root/radiance/ray/src/common/tiffconf.h
Revision: 3.6
Committed: Fri Jun 13 15:27:39 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.5: +1 -1 lines
State: FILE REMOVED
Removed tiff*.h files from repository, since they're part of libtiff
# User Rev Content
1 greg 3.6 /* $Header: /cvs/radiance//ray/src/common/tiffconf.h,v 3.5 2003/06/08 12:03:09 schorsch Exp $ */
2 greg 3.1 /*
3     * Copyright (c) 1988-1997 Sam Leffler
4     * Copyright (c) 1991-1997 Silicon Graphics, Inc.
5     *
6     * Permission to use, copy, modify, distribute, and sell this software and
7     * its documentation for any purpose is hereby granted without fee, provided
8     * that (i) the above copyright notices and this permission notice appear in
9     * all copies of the software and related documentation, and (ii) the names of
10     * Sam Leffler and Silicon Graphics may not be used in any advertising or
11     * publicity relating to the software without the specific, prior written
12     * permission of Sam Leffler and Silicon Graphics.
13     *
14     * THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
15     * EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
16     * WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
17     *
18     * IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
19     * ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
20     * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
21     * WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
22     * LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
23     * OF THIS SOFTWARE.
24     */
25
26     #ifndef _TIFFCONF_
27     #define _TIFFCONF_
28     /*
29     * Library Configuration Definitions.
30     *
31     * This file defines the default configuration for the library.
32     * If the target system does not have make or a way to specify
33     * #defines on the command line, this file can be edited to
34     * configure the library. Otherwise, one can override portability
35     * and configuration-related definitions from a Makefile or command
36     * line by defining FEATURE_SUPPORT and COMPRESSION_SUPPORT (see below).
37     */
38
39     /*
40     * General portability-related defines:
41     *
42     * HAVE_IEEEFP define as 0 or 1 according to the floating point
43     * format suported by the machine
44     * BSDTYPES define this if your system does NOT define the
45     * usual 4BSD typedefs u_int et. al.
46     * HAVE_MMAP enable support for memory mapping read-only files;
47     * this is typically deduced by the configure script
48     * HOST_FILLORDER native cpu bit order: one of FILLORDER_MSB2LSB
49     * or FILLODER_LSB2MSB; this is typically set by the
50     * configure script
51     * HOST_BIGENDIAN native cpu byte order: 1 if big-endian (Motorola)
52     * or 0 if little-endian (Intel); this may be used
53     * in codecs to optimize code
54     * USE_64BIT_API set to 1 if tif_unix.c should use lseek64(),
55     * fstat64() and stat64 allowing 2-4GB files.
56     */
57     #ifndef HAVE_IEEEFP
58     #define HAVE_IEEEFP 1
59     #endif
60     #ifndef HOST_FILLORDER
61     #define HOST_FILLORDER FILLORDER_MSB2LSB
62     #endif
63     #ifndef HOST_BIGENDIAN
64     #define HOST_BIGENDIAN 1
65     #endif
66
67     #ifndef USE_64BIT_API
68     # define USE_64BIT_API 0
69     #endif
70
71     #ifndef FEATURE_SUPPORT
72     /*
73     * Feature support definitions:
74     *
75     * COLORIMETRY_SUPPORT enable support for 6.0 colorimetry tags
76     * YCBCR_SUPPORT enable support for 6.0 YCbCr tags
77     * CMYK_SUPPORT enable support for 6.0 CMYK tags
78     * ICC_SUPPORT enable support for ICC profile tag
79     * PHOTOSHOP_SUPPORT enable support for PHOTOSHOP resource tag
80     * IPTC_SUPPORT enable support for RichTIFF IPTC tag
81     */
82     #define COLORIMETRY_SUPPORT
83     #define YCBCR_SUPPORT
84     #define CMYK_SUPPORT
85     #define ICC_SUPPORT
86     #define PHOTOSHOP_SUPPORT
87     #define IPTC_SUPPORT
88     #endif /* FEATURE_SUPPORT */
89
90     #ifndef COMPRESSION_SUPPORT
91     /*
92     * Compression support defines:
93     *
94     * CCITT_SUPPORT enable support for CCITT Group 3 & 4 algorithms
95     * PACKBITS_SUPPORT enable support for Macintosh PackBits algorithm
96     * LZW_SUPPORT enable support for LZW algorithm
97     * THUNDER_SUPPORT enable support for ThunderScan 4-bit RLE algorithm
98     * NEXT_SUPPORT enable support for NeXT 2-bit RLE algorithm
99     * OJPEG_SUPPORT enable support for 6.0-style JPEG DCT algorithms
100     * (no builtin support, only a codec hook)
101     * JPEG_SUPPORT enable support for post-6.0-style JPEG DCT algorithms
102     * (requires freely available IJG software, see tif_jpeg.c)
103     * ZIP_SUPPORT enable support for Deflate algorithm
104     * (requires freely available zlib software, see tif_zip.c)
105     * PIXARLOG_SUPPORT enable support for Pixar log-format algorithm
106     * LOGLUV_SUPPORT enable support for LogLuv high dynamic range encoding
107     */
108     #define CCITT_SUPPORT
109     #define PACKBITS_SUPPORT
110     #define LZW_SUPPORT
111     #define THUNDER_SUPPORT
112     #define NEXT_SUPPORT
113     #define LOGLUV_SUPPORT
114     #endif /* COMPRESSION_SUPPORT */
115
116     /*
117     * If JPEG compression is enabled then we must also include
118     * support for the colorimetry and YCbCr-related tags.
119     */
120     #ifdef JPEG_SUPPORT
121     #ifndef YCBCR_SUPPORT
122     #define YCBCR_SUPPORT
123     #endif
124     #ifndef COLORIMETRY_SUPPORT
125     #define COLORIMETRY_SUPPORT
126     #endif
127     #endif /* JPEG_SUPPORT */
128
129     /*
130     * ``Orthogonal Features''
131     *
132     * STRIPCHOP_DEFAULT default handling of strip chopping support (whether
133     * or not to convert single-strip uncompressed images
134     * to mutiple strips of ~8Kb--to reduce memory use)
135     * SUBIFD_SUPPORT enable support for SubIFD tag (thumbnails and such)
136     */
137     #ifndef STRIPCHOP_DEFAULT
138     #define STRIPCHOP_DEFAULT TIFF_STRIPCHOP /* default is to enable */
139     #endif
140     #ifndef SUBIFD_SUPPORT
141     #define SUBIFD_SUPPORT 1 /* enable SubIFD tag (330) support */
142     #endif
143     #endif /* _TIFFCONF_ */
