--- ray/src/common/tiffio.h 2003/09/09 15:01:22 3.10 +++ ray/src/common/tiffio.h 2005/07/13 15:25:46 3.11 @@ -1,5 +1,4 @@ -/* $Header: /usr/local/cvs/radiance/ray/src/common/tiffio.h,v 3.10 2003/09/09 15:01:22 greg Exp $ */ - +/* RCSid $Id: tiffio.h,v 3.11 2005/07/13 15:25:46 greg Exp $ */ /* * Copyright (c) 1988-1997 Sam Leffler * Copyright (c) 1991-1997 Silicon Graphics, Inc. @@ -86,18 +85,18 @@ typedef uint32 toff_t; /* file offset */ #endif #if defined(USE_WIN32_FILEIO) -#include -#ifdef __WIN32__ +# include +# ifdef __WIN32__ DECLARE_HANDLE(thandle_t); /* Win32 file handle */ -#else +# else typedef HFILE thandle_t; /* client data handle */ -#endif +# endif /* __WIN32__ */ #else typedef void* thandle_t; /* client data handle */ -#endif +#endif /* USE_WIN32_FILEIO */ #ifndef NULL -#define NULL 0 +# define NULL (void *)0 #endif /* @@ -114,10 +113,62 @@ typedef void* thandle_t; /* client data handle */ #define TIFFPRINT_JPEGACTABLES 0x200 /* JPEG AC tables */ #define TIFFPRINT_JPEGDCTABLES 0x200 /* JPEG DC tables */ +/* + * Colour conversion stuff + */ + +/* reference white */ +#define D65_X0 (95.0470F) +#define D65_Y0 (100.0F) +#define D65_Z0 (108.8827F) + +#define D50_X0 (96.4250F) +#define D50_Y0 (100.0F) +#define D50_Z0 (82.4680F) + +/* Structure for holding information about a display device. */ + +typedef unsigned char TIFFRGBValue; /* 8-bit samples */ + +typedef struct { + float d_mat[3][3]; /* XYZ -> luminance matrix */ + float d_YCR; /* Light o/p for reference white */ + float d_YCG; + float d_YCB; + uint32 d_Vrwr; /* Pixel values for ref. white */ + uint32 d_Vrwg; + uint32 d_Vrwb; + float d_Y0R; /* Residual light for black pixel */ + float d_Y0G; + float d_Y0B; + float d_gammaR; /* Gamma values for the three guns */ + float d_gammaG; + float d_gammaB; +} TIFFDisplay; + +typedef struct { /* YCbCr->RGB support */ + TIFFRGBValue* clamptab; /* range clamping table */ + int* Cr_r_tab; + int* Cb_b_tab; + int32* Cr_g_tab; + int32* Cb_g_tab; + int32* Y_tab; +} TIFFYCbCrToRGB; + +typedef struct { /* CIE Lab 1976->RGB support */ + int range; /* Size of conversion table */ +#define CIELABTORGB_TABLE_RANGE 1500 + float rstep, gstep, bstep; + float X0, Y0, Z0; /* Reference white point */ + TIFFDisplay display; + float Yr2r[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yr to r */ + float Yg2g[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yg to g */ + float Yb2b[CIELABTORGB_TABLE_RANGE + 1]; /* Conversion of Yb to b */ +} TIFFCIELabToRGB; + /* * RGBA-style image support. */ -typedef unsigned char TIFFRGBValue; /* 8-bit samples */ typedef struct _TIFFRGBAImage TIFFRGBAImage; /* * The image reading and conversion routines invoke @@ -138,15 +189,6 @@ typedef void (*tileSeparateRoutine) /* * RGBA-reader state. */ -typedef struct { /* YCbCr->RGB support */ - TIFFRGBValue* clamptab; /* range clamping table */ - int* Cr_r_tab; - int* Cb_b_tab; - int32* Cr_g_tab; - int32* Cb_g_tab; - float coeffs[3]; /* cached for repeated use */ -} TIFFYCbCrToRGB; - struct _TIFFRGBAImage { TIFF* tif; /* image handle */ int stoponerr; /* stop on read error */ @@ -157,6 +199,7 @@ struct _TIFFRGBAImage { uint16 bitspersample; /* image bits/sample */ uint16 samplesperpixel; /* image samples/pixel */ uint16 orientation; /* image orientation */ + uint16 req_orientation; /* requested orientation */ uint16 photometric; /* image photometric interp */ uint16* redcmap; /* colormap pallete */ uint16* greencmap; @@ -172,6 +215,7 @@ struct _TIFFRGBAImage { uint32** BWmap; /* black&white map */ uint32** PALmap; /* palette image map */ TIFFYCbCrToRGB* ycbcr; /* YCbCr conversion state */ + TIFFCIELabToRGB* cielab; /* CIE L*a*b conversion state */ int row_offset; int col_offset; @@ -208,7 +252,7 @@ typedef struct { #define LOGLUV_PUBLIC 1 #endif -#if defined(__cplusplus) +#if defined(c_plusplus) || defined(__cplusplus) extern "C" { #endif typedef void (*TIFFErrorHandler)(const char*, const char*, va_list); @@ -225,6 +269,8 @@ extern const char* TIFFGetVersion(void); extern const TIFFCodec* TIFFFindCODEC(uint16); extern TIFFCodec* TIFFRegisterCODEC(uint16, const char*, TIFFInitMethod); extern void TIFFUnRegisterCODEC(TIFFCodec*); +extern int TIFFIsCODECConfigured(uint16); +extern TIFFCodec* TIFFGetConfiguredCODECs(); extern tdata_t _TIFFmalloc(tsize_t); extern tdata_t _TIFFrealloc(tdata_t, tsize_t); @@ -233,6 +279,7 @@ extern void _TIFFmemcpy(tdata_t, const tdata_t, tsize_ extern int _TIFFmemcmp(const tdata_t, const tdata_t, tsize_t); extern void _TIFFfree(tdata_t); +extern void TIFFCleanup(TIFF*); extern void TIFFClose(TIFF*); extern int TIFFFlush(TIFF*); extern int TIFFFlushData(TIFF*); @@ -244,6 +291,7 @@ extern int TIFFReadDirectory(TIFF*); extern tsize_t TIFFScanlineSize(TIFF*); extern tsize_t TIFFRasterScanlineSize(TIFF*); extern tsize_t TIFFStripSize(TIFF*); +extern tsize_t TIFFRawStripSize(TIFF*, tstrip_t); extern tsize_t TIFFVStripSize(TIFF*, uint32); extern tsize_t TIFFTileRowSize(TIFF*); extern tsize_t TIFFTileSize(TIFF*); @@ -251,11 +299,23 @@ extern tsize_t TIFFVTileSize(TIFF*, uint32); extern uint32 TIFFDefaultStripSize(TIFF*, uint32); extern void TIFFDefaultTileSize(TIFF*, uint32*, uint32*); extern int TIFFFileno(TIFF*); +extern int TIFFSetFileno(TIFF*, int); +extern thandle_t TIFFClientdata(TIFF*); +extern thandle_t TIFFSetClientdata(TIFF*, thandle_t); extern int TIFFGetMode(TIFF*); +extern int TIFFSetMode(TIFF*, int); extern int TIFFIsTiled(TIFF*); extern int TIFFIsByteSwapped(TIFF*); extern int TIFFIsUpSampled(TIFF*); extern int TIFFIsMSB2LSB(TIFF*); +extern int TIFFIsBigEndian(TIFF*); +extern TIFFReadWriteProc TIFFGetReadProc(TIFF*); +extern TIFFReadWriteProc TIFFGetWriteProc(TIFF*); +extern TIFFSeekProc TIFFGetSeekProc(TIFF*); +extern TIFFCloseProc TIFFGetCloseProc(TIFF*); +extern TIFFSizeProc TIFFGetSizeProc(TIFF*); +extern TIFFMapFileProc TIFFGetMapFileProc(TIFF*); +extern TIFFUnmapFileProc TIFFGetUnmapFileProc(TIFF*); extern uint32 TIFFCurrentRow(TIFF*); extern tdir_t TIFFCurrentDirectory(TIFF*); extern tdir_t TIFFNumberOfDirectories(TIFF*); @@ -264,6 +324,7 @@ extern tstrip_t TIFFCurrentStrip(TIFF*); extern ttile_t TIFFCurrentTile(TIFF*); extern int TIFFReadBufferSetup(TIFF*, tdata_t, tsize_t); extern int TIFFWriteBufferSetup(TIFF*, tdata_t, tsize_t); +extern int TIFFSetupStrips(TIFF *); extern int TIFFWriteCheck(TIFF*, int, const char *); extern int TIFFCreateDirectory(TIFF*); extern int TIFFLastDirectory(TIFF*); @@ -273,6 +334,7 @@ extern int TIFFUnlinkDirectory(TIFF*, tdir_t); extern int TIFFSetField(TIFF*, ttag_t, ...); extern int TIFFVSetField(TIFF*, ttag_t, va_list); extern int TIFFWriteDirectory(TIFF *); +extern int TIFFCheckpointDirectory(TIFF *); extern int TIFFRewriteDirectory(TIFF *); extern int TIFFReassignTagToIgnore(enum TIFFIgnoreSense, int); @@ -281,11 +343,14 @@ extern void TIFFPrintDirectory(TIFF*, FILE*, long = 0) extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t = 0); extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t = 0); extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int = 0); +extern int TIFFReadRGBAImageOriented(TIFF*, uint32, uint32, uint32*, + int = ORIENTATION_BOTLEFT, int = 0); #else extern void TIFFPrintDirectory(TIFF*, FILE*, long); extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t); extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t); extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int); +extern int TIFFReadRGBAImageOriented(TIFF*, uint32, uint32, uint32*, int, int); #endif extern int TIFFReadRGBAStrip(TIFF*, tstrip_t, uint32 * ); @@ -295,6 +360,9 @@ extern int TIFFRGBAImageBegin(TIFFRGBAImage*, TIFF*, i extern int TIFFRGBAImageGet(TIFFRGBAImage*, uint32*, uint32, uint32); extern void TIFFRGBAImageEnd(TIFFRGBAImage*); extern TIFF* TIFFOpen(const char*, const char*); +# ifdef __WIN32__ +extern TIFF* TIFFOpenW(const wchar_t*, const char*); +# endif /* __WIN32__ */ extern TIFF* TIFFFdOpen(int, const char*, const char*); extern TIFF* TIFFClientOpen(const char*, const char*, thandle_t, @@ -303,6 +371,7 @@ extern TIFF* TIFFClientOpen(const char*, const char*, TIFFSizeProc, TIFFMapFileProc, TIFFUnmapFileProc); extern const char* TIFFFileName(TIFF*); +extern const char* TIFFSetFileName(TIFF*, const char *); extern void TIFFError(const char*, const char*, ...); extern void TIFFWarning(const char*, const char*, ...); extern TIFFErrorHandler TIFFSetErrorHandler(TIFFErrorHandler); @@ -325,17 +394,19 @@ extern tsize_t TIFFWriteEncodedStrip(TIFF*, tstrip_t, extern tsize_t TIFFWriteRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t); extern tsize_t TIFFWriteEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t); extern tsize_t TIFFWriteRawTile(TIFF*, ttile_t, tdata_t, tsize_t); +extern int TIFFDataWidth(TIFFDataType); /* table of tag datatype widths */ extern void TIFFSetWriteOffset(TIFF*, toff_t); extern void TIFFSwabShort(uint16*); extern void TIFFSwabLong(uint32*); extern void TIFFSwabDouble(double*); extern void TIFFSwabArrayOfShort(uint16*, unsigned long); +extern void TIFFSwabArrayOfTriples(uint8*, unsigned long); extern void TIFFSwabArrayOfLong(uint32*, unsigned long); extern void TIFFSwabArrayOfDouble(double*, unsigned long); extern void TIFFReverseBits(unsigned char *, unsigned long); extern const unsigned char* TIFFGetBitRevTable(int); -#if LOGLUV_PUBLIC +#ifdef LOGLUV_PUBLIC #define U_NEU 0.210526316 #define V_NEU 0.473684211 #define UVSCALE 410. @@ -359,7 +430,72 @@ extern uint32 LogLuv24fromXYZ(float*, int); extern uint32 LogLuv32fromXYZ(float*, int); #endif #endif /* LOGLUV_PUBLIC */ -#if defined(__cplusplus) + +/* +** Stuff, related to tag handling and creating custom tags. +*/ +extern int TIFFGetTagListCount( TIFF * ); +extern ttag_t TIFFGetTagListEntry( TIFF *, int tag_index ); + +#define TIFF_ANY TIFF_NOTYPE /* for field descriptor searching */ +#define TIFF_VARIABLE -1 /* marker for variable length tags */ +#define TIFF_SPP -2 /* marker for SamplesPerPixel tags */ +#define TIFF_VARIABLE2 -3 /* marker for uint32 var-length tags */ + +#define FIELD_CUSTOM 65 + +typedef struct { + ttag_t field_tag; /* field's tag */ + short field_readcount; /* read count/TIFF_VARIABLE/TIFF_SPP */ + short field_writecount; /* write count/TIFF_VARIABLE */ + TIFFDataType field_type; /* type of associated data */ + unsigned short field_bit; /* bit in fieldsset bit vector */ + unsigned char field_oktochange; /* if true, can change while writing */ + unsigned char field_passcount; /* if true, pass dir count on set */ + char *field_name; /* ASCII name */ +} TIFFFieldInfo; + +typedef struct _TIFFTagValue { + const TIFFFieldInfo *info; + int count; + void *value; +} TIFFTagValue; + +extern void TIFFMergeFieldInfo(TIFF*, const TIFFFieldInfo[], int); +extern const TIFFFieldInfo* TIFFFindFieldInfo(TIFF*, ttag_t, TIFFDataType); +extern const TIFFFieldInfo* TIFFFindFieldInfoByName(TIFF* , const char *, + TIFFDataType); +extern const TIFFFieldInfo* TIFFFieldWithTag(TIFF*, ttag_t); +extern const TIFFFieldInfo* TIFFFieldWithName(TIFF*, const char *); + +typedef int (*TIFFVSetMethod)(TIFF*, ttag_t, va_list); +typedef int (*TIFFVGetMethod)(TIFF*, ttag_t, va_list); +typedef void (*TIFFPrintMethod)(TIFF*, FILE*, long); + +typedef struct { + TIFFVSetMethod vsetfield; /* tag set routine */ + TIFFVGetMethod vgetfield; /* tag get routine */ + TIFFPrintMethod printdir; /* directory print routine */ +} TIFFTagMethods; + +extern TIFFTagMethods *TIFFAccessTagMethods( TIFF * ); +extern void *TIFFGetClientInfo( TIFF *, const char * ); +extern void TIFFSetClientInfo( TIFF *, void *, const char * ); + +extern int TIFFCIELabToRGBInit(TIFFCIELabToRGB*, TIFFDisplay *, float*); +extern void TIFFCIELabToXYZ(TIFFCIELabToRGB *, uint32, int32, int32, + float *, float *, float *); +extern void TIFFXYZToRGB(TIFFCIELabToRGB *, float, float, float, + uint32 *, uint32 *, uint32 *); + +extern int TIFFYCbCrToRGBInit(TIFFYCbCrToRGB*, float*, float*); +extern void TIFFYCbCrtoRGB(TIFFYCbCrToRGB *, uint32, int32, int32, + uint32 *, uint32 *, uint32 *); + +#if defined(c_plusplus) || defined(__cplusplus) } #endif + #endif /* _TIFFIO_ */ + +/* vim: set ts=8 sts=8 sw=8 noet: */
