root/radiance/ray/src/common/tiff.h
Revision: 3.17
Committed: Thu Aug 2 18:33:42 2018 UTC (6 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Changes since 3.16: +0 -0 lines
# User Rev Content
1 greg 3.13 /* $Id: tiff.h,v 1.37 2005/06/23 11:01:55 dron Exp $ */
2
3 greg 3.1 /*
4     * Copyright (c) 1988-1997 Sam Leffler
5     * Copyright (c) 1991-1997 Silicon Graphics, Inc.
6     *
7     * Permission to use, copy, modify, distribute, and sell this software and
8     * its documentation for any purpose is hereby granted without fee, provided
9     * that (i) the above copyright notices and this permission notice appear in
10     * all copies of the software and related documentation, and (ii) the names of
11     * Sam Leffler and Silicon Graphics may not be used in any advertising or
12     * publicity relating to the software without the specific, prior written
13     * permission of Sam Leffler and Silicon Graphics.
14     *
15     * THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
16     * EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
17     * WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
18     *
19     * IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
20     * ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
21     * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
22     * WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
23     * LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
24     * OF THIS SOFTWARE.
25     */
26
27     #ifndef _TIFF_
28     #define _TIFF_
29     /*
30     * Tag Image File Format (TIFF)
31     *
32     * Based on Rev 6.0 from:
33     * Developer's Desk
34     * Aldus Corporation
35     * 411 First Ave. South
36     * Suite 200
37     * Seattle, WA 98104
38     * 206-622-5500
39 greg 3.12 *
40     * (http://partners.adobe.com/asn/developer/PDFS/TN/TIFF6.pdf)
41     *
42     * For Big TIFF design notes see the following link
43     * http://gdal.maptools.org/twiki/bin/view/libtiff/BigTIFFDesign
44 greg 3.1 */
45 greg 3.12 #define TIFF_VERSION 42
46     #define TIFF_BIGTIFF_VERSION 43
47 greg 3.1
48     #define TIFF_BIGENDIAN 0x4d4d
49     #define TIFF_LITTLEENDIAN 0x4949
50
51 greg 3.11 /*
52     * The so called TIFF types conflict with definitions from inttypes.h
53     * included from sys/types.h on AIX (at least using VisualAge compiler).
54     * We try to work around this by detecting this case. Defining
55     * _TIFF_DATA_TYPEDEFS_ short circuits the later definitions in tiff.h, and
56     * we will in the holes not provided for by inttypes.h.
57     *
58     * See http://bugzilla.remotesensing.org/show_bug.cgi?id=39
59     */
60 greg 3.12 #if defined(_H_INTTYPES) && defined(_ALL_SOURCE) && defined(USING_VISUALAGE)
61 greg 3.11
62 greg 3.1 #define _TIFF_DATA_TYPEDEFS_
63 greg 3.11 typedef unsigned char uint8;
64     typedef unsigned short uint16;
65     typedef unsigned int uint32;
66
67     #endif
68
69 greg 3.1 /*
70     * Intrinsic data types required by the file format:
71     *
72     * 8-bit quantities int8/uint8
73     * 16-bit quantities int16/uint16
74     * 32-bit quantities int32/uint32
75     * strings unsigned char*
76     */
77 greg 3.11 #ifndef _TIFF_DATA_TYPEDEFS_
78     #define _TIFF_DATA_TYPEDEFS_
79
80 greg 3.1 typedef signed char int8; /* NB: non-ANSI compilers may not grok */
81     typedef unsigned char uint8;
82     typedef short int16;
83     typedef unsigned short uint16; /* sizeof (uint16) must == 2 */
84 greg 3.12 #if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) || defined(__LP64__) || defined(__arch64__) || defined(__sparcv9)
85 greg 3.1 typedef int int32;
86     typedef unsigned int uint32; /* sizeof (uint32) must == 4 */
87     #else
88     typedef long int32;
89     typedef unsigned long uint32; /* sizeof (uint32) must == 4 */
90     #endif
91 greg 3.12
92 greg 3.1 #endif /* _TIFF_DATA_TYPEDEFS_ */
93
94 greg 3.12 /* For TIFFReassignTagToIgnore */
95 greg 3.1 enum TIFFIgnoreSense /* IGNORE tag table */
96     {
97     TIS_STORE,
98     TIS_EXTRACT,
99     TIS_EMPTY
100     };
101
102 greg 3.12 /*
103     * TIFF header.
104     */
105 greg 3.1 typedef struct {
106     uint16 tiff_magic; /* magic number (defines byte order) */
107 greg 3.12 #define TIFF_MAGIC_SIZE 2
108 greg 3.1 uint16 tiff_version; /* TIFF version number */
109 greg 3.12 #define TIFF_VERSION_SIZE 2
110 greg 3.1 uint32 tiff_diroff; /* byte offset to first directory */
111 greg 3.12 #define TIFF_DIROFFSET_SIZE 4
112 greg 3.1 } TIFFHeader;
113
114 greg 3.12
115 greg 3.1 /*
116 greg 3.12 * TIFF Image File Directories are comprised of a table of field
117     * descriptors of the form shown below. The table is sorted in
118     * ascending order by tag. The values associated with each entry are
119     * disjoint and may appear anywhere in the file (so long as they are
120     * placed on a word boundary).
121 greg 3.1 *
122 greg 3.12 * If the value is 4 bytes or less, then it is placed in the offset
123     * field to save space. If the value is less than 4 bytes, it is
124     * left-justified in the offset field.
125 greg 3.1 */
126     typedef struct {
127 greg 3.12 uint16 tdir_tag; /* see below */
128     uint16 tdir_type; /* data type; see below */
129     uint32 tdir_count; /* number of items; length in spec */
130     uint32 tdir_offset; /* byte offset to field data */
131 greg 3.1 } TIFFDirEntry;
132
133     /*
134     * NB: In the comments below,
135     * - items marked with a + are obsoleted by revision 5.0,
136     * - items marked with a ! are introduced in revision 6.0.
137     * - items marked with a % are introduced post revision 6.0.
138     * - items marked with a $ are obsoleted by revision 6.0.
139 greg 3.12 * - items marked with a & are introduced by Adobe DNG specification.
140 greg 3.1 */
141
142     /*
143     * Tag data type information.
144     *
145     * Note: RATIONALs are the ratio of two 32-bit integer values.
146     */
147     typedef enum {
148     TIFF_NOTYPE = 0, /* placeholder */
149     TIFF_BYTE = 1, /* 8-bit unsigned integer */
150     TIFF_ASCII = 2, /* 8-bit bytes w/ last byte null */
151     TIFF_SHORT = 3, /* 16-bit unsigned integer */
152     TIFF_LONG = 4, /* 32-bit unsigned integer */
153     TIFF_RATIONAL = 5, /* 64-bit unsigned fraction */
154     TIFF_SBYTE = 6, /* !8-bit signed integer */
155     TIFF_UNDEFINED = 7, /* !8-bit untyped data */
156     TIFF_SSHORT = 8, /* !16-bit signed integer */
157     TIFF_SLONG = 9, /* !32-bit signed integer */
158     TIFF_SRATIONAL = 10, /* !64-bit signed fraction */
159     TIFF_FLOAT = 11, /* !32-bit IEEE floating point */
160 greg 3.12 TIFF_DOUBLE = 12, /* !64-bit IEEE floating point */
161     TIFF_IFD = 13 /* %32-bit unsigned integer (offset) */
162 greg 3.1 } TIFFDataType;
163
164     /*
165     * TIFF Tag Definitions.
166     */
167     #define TIFFTAG_SUBFILETYPE 254 /* subfile data descriptor */
168     #define FILETYPE_REDUCEDIMAGE 0x1 /* reduced resolution version */
169     #define FILETYPE_PAGE 0x2 /* one page of many */
170     #define FILETYPE_MASK 0x4 /* transparency mask */
171     #define TIFFTAG_OSUBFILETYPE 255 /* +kind of data in subfile */
172     #define OFILETYPE_IMAGE 1 /* full resolution image data */
173     #define OFILETYPE_REDUCEDIMAGE 2 /* reduced size image data */
174     #define OFILETYPE_PAGE 3 /* one page of many */
175     #define TIFFTAG_IMAGEWIDTH 256 /* image width in pixels */
176     #define TIFFTAG_IMAGELENGTH 257 /* image height in pixels */
177     #define TIFFTAG_BITSPERSAMPLE 258 /* bits per channel (sample) */
178     #define TIFFTAG_COMPRESSION 259 /* data compression technique */
179     #define COMPRESSION_NONE 1 /* dump mode */
180     #define COMPRESSION_CCITTRLE 2 /* CCITT modified Huffman RLE */
181     #define COMPRESSION_CCITTFAX3 3 /* CCITT Group 3 fax encoding */
182 greg 3.11 #define COMPRESSION_CCITT_T4 3 /* CCITT T.4 (TIFF 6 name) */
183 greg 3.1 #define COMPRESSION_CCITTFAX4 4 /* CCITT Group 4 fax encoding */
184 greg 3.11 #define COMPRESSION_CCITT_T6 4 /* CCITT T.6 (TIFF 6 name) */
185 greg 3.1 #define COMPRESSION_LZW 5 /* Lempel-Ziv & Welch */
186     #define COMPRESSION_OJPEG 6 /* !6.0 JPEG */
187     #define COMPRESSION_JPEG 7 /* %JPEG DCT compression */
188     #define COMPRESSION_NEXT 32766 /* NeXT 2-bit RLE */
189     #define COMPRESSION_CCITTRLEW 32771 /* #1 w/ word alignment */
190     #define COMPRESSION_PACKBITS 32773 /* Macintosh RLE */
191     #define COMPRESSION_THUNDERSCAN 32809 /* ThunderScan RLE */
192 greg 3.12 /* codes 32895-32898 are reserved for ANSI IT8 TIFF/IT <[email protected]) */
193 greg 3.1 #define COMPRESSION_IT8CTPAD 32895 /* IT8 CT w/padding */
194     #define COMPRESSION_IT8LW 32896 /* IT8 Linework RLE */
195     #define COMPRESSION_IT8MP 32897 /* IT8 Monochrome picture */
196     #define COMPRESSION_IT8BL 32898 /* IT8 Binary line art */
197     /* compression codes 32908-32911 are reserved for Pixar */
198     #define COMPRESSION_PIXARFILM 32908 /* Pixar companded 10bit LZW */
199     #define COMPRESSION_PIXARLOG 32909 /* Pixar companded 11bit ZIP */
200     #define COMPRESSION_DEFLATE 32946 /* Deflate compression */
201 greg 3.12 #define COMPRESSION_ADOBE_DEFLATE 8 /* Deflate compression,
202     as recognized by Adobe */
203 greg 3.1 /* compression code 32947 is reserved for Oceana Matrix <[email protected]> */
204     #define COMPRESSION_DCS 32947 /* Kodak DCS encoding */
205     #define COMPRESSION_JBIG 34661 /* ISO JBIG */
206     #define COMPRESSION_SGILOG 34676 /* SGI Log Luminance RLE */
207     #define COMPRESSION_SGILOG24 34677 /* SGI Log 24-bit packed */
208 greg 3.12 #define COMPRESSION_JP2000 34712 /* Leadtools JPEG2000 */
209 greg 3.1 #define TIFFTAG_PHOTOMETRIC 262 /* photometric interpretation */
210     #define PHOTOMETRIC_MINISWHITE 0 /* min value is white */
211     #define PHOTOMETRIC_MINISBLACK 1 /* min value is black */
212     #define PHOTOMETRIC_RGB 2 /* RGB color model */
213     #define PHOTOMETRIC_PALETTE 3 /* color map indexed */
214     #define PHOTOMETRIC_MASK 4 /* $holdout mask */
215     #define PHOTOMETRIC_SEPARATED 5 /* !color separations */
216     #define PHOTOMETRIC_YCBCR 6 /* !CCIR 601 */
217     #define PHOTOMETRIC_CIELAB 8 /* !1976 CIE L*a*b* */
218 greg 3.12 #define PHOTOMETRIC_ICCLAB 9 /* ICC L*a*b* [Adobe TIFF Technote 4] */
219 greg 3.11 #define PHOTOMETRIC_ITULAB 10 /* ITU L*a*b* */
220 greg 3.1 #define PHOTOMETRIC_LOGL 32844 /* CIE Log2(L) */
221     #define PHOTOMETRIC_LOGLUV 32845 /* CIE Log2(L) (u',v') */
222     #define TIFFTAG_THRESHHOLDING 263 /* +thresholding used on data */
223     #define THRESHHOLD_BILEVEL 1 /* b&w art scan */
224     #define THRESHHOLD_HALFTONE 2 /* or dithered scan */
225     #define THRESHHOLD_ERRORDIFFUSE 3 /* usually floyd-steinberg */
226     #define TIFFTAG_CELLWIDTH 264 /* +dithering matrix width */
227     #define TIFFTAG_CELLLENGTH 265 /* +dithering matrix height */
228     #define TIFFTAG_FILLORDER 266 /* data order within a byte */
229     #define FILLORDER_MSB2LSB 1 /* most significant -> least */
230     #define FILLORDER_LSB2MSB 2 /* least significant -> most */
231     #define TIFFTAG_DOCUMENTNAME 269 /* name of doc. image is from */
232     #define TIFFTAG_IMAGEDESCRIPTION 270 /* info about image */
233     #define TIFFTAG_MAKE 271 /* scanner manufacturer name */
234     #define TIFFTAG_MODEL 272 /* scanner model name/number */
235     #define TIFFTAG_STRIPOFFSETS 273 /* offsets to data strips */
236     #define TIFFTAG_ORIENTATION 274 /* +image orientation */
237     #define ORIENTATION_TOPLEFT 1 /* row 0 top, col 0 lhs */
238     #define ORIENTATION_TOPRIGHT 2 /* row 0 top, col 0 rhs */
239     #define ORIENTATION_BOTRIGHT 3 /* row 0 bottom, col 0 rhs */
240     #define ORIENTATION_BOTLEFT 4 /* row 0 bottom, col 0 lhs */
241     #define ORIENTATION_LEFTTOP 5 /* row 0 lhs, col 0 top */
242     #define ORIENTATION_RIGHTTOP 6 /* row 0 rhs, col 0 top */
243     #define ORIENTATION_RIGHTBOT 7 /* row 0 rhs, col 0 bottom */
244     #define ORIENTATION_LEFTBOT 8 /* row 0 lhs, col 0 bottom */
245     #define TIFFTAG_SAMPLESPERPIXEL 277 /* samples per pixel */
246     #define TIFFTAG_ROWSPERSTRIP 278 /* rows per strip of data */
247     #define TIFFTAG_STRIPBYTECOUNTS 279 /* bytes counts for strips */
248     #define TIFFTAG_MINSAMPLEVALUE 280 /* +minimum sample value */
249     #define TIFFTAG_MAXSAMPLEVALUE 281 /* +maximum sample value */
250     #define TIFFTAG_XRESOLUTION 282 /* pixels/resolution in x */
251     #define TIFFTAG_YRESOLUTION 283 /* pixels/resolution in y */
252     #define TIFFTAG_PLANARCONFIG 284 /* storage organization */
253     #define PLANARCONFIG_CONTIG 1 /* single image plane */
254     #define PLANARCONFIG_SEPARATE 2 /* separate planes of data */
255     #define TIFFTAG_PAGENAME 285 /* page name image is from */
256     #define TIFFTAG_XPOSITION 286 /* x page offset of image lhs */
257     #define TIFFTAG_YPOSITION 287 /* y page offset of image lhs */
258     #define TIFFTAG_FREEOFFSETS 288 /* +byte offset to free block */
259     #define TIFFTAG_FREEBYTECOUNTS 289 /* +sizes of free blocks */
260     #define TIFFTAG_GRAYRESPONSEUNIT 290 /* $gray scale curve accuracy */
261     #define GRAYRESPONSEUNIT_10S 1 /* tenths of a unit */
262     #define GRAYRESPONSEUNIT_100S 2 /* hundredths of a unit */
263     #define GRAYRESPONSEUNIT_1000S 3 /* thousandths of a unit */
264     #define GRAYRESPONSEUNIT_10000S 4 /* ten-thousandths of a unit */
265     #define GRAYRESPONSEUNIT_100000S 5 /* hundred-thousandths */
266     #define TIFFTAG_GRAYRESPONSECURVE 291 /* $gray scale response curve */
267     #define TIFFTAG_GROUP3OPTIONS 292 /* 32 flag bits */
268 greg 3.11 #define TIFFTAG_T4OPTIONS 292 /* TIFF 6.0 proper name alias */
269 greg 3.1 #define GROUP3OPT_2DENCODING 0x1 /* 2-dimensional coding */
270     #define GROUP3OPT_UNCOMPRESSED 0x2 /* data not compressed */
271     #define GROUP3OPT_FILLBITS 0x4 /* fill to byte boundary */
272     #define TIFFTAG_GROUP4OPTIONS 293 /* 32 flag bits */
273 greg 3.11 #define TIFFTAG_T6OPTIONS 293 /* TIFF 6.0 proper name */
274 greg 3.1 #define GROUP4OPT_UNCOMPRESSED 0x2 /* data not compressed */
275     #define TIFFTAG_RESOLUTIONUNIT 296 /* units of resolutions */
276     #define RESUNIT_NONE 1 /* no meaningful units */
277     #define RESUNIT_INCH 2 /* english */
278     #define RESUNIT_CENTIMETER 3 /* metric */
279     #define TIFFTAG_PAGENUMBER 297 /* page numbers of multi-page */
280     #define TIFFTAG_COLORRESPONSEUNIT 300 /* $color curve accuracy */
281     #define COLORRESPONSEUNIT_10S 1 /* tenths of a unit */
282     #define COLORRESPONSEUNIT_100S 2 /* hundredths of a unit */
283     #define COLORRESPONSEUNIT_1000S 3 /* thousandths of a unit */
284     #define COLORRESPONSEUNIT_10000S 4 /* ten-thousandths of a unit */
285     #define COLORRESPONSEUNIT_100000S 5 /* hundred-thousandths */
286     #define TIFFTAG_TRANSFERFUNCTION 301 /* !colorimetry info */
287     #define TIFFTAG_SOFTWARE 305 /* name & release */
288     #define TIFFTAG_DATETIME 306 /* creation date and time */
289     #define TIFFTAG_ARTIST 315 /* creator of image */
290     #define TIFFTAG_HOSTCOMPUTER 316 /* machine where created */
291     #define TIFFTAG_PREDICTOR 317 /* prediction scheme w/ LZW */
292 greg 3.12 #define PREDICTOR_NONE 1 /* no prediction scheme used */
293     #define PREDICTOR_HORIZONTAL 2 /* horizontal differencing */
294     #define PREDICTOR_FLOATINGPOINT 3 /* floating point predictor */
295 greg 3.1 #define TIFFTAG_WHITEPOINT 318 /* image white point */
296     #define TIFFTAG_PRIMARYCHROMATICITIES 319 /* !primary chromaticities */
297     #define TIFFTAG_COLORMAP 320 /* RGB map for pallette image */
298     #define TIFFTAG_HALFTONEHINTS 321 /* !highlight+shadow info */
299 greg 3.12 #define TIFFTAG_TILEWIDTH 322 /* !tile width in pixels */
300     #define TIFFTAG_TILELENGTH 323 /* !tile height in pixels */
301 greg 3.1 #define TIFFTAG_TILEOFFSETS 324 /* !offsets to data tiles */
302     #define TIFFTAG_TILEBYTECOUNTS 325 /* !byte counts for tiles */
303     #define TIFFTAG_BADFAXLINES 326 /* lines w/ wrong pixel count */
304     #define TIFFTAG_CLEANFAXDATA 327 /* regenerated line info */
305     #define CLEANFAXDATA_CLEAN 0 /* no errors detected */
306     #define CLEANFAXDATA_REGENERATED 1 /* receiver regenerated lines */
307     #define CLEANFAXDATA_UNCLEAN 2 /* uncorrected errors exist */
308     #define TIFFTAG_CONSECUTIVEBADFAXLINES 328 /* max consecutive bad lines */
309     #define TIFFTAG_SUBIFD 330 /* subimage descriptors */
310     #define TIFFTAG_INKSET 332 /* !inks in separated image */
311 greg 3.12 #define INKSET_CMYK 1 /* !cyan-magenta-yellow-black color */
312     #define INKSET_MULTIINK 2 /* !multi-ink or hi-fi color */
313 greg 3.1 #define TIFFTAG_INKNAMES 333 /* !ascii names of inks */
314     #define TIFFTAG_NUMBEROFINKS 334 /* !number of inks */
315     #define TIFFTAG_DOTRANGE 336 /* !0% and 100% dot codes */
316     #define TIFFTAG_TARGETPRINTER 337 /* !separation target */
317     #define TIFFTAG_EXTRASAMPLES 338 /* !info about extra samples */
318     #define EXTRASAMPLE_UNSPECIFIED 0 /* !unspecified data */
319     #define EXTRASAMPLE_ASSOCALPHA 1 /* !associated alpha data */
320     #define EXTRASAMPLE_UNASSALPHA 2 /* !unassociated alpha data */
321     #define TIFFTAG_SAMPLEFORMAT 339 /* !data sample format */
322     #define SAMPLEFORMAT_UINT 1 /* !unsigned integer data */
323     #define SAMPLEFORMAT_INT 2 /* !signed integer data */
324     #define SAMPLEFORMAT_IEEEFP 3 /* !IEEE floating point data */
325     #define SAMPLEFORMAT_VOID 4 /* !untyped data */
326     #define SAMPLEFORMAT_COMPLEXINT 5 /* !complex signed int */
327     #define SAMPLEFORMAT_COMPLEXIEEEFP 6 /* !complex ieee floating */
328     #define TIFFTAG_SMINSAMPLEVALUE 340 /* !variable MinSampleValue */
329     #define TIFFTAG_SMAXSAMPLEVALUE 341 /* !variable MaxSampleValue */
330 greg 3.12 #define TIFFTAG_CLIPPATH 343 /* %ClipPath
331     [Adobe TIFF technote 2] */
332     #define TIFFTAG_XCLIPPATHUNITS 344 /* %XClipPathUnits
333     [Adobe TIFF technote 2] */
334     #define TIFFTAG_YCLIPPATHUNITS 345 /* %YClipPathUnits
335     [Adobe TIFF technote 2] */
336     #define TIFFTAG_INDEXED 346 /* %Indexed
337     [Adobe TIFF Technote 3] */
338 greg 3.1 #define TIFFTAG_JPEGTABLES 347 /* %JPEG table stream */
339 greg 3.12 #define TIFFTAG_OPIPROXY 351 /* %OPI Proxy [Adobe TIFF technote] */
340 greg 3.1 /*
341 greg 3.12 * Tags 512-521 are obsoleted by Technical Note #2 which specifies a
342     * revised JPEG-in-TIFF scheme.
343 greg 3.1 */
344     #define TIFFTAG_JPEGPROC 512 /* !JPEG processing algorithm */
345     #define JPEGPROC_BASELINE 1 /* !baseline sequential */
346     #define JPEGPROC_LOSSLESS 14 /* !Huffman coded lossless */
347     #define TIFFTAG_JPEGIFOFFSET 513 /* !pointer to SOI marker */
348     #define TIFFTAG_JPEGIFBYTECOUNT 514 /* !JFIF stream length */
349     #define TIFFTAG_JPEGRESTARTINTERVAL 515 /* !restart interval length */
350     #define TIFFTAG_JPEGLOSSLESSPREDICTORS 517 /* !lossless proc predictor */
351     #define TIFFTAG_JPEGPOINTTRANSFORM 518 /* !lossless point transform */
352     #define TIFFTAG_JPEGQTABLES 519 /* !Q matrice offsets */
353     #define TIFFTAG_JPEGDCTABLES 520 /* !DCT table offsets */
354     #define TIFFTAG_JPEGACTABLES 521 /* !AC coefficient offsets */
355     #define TIFFTAG_YCBCRCOEFFICIENTS 529 /* !RGB -> YCbCr transform */
356     #define TIFFTAG_YCBCRSUBSAMPLING 530 /* !YCbCr subsampling factors */
357     #define TIFFTAG_YCBCRPOSITIONING 531 /* !subsample positioning */
358     #define YCBCRPOSITION_CENTERED 1 /* !as in PostScript Level 2 */
359     #define YCBCRPOSITION_COSITED 2 /* !as in CCIR 601-1 */
360     #define TIFFTAG_REFERENCEBLACKWHITE 532 /* !colorimetry info */
361 greg 3.12 #define TIFFTAG_XMLPACKET 700 /* %XML packet
362     [Adobe XMP Specification,
363     January 2004 */
364     #define TIFFTAG_OPIIMAGEID 32781 /* %OPI ImageID
365     [Adobe TIFF technote] */
366 greg 3.1 /* tags 32952-32956 are private tags registered to Island Graphics */
367     #define TIFFTAG_REFPTS 32953 /* image reference points */
368     #define TIFFTAG_REGIONTACKPOINT 32954 /* region-xform tack point */
369     #define TIFFTAG_REGIONWARPCORNERS 32955 /* warp quadrilateral */
370     #define TIFFTAG_REGIONAFFINE 32956 /* affine transformation mat */
371     /* tags 32995-32999 are private tags registered to SGI */
372     #define TIFFTAG_MATTEING 32995 /* $use ExtraSamples */
373     #define TIFFTAG_DATATYPE 32996 /* $use SampleFormat */
374     #define TIFFTAG_IMAGEDEPTH 32997 /* z depth of image */
375     #define TIFFTAG_TILEDEPTH 32998 /* z depth/data tile */
376     /* tags 33300-33309 are private tags registered to Pixar */
377     /*
378     * TIFFTAG_PIXAR_IMAGEFULLWIDTH and TIFFTAG_PIXAR_IMAGEFULLLENGTH
379     * are set when an image has been cropped out of a larger image.
380     * They reflect the size of the original uncropped image.
381     * The TIFFTAG_XPOSITION and TIFFTAG_YPOSITION can be used
382     * to determine the position of the smaller image in the larger one.
383     */
384     #define TIFFTAG_PIXAR_IMAGEFULLWIDTH 33300 /* full image size in x */
385     #define TIFFTAG_PIXAR_IMAGEFULLLENGTH 33301 /* full image size in y */
386     /* Tags 33302-33306 are used to identify special image modes and data
387     * used by Pixar's texture formats.
388     */
389     #define TIFFTAG_PIXAR_TEXTUREFORMAT 33302 /* texture map format */
390     #define TIFFTAG_PIXAR_WRAPMODES 33303 /* s & t wrap modes */
391     #define TIFFTAG_PIXAR_FOVCOT 33304 /* cotan(fov) for env. maps */
392     #define TIFFTAG_PIXAR_MATRIX_WORLDTOSCREEN 33305
393     #define TIFFTAG_PIXAR_MATRIX_WORLDTOCAMERA 33306
394     /* tag 33405 is a private tag registered to Eastman Kodak */
395     #define TIFFTAG_WRITERSERIALNUMBER 33405 /* device serial number */
396     /* tag 33432 is listed in the 6.0 spec w/ unknown ownership */
397     #define TIFFTAG_COPYRIGHT 33432 /* copyright string */
398     /* IPTC TAG from RichTIFF specifications */
399 greg 3.12 #define TIFFTAG_RICHTIFFIPTC 33723
400     /* 34016-34029 are reserved for ANSI IT8 TIFF/IT <[email protected]) */
401 greg 3.1 #define TIFFTAG_IT8SITE 34016 /* site name */
402     #define TIFFTAG_IT8COLORSEQUENCE 34017 /* color seq. [RGB,CMYK,etc] */
403     #define TIFFTAG_IT8HEADER 34018 /* DDES Header */
404     #define TIFFTAG_IT8RASTERPADDING 34019 /* raster scanline padding */
405     #define TIFFTAG_IT8BITSPERRUNLENGTH 34020 /* # of bits in short run */
406     #define TIFFTAG_IT8BITSPEREXTENDEDRUNLENGTH 34021/* # of bits in long run */
407     #define TIFFTAG_IT8COLORTABLE 34022 /* LW colortable */
408     #define TIFFTAG_IT8IMAGECOLORINDICATOR 34023 /* BP/BL image color switch */
409     #define TIFFTAG_IT8BKGCOLORINDICATOR 34024 /* BP/BL bg color switch */
410     #define TIFFTAG_IT8IMAGECOLORVALUE 34025 /* BP/BL image color value */
411     #define TIFFTAG_IT8BKGCOLORVALUE 34026 /* BP/BL bg color value */
412     #define TIFFTAG_IT8PIXELINTENSITYRANGE 34027 /* MP pixel intensity value */
413     #define TIFFTAG_IT8TRANSPARENCYINDICATOR 34028 /* HC transparency switch */
414     #define TIFFTAG_IT8COLORCHARACTERIZATION 34029 /* color character. table */
415 greg 3.12 #define TIFFTAG_IT8HCUSAGE 34030 /* HC usage indicator */
416     #define TIFFTAG_IT8TRAPINDICATOR 34031 /* Trapping indicator
417     (untrapped=0, trapped=1) */
418     #define TIFFTAG_IT8CMYKEQUIVALENT 34032 /* CMYK color equivalents */
419 greg 3.1 /* tags 34232-34236 are private tags registered to Texas Instruments */
420     #define TIFFTAG_FRAMECOUNT 34232 /* Sequence Frame Count */
421 greg 3.12 /* tag 34377 is private tag registered to Adobe for PhotoShop */
422     #define TIFFTAG_PHOTOSHOP 34377
423     /* tags 34665, 34853 and 40965 are documented in EXIF specification */
424     #define TIFFTAG_EXIFIFD 34665 /* Pointer to EXIF private directory */
425 greg 3.1 /* tag 34750 is a private tag registered to Adobe? */
426     #define TIFFTAG_ICCPROFILE 34675 /* ICC profile data */
427     /* tag 34750 is a private tag registered to Pixel Magic */
428     #define TIFFTAG_JBIGOPTIONS 34750 /* JBIG options */
429 greg 3.12 #define TIFFTAG_GPSIFD 34853 /* Pointer to GPS private directory */
430 greg 3.1 /* tags 34908-34914 are private tags registered to SGI */
431     #define TIFFTAG_FAXRECVPARAMS 34908 /* encoded Class 2 ses. parms */
432     #define TIFFTAG_FAXSUBADDRESS 34909 /* received SubAddr string */
433     #define TIFFTAG_FAXRECVTIME 34910 /* receive time (secs) */
434 greg 3.12 #define TIFFTAG_FAXDCS 34911 /* encoded fax ses. params, Table 2/T.30 */
435 greg 3.11 /* tags 37439-37443 are registered to SGI <[email protected]> */
436     #define TIFFTAG_STONITS 37439 /* Sample value to Nits */
437 greg 3.1 /* tag 34929 is a private tag registered to FedEx */
438     #define TIFFTAG_FEDEX_EDR 34929 /* unknown use */
439 greg 3.12 #define TIFFTAG_INTEROPERABILITYIFD 40965 /* Pointer to Interoperability private directory */
440     /* Adobe Digital Negative (DNG) format tags */
441     #define TIFFTAG_DNGVERSION 50706 /* &DNG version number */
442     #define TIFFTAG_DNGBACKWARDVERSION 50707 /* &DNG compatibility version */
443     #define TIFFTAG_UNIQUECAMERAMODEL 50708 /* &name for the camera model */
444     #define TIFFTAG_LOCALIZEDCAMERAMODEL 50709 /* &localized camera model
445     name */
446     #define TIFFTAG_CFAPLANECOLOR 50710 /* &CFAPattern->LinearRaw space
447     mapping */
448     #define TIFFTAG_CFALAYOUT 50711 /* &spatial layout of the CFA */
449     #define TIFFTAG_LINEARIZATIONTABLE 50712 /* &lookup table description */
450     #define TIFFTAG_BLACKLEVELREPEATDIM 50713 /* &repeat pattern size for
451     the BlackLevel tag */
452     #define TIFFTAG_BLACKLEVEL 50714 /* &zero light encoding level */
453     #define TIFFTAG_BLACKLEVELDELTAH 50715 /* &zero light encoding level
454     differences (columns) */
455     #define TIFFTAG_BLACKLEVELDELTAV 50716 /* &zero light encoding level
456     differences (rows) */
457     #define TIFFTAG_WHITELEVEL 50717 /* &fully saturated encoding
458     level */
459     #define TIFFTAG_DEFAULTSCALE 50718 /* &default scale factors */
460     #define TIFFTAG_DEFAULTCROPORIGIN 50719 /* &origin of the final image
461     area */
462     #define TIFFTAG_DEFAULTCROPSIZE 50720 /* &size of the final image
463     area */
464     #define TIFFTAG_COLORMATRIX1 50721 /* &XYZ->reference color space
465     transformation matrix 1 */
466     #define TIFFTAG_COLORMATRIX2 50722 /* &XYZ->reference color space
467     transformation matrix 2 */
468     #define TIFFTAG_CAMERACALIBRATION1 50723 /* &calibration matrix 1 */
469     #define TIFFTAG_CAMERACALIBRATION2 50724 /* &calibration matrix 2 */
470     #define TIFFTAG_REDUCTIONMATRIX1 50725 /* &dimensionality reduction
471     matrix 1 */
472     #define TIFFTAG_REDUCTIONMATRIX2 50726 /* &dimensionality reduction
473     matrix 2 */
474     #define TIFFTAG_ANALOGBALANCE 50727 /* &gain applied the stored raw
475     values*/
476     #define TIFFTAG_ASSHOTNEUTRAL 50728 /* &selected white balance in
477     linear reference space */
478     #define TIFFTAG_ASSHOTWHITEXY 50729 /* &selected white balance in
479     x-y chromaticity
480     coordinates */
481     #define TIFFTAG_BASELINEEXPOSURE 50730 /* &how much to move the zero
482     point */
483     #define TIFFTAG_BASELINENOISE 50731 /* &relative noise level */
484     #define TIFFTAG_BASELINESHARPNESS 50732 /* &relative amount of
485     sharpening */
486     #define TIFFTAG_BAYERGREENSPLIT 50733 /* &how closely the values of
487     the green pixels in the
488     blue/green rows track the
489     values of the green pixels
490     in the red/green rows */
491     #define TIFFTAG_LINEARRESPONSELIMIT 50734 /* &non-linear encoding range */
492     #define TIFFTAG_CAMERASERIALNUMBER 50735 /* &camera's serial number */
493     #define TIFFTAG_LENSINFO 50736 /* info about the lens */
494     #define TIFFTAG_CHROMABLURRADIUS 50737 /* &chroma blur radius */
495     #define TIFFTAG_ANTIALIASSTRENGTH 50738 /* &relative strength of the
496     camera's anti-alias filter */
497     #define TIFFTAG_SHADOWSCALE 50739 /* &used by Adobe Camera Raw */
498     #define TIFFTAG_DNGPRIVATEDATA 50740 /* &manufacturer's private data */
499     #define TIFFTAG_MAKERNOTESAFETY 50741 /* &whether the EXIF MakerNote
500     tag is safe to preserve
501     along with the rest of the
502     EXIF data */
503     #define TIFFTAG_CALIBRATIONILLUMINANT1 50778 /* &illuminant 1 */
504     #define TIFFTAG_CALIBRATIONILLUMINANT2 50779 /* &illuminant 2 */
505     #define TIFFTAG_BESTQUALITYSCALE 50780 /* &best quality multiplier */
506     #define TIFFTAG_RAWDATAUNIQUEID 50781 /* &unique identifier for
507     the raw image data */
508     #define TIFFTAG_ORIGINALRAWFILENAME 50827 /* &file name of the original
509     raw file */
510     #define TIFFTAG_ORIGINALRAWFILEDATA 50828 /* &contents of the original
511     raw file */
512     #define TIFFTAG_ACTIVEAREA 50829 /* &active (non-masked) pixels
513     of the sensor */
514     #define TIFFTAG_MASKEDAREAS 50830 /* &list of coordinates
515     of fully masked pixels */
516     #define TIFFTAG_ASSHOTICCPROFILE 50831 /* &these two tags used to */
517     #define TIFFTAG_ASSHOTPREPROFILEMATRIX 50832 /* map cameras's color space
518     into ICC profile space */
519     #define TIFFTAG_CURRENTICCPROFILE 50833 /* & */
520     #define TIFFTAG_CURRENTPREPROFILEMATRIX 50834 /* & */
521 greg 3.1 /* tag 65535 is an undefined tag used by Eastman Kodak */
522     #define TIFFTAG_DCSHUESHIFTVALUES 65535 /* hue shift correction data */
523
524     /*
525 greg 3.12 * The following are ``pseudo tags'' that can be used to control
526     * codec-specific functionality. These tags are not written to file.
527     * Note that these values start at 0xffff+1 so that they'll never
528     * collide with Aldus-assigned tags.
529 greg 3.1 *
530 greg 3.12 * If you want your private pseudo tags ``registered'' (i.e. added to
531     * this file), please post a bug report via the tracking system at
532     * http://www.remotesensing.org/libtiff/bugs.html with the appropriate
533     * C definitions to add.
534 greg 3.1 */
535     #define TIFFTAG_FAXMODE 65536 /* Group 3/4 format control */
536     #define FAXMODE_CLASSIC 0x0000 /* default, include RTC */
537     #define FAXMODE_NORTC 0x0001 /* no RTC at end of data */
538     #define FAXMODE_NOEOL 0x0002 /* no EOL code at end of row */
539     #define FAXMODE_BYTEALIGN 0x0004 /* byte align row */
540     #define FAXMODE_WORDALIGN 0x0008 /* word align row */
541     #define FAXMODE_CLASSF FAXMODE_NORTC /* TIFF Class F */
542     #define TIFFTAG_JPEGQUALITY 65537 /* Compression quality level */
543     /* Note: quality level is on the IJG 0-100 scale. Default value is 75 */
544     #define TIFFTAG_JPEGCOLORMODE 65538 /* Auto RGB<=>YCbCr convert? */
545     #define JPEGCOLORMODE_RAW 0x0000 /* no conversion (default) */
546     #define JPEGCOLORMODE_RGB 0x0001 /* do auto conversion */
547     #define TIFFTAG_JPEGTABLESMODE 65539 /* What to put in JPEGTables */
548     #define JPEGTABLESMODE_QUANT 0x0001 /* include quantization tbls */
549     #define JPEGTABLESMODE_HUFF 0x0002 /* include Huffman tbls */
550     /* Note: default is JPEGTABLESMODE_QUANT | JPEGTABLESMODE_HUFF */
551     #define TIFFTAG_FAXFILLFUNC 65540 /* G3/G4 fill function */
552     #define TIFFTAG_PIXARLOGDATAFMT 65549 /* PixarLogCodec I/O data sz */
553     #define PIXARLOGDATAFMT_8BIT 0 /* regular u_char samples */
554     #define PIXARLOGDATAFMT_8BITABGR 1 /* ABGR-order u_chars */
555     #define PIXARLOGDATAFMT_11BITLOG 2 /* 11-bit log-encoded (raw) */
556     #define PIXARLOGDATAFMT_12BITPICIO 3 /* as per PICIO (1.0==2048) */
557     #define PIXARLOGDATAFMT_16BIT 4 /* signed short samples */
558     #define PIXARLOGDATAFMT_FLOAT 5 /* IEEE float samples */
559     /* 65550-65556 are allocated to Oceana Matrix <[email protected]> */
560     #define TIFFTAG_DCSIMAGERTYPE 65550 /* imager model & filter */
561     #define DCSIMAGERMODEL_M3 0 /* M3 chip (1280 x 1024) */
562     #define DCSIMAGERMODEL_M5 1 /* M5 chip (1536 x 1024) */
563     #define DCSIMAGERMODEL_M6 2 /* M6 chip (3072 x 2048) */
564     #define DCSIMAGERFILTER_IR 0 /* infrared filter */
565     #define DCSIMAGERFILTER_MONO 1 /* monochrome filter */
566     #define DCSIMAGERFILTER_CFA 2 /* color filter array */
567     #define DCSIMAGERFILTER_OTHER 3 /* other filter */
568     #define TIFFTAG_DCSINTERPMODE 65551 /* interpolation mode */
569     #define DCSINTERPMODE_NORMAL 0x0 /* whole image, default */
570     #define DCSINTERPMODE_PREVIEW 0x1 /* preview of image (384x256) */
571     #define TIFFTAG_DCSBALANCEARRAY 65552 /* color balance values */
572     #define TIFFTAG_DCSCORRECTMATRIX 65553 /* color correction values */
573     #define TIFFTAG_DCSGAMMA 65554 /* gamma value */
574     #define TIFFTAG_DCSTOESHOULDERPTS 65555 /* toe & shoulder points */
575     #define TIFFTAG_DCSCALIBRATIONFD 65556 /* calibration file desc */
576     /* Note: quality level is on the ZLIB 1-9 scale. Default value is -1 */
577     #define TIFFTAG_ZIPQUALITY 65557 /* compression quality level */
578     #define TIFFTAG_PIXARLOGQUALITY 65558 /* PixarLog uses same scale */
579     /* 65559 is allocated to Oceana Matrix <[email protected]> */
580     #define TIFFTAG_DCSCLIPRECTANGLE 65559 /* area of image to acquire */
581     #define TIFFTAG_SGILOGDATAFMT 65560 /* SGILog user data format */
582     #define SGILOGDATAFMT_FLOAT 0 /* IEEE float samples */
583     #define SGILOGDATAFMT_16BIT 1 /* 16-bit samples */
584     #define SGILOGDATAFMT_RAW 2 /* uninterpreted data */
585     #define SGILOGDATAFMT_8BIT 3 /* 8-bit RGB monitor values */
586 greg 3.11 #define TIFFTAG_SGILOGENCODE 65561 /* SGILog data encoding control*/
587     #define SGILOGENCODE_NODITHER 0 /* do not dither encoded values*/
588     #define SGILOGENCODE_RANDITHER 1 /* randomly dither encd values */
589 greg 3.1 #endif /* _TIFF_ */
590 greg 3.12
591     /* vim: set ts=8 sts=8 sw=8 noet: */
