char*);
| 190 |
| 191 |
* RGBA-reader state.
| 192 |
| 193 |
struct _TIFFRGBAImage {
| 194 |
TIFF* tif; /* image handle */
| 195 |
int stoponerr; /* stop on read error */
| 196 |
int isContig; /* data is packed/separate */
| 197 |
int alpha; /* type of alpha data present */
| 198 |
uint32 width; /* image width */
| 199 |
uint32 height; /* image height */
| 200 |
uint16 bitspersample; /* image bits/sample */
| 201 |
uint16 samplesperpixel; /* image samples/pixel */
| 202 |
uint16 orientation; /* image orientation */
| 203 |
uint16 req_orientation; /* requested orientation */
| 204 |
uint16 photometric; /* image photometric interp */
| 205 |
uint16* redcmap; /* colormap pallete */
| 206 |
uint16* greencmap;
| 207 |
uint16* bluecmap;
| 208 |
/* get image data routine */
| 209 |
int (*get)(TIFFRGBAImage*, uint32*, uint32, uint32);
| 210 |
union {
| 211 |
void (*any)(TIFFRGBAImage*);
| 212 |
tileContigRoutine contig;
| 213 |
tileSeparateRoutine separate;
| 214 |
} put; /* put decoded strip/tile */
| 215 |
TIFFRGBValue* Map; /* sample mapping array */
| 216 |
uint32** BWmap; /* black&white map */
| 217 |
uint32** PALmap; /* palette image map */
| 218 |
TIFFYCbCrToRGB* ycbcr; /* YCbCr conversion state */
| 219 |
TIFFCIELabToRGB* cielab; /* CIE L*a*b conversion state */
| 220 |
| 221 |
int row_offset;
| 222 |
int col_offset;
| 223 |
| 224 |
| 225 |
| 226 |
* Macros for extracting components from the
| 227 |
* packed ABGR form returned by TIFFReadRGBAImage.
| 228 |
| 229 |
#define TIFFGetR(abgr) ((abgr) & 0xff)
| 230 |
#define TIFFGetG(abgr) (((abgr) >> 8) & 0xff)
| 231 |
#define TIFFGetB(abgr) (((abgr) >> 16) & 0xff)
| 232 |
#define TIFFGetA(abgr) (((abgr) >> 24) & 0xff)
| 233 |
| 234 |
| 235 |
* A CODEC is a software package that implements decoding,
| 236 |
* encoding, or decoding+encoding of a compression algorithm.
| 237 |
* The library provides a collection of builtin codecs.
| 238 |
* More codecs may be registered through calls to the library
| 239 |
* and/or the builtin implementations may be overridden.
| 240 |
| 241 |
typedef int (*TIFFInitMethod)(TIFF*, int);
| 242 |
typedef struct {
| 243 |
char* name;
| 244 |
uint16 scheme;
| 245 |
TIFFInitMethod init;
| 246 |
} TIFFCodec;
| 247 |
| 248 |
#include <stdio.h>
| 249 |
#include <stdarg.h>
| 250 |
| 251 |
/* share internal LogLuv conversion routines? */
| 252 |
#ifndef LOGLUV_PUBLIC
| 253 |
#define LOGLUV_PUBLIC 1
| 254 |
#endif
| 255 |
| 256 |
#if defined(c_plusplus) || defined(__cplusplus)
| 257 |
extern "C" {
| 258 |
#endif
| 259 |
typedef void (*TIFFErrorHandler)(const char*, const char*, va_list);
| 260 |
typedef tsize_t (*TIFFReadWriteProc)(thandle_t, tdata_t, tsize_t);
| 261 |
typedef toff_t (*TIFFSeekProc)(thandle_t, toff_t, int);
| 262 |
typedef int (*TIFFCloseProc)(thandle_t);
| 263 |
typedef toff_t (*TIFFSizeProc)(thandle_t);
| 264 |
typedef int (*TIFFMapFileProc)(thandle_t, tdata_t*, toff_t*);
| 265 |
typedef void (*TIFFUnmapFileProc)(thandle_t, tdata_t, toff_t);
| 266 |
typedef void (*TIFFExtendProc)(TIFF*);
| 267 |
| 268 |
extern const char* TIFFGetVersion(void);
| 269 |
| 270 |
extern const TIFFCodec* TIFFFindCODEC(uint16);
| 271 |
extern TIFFCodec* TIFFRegisterCODEC(uint16, const char*, TIFFInitMethod);
| 272 |
extern void TIFFUnRegisterCODEC(TIFFCodec*);
| 273 |
extern int TIFFIsCODECConfigured(uint16);
| 274 |
extern TIFFCodec* TIFFGetConfiguredCODECs();
| 275 |
| 276 |
extern tdata_t _TIFFmalloc(tsize_t);
| 277 |
extern tdata_t _TIFFrealloc(tdata_t, tsize_t);
| 278 |
extern void _TIFFmemset(tdata_t, int, tsize_t);
| 279 |
extern void _TIFFmemcpy(tdata_t, const tdata_t, tsize_t);
| 280 |
extern int _TIFFmemcmp(const tdata_t, const tdata_t, tsize_t);
| 281 |
extern void _TIFFfree(tdata_t);
| 282 |
| 283 |
extern void TIFFCleanup(TIFF*);
| 284 |
extern void TIFFClose(TIFF*);
| 285 |
extern int TIFFFlush(TIFF*);
| 286 |
extern int TIFFFlushData(TIFF*);
| 287 |
extern int TIFFGetField(TIFF*, ttag_t, ...);
| 288 |
extern int TIFFVGetField(TIFF*, ttag_t, va_list);
| 289 |
extern int TIFFGetFieldDefaulted(TIFF*, ttag_t, ...);
| 290 |
extern int TIFFVGetFieldDefaulted(TIFF*, ttag_t, va_list);
| 291 |
extern int TIFFReadDirectory(TIFF*);
| 292 |
extern tsize_t TIFFScanlineSize(TIFF*);
| 293 |
extern tsize_t TIFFRasterScanlineSize(TIFF*);
| 294 |
extern tsize_t TIFFStripSize(TIFF*);
| 295 |
extern tsize_t TIFFRawStripSize(TIFF*, tstrip_t);
| 296 |
extern tsize_t TIFFVStripSize(TIFF*, uint32);
| 297 |
extern tsize_t TIFFTileRowSize(TIFF*);
| 298 |
extern tsize_t TIFFTileSize(TIFF*);
| 299 |
extern tsize_t TIFFVTileSize(TIFF*, uint32);
| 300 |
extern uint32 TIFFDefaultStripSize(TIFF*, uint32);
| 301 |
extern void TIFFDefaultTileSize(TIFF*, uint32*, uint32*);
| 302 |
extern int TIFFFileno(TIFF*);
| 303 |
extern int TIFFSetFileno(TIFF*, int);
| 304 |
extern thandle_t TIFFClientdata(TIFF*);
| 305 |
extern thandle_t TIFFSetClientdata(TIFF*, thandle_t);
| 306 |
extern int TIFFGetMode(TIFF*);
| 307 |
extern int TIFFSetMode(TIFF*, int);
| 308 |
extern int TIFFIsTiled(TIFF*);
| 309 |
extern int TIFFIsByteSwapped(TIFF*);
| 310 |
extern int TIFFIsUpSampled(TIFF*);
| 311 |
extern int TIFFIsMSB2LSB(TIFF*);
| 312 |
extern int TIFFIsBigEndian(TIFF*);
| 313 |
extern TIFFReadWriteProc TIFFGetReadProc(TIFF*);
| 314 |
extern TIFFReadWriteProc TIFFGetWriteProc(TIFF*);
| 315 |
extern TIFFSeekProc TIFFGetSeekProc(TIFF*);
| 316 |
extern TIFFCloseProc TIFFGetCloseProc(TIFF*);
| 317 |
extern TIFFSizeProc TIFFGetSizeProc(TIFF*);
| 318 |
extern TIFFMapFileProc TIFFGetMapFileProc(TIFF*);
| 319 |
extern TIFFUnmapFileProc TIFFGetUnmapFileProc(TIFF*);
| 320 |
extern uint32 TIFFCurrentRow(TIFF*);
| 321 |
extern tdir_t TIFFCurrentDirectory(TIFF*);
| 322 |
extern tdir_t TIFFNumberOfDirectories(TIFF*);
| 323 |
extern uint32 TIFFCurrentDirOffset(TIFF*);
| 324 |
extern tstrip_t TIFFCurrentStrip(TIFF*);
| 325 |
extern ttile_t TIFFCurrentTile(TIFF*);
| 326 |
extern int TIFFReadBufferSetup(TIFF*, tdata_t, tsize_t);
| 327 |
extern int TIFFWriteBufferSetup(TIFF*, tdata_t, tsize_t);
| 328 |
extern int TIFFSetupStrips(TIFF *);
| 329 |
extern int TIFFWriteCheck(TIFF*, int, const char *);
| 330 |
extern int TIFFCreateDirectory(TIFF*);
| 331 |
extern int TIFFLastDirectory(TIFF*);
| 332 |
extern int TIFFSetDirectory(TIFF*, tdir_t);
| 333 |
extern int TIFFSetSubDirectory(TIFF*, uint32);
| 334 |
extern int TIFFUnlinkDirectory(TIFF*, tdir_t);
| 335 |
extern int TIFFSetField(TIFF*, ttag_t, ...);
| 336 |
extern int TIFFVSetField(TIFF*, ttag_t, va_list);
| 337 |
extern int TIFFWriteDirectory(TIFF *);
| 338 |
extern int TIFFCheckpointDirectory(TIFF *);
| 339 |
extern int TIFFRewriteDirectory(TIFF *);
| 340 |
extern int TIFFReassignTagToIgnore(enum TIFFIgnoreSense, int);
| 341 |
| 342 |
| 343 |
extern void TIFFPrintDirectory(TIFF*, FILE*, long = 0);
| 344 |
extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t = 0);
| 345 |
extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t = 0);
| 346 |
extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int = 0);
| 347 |
extern int TIFFReadRGBAImageOriented(TIFF*, uint32, uint32, uint32*,
| 348 |
int = ORIENTATION_BOTLEFT, int = 0);
| 349 |
#else
| 350 |
extern void TIFFPrintDirectory(TIFF*, FILE*, long);
| 351 |
extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t);
| 352 |
extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t);
| 353 |
extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int);
| 354 |
extern int TIFFReadRGBAImageOriented(TIFF*, uint32, uint32, uint32*, int, int);
| 355 |
#endif
| 356 |
| 357 |
extern int TIFFReadRGBAStrip(TIFF*, tstrip_t, uint32 * );
| 358 |
extern int TIFFReadRGBATile(TIFF*, uint32, uint32, uint32 * );
| 359 |
extern int TIFFRGBAImageOK(TIFF*, char [1024]);
| 360 |
extern int TIFFRGBAImageBegin(TIFFRGBAImage*, TIFF*, int, char [1024]);
| 361 |
extern int TIFFRGBAImageGet(TIFFRGBAImage*, uint32*, uint32, uint32);
| 362 |
extern void TIFFRGBAImageEnd(TIFFRGBAImage*);
| 363 |
extern TIFF* TIFFOpen(const char*, const char*);
| 364 |
# ifdef __WIN32__
| 365 |
extern TIFF* TIFFOpenW(const wchar_t*, const char*);
| 366 |
| 367 |
extern TIFF* TIFFFdOpen(int, const char*, const char*);
| 368 |
extern TIFF* TIFFClientOpen(const char*, const char*,
| 369 |
thandle_t,
| 370 |
TIFFReadWriteProc, TIFFReadWriteProc,
| 371 |
TIFFSeekProc, TIFFCloseProc,
| 372 |
TIFFSizeProc,
| 373 |
TIFFMapFileProc, TIFFUnmapFileProc);
| 374 |
extern const char* TIFFFileName(TIFF*);
| 375 |
extern const char* TIFFSetFileName(TIFF*, const char *);
| 376 |
extern void TIFFError(const char*, const char*, ...);
| 377 |
extern void TIFFWarning(const char*, const char*, ...);
| 378 |
extern TIFFErrorHandler TIFFSetErrorHandler(TIFFErrorHandler);
| 379 |
extern TIFFErrorHandler TIFFSetWarningHandler(TIFFErrorHandler);
| 380 |
extern TIFFExtendProc TIFFSetTagExtender(TIFFExtendProc);
| 381 |
extern ttile_t TIFFComputeTile(TIFF*, uint32, uint32, uint32, tsample_t);
| 382 |
extern int TIFFCheckTile(TIFF*, uint32, uint32, uint32, tsample_t);
| 383 |
extern ttile_t TIFFNumberOfTiles(TIFF*);
| 384 |
extern tsize_t TIFFReadTile(TIFF*,
| 385 |
tdata_t, uint32, uint32, uint32, tsample_t);
| 386 |
extern tsize_t TIFFWriteTile(TIFF*,
| 387 |
| 388 |
extern tstrip_t TIFFComputeStrip(TIFF*, uint32, tsample_t);
| 389 |
extern tstrip_t TIFFNumberOfStrips(TIFF*);
| 390 |
extern tsize_t TIFFReadEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
| 391 |
extern tsize_t TIFFReadRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
| 392 |
extern tsize_t TIFFReadEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t);
| 393 |
extern tsize_t TIFFReadRawTile(TIFF*, ttile_t, tdata_t, tsize_t);
| 394 |
extern tsize_t TIFFWriteEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
| 395 |
extern tsize_t TIFFWriteRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
| 396 |
extern tsize_t TIFFWriteEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t);
| 397 |
extern tsize_t TIFFWriteRawTile(TIFF*, ttile_t, tdata_t, tsize_t);
| 398 |
extern int TIFFDataWidth(TIFFDataType); /* table of tag datatype widths */
| 399 |
extern void TIFFSetWriteOffset(TIFF*, toff_t);
| 400 |
extern void TIFFSwabShort(uint16*);
| 401 |
extern void TIFFSwabLong(uint32*);
| 402 |
extern void TIFFSwabDouble(double*);
| 403 |
extern void TIFFSwabArrayOfShort(uint16*, unsigned long);
| 404 |
extern void TIFFSwabArrayOfTriples(uint8*, unsigned long);
| 405 |
extern void TIFFSwabArrayOfLong(uint32*, unsigned long);
| 406 |
extern void TIFFSwabArrayOfDouble(double*, unsigned long);
| 407 |
extern void TIFFReverseBits(unsigned char *, unsigned long);
| 408 |
extern const unsigned char* TIFFGetBitRevTable(int);
| 409 |
| 410 |
#ifdef LOGLUV_PUBLIC
| 411 |
#define U_NEU 0.210526316
| 412 |
#define V_NEU 0.473684211
| 413 |
#define UVSCALE 410.
| 414 |
extern double LogL16toY(int);
| 415 |
extern double LogL10toY(int);
| 416 |
extern void XYZtoRGB24(float*, uint8*);
| 417 |
extern int uv_decode(double*, double*, int);
| 418 |
extern void LogLuv24toXYZ(uint32, float*);
| 419 |
extern void LogLuv32toXYZ(uint32, float*);
| 420 |
| 421 |
extern int LogL16fromY(double, int = SGILOGENCODE_NODITHER);
| 422 |
extern int LogL10fromY(double, int = SGILOGENCODE_NODITHER);
| 423 |
extern int uv_encode(double, double, int = SGILOGENCODE_NODITHER);
| 424 |
extern uint32 LogLuv24fromXYZ(float*, int = SGILOGENCODE_NODITHER);
| 425 |
extern uint32 LogLuv32fromXYZ(float*, int = SGILOGENCODE_NODITHER);
| 426 |
#else
| 427 |
extern int LogL16fromY(double, int);
| 428 |
extern int LogL10fromY(double, int);
| 429 |
extern int uv_encode(double, double, int);
| 430 |
extern uint32 LogLuv24fromXYZ(float*, int);
| 431 |
extern uint32 LogLuv32fromXYZ(float*, int);
| 432 |
#endif
| 433 |
#endif /* LOGLUV_PUBLIC */
| 434 |
| 435 |
| 436 |
** Stuff, related to tag handling and creating custom tags.
| 437 |
| 438 |
extern int TIFFGetTagListCount( TIFF * );
| 439 |
extern ttag_t TIFFGetTagListEntry( TIFF *, int tag_index );
| 440 |
| 441 |
#define TIFF_ANY TIFF_NOTYPE /* for field descriptor searching */
| 442 |
#define TIFF_VARIABLE -1 /* marker for variable length tags */
| 443 |
#define TIFF_SPP -2 /* marker for SamplesPerPixel tags */
| 444 |
#define TIFF_VARIABLE2 -3 /* marker for uint32 var-length tags */
| 445 |
| 446 |
#define FIELD_CUSTOM 65
| 447 |
| 448 |
typedef struct {
| 449 |
ttag_t field_tag; /* field's tag */
| 450 |
short field_readcount; /* read count/TIFF_VARIABLE/TIFF_SPP */
| 451 |
short field_writecount; /* write count/TIFF_VARIABLE */
| 452 |
TIFFDataType field_type; /* type of associated data */
| 453 |
unsigned short field_bit; /* bit in fieldsset bit vector */
| 454 |
unsigned char field_oktochange; /* if true, can change while writing */
| 455 |
unsigned char field_passcount; /* if true, pass dir count on set */
| 456 |
char *field_name; /* ASCII name */
| 457 |
} TIFFFieldInfo;
| 458 |
| 459 |
typedef struct _TIFFTagValue {
| 460 |
const TIFFFieldInfo *info;
| 461 |
int count;
| 462 |
void *value;
| 463 |
} TIFFTagValue;
| 464 |
| 465 |
extern void TIFFMergeFieldInfo(TIFF*, const TIFFFieldInfo[], int);
| 466 |
extern const TIFFFieldInfo* TIFFFindFieldInfo(TIFF*, ttag_t, TIFFDataType);
| 467 |
extern const TIFFFieldInfo* TIFFFindFieldInfoByName(TIFF* , const char *,
| 468 |
TIFFDataType);
| 469 |
extern const TIFFFieldInfo* TIFFFieldWithTag(TIFF*, ttag_t);
| 470 |
extern const TIFFFieldInfo* TIFFFieldWithName(TIFF*, const char *);
| 471 |
| 472 |
typedef int (*TIFFVSetMethod)(TIFF*, ttag_t, va_list);
| 473 |
typedef int (*TIFFVGetMethod)(TIFF*, ttag_t, va_list);
| 474 |
typedef void (*TIFFPrintMethod)(TIFF*, FILE*, long);
| 475 |
| 476 |
typedef struct {
| 477 |
TIFFVSetMethod vsetfield; /* tag set routine */
| 478 |
TIFFVGetMethod vgetfield; /* tag get routine */
| 479 |
TIFFPrintMethod printdir; /* directory print routine */
| 480 |
} TIFFTagMethods;
| 481 |
| 482 |
extern TIFFTagMethods *TIFFAccessTagMethods( TIFF * );
| 483 |
extern void *TIFFGetClientInfo( TIFF *, const char * );
| 484 |
extern void TIFFSetClientInfo( TIFF *, void *, const char * );
| 485 |
| 486 |
extern int TIFFCIELabToRGBInit(TIFFCIELabToRGB*, TIFFDisplay *, float*);
| 487 |
extern void TIFFCIELabToXYZ(TIFFCIELabToRGB *, uint32, int32, int32,
| 488 |
float *, float *, float *);
| 489 |
extern void TIFFXYZToRGB(TIFFCIELabToRGB *, float, float, float,
| 490 |
uint32 *, uint32 *, uint32 *);
| 491 |
| 492 |
extern int TIFFYCbCrToRGBInit(TIFFYCbCrToRGB*, float*, float*);
| 493 |
extern void TIFFYCbCrtoRGB(TIFFYCbCrToRGB *, uint32, int32, int32,
| 494 |
| 495 |
| 496 |
| 497 |
| 498 |
#endif
| 499 |
| 500 |
#endif /* _TIFFIO_ */
| 501 |
| 502 |
/* vim: set ts=8 sts=8 sw=8 noet: */
