root/Development/ray/src/common/tiffio.h
Revision: 3.10
Committed: Tue Sep 9 15:01:22 2003 UTC (22 years, 4 months ago) by greg
CVS Tags: rad3R6P1, rad3R6
Changes since 3.9: +4 -3 lines
Updated to TIFF library version 3.5.7
# User Rev Content
1 greg 3.10 /* $Header: /cvsroot/osrs/libtiff/libtiff/tiffio.h,v 1.11 2001/09/26 17:42:18 warmerda Exp $ */
2 schorsch 3.2
3 greg 3.1 /*
4     * Copyright (c) 1988-1997 Sam Leffler
5     * Copyright (c) 1991-1997 Silicon Graphics, Inc.
6     *
7     * Permission to use, copy, modify, distribute, and sell this software and
8     * its documentation for any purpose is hereby granted without fee, provided
9     * that (i) the above copyright notices and this permission notice appear in
10     * all copies of the software and related documentation, and (ii) the names of
11     * Sam Leffler and Silicon Graphics may not be used in any advertising or
12     * publicity relating to the software without the specific, prior written
13     * permission of Sam Leffler and Silicon Graphics.
14     *
15     * THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
16     * EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
17     * WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
18     *
19     * IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
20     * ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
21     * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
22     * WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
23     * LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
24     * OF THIS SOFTWARE.
25     */
26
27     #ifndef _TIFFIO_
28     #define _TIFFIO_
29
30     /*
31     * TIFF I/O Library Definitions.
32     */
33     #include "tiff.h"
34     #include "tiffvers.h"
35
36     /*
37     * TIFF is defined as an incomplete type to hide the
38     * library's internal data structures from clients.
39     */
40     typedef struct tiff TIFF;
41
42     /*
43     * The following typedefs define the intrinsic size of
44     * data types used in the *exported* interfaces. These
45     * definitions depend on the proper definition of types
46     * in tiff.h. Note also that the varargs interface used
47     * to pass tag types and values uses the types defined in
48     * tiff.h directly.
49     *
50     * NB: ttag_t is unsigned int and not unsigned short because
51     * ANSI C requires that the type before the ellipsis be a
52     * promoted type (i.e. one of int, unsigned int, pointer,
53     * or double) and because we defined pseudo-tags that are
54     * outside the range of legal Aldus-assigned tags.
55     * NB: tsize_t is int32 and not uint32 because some functions
56     * return -1.
57     * NB: toff_t is not off_t for many reasons; TIFFs max out at
58     * 32-bit file offsets being the most important, and to ensure
59     * that it is unsigned, rather than signed.
60     */
61     typedef uint32 ttag_t; /* directory tag */
62     typedef uint16 tdir_t; /* directory index */
63     typedef uint16 tsample_t; /* sample number */
64     typedef uint32 tstrip_t; /* strip number */
65     typedef uint32 ttile_t; /* tile number */
66     typedef int32 tsize_t; /* i/o size in bytes */
67     typedef void* tdata_t; /* image data ref */
68     typedef uint32 toff_t; /* file offset */
69
70     #if !defined(__WIN32__) && (defined(_WIN32) || defined(WIN32))
71     #define __WIN32__
72     #endif
73
74     /*
75     * On windows you should define USE_WIN32_FILEIO if you are using tif_win32.c
76     * or AVOID_WIN32_FILEIO if you are using something else (like tif_unix.c).
77     *
78     * By default tif_win32.c is assumed on windows if not using the cygwin
79     * environment.
80     */
81
82     #if defined(_WINDOWS) || defined(__WIN32__) || defined(_Windows)
83     # if !defined(__CYGWIN) && !defined(AVOID_WIN32_FILEIO) && !defined(USE_WIN32_FILIO)
84     # define USE_WIN32_FILEIO
85     # endif
86     #endif
87
88     #if defined(USE_WIN32_FILEIO)
89     #include <windows.h>
90     #ifdef __WIN32__
91     DECLARE_HANDLE(thandle_t); /* Win32 file handle */
92     #else
93     typedef HFILE thandle_t; /* client data handle */
94     #endif
95     #else
96     typedef void* thandle_t; /* client data handle */
97     #endif
98
99     #ifndef NULL
100     #define NULL 0
101     #endif
102
103     /*
104     * Flags to pass to TIFFPrintDirectory to control
105     * printing of data structures that are potentially
106     * very large. Bit-or these flags to enable printing
107     * multiple items.
108     */
109     #define TIFFPRINT_NONE 0x0 /* no extra info */
110     #define TIFFPRINT_STRIPS 0x1 /* strips/tiles info */
111     #define TIFFPRINT_CURVES 0x2 /* color/gray response curves */
112     #define TIFFPRINT_COLORMAP 0x4 /* colormap */
113     #define TIFFPRINT_JPEGQTABLES 0x100 /* JPEG Q matrices */
114     #define TIFFPRINT_JPEGACTABLES 0x200 /* JPEG AC tables */
115     #define TIFFPRINT_JPEGDCTABLES 0x200 /* JPEG DC tables */
116
117     /*
118     * RGBA-style image support.
119     */
120     typedef unsigned char TIFFRGBValue; /* 8-bit samples */
121     typedef struct _TIFFRGBAImage TIFFRGBAImage;
122     /*
123     * The image reading and conversion routines invoke
124     * ``put routines'' to copy/image/whatever tiles of
125     * raw image data. A default set of routines are
126     * provided to convert/copy raw image data to 8-bit
127     * packed ABGR format rasters. Applications can supply
128     * alternate routines that unpack the data into a
129     * different format or, for example, unpack the data
130     * and draw the unpacked raster on the display.
131     */
132     typedef void (*tileContigRoutine)
133     (TIFFRGBAImage*, uint32*, uint32, uint32, uint32, uint32, int32, int32,
134     unsigned char*);
135     typedef void (*tileSeparateRoutine)
136     (TIFFRGBAImage*, uint32*, uint32, uint32, uint32, uint32, int32, int32,
137     unsigned char*, unsigned char*, unsigned char*, unsigned char*);
138     /*
139     * RGBA-reader state.
140     */
141     typedef struct { /* YCbCr->RGB support */
142     TIFFRGBValue* clamptab; /* range clamping table */
143     int* Cr_r_tab;
144     int* Cb_b_tab;
145     int32* Cr_g_tab;
146     int32* Cb_g_tab;
147     float coeffs[3]; /* cached for repeated use */
148     } TIFFYCbCrToRGB;
149
150     struct _TIFFRGBAImage {
151     TIFF* tif; /* image handle */
152     int stoponerr; /* stop on read error */
153     int isContig; /* data is packed/separate */
154     int alpha; /* type of alpha data present */
155     uint32 width; /* image width */
156     uint32 height; /* image height */
157     uint16 bitspersample; /* image bits/sample */
158     uint16 samplesperpixel; /* image samples/pixel */
159     uint16 orientation; /* image orientation */
160     uint16 photometric; /* image photometric interp */
161     uint16* redcmap; /* colormap pallete */
162     uint16* greencmap;
163     uint16* bluecmap;
164     /* get image data routine */
165     int (*get)(TIFFRGBAImage*, uint32*, uint32, uint32);
166     union {
167     void (*any)(TIFFRGBAImage*);
168     tileContigRoutine contig;
169     tileSeparateRoutine separate;
170     } put; /* put decoded strip/tile */
171     TIFFRGBValue* Map; /* sample mapping array */
172     uint32** BWmap; /* black&white map */
173     uint32** PALmap; /* palette image map */
174     TIFFYCbCrToRGB* ycbcr; /* YCbCr conversion state */
175
176     int row_offset;
177     int col_offset;
178     };
179
180     /*
181     * Macros for extracting components from the
182     * packed ABGR form returned by TIFFReadRGBAImage.
183     */
184     #define TIFFGetR(abgr) ((abgr) & 0xff)
185     #define TIFFGetG(abgr) (((abgr) >> 8) & 0xff)
186     #define TIFFGetB(abgr) (((abgr) >> 16) & 0xff)
187     #define TIFFGetA(abgr) (((abgr) >> 24) & 0xff)
188
189     /*
190     * A CODEC is a software package that implements decoding,
191     * encoding, or decoding+encoding of a compression algorithm.
192     * The library provides a collection of builtin codecs.
193     * More codecs may be registered through calls to the library
194     * and/or the builtin implementations may be overridden.
195     */
196     typedef int (*TIFFInitMethod)(TIFF*, int);
197     typedef struct {
198     char* name;
199     uint16 scheme;
200     TIFFInitMethod init;
201     } TIFFCodec;
202
203     #include <stdio.h>
204     #include <stdarg.h>
205
206 greg 3.10 /* share internal LogLuv conversion routines? */
207 greg 3.1 #ifndef LOGLUV_PUBLIC
208 greg 3.10 #define LOGLUV_PUBLIC 1
209 greg 3.1 #endif
210
211     #if defined(__cplusplus)
212     extern "C" {
213     #endif
214     typedef void (*TIFFErrorHandler)(const char*, const char*, va_list);
215     typedef tsize_t (*TIFFReadWriteProc)(thandle_t, tdata_t, tsize_t);
216     typedef toff_t (*TIFFSeekProc)(thandle_t, toff_t, int);
217     typedef int (*TIFFCloseProc)(thandle_t);
218     typedef toff_t (*TIFFSizeProc)(thandle_t);
219     typedef int (*TIFFMapFileProc)(thandle_t, tdata_t*, toff_t*);
220     typedef void (*TIFFUnmapFileProc)(thandle_t, tdata_t, toff_t);
221     typedef void (*TIFFExtendProc)(TIFF*);
222
223     extern const char* TIFFGetVersion(void);
224
225     extern const TIFFCodec* TIFFFindCODEC(uint16);
226     extern TIFFCodec* TIFFRegisterCODEC(uint16, const char*, TIFFInitMethod);
227     extern void TIFFUnRegisterCODEC(TIFFCodec*);
228
229     extern tdata_t _TIFFmalloc(tsize_t);
230     extern tdata_t _TIFFrealloc(tdata_t, tsize_t);
231     extern void _TIFFmemset(tdata_t, int, tsize_t);
232     extern void _TIFFmemcpy(tdata_t, const tdata_t, tsize_t);
233     extern int _TIFFmemcmp(const tdata_t, const tdata_t, tsize_t);
234     extern void _TIFFfree(tdata_t);
235
236     extern void TIFFClose(TIFF*);
237     extern int TIFFFlush(TIFF*);
238     extern int TIFFFlushData(TIFF*);
239     extern int TIFFGetField(TIFF*, ttag_t, ...);
240     extern int TIFFVGetField(TIFF*, ttag_t, va_list);
241     extern int TIFFGetFieldDefaulted(TIFF*, ttag_t, ...);
242     extern int TIFFVGetFieldDefaulted(TIFF*, ttag_t, va_list);
243     extern int TIFFReadDirectory(TIFF*);
244     extern tsize_t TIFFScanlineSize(TIFF*);
245     extern tsize_t TIFFRasterScanlineSize(TIFF*);
246     extern tsize_t TIFFStripSize(TIFF*);
247     extern tsize_t TIFFVStripSize(TIFF*, uint32);
248     extern tsize_t TIFFTileRowSize(TIFF*);
249     extern tsize_t TIFFTileSize(TIFF*);
250     extern tsize_t TIFFVTileSize(TIFF*, uint32);
251     extern uint32 TIFFDefaultStripSize(TIFF*, uint32);
252     extern void TIFFDefaultTileSize(TIFF*, uint32*, uint32*);
253     extern int TIFFFileno(TIFF*);
254     extern int TIFFGetMode(TIFF*);
255     extern int TIFFIsTiled(TIFF*);
256     extern int TIFFIsByteSwapped(TIFF*);
257     extern int TIFFIsUpSampled(TIFF*);
258     extern int TIFFIsMSB2LSB(TIFF*);
259     extern uint32 TIFFCurrentRow(TIFF*);
260     extern tdir_t TIFFCurrentDirectory(TIFF*);
261     extern tdir_t TIFFNumberOfDirectories(TIFF*);
262     extern uint32 TIFFCurrentDirOffset(TIFF*);
263     extern tstrip_t TIFFCurrentStrip(TIFF*);
264     extern ttile_t TIFFCurrentTile(TIFF*);
265     extern int TIFFReadBufferSetup(TIFF*, tdata_t, tsize_t);
266     extern int TIFFWriteBufferSetup(TIFF*, tdata_t, tsize_t);
267     extern int TIFFWriteCheck(TIFF*, int, const char *);
268     extern int TIFFCreateDirectory(TIFF*);
269     extern int TIFFLastDirectory(TIFF*);
270     extern int TIFFSetDirectory(TIFF*, tdir_t);
271     extern int TIFFSetSubDirectory(TIFF*, uint32);
272     extern int TIFFUnlinkDirectory(TIFF*, tdir_t);
273     extern int TIFFSetField(TIFF*, ttag_t, ...);
274     extern int TIFFVSetField(TIFF*, ttag_t, va_list);
275     extern int TIFFWriteDirectory(TIFF *);
276 greg 3.10 extern int TIFFRewriteDirectory(TIFF *);
277 greg 3.1 extern int TIFFReassignTagToIgnore(enum TIFFIgnoreSense, int);
278
279     #if defined(c_plusplus) || defined(__cplusplus)
280     extern void TIFFPrintDirectory(TIFF*, FILE*, long = 0);
281     extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t = 0);
282     extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t = 0);
283     extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int = 0);
284     #else
285     extern void TIFFPrintDirectory(TIFF*, FILE*, long);
286     extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t);
287     extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t);
288     extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int);
289     #endif
290
291     extern int TIFFReadRGBAStrip(TIFF*, tstrip_t, uint32 * );
292     extern int TIFFReadRGBATile(TIFF*, uint32, uint32, uint32 * );
293     extern int TIFFRGBAImageOK(TIFF*, char [1024]);
294     extern int TIFFRGBAImageBegin(TIFFRGBAImage*, TIFF*, int, char [1024]);
295     extern int TIFFRGBAImageGet(TIFFRGBAImage*, uint32*, uint32, uint32);
296     extern void TIFFRGBAImageEnd(TIFFRGBAImage*);
297     extern TIFF* TIFFOpen(const char*, const char*);
298     extern TIFF* TIFFFdOpen(int, const char*, const char*);
299     extern TIFF* TIFFClientOpen(const char*, const char*,
300     thandle_t,
301     TIFFReadWriteProc, TIFFReadWriteProc,
302     TIFFSeekProc, TIFFCloseProc,
303     TIFFSizeProc,
304     TIFFMapFileProc, TIFFUnmapFileProc);
305     extern const char* TIFFFileName(TIFF*);
306     extern void TIFFError(const char*, const char*, ...);
307     extern void TIFFWarning(const char*, const char*, ...);
308     extern TIFFErrorHandler TIFFSetErrorHandler(TIFFErrorHandler);
309     extern TIFFErrorHandler TIFFSetWarningHandler(TIFFErrorHandler);
310     extern TIFFExtendProc TIFFSetTagExtender(TIFFExtendProc);
311     extern ttile_t TIFFComputeTile(TIFF*, uint32, uint32, uint32, tsample_t);
312     extern int TIFFCheckTile(TIFF*, uint32, uint32, uint32, tsample_t);
313     extern ttile_t TIFFNumberOfTiles(TIFF*);
314     extern tsize_t TIFFReadTile(TIFF*,
315     tdata_t, uint32, uint32, uint32, tsample_t);
316     extern tsize_t TIFFWriteTile(TIFF*,
317     tdata_t, uint32, uint32, uint32, tsample_t);
318     extern tstrip_t TIFFComputeStrip(TIFF*, uint32, tsample_t);
319     extern tstrip_t TIFFNumberOfStrips(TIFF*);
320     extern tsize_t TIFFReadEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
321     extern tsize_t TIFFReadRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
322     extern tsize_t TIFFReadEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t);
323     extern tsize_t TIFFReadRawTile(TIFF*, ttile_t, tdata_t, tsize_t);
324     extern tsize_t TIFFWriteEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
325     extern tsize_t TIFFWriteRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t);
326     extern tsize_t TIFFWriteEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t);
327     extern tsize_t TIFFWriteRawTile(TIFF*, ttile_t, tdata_t, tsize_t);
328     extern void TIFFSetWriteOffset(TIFF*, toff_t);
329     extern void TIFFSwabShort(uint16*);
330     extern void TIFFSwabLong(uint32*);
331     extern void TIFFSwabDouble(double*);
332     extern void TIFFSwabArrayOfShort(uint16*, unsigned long);
333     extern void TIFFSwabArrayOfLong(uint32*, unsigned long);
334     extern void TIFFSwabArrayOfDouble(double*, unsigned long);
335     extern void TIFFReverseBits(unsigned char *, unsigned long);
336     extern const unsigned char* TIFFGetBitRevTable(int);
337
338     #if LOGLUV_PUBLIC
339     #define U_NEU 0.210526316
340     #define V_NEU 0.473684211
341     #define UVSCALE 410.
342     extern double LogL16toY(int);
343     extern double LogL10toY(int);
344     extern void XYZtoRGB24(float*, uint8*);
345     extern int uv_decode(double*, double*, int);
346     extern void LogLuv24toXYZ(uint32, float*);
347     extern void LogLuv32toXYZ(uint32, float*);
348     #if defined(c_plusplus) || defined(__cplusplus)
349     extern int LogL16fromY(double, int = SGILOGENCODE_NODITHER);
350     extern int LogL10fromY(double, int = SGILOGENCODE_NODITHER);
351     extern int uv_encode(double, double, int = SGILOGENCODE_NODITHER);
352     extern uint32 LogLuv24fromXYZ(float*, int = SGILOGENCODE_NODITHER);
353     extern uint32 LogLuv32fromXYZ(float*, int = SGILOGENCODE_NODITHER);
354     #else
355     extern int LogL16fromY(double, int);
356     extern int LogL10fromY(double, int);
357     extern int uv_encode(double, double, int);
358     extern uint32 LogLuv24fromXYZ(float*, int);
359     extern uint32 LogLuv32fromXYZ(float*, int);
360     #endif
361     #endif /* LOGLUV_PUBLIC */
362     #if defined(__cplusplus)
363     }
364     #endif
365     #endif /* _TIFFIO_ */
