root/radiance/ray/src/common/tiffconf.h
Revision: 3.1
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 4 months ago) by greg
1 /* RCSid: $Id$ */
2 /*
3 * Copyright (c) 1988-1997 Sam Leffler
4 * Copyright (c) 1991-1997 Silicon Graphics, Inc.
5 *
6 * Permission to use, copy, modify, distribute, and sell this software and
7 * its documentation for any purpose is hereby granted without fee, provided
8 * that (i) the above copyright notices and this permission notice appear in
9 * all copies of the software and related documentation, and (ii) the names of
10 * Sam Leffler and Silicon Graphics may not be used in any advertising or
11 * publicity relating to the software without the specific, prior written
12 * permission of Sam Leffler and Silicon Graphics.
13 *
14 * THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
15 * EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
16 * WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
17 *
18 * IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
19 * ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
20 * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
21 * WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
22 * LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
23 * OF THIS SOFTWARE.
24 */
25
26 #ifndef _TIFFCONF_
27 #define _TIFFCONF_
28 /*
29 * Library Configuration Definitions.
30 *
31 * This file defines the default configuration for the library.
32 * If the target system does not have make or a way to specify
33 * #defines on the command line, this file can be edited to
34 * configure the library. Otherwise, one can override portability
35 * and configuration-related definitions from a Makefile or command
36 * line by defining FEATURE_SUPPORT and COMPRESSION_SUPPORT (see below).
37 */
38
39 /*
40 * General portability-related defines:
41 *
42 * HAVE_IEEEFP define as 0 or 1 according to the floating point
43 * format suported by the machine
44 * BSDTYPES define this if your system does NOT define the
45 * usual 4BSD typedefs u_int et. al.
46 * HAVE_MMAP enable support for memory mapping read-only files;
47 * this is typically deduced by the configure script
48 * HOST_FILLORDER native cpu bit order: one of FILLORDER_MSB2LSB
49 * or FILLODER_LSB2MSB; this is typically set by the
50 * configure script
51 * HOST_BIGENDIAN native cpu byte order: 1 if big-endian (Motorola)
52 * or 0 if little-endian (Intel); this may be used
53 * in codecs to optimize code
54 * USE_64BIT_API set to 1 if tif_unix.c should use lseek64(),
55 * fstat64() and stat64 allowing 2-4GB files.
56 */
57 #ifndef HAVE_IEEEFP
58 #define HAVE_IEEEFP 1
59 #endif
60 #ifndef HOST_FILLORDER
61 #define HOST_FILLORDER FILLORDER_MSB2LSB
62 #endif
63 #ifndef HOST_BIGENDIAN
64 #define HOST_BIGENDIAN 1
65 #endif
66
67 #ifndef USE_64BIT_API
68 # define USE_64BIT_API 0
69 #endif
70
71 #ifndef FEATURE_SUPPORT
72 /*
73 * Feature support definitions:
74 *
75 * COLORIMETRY_SUPPORT enable support for 6.0 colorimetry tags
76 * YCBCR_SUPPORT enable support for 6.0 YCbCr tags
77 * CMYK_SUPPORT enable support for 6.0 CMYK tags
78 * ICC_SUPPORT enable support for ICC profile tag
79 * PHOTOSHOP_SUPPORT enable support for PHOTOSHOP resource tag
80 * IPTC_SUPPORT enable support for RichTIFF IPTC tag
81 */
82 #define COLORIMETRY_SUPPORT
83 #define YCBCR_SUPPORT
84 #define CMYK_SUPPORT
85 #define ICC_SUPPORT
86 #define PHOTOSHOP_SUPPORT
87 #define IPTC_SUPPORT
88 #endif /* FEATURE_SUPPORT */
89
90 #ifndef COMPRESSION_SUPPORT
91 /*
92 * Compression support defines:
93 *
94 * CCITT_SUPPORT enable support for CCITT Group 3 & 4 algorithms
95 * PACKBITS_SUPPORT enable support for Macintosh PackBits algorithm
96 * LZW_SUPPORT enable support for LZW algorithm
97 * THUNDER_SUPPORT enable support for ThunderScan 4-bit RLE algorithm
98 * NEXT_SUPPORT enable support for NeXT 2-bit RLE algorithm
99 * OJPEG_SUPPORT enable support for 6.0-style JPEG DCT algorithms
100 * (no builtin support, only a codec hook)
101 * JPEG_SUPPORT enable support for post-6.0-style JPEG DCT algorithms
102 * (requires freely available IJG software, see tif_jpeg.c)
103 * ZIP_SUPPORT enable support for Deflate algorithm
104 * (requires freely available zlib software, see tif_zip.c)
105 * PIXARLOG_SUPPORT enable support for Pixar log-format algorithm
106 * LOGLUV_SUPPORT enable support for LogLuv high dynamic range encoding
107 */
108 #define CCITT_SUPPORT
109 #define PACKBITS_SUPPORT
110 #define LZW_SUPPORT
111 #define THUNDER_SUPPORT
112 #define NEXT_SUPPORT
113 #define LOGLUV_SUPPORT
114 #endif /* COMPRESSION_SUPPORT */
115
116 /*
117 * If JPEG compression is enabled then we must also include
118 * support for the colorimetry and YCbCr-related tags.
119 */
120 #ifdef JPEG_SUPPORT
121 #ifndef YCBCR_SUPPORT
122 #define YCBCR_SUPPORT
123 #endif
124 #ifndef COLORIMETRY_SUPPORT
125 #define COLORIMETRY_SUPPORT
126 #endif
127 #endif /* JPEG_SUPPORT */
128
129 /*
130 * ``Orthogonal Features''
131 *
132 * STRIPCHOP_DEFAULT default handling of strip chopping support (whether
133 * or not to convert single-strip uncompressed images
134 * to mutiple strips of ~8Kb--to reduce memory use)
135 * SUBIFD_SUPPORT enable support for SubIFD tag (thumbnails and such)
136 */
137 #ifndef STRIPCHOP_DEFAULT
138 #define STRIPCHOP_DEFAULT TIFF_STRIPCHOP /* default is to enable */
139 #endif
140 #ifndef SUBIFD_SUPPORT
141 #define SUBIFD_SUPPORT 1 /* enable SubIFD tag (330) support */
142 #endif
143 #endif /* _TIFFCONF_ */
