1 |
/* RCSid: $Id$ */ |
2 |
3 |
* Copyright (c) 1988-1997 Sam Leffler |
4 |
* Copyright (c) 1991-1997 Silicon Graphics, Inc. |
5 |
6 |
* Permission to use, copy, modify, distribute, and sell this software and |
7 |
* its documentation for any purpose is hereby granted without fee, provided |
8 |
* that (i) the above copyright notices and this permission notice appear in |
9 |
* all copies of the software and related documentation, and (ii) the names of |
10 |
* Sam Leffler and Silicon Graphics may not be used in any advertising or |
11 |
* publicity relating to the software without the specific, prior written |
12 |
* permission of Sam Leffler and Silicon Graphics. |
13 |
14 |
* THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND, |
15 |
* EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY |
16 |
* WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. |
17 |
18 |
* IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR |
19 |
* ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND, |
20 |
* OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, |
21 |
* WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF |
22 |
* LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE |
23 |
* OF THIS SOFTWARE. |
24 |
25 |
26 |
#ifndef _TIFFIO_ |
27 |
#define _TIFFIO_ |
28 |
29 |
30 |
* TIFF I/O Library Definitions. |
31 |
32 |
#include "tiff.h" |
33 |
#include "tiffvers.h" |
34 |
35 |
36 |
* TIFF is defined as an incomplete type to hide the |
37 |
* library's internal data structures from clients. |
38 |
39 |
typedef struct tiff TIFF; |
40 |
41 |
42 |
* The following typedefs define the intrinsic size of |
43 |
* data types used in the *exported* interfaces. These |
44 |
* definitions depend on the proper definition of types |
45 |
* in tiff.h. Note also that the varargs interface used |
46 |
* to pass tag types and values uses the types defined in |
47 |
* tiff.h directly. |
48 |
49 |
* NB: ttag_t is unsigned int and not unsigned short because |
50 |
* ANSI C requires that the type before the ellipsis be a |
51 |
* promoted type (i.e. one of int, unsigned int, pointer, |
52 |
* or double) and because we defined pseudo-tags that are |
53 |
* outside the range of legal Aldus-assigned tags. |
54 |
* NB: tsize_t is int32 and not uint32 because some functions |
55 |
* return -1. |
56 |
* NB: toff_t is not off_t for many reasons; TIFFs max out at |
57 |
* 32-bit file offsets being the most important, and to ensure |
58 |
* that it is unsigned, rather than signed. |
59 |
60 |
typedef uint32 ttag_t; /* directory tag */ |
61 |
typedef uint16 tdir_t; /* directory index */ |
62 |
typedef uint16 tsample_t; /* sample number */ |
63 |
typedef uint32 tstrip_t; /* strip number */ |
64 |
typedef uint32 ttile_t; /* tile number */ |
65 |
typedef int32 tsize_t; /* i/o size in bytes */ |
66 |
typedef void* tdata_t; /* image data ref */ |
67 |
typedef uint32 toff_t; /* file offset */ |
68 |
69 |
#if !defined(__WIN32__) && (defined(_WIN32) || defined(WIN32)) |
70 |
#define __WIN32__ |
71 |
#endif |
72 |
73 |
74 |
* On windows you should define USE_WIN32_FILEIO if you are using tif_win32.c |
75 |
* or AVOID_WIN32_FILEIO if you are using something else (like tif_unix.c). |
76 |
77 |
* By default tif_win32.c is assumed on windows if not using the cygwin |
78 |
* environment. |
79 |
80 |
81 |
#if defined(_WINDOWS) || defined(__WIN32__) || defined(_Windows) |
82 |
# if !defined(__CYGWIN) && !defined(AVOID_WIN32_FILEIO) && !defined(USE_WIN32_FILIO) |
83 |
# define USE_WIN32_FILEIO |
84 |
# endif |
85 |
#endif |
86 |
87 |
#if defined(USE_WIN32_FILEIO) |
88 |
#include <windows.h> |
89 |
#ifdef __WIN32__ |
90 |
DECLARE_HANDLE(thandle_t); /* Win32 file handle */ |
91 |
#else |
92 |
typedef HFILE thandle_t; /* client data handle */ |
93 |
#endif |
94 |
#else |
95 |
typedef void* thandle_t; /* client data handle */ |
96 |
#endif |
97 |
98 |
#ifndef NULL |
99 |
#define NULL 0 |
100 |
#endif |
101 |
102 |
103 |
* Flags to pass to TIFFPrintDirectory to control |
104 |
* printing of data structures that are potentially |
105 |
* very large. Bit-or these flags to enable printing |
106 |
* multiple items. |
107 |
108 |
#define TIFFPRINT_NONE 0x0 /* no extra info */ |
109 |
#define TIFFPRINT_STRIPS 0x1 /* strips/tiles info */ |
110 |
#define TIFFPRINT_CURVES 0x2 /* color/gray response curves */ |
111 |
#define TIFFPRINT_COLORMAP 0x4 /* colormap */ |
112 |
#define TIFFPRINT_JPEGQTABLES 0x100 /* JPEG Q matrices */ |
113 |
#define TIFFPRINT_JPEGACTABLES 0x200 /* JPEG AC tables */ |
114 |
#define TIFFPRINT_JPEGDCTABLES 0x200 /* JPEG DC tables */ |
115 |
116 |
117 |
* RGBA-style image support. |
118 |
119 |
typedef unsigned char TIFFRGBValue; /* 8-bit samples */ |
120 |
typedef struct _TIFFRGBAImage TIFFRGBAImage; |
121 |
122 |
* The image reading and conversion routines invoke |
123 |
* ``put routines'' to copy/image/whatever tiles of |
124 |
* raw image data. A default set of routines are |
125 |
* provided to convert/copy raw image data to 8-bit |
126 |
* packed ABGR format rasters. Applications can supply |
127 |
* alternate routines that unpack the data into a |
128 |
* different format or, for example, unpack the data |
129 |
* and draw the unpacked raster on the display. |
130 |
131 |
typedef void (*tileContigRoutine) |
132 |
(TIFFRGBAImage*, uint32*, uint32, uint32, uint32, uint32, int32, int32, |
133 |
unsigned char*); |
134 |
typedef void (*tileSeparateRoutine) |
135 |
136 |
unsigned char*, unsigned char*, unsigned char*, unsigned char*); |
137 |
138 |
* RGBA-reader state. |
139 |
140 |
typedef struct { /* YCbCr->RGB support */ |
141 |
TIFFRGBValue* clamptab; /* range clamping table */ |
142 |
int* Cr_r_tab; |
143 |
int* Cb_b_tab; |
144 |
int32* Cr_g_tab; |
145 |
int32* Cb_g_tab; |
146 |
float coeffs[3]; /* cached for repeated use */ |
147 |
} TIFFYCbCrToRGB; |
148 |
149 |
struct _TIFFRGBAImage { |
150 |
TIFF* tif; /* image handle */ |
151 |
int stoponerr; /* stop on read error */ |
152 |
int isContig; /* data is packed/separate */ |
153 |
int alpha; /* type of alpha data present */ |
154 |
uint32 width; /* image width */ |
155 |
uint32 height; /* image height */ |
156 |
uint16 bitspersample; /* image bits/sample */ |
157 |
uint16 samplesperpixel; /* image samples/pixel */ |
158 |
uint16 orientation; /* image orientation */ |
159 |
uint16 photometric; /* image photometric interp */ |
160 |
uint16* redcmap; /* colormap pallete */ |
161 |
uint16* greencmap; |
162 |
uint16* bluecmap; |
163 |
/* get image data routine */ |
164 |
int (*get)(TIFFRGBAImage*, uint32*, uint32, uint32); |
165 |
union { |
166 |
void (*any)(TIFFRGBAImage*); |
167 |
tileContigRoutine contig; |
168 |
tileSeparateRoutine separate; |
169 |
} put; /* put decoded strip/tile */ |
170 |
TIFFRGBValue* Map; /* sample mapping array */ |
171 |
uint32** BWmap; /* black&white map */ |
172 |
uint32** PALmap; /* palette image map */ |
173 |
TIFFYCbCrToRGB* ycbcr; /* YCbCr conversion state */ |
174 |
175 |
int row_offset; |
176 |
int col_offset; |
177 |
178 |
179 |
180 |
* Macros for extracting components from the |
181 |
* packed ABGR form returned by TIFFReadRGBAImage. |
182 |
183 |
#define TIFFGetR(abgr) ((abgr) & 0xff) |
184 |
#define TIFFGetG(abgr) (((abgr) >> 8) & 0xff) |
185 |
#define TIFFGetB(abgr) (((abgr) >> 16) & 0xff) |
186 |
#define TIFFGetA(abgr) (((abgr) >> 24) & 0xff) |
187 |
188 |
189 |
* A CODEC is a software package that implements decoding, |
190 |
* encoding, or decoding+encoding of a compression algorithm. |
191 |
* The library provides a collection of builtin codecs. |
192 |
* More codecs may be registered through calls to the library |
193 |
* and/or the builtin implementations may be overridden. |
194 |
195 |
typedef int (*TIFFInitMethod)(TIFF*, int); |
196 |
typedef struct { |
197 |
char* name; |
198 |
uint16 scheme; |
199 |
TIFFInitMethod init; |
200 |
} TIFFCodec; |
201 |
202 |
#include <stdio.h> |
203 |
#include <stdarg.h> |
204 |
205 |
/* share internal LogLuv conversion routines */ |
206 |
#ifndef LOGLUV_PUBLIC |
207 |
#define LOGLUV_PUBLIC 1 |
208 |
#endif |
209 |
210 |
#if defined(__cplusplus) |
211 |
extern "C" { |
212 |
#endif |
213 |
typedef void (*TIFFErrorHandler)(const char*, const char*, va_list); |
214 |
typedef tsize_t (*TIFFReadWriteProc)(thandle_t, tdata_t, tsize_t); |
215 |
typedef toff_t (*TIFFSeekProc)(thandle_t, toff_t, int); |
216 |
typedef int (*TIFFCloseProc)(thandle_t); |
217 |
typedef toff_t (*TIFFSizeProc)(thandle_t); |
218 |
typedef int (*TIFFMapFileProc)(thandle_t, tdata_t*, toff_t*); |
219 |
typedef void (*TIFFUnmapFileProc)(thandle_t, tdata_t, toff_t); |
220 |
typedef void (*TIFFExtendProc)(TIFF*); |
221 |
222 |
extern const char* TIFFGetVersion(void); |
223 |
224 |
extern const TIFFCodec* TIFFFindCODEC(uint16); |
225 |
extern TIFFCodec* TIFFRegisterCODEC(uint16, const char*, TIFFInitMethod); |
226 |
extern void TIFFUnRegisterCODEC(TIFFCodec*); |
227 |
228 |
extern tdata_t _TIFFmalloc(tsize_t); |
229 |
extern tdata_t _TIFFrealloc(tdata_t, tsize_t); |
230 |
extern void _TIFFmemset(tdata_t, int, tsize_t); |
231 |
extern void _TIFFmemcpy(tdata_t, const tdata_t, tsize_t); |
232 |
extern int _TIFFmemcmp(const tdata_t, const tdata_t, tsize_t); |
233 |
extern void _TIFFfree(tdata_t); |
234 |
235 |
extern void TIFFClose(TIFF*); |
236 |
extern int TIFFFlush(TIFF*); |
237 |
extern int TIFFFlushData(TIFF*); |
238 |
extern int TIFFGetField(TIFF*, ttag_t, ...); |
239 |
extern int TIFFVGetField(TIFF*, ttag_t, va_list); |
240 |
extern int TIFFGetFieldDefaulted(TIFF*, ttag_t, ...); |
241 |
extern int TIFFVGetFieldDefaulted(TIFF*, ttag_t, va_list); |
242 |
extern int TIFFReadDirectory(TIFF*); |
243 |
extern tsize_t TIFFScanlineSize(TIFF*); |
244 |
extern tsize_t TIFFRasterScanlineSize(TIFF*); |
245 |
extern tsize_t TIFFStripSize(TIFF*); |
246 |
extern tsize_t TIFFVStripSize(TIFF*, uint32); |
247 |
extern tsize_t TIFFTileRowSize(TIFF*); |
248 |
extern tsize_t TIFFTileSize(TIFF*); |
249 |
extern tsize_t TIFFVTileSize(TIFF*, uint32); |
250 |
extern uint32 TIFFDefaultStripSize(TIFF*, uint32); |
251 |
extern void TIFFDefaultTileSize(TIFF*, uint32*, uint32*); |
252 |
extern int TIFFFileno(TIFF*); |
253 |
extern int TIFFGetMode(TIFF*); |
254 |
extern int TIFFIsTiled(TIFF*); |
255 |
extern int TIFFIsByteSwapped(TIFF*); |
256 |
extern int TIFFIsUpSampled(TIFF*); |
257 |
extern int TIFFIsMSB2LSB(TIFF*); |
258 |
extern uint32 TIFFCurrentRow(TIFF*); |
259 |
extern tdir_t TIFFCurrentDirectory(TIFF*); |
260 |
extern tdir_t TIFFNumberOfDirectories(TIFF*); |
261 |
extern uint32 TIFFCurrentDirOffset(TIFF*); |
262 |
extern tstrip_t TIFFCurrentStrip(TIFF*); |
263 |
extern ttile_t TIFFCurrentTile(TIFF*); |
264 |
extern int TIFFReadBufferSetup(TIFF*, tdata_t, tsize_t); |
265 |
extern int TIFFWriteBufferSetup(TIFF*, tdata_t, tsize_t); |
266 |
extern int TIFFWriteCheck(TIFF*, int, const char *); |
267 |
extern int TIFFCreateDirectory(TIFF*); |
268 |
extern int TIFFLastDirectory(TIFF*); |
269 |
extern int TIFFSetDirectory(TIFF*, tdir_t); |
270 |
extern int TIFFSetSubDirectory(TIFF*, uint32); |
271 |
extern int TIFFUnlinkDirectory(TIFF*, tdir_t); |
272 |
extern int TIFFSetField(TIFF*, ttag_t, ...); |
273 |
extern int TIFFVSetField(TIFF*, ttag_t, va_list); |
274 |
extern int TIFFWriteDirectory(TIFF *); |
275 |
extern int TIFFReassignTagToIgnore(enum TIFFIgnoreSense, int); |
276 |
277 |
#if defined(c_plusplus) || defined(__cplusplus) |
278 |
extern void TIFFPrintDirectory(TIFF*, FILE*, long = 0); |
279 |
extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t = 0); |
280 |
extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t = 0); |
281 |
extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int = 0); |
282 |
#else |
283 |
extern void TIFFPrintDirectory(TIFF*, FILE*, long); |
284 |
extern int TIFFReadScanline(TIFF*, tdata_t, uint32, tsample_t); |
285 |
extern int TIFFWriteScanline(TIFF*, tdata_t, uint32, tsample_t); |
286 |
extern int TIFFReadRGBAImage(TIFF*, uint32, uint32, uint32*, int); |
287 |
#endif |
288 |
289 |
extern int TIFFReadRGBAStrip(TIFF*, tstrip_t, uint32 * ); |
290 |
extern int TIFFReadRGBATile(TIFF*, uint32, uint32, uint32 * ); |
291 |
extern int TIFFRGBAImageOK(TIFF*, char [1024]); |
292 |
extern int TIFFRGBAImageBegin(TIFFRGBAImage*, TIFF*, int, char [1024]); |
293 |
extern int TIFFRGBAImageGet(TIFFRGBAImage*, uint32*, uint32, uint32); |
294 |
extern void TIFFRGBAImageEnd(TIFFRGBAImage*); |
295 |
extern TIFF* TIFFOpen(const char*, const char*); |
296 |
extern TIFF* TIFFFdOpen(int, const char*, const char*); |
297 |
extern TIFF* TIFFClientOpen(const char*, const char*, |
298 |
thandle_t, |
299 |
TIFFReadWriteProc, TIFFReadWriteProc, |
300 |
TIFFSeekProc, TIFFCloseProc, |
301 |
TIFFSizeProc, |
302 |
TIFFMapFileProc, TIFFUnmapFileProc); |
303 |
extern const char* TIFFFileName(TIFF*); |
304 |
extern void TIFFError(const char*, const char*, ...); |
305 |
extern void TIFFWarning(const char*, const char*, ...); |
306 |
extern TIFFErrorHandler TIFFSetErrorHandler(TIFFErrorHandler); |
307 |
extern TIFFErrorHandler TIFFSetWarningHandler(TIFFErrorHandler); |
308 |
extern TIFFExtendProc TIFFSetTagExtender(TIFFExtendProc); |
309 |
extern ttile_t TIFFComputeTile(TIFF*, uint32, uint32, uint32, tsample_t); |
310 |
extern int TIFFCheckTile(TIFF*, uint32, uint32, uint32, tsample_t); |
311 |
extern ttile_t TIFFNumberOfTiles(TIFF*); |
312 |
extern tsize_t TIFFReadTile(TIFF*, |
313 |
tdata_t, uint32, uint32, uint32, tsample_t); |
314 |
extern tsize_t TIFFWriteTile(TIFF*, |
315 |
316 |
extern tstrip_t TIFFComputeStrip(TIFF*, uint32, tsample_t); |
317 |
extern tstrip_t TIFFNumberOfStrips(TIFF*); |
318 |
extern tsize_t TIFFReadEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t); |
319 |
extern tsize_t TIFFReadRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t); |
320 |
extern tsize_t TIFFReadEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t); |
321 |
extern tsize_t TIFFReadRawTile(TIFF*, ttile_t, tdata_t, tsize_t); |
322 |
extern tsize_t TIFFWriteEncodedStrip(TIFF*, tstrip_t, tdata_t, tsize_t); |
323 |
extern tsize_t TIFFWriteRawStrip(TIFF*, tstrip_t, tdata_t, tsize_t); |
324 |
extern tsize_t TIFFWriteEncodedTile(TIFF*, ttile_t, tdata_t, tsize_t); |
325 |
extern tsize_t TIFFWriteRawTile(TIFF*, ttile_t, tdata_t, tsize_t); |
326 |
extern void TIFFSetWriteOffset(TIFF*, toff_t); |
327 |
extern void TIFFSwabShort(uint16*); |
328 |
extern void TIFFSwabLong(uint32*); |
329 |
extern void TIFFSwabDouble(double*); |
330 |
extern void TIFFSwabArrayOfShort(uint16*, unsigned long); |
331 |
extern void TIFFSwabArrayOfLong(uint32*, unsigned long); |
332 |
extern void TIFFSwabArrayOfDouble(double*, unsigned long); |
333 |
extern void TIFFReverseBits(unsigned char *, unsigned long); |
334 |
extern const unsigned char* TIFFGetBitRevTable(int); |
335 |
336 |
#if LOGLUV_PUBLIC |
337 |
#define U_NEU 0.210526316 |
338 |
#define V_NEU 0.473684211 |
339 |
#define UVSCALE 410. |
340 |
extern double LogL16toY(int); |
341 |
extern double LogL10toY(int); |
342 |
extern void XYZtoRGB24(float*, uint8*); |
343 |
extern int uv_decode(double*, double*, int); |
344 |
extern void LogLuv24toXYZ(uint32, float*); |
345 |
extern void LogLuv32toXYZ(uint32, float*); |
346 |
347 |
extern int LogL16fromY(double, int = SGILOGENCODE_NODITHER); |
348 |
extern int LogL10fromY(double, int = SGILOGENCODE_NODITHER); |
349 |
extern int uv_encode(double, double, int = SGILOGENCODE_NODITHER); |
350 |
extern uint32 LogLuv24fromXYZ(float*, int = SGILOGENCODE_NODITHER); |
351 |
extern uint32 LogLuv32fromXYZ(float*, int = SGILOGENCODE_NODITHER); |
352 |
#else |
353 |
extern int LogL16fromY(double, int); |
354 |
extern int LogL10fromY(double, int); |
355 |
extern int uv_encode(double, double, int); |
356 |
extern uint32 LogLuv24fromXYZ(float*, int); |
357 |
extern uint32 LogLuv32fromXYZ(float*, int); |
358 |
#endif |
359 |
#endif /* LOGLUV_PUBLIC */ |
360 |
361 |
362 |
#endif |
363 |
#endif /* _TIFFIO_ */ |
