1 |
/* RCSid $Id$ */ |
2 |
3 |
* Copyright (c) 1988-1997 Sam Leffler |
4 |
* Copyright (c) 1991-1997 Silicon Graphics, Inc. |
5 |
6 |
* Permission to use, copy, modify, distribute, and sell this software and |
7 |
* its documentation for any purpose is hereby granted without fee, provided |
8 |
* that (i) the above copyright notices and this permission notice appear in |
9 |
* all copies of the software and related documentation, and (ii) the names of |
10 |
* Sam Leffler and Silicon Graphics may not be used in any advertising or |
11 |
* publicity relating to the software without the specific, prior written |
12 |
* permission of Sam Leffler and Silicon Graphics. |
13 |
14 |
* THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND, |
15 |
* EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY |
16 |
* WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. |
17 |
18 |
* IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR |
19 |
* ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND, |
20 |
* OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, |
21 |
* WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF |
22 |
* LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE |
23 |
* OF THIS SOFTWARE. |
24 |
25 |
26 |
#ifndef _TIFF_ |
27 |
#define _TIFF_ |
28 |
29 |
* Tag Image File Format (TIFF) |
30 |
31 |
* Based on Rev 6.0 from: |
32 |
* Developer's Desk |
33 |
* Aldus Corporation |
34 |
* 411 First Ave. South |
35 |
* Suite 200 |
36 |
* Seattle, WA 98104 |
37 |
* 206-622-5500 |
38 |
39 |
* (http://partners.adobe.com/asn/developer/PDFS/TN/TIFF6.pdf) |
40 |
41 |
* For Big TIFF design notes see the following link |
42 |
* http://gdal.maptools.org/twiki/bin/view/libtiff/BigTIFFDesign |
43 |
44 |
#define TIFF_VERSION 42 |
45 |
#define TIFF_BIGTIFF_VERSION 43 |
46 |
47 |
#define TIFF_BIGENDIAN 0x4d4d |
48 |
#define TIFF_LITTLEENDIAN 0x4949 |
49 |
50 |
51 |
* The so called TIFF types conflict with definitions from inttypes.h |
52 |
* included from sys/types.h on AIX (at least using VisualAge compiler). |
53 |
* We try to work around this by detecting this case. Defining |
54 |
* _TIFF_DATA_TYPEDEFS_ short circuits the later definitions in tiff.h, and |
55 |
* we will in the holes not provided for by inttypes.h. |
56 |
57 |
* See http://bugzilla.remotesensing.org/show_bug.cgi?id=39 |
58 |
59 |
#if defined(_H_INTTYPES) && defined(_ALL_SOURCE) && defined(USING_VISUALAGE) |
60 |
61 |
#define _TIFF_DATA_TYPEDEFS_ |
62 |
typedef unsigned char uint8; |
63 |
typedef unsigned short uint16; |
64 |
typedef unsigned int uint32; |
65 |
66 |
#endif |
67 |
68 |
69 |
* Intrinsic data types required by the file format: |
70 |
71 |
* 8-bit quantities int8/uint8 |
72 |
* 16-bit quantities int16/uint16 |
73 |
* 32-bit quantities int32/uint32 |
74 |
* strings unsigned char* |
75 |
76 |
#ifndef _TIFF_DATA_TYPEDEFS_ |
77 |
78 |
79 |
typedef signed char int8; /* NB: non-ANSI compilers may not grok */ |
80 |
81 |
typedef short int16; |
82 |
typedef unsigned short uint16; /* sizeof (uint16) must == 2 */ |
83 |
#if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) || defined(__LP64__) || defined(__arch64__) || defined(__sparcv9) |
84 |
typedef int int32; |
85 |
typedef unsigned int uint32; /* sizeof (uint32) must == 4 */ |
86 |
#else |
87 |
typedef long int32; |
88 |
typedef unsigned long uint32; /* sizeof (uint32) must == 4 */ |
89 |
#endif |
90 |
91 |
#endif /* _TIFF_DATA_TYPEDEFS_ */ |
92 |
93 |
/* For TIFFReassignTagToIgnore */ |
94 |
enum TIFFIgnoreSense /* IGNORE tag table */ |
95 |
96 |
TIS_STORE, |
97 |
TIS_EXTRACT, |
98 |
TIS_EMPTY |
99 |
100 |
101 |
102 |
* TIFF header. |
103 |
104 |
typedef struct { |
105 |
uint16 tiff_magic; /* magic number (defines byte order) */ |
106 |
#define TIFF_MAGIC_SIZE 2 |
107 |
uint16 tiff_version; /* TIFF version number */ |
108 |
#define TIFF_VERSION_SIZE 2 |
109 |
uint32 tiff_diroff; /* byte offset to first directory */ |
110 |
#define TIFF_DIROFFSET_SIZE 4 |
111 |
} TIFFHeader; |
112 |
113 |
114 |
115 |
* TIFF Image File Directories are comprised of a table of field |
116 |
* descriptors of the form shown below. The table is sorted in |
117 |
* ascending order by tag. The values associated with each entry are |
118 |
* disjoint and may appear anywhere in the file (so long as they are |
119 |
* placed on a word boundary). |
120 |
121 |
* If the value is 4 bytes or less, then it is placed in the offset |
122 |
* field to save space. If the value is less than 4 bytes, it is |
123 |
* left-justified in the offset field. |
124 |
125 |
typedef struct { |
126 |
uint16 tdir_tag; /* see below */ |
127 |
uint16 tdir_type; /* data type; see below */ |
128 |
uint32 tdir_count; /* number of items; length in spec */ |
129 |
uint32 tdir_offset; /* byte offset to field data */ |
130 |
} TIFFDirEntry; |
131 |
132 |
133 |
* NB: In the comments below, |
134 |
* - items marked with a + are obsoleted by revision 5.0, |
135 |
* - items marked with a ! are introduced in revision 6.0. |
136 |
* - items marked with a % are introduced post revision 6.0. |
137 |
* - items marked with a $ are obsoleted by revision 6.0. |
138 |
* - items marked with a & are introduced by Adobe DNG specification. |
139 |
140 |
141 |
142 |
* Tag data type information. |
143 |
144 |
* Note: RATIONALs are the ratio of two 32-bit integer values. |
145 |
146 |
typedef enum { |
147 |
TIFF_NOTYPE = 0, /* placeholder */ |
148 |
TIFF_BYTE = 1, /* 8-bit unsigned integer */ |
149 |
TIFF_ASCII = 2, /* 8-bit bytes w/ last byte null */ |
150 |
TIFF_SHORT = 3, /* 16-bit unsigned integer */ |
151 |
TIFF_LONG = 4, /* 32-bit unsigned integer */ |
152 |
TIFF_RATIONAL = 5, /* 64-bit unsigned fraction */ |
153 |
TIFF_SBYTE = 6, /* !8-bit signed integer */ |
154 |
TIFF_UNDEFINED = 7, /* !8-bit untyped data */ |
155 |
TIFF_SSHORT = 8, /* !16-bit signed integer */ |
156 |
TIFF_SLONG = 9, /* !32-bit signed integer */ |
157 |
TIFF_SRATIONAL = 10, /* !64-bit signed fraction */ |
158 |
TIFF_FLOAT = 11, /* !32-bit IEEE floating point */ |
159 |
TIFF_DOUBLE = 12, /* !64-bit IEEE floating point */ |
160 |
TIFF_IFD = 13 /* %32-bit unsigned integer (offset) */ |
161 |
} TIFFDataType; |
162 |
163 |
164 |
* TIFF Tag Definitions. |
165 |
166 |
#define TIFFTAG_SUBFILETYPE 254 /* subfile data descriptor */ |
167 |
#define FILETYPE_REDUCEDIMAGE 0x1 /* reduced resolution version */ |
168 |
#define FILETYPE_PAGE 0x2 /* one page of many */ |
169 |
#define FILETYPE_MASK 0x4 /* transparency mask */ |
170 |
#define TIFFTAG_OSUBFILETYPE 255 /* +kind of data in subfile */ |
171 |
#define OFILETYPE_IMAGE 1 /* full resolution image data */ |
172 |
#define OFILETYPE_REDUCEDIMAGE 2 /* reduced size image data */ |
173 |
#define OFILETYPE_PAGE 3 /* one page of many */ |
174 |
#define TIFFTAG_IMAGEWIDTH 256 /* image width in pixels */ |
175 |
#define TIFFTAG_IMAGELENGTH 257 /* image height in pixels */ |
176 |
#define TIFFTAG_BITSPERSAMPLE 258 /* bits per channel (sample) */ |
177 |
#define TIFFTAG_COMPRESSION 259 /* data compression technique */ |
178 |
#define COMPRESSION_NONE 1 /* dump mode */ |
179 |
#define COMPRESSION_CCITTRLE 2 /* CCITT modified Huffman RLE */ |
180 |
#define COMPRESSION_CCITTFAX3 3 /* CCITT Group 3 fax encoding */ |
181 |
#define COMPRESSION_CCITT_T4 3 /* CCITT T.4 (TIFF 6 name) */ |
182 |
#define COMPRESSION_CCITTFAX4 4 /* CCITT Group 4 fax encoding */ |
183 |
#define COMPRESSION_CCITT_T6 4 /* CCITT T.6 (TIFF 6 name) */ |
184 |
#define COMPRESSION_LZW 5 /* Lempel-Ziv & Welch */ |
185 |
#define COMPRESSION_OJPEG 6 /* !6.0 JPEG */ |
186 |
#define COMPRESSION_JPEG 7 /* %JPEG DCT compression */ |
187 |
#define COMPRESSION_NEXT 32766 /* NeXT 2-bit RLE */ |
188 |
#define COMPRESSION_CCITTRLEW 32771 /* #1 w/ word alignment */ |
189 |
#define COMPRESSION_PACKBITS 32773 /* Macintosh RLE */ |
190 |
#define COMPRESSION_THUNDERSCAN 32809 /* ThunderScan RLE */ |
191 |
/* codes 32895-32898 are reserved for ANSI IT8 TIFF/IT <[email protected]) */ |
192 |
#define COMPRESSION_IT8CTPAD 32895 /* IT8 CT w/padding */ |
193 |
#define COMPRESSION_IT8LW 32896 /* IT8 Linework RLE */ |
194 |
#define COMPRESSION_IT8MP 32897 /* IT8 Monochrome picture */ |
195 |
#define COMPRESSION_IT8BL 32898 /* IT8 Binary line art */ |
196 |
/* compression codes 32908-32911 are reserved for Pixar */ |
197 |
#define COMPRESSION_PIXARFILM 32908 /* Pixar companded 10bit LZW */ |
198 |
#define COMPRESSION_PIXARLOG 32909 /* Pixar companded 11bit ZIP */ |
199 |
#define COMPRESSION_DEFLATE 32946 /* Deflate compression */ |
200 |
#define COMPRESSION_ADOBE_DEFLATE 8 /* Deflate compression, |
201 |
as recognized by Adobe */ |
202 |
/* compression code 32947 is reserved for Oceana Matrix <[email protected]> */ |
203 |
#define COMPRESSION_DCS 32947 /* Kodak DCS encoding */ |
204 |
#define COMPRESSION_JBIG 34661 /* ISO JBIG */ |
205 |
#define COMPRESSION_SGILOG 34676 /* SGI Log Luminance RLE */ |
206 |
#define COMPRESSION_SGILOG24 34677 /* SGI Log 24-bit packed */ |
207 |
#define COMPRESSION_JP2000 34712 /* Leadtools JPEG2000 */ |
208 |
#define TIFFTAG_PHOTOMETRIC 262 /* photometric interpretation */ |
209 |
#define PHOTOMETRIC_MINISWHITE 0 /* min value is white */ |
210 |
#define PHOTOMETRIC_MINISBLACK 1 /* min value is black */ |
211 |
#define PHOTOMETRIC_RGB 2 /* RGB color model */ |
212 |
#define PHOTOMETRIC_PALETTE 3 /* color map indexed */ |
213 |
#define PHOTOMETRIC_MASK 4 /* $holdout mask */ |
214 |
#define PHOTOMETRIC_SEPARATED 5 /* !color separations */ |
215 |
#define PHOTOMETRIC_YCBCR 6 /* !CCIR 601 */ |
216 |
#define PHOTOMETRIC_CIELAB 8 /* !1976 CIE L*a*b* */ |
217 |
#define PHOTOMETRIC_ICCLAB 9 /* ICC L*a*b* [Adobe TIFF Technote 4] */ |
218 |
#define PHOTOMETRIC_ITULAB 10 /* ITU L*a*b* */ |
219 |
#define PHOTOMETRIC_LOGL 32844 /* CIE Log2(L) */ |
220 |
#define PHOTOMETRIC_LOGLUV 32845 /* CIE Log2(L) (u',v') */ |
221 |
#define TIFFTAG_THRESHHOLDING 263 /* +thresholding used on data */ |
222 |
#define THRESHHOLD_BILEVEL 1 /* b&w art scan */ |
223 |
#define THRESHHOLD_HALFTONE 2 /* or dithered scan */ |
224 |
#define THRESHHOLD_ERRORDIFFUSE 3 /* usually floyd-steinberg */ |
225 |
#define TIFFTAG_CELLWIDTH 264 /* +dithering matrix width */ |
226 |
#define TIFFTAG_CELLLENGTH 265 /* +dithering matrix height */ |
227 |
#define TIFFTAG_FILLORDER 266 /* data order within a byte */ |
228 |
#define FILLORDER_MSB2LSB 1 /* most significant -> least */ |
229 |
#define FILLORDER_LSB2MSB 2 /* least significant -> most */ |
230 |
#define TIFFTAG_DOCUMENTNAME 269 /* name of doc. image is from */ |
231 |
#define TIFFTAG_IMAGEDESCRIPTION 270 /* info about image */ |
232 |
#define TIFFTAG_MAKE 271 /* scanner manufacturer name */ |
233 |
#define TIFFTAG_MODEL 272 /* scanner model name/number */ |
234 |
#define TIFFTAG_STRIPOFFSETS 273 /* offsets to data strips */ |
235 |
#define TIFFTAG_ORIENTATION 274 /* +image orientation */ |
236 |
#define ORIENTATION_TOPLEFT 1 /* row 0 top, col 0 lhs */ |
237 |
#define ORIENTATION_TOPRIGHT 2 /* row 0 top, col 0 rhs */ |
238 |
#define ORIENTATION_BOTRIGHT 3 /* row 0 bottom, col 0 rhs */ |
239 |
#define ORIENTATION_BOTLEFT 4 /* row 0 bottom, col 0 lhs */ |
240 |
#define ORIENTATION_LEFTTOP 5 /* row 0 lhs, col 0 top */ |
241 |
#define ORIENTATION_RIGHTTOP 6 /* row 0 rhs, col 0 top */ |
242 |
#define ORIENTATION_RIGHTBOT 7 /* row 0 rhs, col 0 bottom */ |
243 |
#define ORIENTATION_LEFTBOT 8 /* row 0 lhs, col 0 bottom */ |
244 |
#define TIFFTAG_SAMPLESPERPIXEL 277 /* samples per pixel */ |
245 |
#define TIFFTAG_ROWSPERSTRIP 278 /* rows per strip of data */ |
246 |
#define TIFFTAG_STRIPBYTECOUNTS 279 /* bytes counts for strips */ |
247 |
#define TIFFTAG_MINSAMPLEVALUE 280 /* +minimum sample value */ |
248 |
#define TIFFTAG_MAXSAMPLEVALUE 281 /* +maximum sample value */ |
249 |
#define TIFFTAG_XRESOLUTION 282 /* pixels/resolution in x */ |
250 |
#define TIFFTAG_YRESOLUTION 283 /* pixels/resolution in y */ |
251 |
#define TIFFTAG_PLANARCONFIG 284 /* storage organization */ |
252 |
#define PLANARCONFIG_CONTIG 1 /* single image plane */ |
253 |
#define PLANARCONFIG_SEPARATE 2 /* separate planes of data */ |
254 |
#define TIFFTAG_PAGENAME 285 /* page name image is from */ |
255 |
#define TIFFTAG_XPOSITION 286 /* x page offset of image lhs */ |
256 |
#define TIFFTAG_YPOSITION 287 /* y page offset of image lhs */ |
257 |
#define TIFFTAG_FREEOFFSETS 288 /* +byte offset to free block */ |
258 |
#define TIFFTAG_FREEBYTECOUNTS 289 /* +sizes of free blocks */ |
259 |
#define TIFFTAG_GRAYRESPONSEUNIT 290 /* $gray scale curve accuracy */ |
260 |
#define GRAYRESPONSEUNIT_10S 1 /* tenths of a unit */ |
261 |
#define GRAYRESPONSEUNIT_100S 2 /* hundredths of a unit */ |
262 |
#define GRAYRESPONSEUNIT_1000S 3 /* thousandths of a unit */ |
263 |
#define GRAYRESPONSEUNIT_10000S 4 /* ten-thousandths of a unit */ |
264 |
#define GRAYRESPONSEUNIT_100000S 5 /* hundred-thousandths */ |
265 |
#define TIFFTAG_GRAYRESPONSECURVE 291 /* $gray scale response curve */ |
266 |
#define TIFFTAG_GROUP3OPTIONS 292 /* 32 flag bits */ |
267 |
#define TIFFTAG_T4OPTIONS 292 /* TIFF 6.0 proper name alias */ |
268 |
#define GROUP3OPT_2DENCODING 0x1 /* 2-dimensional coding */ |
269 |
#define GROUP3OPT_UNCOMPRESSED 0x2 /* data not compressed */ |
270 |
#define GROUP3OPT_FILLBITS 0x4 /* fill to byte boundary */ |
271 |
#define TIFFTAG_GROUP4OPTIONS 293 /* 32 flag bits */ |
272 |
#define TIFFTAG_T6OPTIONS 293 /* TIFF 6.0 proper name */ |
273 |
#define GROUP4OPT_UNCOMPRESSED 0x2 /* data not compressed */ |
274 |
#define TIFFTAG_RESOLUTIONUNIT 296 /* units of resolutions */ |
275 |
#define RESUNIT_NONE 1 /* no meaningful units */ |
276 |
#define RESUNIT_INCH 2 /* english */ |
277 |
#define RESUNIT_CENTIMETER 3 /* metric */ |
278 |
#define TIFFTAG_PAGENUMBER 297 /* page numbers of multi-page */ |
279 |
#define TIFFTAG_COLORRESPONSEUNIT 300 /* $color curve accuracy */ |
280 |
#define COLORRESPONSEUNIT_10S 1 /* tenths of a unit */ |
281 |
#define COLORRESPONSEUNIT_100S 2 /* hundredths of a unit */ |
282 |
#define COLORRESPONSEUNIT_1000S 3 /* thousandths of a unit */ |
283 |
#define COLORRESPONSEUNIT_10000S 4 /* ten-thousandths of a unit */ |
284 |
#define COLORRESPONSEUNIT_100000S 5 /* hundred-thousandths */ |
285 |
#define TIFFTAG_TRANSFERFUNCTION 301 /* !colorimetry info */ |
286 |
#define TIFFTAG_SOFTWARE 305 /* name & release */ |
287 |
#define TIFFTAG_DATETIME 306 /* creation date and time */ |
288 |
#define TIFFTAG_ARTIST 315 /* creator of image */ |
289 |
#define TIFFTAG_HOSTCOMPUTER 316 /* machine where created */ |
290 |
#define TIFFTAG_PREDICTOR 317 /* prediction scheme w/ LZW */ |
291 |
#define PREDICTOR_NONE 1 /* no prediction scheme used */ |
292 |
#define PREDICTOR_HORIZONTAL 2 /* horizontal differencing */ |
293 |
#define PREDICTOR_FLOATINGPOINT 3 /* floating point predictor */ |
294 |
#define TIFFTAG_WHITEPOINT 318 /* image white point */ |
295 |
#define TIFFTAG_PRIMARYCHROMATICITIES 319 /* !primary chromaticities */ |
296 |
#define TIFFTAG_COLORMAP 320 /* RGB map for pallette image */ |
297 |
#define TIFFTAG_HALFTONEHINTS 321 /* !highlight+shadow info */ |
298 |
#define TIFFTAG_TILEWIDTH 322 /* !tile width in pixels */ |
299 |
#define TIFFTAG_TILELENGTH 323 /* !tile height in pixels */ |
300 |
#define TIFFTAG_TILEOFFSETS 324 /* !offsets to data tiles */ |
301 |
#define TIFFTAG_TILEBYTECOUNTS 325 /* !byte counts for tiles */ |
302 |
#define TIFFTAG_BADFAXLINES 326 /* lines w/ wrong pixel count */ |
303 |
#define TIFFTAG_CLEANFAXDATA 327 /* regenerated line info */ |
304 |
#define CLEANFAXDATA_CLEAN 0 /* no errors detected */ |
305 |
#define CLEANFAXDATA_REGENERATED 1 /* receiver regenerated lines */ |
306 |
#define CLEANFAXDATA_UNCLEAN 2 /* uncorrected errors exist */ |
307 |
#define TIFFTAG_CONSECUTIVEBADFAXLINES 328 /* max consecutive bad lines */ |
308 |
#define TIFFTAG_SUBIFD 330 /* subimage descriptors */ |
309 |
#define TIFFTAG_INKSET 332 /* !inks in separated image */ |
310 |
#define INKSET_CMYK 1 /* !cyan-magenta-yellow-black color */ |
311 |
#define INKSET_MULTIINK 2 /* !multi-ink or hi-fi color */ |
312 |
#define TIFFTAG_INKNAMES 333 /* !ascii names of inks */ |
313 |
#define TIFFTAG_NUMBEROFINKS 334 /* !number of inks */ |
314 |
#define TIFFTAG_DOTRANGE 336 /* !0% and 100% dot codes */ |
315 |
#define TIFFTAG_TARGETPRINTER 337 /* !separation target */ |
316 |
#define TIFFTAG_EXTRASAMPLES 338 /* !info about extra samples */ |
317 |
#define EXTRASAMPLE_UNSPECIFIED 0 /* !unspecified data */ |
318 |
#define EXTRASAMPLE_ASSOCALPHA 1 /* !associated alpha data */ |
319 |
#define EXTRASAMPLE_UNASSALPHA 2 /* !unassociated alpha data */ |
320 |
#define TIFFTAG_SAMPLEFORMAT 339 /* !data sample format */ |
321 |
#define SAMPLEFORMAT_UINT 1 /* !unsigned integer data */ |
322 |
#define SAMPLEFORMAT_INT 2 /* !signed integer data */ |
323 |
#define SAMPLEFORMAT_IEEEFP 3 /* !IEEE floating point data */ |
324 |
#define SAMPLEFORMAT_VOID 4 /* !untyped data */ |
325 |
#define SAMPLEFORMAT_COMPLEXINT 5 /* !complex signed int */ |
326 |
#define SAMPLEFORMAT_COMPLEXIEEEFP 6 /* !complex ieee floating */ |
327 |
#define TIFFTAG_SMINSAMPLEVALUE 340 /* !variable MinSampleValue */ |
328 |
#define TIFFTAG_SMAXSAMPLEVALUE 341 /* !variable MaxSampleValue */ |
329 |
#define TIFFTAG_CLIPPATH 343 /* %ClipPath |
330 |
[Adobe TIFF technote 2] */ |
331 |
#define TIFFTAG_XCLIPPATHUNITS 344 /* %XClipPathUnits |
332 |
333 |
#define TIFFTAG_YCLIPPATHUNITS 345 /* %YClipPathUnits |
334 |
335 |
#define TIFFTAG_INDEXED 346 /* %Indexed |
336 |
[Adobe TIFF Technote 3] */ |
337 |
#define TIFFTAG_JPEGTABLES 347 /* %JPEG table stream */ |
338 |
#define TIFFTAG_OPIPROXY 351 /* %OPI Proxy [Adobe TIFF technote] */ |
339 |
340 |
* Tags 512-521 are obsoleted by Technical Note #2 which specifies a |
341 |
* revised JPEG-in-TIFF scheme. |
342 |
343 |
#define TIFFTAG_JPEGPROC 512 /* !JPEG processing algorithm */ |
344 |
#define JPEGPROC_BASELINE 1 /* !baseline sequential */ |
345 |
#define JPEGPROC_LOSSLESS 14 /* !Huffman coded lossless */ |
346 |
#define TIFFTAG_JPEGIFOFFSET 513 /* !pointer to SOI marker */ |
347 |
#define TIFFTAG_JPEGIFBYTECOUNT 514 /* !JFIF stream length */ |
348 |
#define TIFFTAG_JPEGRESTARTINTERVAL 515 /* !restart interval length */ |
349 |
#define TIFFTAG_JPEGLOSSLESSPREDICTORS 517 /* !lossless proc predictor */ |
350 |
#define TIFFTAG_JPEGPOINTTRANSFORM 518 /* !lossless point transform */ |
351 |
#define TIFFTAG_JPEGQTABLES 519 /* !Q matrice offsets */ |
352 |
#define TIFFTAG_JPEGDCTABLES 520 /* !DCT table offsets */ |
353 |
#define TIFFTAG_JPEGACTABLES 521 /* !AC coefficient offsets */ |
354 |
#define TIFFTAG_YCBCRCOEFFICIENTS 529 /* !RGB -> YCbCr transform */ |
355 |
#define TIFFTAG_YCBCRSUBSAMPLING 530 /* !YCbCr subsampling factors */ |
356 |
#define TIFFTAG_YCBCRPOSITIONING 531 /* !subsample positioning */ |
357 |
#define YCBCRPOSITION_CENTERED 1 /* !as in PostScript Level 2 */ |
358 |
#define YCBCRPOSITION_COSITED 2 /* !as in CCIR 601-1 */ |
359 |
#define TIFFTAG_REFERENCEBLACKWHITE 532 /* !colorimetry info */ |
360 |
#define TIFFTAG_XMLPACKET 700 /* %XML packet |
361 |
[Adobe XMP Specification, |
362 |
January 2004 */ |
363 |
#define TIFFTAG_OPIIMAGEID 32781 /* %OPI ImageID |
364 |
365 |
/* tags 32952-32956 are private tags registered to Island Graphics */ |
366 |
#define TIFFTAG_REFPTS 32953 /* image reference points */ |
367 |
#define TIFFTAG_REGIONTACKPOINT 32954 /* region-xform tack point */ |
368 |
#define TIFFTAG_REGIONWARPCORNERS 32955 /* warp quadrilateral */ |
369 |
#define TIFFTAG_REGIONAFFINE 32956 /* affine transformation mat */ |
370 |
/* tags 32995-32999 are private tags registered to SGI */ |
371 |
#define TIFFTAG_MATTEING 32995 /* $use ExtraSamples */ |
372 |
#define TIFFTAG_DATATYPE 32996 /* $use SampleFormat */ |
373 |
#define TIFFTAG_IMAGEDEPTH 32997 /* z depth of image */ |
374 |
#define TIFFTAG_TILEDEPTH 32998 /* z depth/data tile */ |
375 |
/* tags 33300-33309 are private tags registered to Pixar */ |
376 |
377 |
* TIFFTAG_PIXAR_IMAGEFULLWIDTH and TIFFTAG_PIXAR_IMAGEFULLLENGTH |
378 |
* are set when an image has been cropped out of a larger image. |
379 |
* They reflect the size of the original uncropped image. |
380 |
* The TIFFTAG_XPOSITION and TIFFTAG_YPOSITION can be used |
381 |
* to determine the position of the smaller image in the larger one. |
382 |
383 |
#define TIFFTAG_PIXAR_IMAGEFULLWIDTH 33300 /* full image size in x */ |
384 |
#define TIFFTAG_PIXAR_IMAGEFULLLENGTH 33301 /* full image size in y */ |
385 |
/* Tags 33302-33306 are used to identify special image modes and data |
386 |
* used by Pixar's texture formats. |
387 |
388 |
#define TIFFTAG_PIXAR_TEXTUREFORMAT 33302 /* texture map format */ |
389 |
#define TIFFTAG_PIXAR_WRAPMODES 33303 /* s & t wrap modes */ |
390 |
#define TIFFTAG_PIXAR_FOVCOT 33304 /* cotan(fov) for env. maps */ |
391 |
#define TIFFTAG_PIXAR_MATRIX_WORLDTOSCREEN 33305 |
392 |
#define TIFFTAG_PIXAR_MATRIX_WORLDTOCAMERA 33306 |
393 |
/* tag 33405 is a private tag registered to Eastman Kodak */ |
394 |
#define TIFFTAG_WRITERSERIALNUMBER 33405 /* device serial number */ |
395 |
/* tag 33432 is listed in the 6.0 spec w/ unknown ownership */ |
396 |
#define TIFFTAG_COPYRIGHT 33432 /* copyright string */ |
397 |
/* IPTC TAG from RichTIFF specifications */ |
398 |
#define TIFFTAG_RICHTIFFIPTC 33723 |
399 |
/* 34016-34029 are reserved for ANSI IT8 TIFF/IT <[email protected]) */ |
400 |
#define TIFFTAG_IT8SITE 34016 /* site name */ |
401 |
#define TIFFTAG_IT8COLORSEQUENCE 34017 /* color seq. [RGB,CMYK,etc] */ |
402 |
#define TIFFTAG_IT8HEADER 34018 /* DDES Header */ |
403 |
#define TIFFTAG_IT8RASTERPADDING 34019 /* raster scanline padding */ |
404 |
#define TIFFTAG_IT8BITSPERRUNLENGTH 34020 /* # of bits in short run */ |
405 |
#define TIFFTAG_IT8BITSPEREXTENDEDRUNLENGTH 34021/* # of bits in long run */ |
406 |
#define TIFFTAG_IT8COLORTABLE 34022 /* LW colortable */ |
407 |
#define TIFFTAG_IT8IMAGECOLORINDICATOR 34023 /* BP/BL image color switch */ |
408 |
#define TIFFTAG_IT8BKGCOLORINDICATOR 34024 /* BP/BL bg color switch */ |
409 |
#define TIFFTAG_IT8IMAGECOLORVALUE 34025 /* BP/BL image color value */ |
410 |
#define TIFFTAG_IT8BKGCOLORVALUE 34026 /* BP/BL bg color value */ |
411 |
#define TIFFTAG_IT8PIXELINTENSITYRANGE 34027 /* MP pixel intensity value */ |
412 |
#define TIFFTAG_IT8TRANSPARENCYINDICATOR 34028 /* HC transparency switch */ |
413 |
#define TIFFTAG_IT8COLORCHARACTERIZATION 34029 /* color character. table */ |
414 |
#define TIFFTAG_IT8HCUSAGE 34030 /* HC usage indicator */ |
415 |
#define TIFFTAG_IT8TRAPINDICATOR 34031 /* Trapping indicator |
416 |
(untrapped=0, trapped=1) */ |
417 |
#define TIFFTAG_IT8CMYKEQUIVALENT 34032 /* CMYK color equivalents */ |
418 |
/* tags 34232-34236 are private tags registered to Texas Instruments */ |
419 |
#define TIFFTAG_FRAMECOUNT 34232 /* Sequence Frame Count */ |
420 |
/* tag 34377 is private tag registered to Adobe for PhotoShop */ |
421 |
#define TIFFTAG_PHOTOSHOP 34377 |
422 |
/* tags 34665, 34853 and 40965 are documented in EXIF specification */ |
423 |
#define TIFFTAG_EXIFIFD 34665 /* Pointer to EXIF private directory */ |
424 |
/* tag 34750 is a private tag registered to Adobe? */ |
425 |
#define TIFFTAG_ICCPROFILE 34675 /* ICC profile data */ |
426 |
/* tag 34750 is a private tag registered to Pixel Magic */ |
427 |
#define TIFFTAG_JBIGOPTIONS 34750 /* JBIG options */ |
428 |
#define TIFFTAG_GPSIFD 34853 /* Pointer to GPS private directory */ |
429 |
/* tags 34908-34914 are private tags registered to SGI */ |
430 |
#define TIFFTAG_FAXRECVPARAMS 34908 /* encoded Class 2 ses. parms */ |
431 |
#define TIFFTAG_FAXSUBADDRESS 34909 /* received SubAddr string */ |
432 |
#define TIFFTAG_FAXRECVTIME 34910 /* receive time (secs) */ |
433 |
#define TIFFTAG_FAXDCS 34911 /* encoded fax ses. params, Table 2/T.30 */ |
434 |
/* tags 37439-37443 are registered to SGI <[email protected]> */ |
435 |
#define TIFFTAG_STONITS 37439 /* Sample value to Nits */ |
436 |
/* tag 34929 is a private tag registered to FedEx */ |
437 |
#define TIFFTAG_FEDEX_EDR 34929 /* unknown use */ |
438 |
#define TIFFTAG_INTEROPERABILITYIFD 40965 /* Pointer to Interoperability private directory */ |
439 |
/* Adobe Digital Negative (DNG) format tags */ |
440 |
#define TIFFTAG_DNGVERSION 50706 /* &DNG version number */ |
441 |
#define TIFFTAG_DNGBACKWARDVERSION 50707 /* &DNG compatibility version */ |
442 |
#define TIFFTAG_UNIQUECAMERAMODEL 50708 /* &name for the camera model */ |
443 |
#define TIFFTAG_LOCALIZEDCAMERAMODEL 50709 /* &localized camera model |
444 |
name */ |
445 |
#define TIFFTAG_CFAPLANECOLOR 50710 /* &CFAPattern->LinearRaw space |
446 |
mapping */ |
447 |
#define TIFFTAG_CFALAYOUT 50711 /* &spatial layout of the CFA */ |
448 |
#define TIFFTAG_LINEARIZATIONTABLE 50712 /* &lookup table description */ |
449 |
#define TIFFTAG_BLACKLEVELREPEATDIM 50713 /* &repeat pattern size for |
450 |
the BlackLevel tag */ |
451 |
#define TIFFTAG_BLACKLEVEL 50714 /* &zero light encoding level */ |
452 |
#define TIFFTAG_BLACKLEVELDELTAH 50715 /* &zero light encoding level |
453 |
differences (columns) */ |
454 |
#define TIFFTAG_BLACKLEVELDELTAV 50716 /* &zero light encoding level |
455 |
differences (rows) */ |
456 |
#define TIFFTAG_WHITELEVEL 50717 /* &fully saturated encoding |
457 |
level */ |
458 |
#define TIFFTAG_DEFAULTSCALE 50718 /* &default scale factors */ |
459 |
#define TIFFTAG_DEFAULTCROPORIGIN 50719 /* &origin of the final image |
460 |
area */ |
461 |
#define TIFFTAG_DEFAULTCROPSIZE 50720 /* &size of the final image |
462 |
area */ |
463 |
#define TIFFTAG_COLORMATRIX1 50721 /* &XYZ->reference color space |
464 |
transformation matrix 1 */ |
465 |
#define TIFFTAG_COLORMATRIX2 50722 /* &XYZ->reference color space |
466 |
transformation matrix 2 */ |
467 |
#define TIFFTAG_CAMERACALIBRATION1 50723 /* &calibration matrix 1 */ |
468 |
#define TIFFTAG_CAMERACALIBRATION2 50724 /* &calibration matrix 2 */ |
469 |
#define TIFFTAG_REDUCTIONMATRIX1 50725 /* &dimensionality reduction |
470 |
matrix 1 */ |
471 |
#define TIFFTAG_REDUCTIONMATRIX2 50726 /* &dimensionality reduction |
472 |
matrix 2 */ |
473 |
#define TIFFTAG_ANALOGBALANCE 50727 /* &gain applied the stored raw |
474 |
values*/ |
475 |
#define TIFFTAG_ASSHOTNEUTRAL 50728 /* &selected white balance in |
476 |
linear reference space */ |
477 |
#define TIFFTAG_ASSHOTWHITEXY 50729 /* &selected white balance in |
478 |
x-y chromaticity |
479 |
coordinates */ |
480 |
#define TIFFTAG_BASELINEEXPOSURE 50730 /* &how much to move the zero |
481 |
point */ |
482 |
#define TIFFTAG_BASELINENOISE 50731 /* &relative noise level */ |
483 |
#define TIFFTAG_BASELINESHARPNESS 50732 /* &relative amount of |
484 |
sharpening */ |
485 |
#define TIFFTAG_BAYERGREENSPLIT 50733 /* &how closely the values of |
486 |
the green pixels in the |
487 |
blue/green rows track the |
488 |
values of the green pixels |
489 |
in the red/green rows */ |
490 |
#define TIFFTAG_LINEARRESPONSELIMIT 50734 /* &non-linear encoding range */ |
491 |
#define TIFFTAG_CAMERASERIALNUMBER 50735 /* &camera's serial number */ |
492 |
#define TIFFTAG_LENSINFO 50736 /* info about the lens */ |
493 |
#define TIFFTAG_CHROMABLURRADIUS 50737 /* &chroma blur radius */ |
494 |
#define TIFFTAG_ANTIALIASSTRENGTH 50738 /* &relative strength of the |
495 |
camera's anti-alias filter */ |
496 |
#define TIFFTAG_SHADOWSCALE 50739 /* &used by Adobe Camera Raw */ |
497 |
#define TIFFTAG_DNGPRIVATEDATA 50740 /* &manufacturer's private data */ |
498 |
#define TIFFTAG_MAKERNOTESAFETY 50741 /* &whether the EXIF MakerNote |
499 |
tag is safe to preserve |
500 |
along with the rest of the |
501 |
EXIF data */ |
502 |
#define TIFFTAG_CALIBRATIONILLUMINANT1 50778 /* &illuminant 1 */ |
503 |
#define TIFFTAG_CALIBRATIONILLUMINANT2 50779 /* &illuminant 2 */ |
504 |
#define TIFFTAG_BESTQUALITYSCALE 50780 /* &best quality multiplier */ |
505 |
#define TIFFTAG_RAWDATAUNIQUEID 50781 /* &unique identifier for |
506 |
the raw image data */ |
507 |
#define TIFFTAG_ORIGINALRAWFILENAME 50827 /* &file name of the original |
508 |
raw file */ |
509 |
#define TIFFTAG_ORIGINALRAWFILEDATA 50828 /* &contents of the original |
510 |
raw file */ |
511 |
#define TIFFTAG_ACTIVEAREA 50829 /* &active (non-masked) pixels |
512 |
of the sensor */ |
513 |
#define TIFFTAG_MASKEDAREAS 50830 /* &list of coordinates |
514 |
of fully masked pixels */ |
515 |
#define TIFFTAG_ASSHOTICCPROFILE 50831 /* &these two tags used to */ |
516 |
#define TIFFTAG_ASSHOTPREPROFILEMATRIX 50832 /* map cameras's color space |
517 |
into ICC profile space */ |
518 |
#define TIFFTAG_CURRENTICCPROFILE 50833 /* & */ |
519 |
#define TIFFTAG_CURRENTPREPROFILEMATRIX 50834 /* & */ |
520 |
/* tag 65535 is an undefined tag used by Eastman Kodak */ |
521 |
#define TIFFTAG_DCSHUESHIFTVALUES 65535 /* hue shift correction data */ |
522 |
523 |
524 |
* The following are ``pseudo tags'' that can be used to control |
525 |
* codec-specific functionality. These tags are not written to file. |
526 |
* Note that these values start at 0xffff+1 so that they'll never |
527 |
* collide with Aldus-assigned tags. |
528 |
529 |
* If you want your private pseudo tags ``registered'' (i.e. added to |
530 |
* this file), please post a bug report via the tracking system at |
531 |
* http://www.remotesensing.org/libtiff/bugs.html with the appropriate |
532 |
* C definitions to add. |
533 |
534 |
#define TIFFTAG_FAXMODE 65536 /* Group 3/4 format control */ |
535 |
#define FAXMODE_CLASSIC 0x0000 /* default, include RTC */ |
536 |
#define FAXMODE_NORTC 0x0001 /* no RTC at end of data */ |
537 |
#define FAXMODE_NOEOL 0x0002 /* no EOL code at end of row */ |
538 |
#define FAXMODE_BYTEALIGN 0x0004 /* byte align row */ |
539 |
#define FAXMODE_WORDALIGN 0x0008 /* word align row */ |
540 |
#define FAXMODE_CLASSF FAXMODE_NORTC /* TIFF Class F */ |
541 |
#define TIFFTAG_JPEGQUALITY 65537 /* Compression quality level */ |
542 |
/* Note: quality level is on the IJG 0-100 scale. Default value is 75 */ |
543 |
#define TIFFTAG_JPEGCOLORMODE 65538 /* Auto RGB<=>YCbCr convert? */ |
544 |
#define JPEGCOLORMODE_RAW 0x0000 /* no conversion (default) */ |
545 |
#define JPEGCOLORMODE_RGB 0x0001 /* do auto conversion */ |
546 |
#define TIFFTAG_JPEGTABLESMODE 65539 /* What to put in JPEGTables */ |
547 |
#define JPEGTABLESMODE_QUANT 0x0001 /* include quantization tbls */ |
548 |
#define JPEGTABLESMODE_HUFF 0x0002 /* include Huffman tbls */ |
549 |
/* Note: default is JPEGTABLESMODE_QUANT | JPEGTABLESMODE_HUFF */ |
550 |
#define TIFFTAG_FAXFILLFUNC 65540 /* G3/G4 fill function */ |
551 |
#define TIFFTAG_PIXARLOGDATAFMT 65549 /* PixarLogCodec I/O data sz */ |
552 |
#define PIXARLOGDATAFMT_8BIT 0 /* regular u_char samples */ |
553 |
#define PIXARLOGDATAFMT_8BITABGR 1 /* ABGR-order u_chars */ |
554 |
#define PIXARLOGDATAFMT_11BITLOG 2 /* 11-bit log-encoded (raw) */ |
555 |
#define PIXARLOGDATAFMT_12BITPICIO 3 /* as per PICIO (1.0==2048) */ |
556 |
#define PIXARLOGDATAFMT_16BIT 4 /* signed short samples */ |
557 |
#define PIXARLOGDATAFMT_FLOAT 5 /* IEEE float samples */ |
558 |
/* 65550-65556 are allocated to Oceana Matrix <[email protected]> */ |
559 |
#define TIFFTAG_DCSIMAGERTYPE 65550 /* imager model & filter */ |
560 |
#define DCSIMAGERMODEL_M3 0 /* M3 chip (1280 x 1024) */ |
561 |
#define DCSIMAGERMODEL_M5 1 /* M5 chip (1536 x 1024) */ |
562 |
#define DCSIMAGERMODEL_M6 2 /* M6 chip (3072 x 2048) */ |
563 |
#define DCSIMAGERFILTER_IR 0 /* infrared filter */ |
564 |
#define DCSIMAGERFILTER_MONO 1 /* monochrome filter */ |
565 |
#define DCSIMAGERFILTER_CFA 2 /* color filter array */ |
566 |
#define DCSIMAGERFILTER_OTHER 3 /* other filter */ |
567 |
#define TIFFTAG_DCSINTERPMODE 65551 /* interpolation mode */ |
568 |
#define DCSINTERPMODE_NORMAL 0x0 /* whole image, default */ |
569 |
#define DCSINTERPMODE_PREVIEW 0x1 /* preview of image (384x256) */ |
570 |
#define TIFFTAG_DCSBALANCEARRAY 65552 /* color balance values */ |
571 |
#define TIFFTAG_DCSCORRECTMATRIX 65553 /* color correction values */ |
572 |
#define TIFFTAG_DCSGAMMA 65554 /* gamma value */ |
573 |
#define TIFFTAG_DCSTOESHOULDERPTS 65555 /* toe & shoulder points */ |
574 |
#define TIFFTAG_DCSCALIBRATIONFD 65556 /* calibration file desc */ |
575 |
/* Note: quality level is on the ZLIB 1-9 scale. Default value is -1 */ |
576 |
#define TIFFTAG_ZIPQUALITY 65557 /* compression quality level */ |
577 |
#define TIFFTAG_PIXARLOGQUALITY 65558 /* PixarLog uses same scale */ |
578 |
/* 65559 is allocated to Oceana Matrix <[email protected]> */ |
579 |
#define TIFFTAG_DCSCLIPRECTANGLE 65559 /* area of image to acquire */ |
580 |
#define TIFFTAG_SGILOGDATAFMT 65560 /* SGILog user data format */ |
581 |
#define SGILOGDATAFMT_FLOAT 0 /* IEEE float samples */ |
582 |
#define SGILOGDATAFMT_16BIT 1 /* 16-bit samples */ |
583 |
#define SGILOGDATAFMT_RAW 2 /* uninterpreted data */ |
584 |
#define SGILOGDATAFMT_8BIT 3 /* 8-bit RGB monitor values */ |
585 |
#define TIFFTAG_SGILOGENCODE 65561 /* SGILog data encoding control*/ |
586 |
#define SGILOGENCODE_NODITHER 0 /* do not dither encoded values*/ |
587 |
#define SGILOGENCODE_RANDITHER 1 /* randomly dither encd values */ |
588 |
#endif /* _TIFF_ */ |
589 |
590 |
/* vim: set ts=8 sts=8 sw=8 noet: */ |
