root/radiance/ray/src/common/tiffio.h
Revision 3.15 - (view) (download) (annotate) - [selected]
Fri Mar 10 16:43:39 2006 UTC (19 years, 1 month ago) by greg
CVS Tags: rad3R8, rad3R9
Diff to previous 3.14
Adjusted UVSCALE factor at request of Frank Klemm
Fri Sep 23 19:22:37 2005 UTC (19 years, 7 months ago) by greg
Changes since 3.13: +0 -0 lines
Diff to previous 3.13 , to selected 3.15
Removed some redundant globals
Fri Sep 23 19:04:52 2005 UTC (19 years, 7 months ago) by greg
Changes since 3.12: +0 -0 lines
Diff to previous 3.12 , to selected 3.15
Sun Jul 24 19:53:07 2005 UTC (19 years, 9 months ago) by greg
Changes since 3.11: +2 -1 lines
Diff to previous 3.11 , to selected 3.15
Wed Jul 13 15:25:46 2005 UTC (19 years, 9 months ago) by greg
Changes since 3.10: +157 -21 lines
Diff to previous 3.10 , to selected 3.15
Updated TIFF library to 3.7.3
Tue Sep 9 15:01:22 2003 UTC (21 years, 7 months ago) by greg
Changes since 3.9: +4 -3 lines
Diff to previous 3.9 , to selected 3.15
Updated to TIFF library version 3.5.7
Sun Jul 27 22:12:01 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.8: +0 -0 lines
Diff to previous 3.8 , to selected 3.15
Mon Jul 21 22:30:17 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.7: +0 -0 lines
Diff to previous 3.7 , to selected 3.15
Mon Jul 14 20:02:29 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.6: +0 -0 lines
Diff to previous 3.6 , to selected 3.15
Thu Jun 19 23:14:31 2003 UTC (21 years, 10 months ago) by greg
Changes since 3.5: +1 -1 lines
Diff to previous 3.5 , to selected 3.15
Reinstated original tiff headers in ray/common -- needed for build to work!
Revision 3.5
Fri Jun 13 15:27:39 2003 UTC (21 years, 10 months ago) by greg
FILE REMOVED
Removed tiff*.h files from repository, since they're part of libtiff
Sun Jun 8 12:03:09 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.3: +0 -0 lines
Diff to previous 3.3 , to selected 3.15
Sat Jun 7 12:50:21 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.2: +0 -0 lines
Diff to previous 3.2 , to selected 3.15
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.1: +2 -1 lines
Diff to previous 3.1 , to selected 3.15
Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Diff to selected 3.15
