--- ray/src/common/tiff.h 2003/06/19 23:14:31 3.7 +++ ray/src/common/tiff.h 2005/09/23 19:04:52 3.14 @@ -1,4 +1,4 @@ -/* $Header: /usr/local/cvs/radiance/ray/src/common/tiff.h,v 3.7 2003/06/19 23:14:31 greg Exp $ */ +/* $Id: tiff.h,v 3.14 2005/09/23 19:04:52 greg Exp $ */ /* * Copyright (c) 1988-1997 Sam Leffler @@ -36,14 +36,36 @@ * Suite 200 * Seattle, WA 98104 * 206-622-5500 + * + * (http://partners.adobe.com/asn/developer/PDFS/TN/TIFF6.pdf) + * + * For Big TIFF design notes see the following link + * http://gdal.maptools.org/twiki/bin/view/libtiff/BigTIFFDesign */ -#define TIFF_VERSION 42 +#define TIFF_VERSION 42 +#define TIFF_BIGTIFF_VERSION 43 #define TIFF_BIGENDIAN 0x4d4d #define TIFF_LITTLEENDIAN 0x4949 -#ifndef _TIFF_DATA_TYPEDEFS_ +/* + * The so called TIFF types conflict with definitions from inttypes.h + * included from sys/types.h on AIX (at least using VisualAge compiler). + * We try to work around this by detecting this case. Defining + * _TIFF_DATA_TYPEDEFS_ short circuits the later definitions in tiff.h, and + * we will in the holes not provided for by inttypes.h. + * + * See http://bugzilla.remotesensing.org/show_bug.cgi?id=39 + */ +#if defined(_H_INTTYPES) && defined(_ALL_SOURCE) && defined(USING_VISUALAGE) + #define _TIFF_DATA_TYPEDEFS_ +typedef unsigned char uint8; +typedef unsigned short uint16; +typedef unsigned int uint32; + +#endif + /* * Intrinsic data types required by the file format: * @@ -52,24 +74,24 @@ * 32-bit quantities int32/uint32 * strings unsigned char* */ -#ifdef __STDC__ +#ifndef _TIFF_DATA_TYPEDEFS_ +#define _TIFF_DATA_TYPEDEFS_ + typedef signed char int8; /* NB: non-ANSI compilers may not grok */ -#else -typedef char int8; -#endif typedef unsigned char uint8; typedef short int16; typedef unsigned short uint16; /* sizeof (uint16) must == 2 */ -#if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) +#if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) || defined(__LP64__) || defined(__arch64__) || defined(__sparcv9) typedef int int32; typedef unsigned int uint32; /* sizeof (uint32) must == 4 */ #else typedef long int32; typedef unsigned long uint32; /* sizeof (uint32) must == 4 */ #endif + #endif /* _TIFF_DATA_TYPEDEFS_ */ -/* For TIFFReassignTagToIgnore */ +/* For TIFFReassignTagToIgnore */ enum TIFFIgnoreSense /* IGNORE tag table */ { TIS_STORE, @@ -77,30 +99,35 @@ enum TIFFIgnoreSense /* IGNORE tag table */ TIS_EMPTY }; +/* + * TIFF header. + */ typedef struct { uint16 tiff_magic; /* magic number (defines byte order) */ +#define TIFF_MAGIC_SIZE 2 uint16 tiff_version; /* TIFF version number */ +#define TIFF_VERSION_SIZE 2 uint32 tiff_diroff; /* byte offset to first directory */ +#define TIFF_DIROFFSET_SIZE 4 } TIFFHeader; + /* - * TIFF Image File Directories are comprised of - * a table of field descriptors of the form shown - * below. The table is sorted in ascending order - * by tag. The values associated with each entry - * are disjoint and may appear anywhere in the file - * (so long as they are placed on a word boundary). + * TIFF Image File Directories are comprised of a table of field + * descriptors of the form shown below. The table is sorted in + * ascending order by tag. The values associated with each entry are + * disjoint and may appear anywhere in the file (so long as they are + * placed on a word boundary). * - * If the value is 4 bytes or less, then it is placed - * in the offset field to save space. If the value - * is less than 4 bytes, it is left-justified in the - * offset field. + * If the value is 4 bytes or less, then it is placed in the offset + * field to save space. If the value is less than 4 bytes, it is + * left-justified in the offset field. */ typedef struct { - uint16 tdir_tag; /* see below */ - uint16 tdir_type; /* data type; see below */ - uint32 tdir_count; /* number of items; length in spec */ - uint32 tdir_offset; /* byte offset to field data */ + uint16 tdir_tag; /* see below */ + uint16 tdir_type; /* data type; see below */ + uint32 tdir_count; /* number of items; length in spec */ + uint32 tdir_offset; /* byte offset to field data */ } TIFFDirEntry; /* @@ -109,6 +136,7 @@ typedef struct { * - items marked with a ! are introduced in revision 6.0. * - items marked with a % are introduced post revision 6.0. * - items marked with a $ are obsoleted by revision 6.0. + * - items marked with a & are introduced by Adobe DNG specification. */ /* @@ -129,7 +157,8 @@ typedef enum { TIFF_SLONG = 9, /* !32-bit signed integer */ TIFF_SRATIONAL = 10, /* !64-bit signed fraction */ TIFF_FLOAT = 11, /* !32-bit IEEE floating point */ - TIFF_DOUBLE = 12 /* !64-bit IEEE floating point */ + TIFF_DOUBLE = 12, /* !64-bit IEEE floating point */ + TIFF_IFD = 13 /* %32-bit unsigned integer (offset) */ } TIFFDataType; /* @@ -150,7 +179,9 @@ typedef enum { #define COMPRESSION_NONE 1 /* dump mode */ #define COMPRESSION_CCITTRLE 2 /* CCITT modified Huffman RLE */ #define COMPRESSION_CCITTFAX3 3 /* CCITT Group 3 fax encoding */ +#define COMPRESSION_CCITT_T4 3 /* CCITT T.4 (TIFF 6 name) */ #define COMPRESSION_CCITTFAX4 4 /* CCITT Group 4 fax encoding */ +#define COMPRESSION_CCITT_T6 4 /* CCITT T.6 (TIFF 6 name) */ #define COMPRESSION_LZW 5 /* Lempel-Ziv & Welch */ #define COMPRESSION_OJPEG 6 /* !6.0 JPEG */ #define COMPRESSION_JPEG 7 /* %JPEG DCT compression */ @@ -158,7 +189,7 @@ typedef enum { #define COMPRESSION_CCITTRLEW 32771 /* #1 w/ word alignment */ #define COMPRESSION_PACKBITS 32773 /* Macintosh RLE */ #define COMPRESSION_THUNDERSCAN 32809 /* ThunderScan RLE */ -/* codes 32895-32898 are reserved for ANSI IT8 TIFF/IT */ #define COMPRESSION_DCS 32947 /* Kodak DCS encoding */ #define COMPRESSION_JBIG 34661 /* ISO JBIG */ #define COMPRESSION_SGILOG 34676 /* SGI Log Luminance RLE */ #define COMPRESSION_SGILOG24 34677 /* SGI Log 24-bit packed */ +#define COMPRESSION_JP2000 34712 /* Leadtools JPEG2000 */ #define TIFFTAG_PHOTOMETRIC 262 /* photometric interpretation */ #define PHOTOMETRIC_MINISWHITE 0 /* min value is white */ #define PHOTOMETRIC_MINISBLACK 1 /* min value is black */ @@ -182,6 +215,8 @@ typedef enum { #define PHOTOMETRIC_SEPARATED 5 /* !color separations */ #define PHOTOMETRIC_YCBCR 6 /* !CCIR 601 */ #define PHOTOMETRIC_CIELAB 8 /* !1976 CIE L*a*b* */ +#define PHOTOMETRIC_ICCLAB 9 /* ICC L*a*b* [Adobe TIFF Technote 4] */ +#define PHOTOMETRIC_ITULAB 10 /* ITU L*a*b* */ #define PHOTOMETRIC_LOGL 32844 /* CIE Log2(L) */ #define PHOTOMETRIC_LOGLUV 32845 /* CIE Log2(L) (u',v') */ #define TIFFTAG_THRESHHOLDING 263 /* +thresholding used on data */ @@ -230,10 +265,12 @@ typedef enum { #define GRAYRESPONSEUNIT_100000S 5 /* hundred-thousandths */ #define TIFFTAG_GRAYRESPONSECURVE 291 /* $gray scale response curve */ #define TIFFTAG_GROUP3OPTIONS 292 /* 32 flag bits */ +#define TIFFTAG_T4OPTIONS 292 /* TIFF 6.0 proper name alias */ #define GROUP3OPT_2DENCODING 0x1 /* 2-dimensional coding */ #define GROUP3OPT_UNCOMPRESSED 0x2 /* data not compressed */ #define GROUP3OPT_FILLBITS 0x4 /* fill to byte boundary */ #define TIFFTAG_GROUP4OPTIONS 293 /* 32 flag bits */ +#define TIFFTAG_T6OPTIONS 293 /* TIFF 6.0 proper name */ #define GROUP4OPT_UNCOMPRESSED 0x2 /* data not compressed */ #define TIFFTAG_RESOLUTIONUNIT 296 /* units of resolutions */ #define RESUNIT_NONE 1 /* no meaningful units */ @@ -252,12 +289,15 @@ typedef enum { #define TIFFTAG_ARTIST 315 /* creator of image */ #define TIFFTAG_HOSTCOMPUTER 316 /* machine where created */ #define TIFFTAG_PREDICTOR 317 /* prediction scheme w/ LZW */ +#define PREDICTOR_NONE 1 /* no prediction scheme used */ +#define PREDICTOR_HORIZONTAL 2 /* horizontal differencing */ +#define PREDICTOR_FLOATINGPOINT 3 /* floating point predictor */ #define TIFFTAG_WHITEPOINT 318 /* image white point */ #define TIFFTAG_PRIMARYCHROMATICITIES 319 /* !primary chromaticities */ #define TIFFTAG_COLORMAP 320 /* RGB map for pallette image */ #define TIFFTAG_HALFTONEHINTS 321 /* !highlight+shadow info */ -#define TIFFTAG_TILEWIDTH 322 /* !rows/data tile */ -#define TIFFTAG_TILELENGTH 323 /* !cols/data tile */ +#define TIFFTAG_TILEWIDTH 322 /* !tile width in pixels */ +#define TIFFTAG_TILELENGTH 323 /* !tile height in pixels */ #define TIFFTAG_TILEOFFSETS 324 /* !offsets to data tiles */ #define TIFFTAG_TILEBYTECOUNTS 325 /* !byte counts for tiles */ #define TIFFTAG_BADFAXLINES 326 /* lines w/ wrong pixel count */ @@ -268,7 +308,8 @@ typedef enum { #define TIFFTAG_CONSECUTIVEBADFAXLINES 328 /* max consecutive bad lines */ #define TIFFTAG_SUBIFD 330 /* subimage descriptors */ #define TIFFTAG_INKSET 332 /* !inks in separated image */ -#define INKSET_CMYK 1 /* !cyan-magenta-yellow-black */ +#define INKSET_CMYK 1 /* !cyan-magenta-yellow-black color */ +#define INKSET_MULTIINK 2 /* !multi-ink or hi-fi color */ #define TIFFTAG_INKNAMES 333 /* !ascii names of inks */ #define TIFFTAG_NUMBEROFINKS 334 /* !number of inks */ #define TIFFTAG_DOTRANGE 336 /* !0% and 100% dot codes */ @@ -286,10 +327,19 @@ typedef enum { #define SAMPLEFORMAT_COMPLEXIEEEFP 6 /* !complex ieee floating */ #define TIFFTAG_SMINSAMPLEVALUE 340 /* !variable MinSampleValue */ #define TIFFTAG_SMAXSAMPLEVALUE 341 /* !variable MaxSampleValue */ +#define TIFFTAG_CLIPPATH 343 /* %ClipPath + [Adobe TIFF technote 2] */ +#define TIFFTAG_XCLIPPATHUNITS 344 /* %XClipPathUnits + [Adobe TIFF technote 2] */ +#define TIFFTAG_YCLIPPATHUNITS 345 /* %YClipPathUnits + [Adobe TIFF technote 2] */ +#define TIFFTAG_INDEXED 346 /* %Indexed + [Adobe TIFF Technote 3] */ #define TIFFTAG_JPEGTABLES 347 /* %JPEG table stream */ +#define TIFFTAG_OPIPROXY 351 /* %OPI Proxy [Adobe TIFF technote] */ /* - * Tags 512-521 are obsoleted by Technical Note #2 - * which specifies a revised JPEG-in-TIFF scheme. + * Tags 512-521 are obsoleted by Technical Note #2 which specifies a + * revised JPEG-in-TIFF scheme. */ #define TIFFTAG_JPEGPROC 512 /* !JPEG processing algorithm */ #define JPEGPROC_BASELINE 1 /* !baseline sequential */ @@ -308,6 +358,11 @@ typedef enum { #define YCBCRPOSITION_CENTERED 1 /* !as in PostScript Level 2 */ #define YCBCRPOSITION_COSITED 2 /* !as in CCIR 601-1 */ #define TIFFTAG_REFERENCEBLACKWHITE 532 /* !colorimetry info */ +#define TIFFTAG_XMLPACKET 700 /* %XML packet + [Adobe XMP Specification, + January 2004 */ +#define TIFFTAG_OPIIMAGEID 32781 /* %OPI ImageID + [Adobe TIFF technote] */ /* tags 32952-32956 are private tags registered to Island Graphics */ #define TIFFTAG_REFPTS 32953 /* image reference points */ #define TIFFTAG_REGIONTACKPOINT 32954 /* region-xform tack point */ @@ -341,8 +396,8 @@ typedef enum { /* tag 33432 is listed in the 6.0 spec w/ unknown ownership */ #define TIFFTAG_COPYRIGHT 33432 /* copyright string */ /* IPTC TAG from RichTIFF specifications */ -#define TIFFTAG_RICHTIFFIPTC 33723 -/* 34016-34029 are reserved for ANSI IT8 TIFF/IT */ #define TIFFTAG_STONITS 37439 /* Sample value to Nits */ +/* tag 34929 is a private tag registered to FedEx */ +#define TIFFTAG_FEDEX_EDR 34929 /* unknown use */ +#define TIFFTAG_INTEROPERABILITYIFD 40965 /* Pointer to Interoperability private directory */ +/* Adobe Digital Negative (DNG) format tags */ +#define TIFFTAG_DNGVERSION 50706 /* &DNG version number */ +#define TIFFTAG_DNGBACKWARDVERSION 50707 /* &DNG compatibility version */ +#define TIFFTAG_UNIQUECAMERAMODEL 50708 /* &name for the camera model */ +#define TIFFTAG_LOCALIZEDCAMERAMODEL 50709 /* &localized camera model + name */ +#define TIFFTAG_CFAPLANECOLOR 50710 /* &CFAPattern->LinearRaw space + mapping */ +#define TIFFTAG_CFALAYOUT 50711 /* &spatial layout of the CFA */ +#define TIFFTAG_LINEARIZATIONTABLE 50712 /* &lookup table description */ +#define TIFFTAG_BLACKLEVELREPEATDIM 50713 /* &repeat pattern size for + the BlackLevel tag */ +#define TIFFTAG_BLACKLEVEL 50714 /* &zero light encoding level */ +#define TIFFTAG_BLACKLEVELDELTAH 50715 /* &zero light encoding level + differences (columns) */ +#define TIFFTAG_BLACKLEVELDELTAV 50716 /* &zero light encoding level + differences (rows) */ +#define TIFFTAG_WHITELEVEL 50717 /* &fully saturated encoding + level */ +#define TIFFTAG_DEFAULTSCALE 50718 /* &default scale factors */ +#define TIFFTAG_DEFAULTCROPORIGIN 50719 /* &origin of the final image + area */ +#define TIFFTAG_DEFAULTCROPSIZE 50720 /* &size of the final image + area */ +#define TIFFTAG_COLORMATRIX1 50721 /* &XYZ->reference color space + transformation matrix 1 */ +#define TIFFTAG_COLORMATRIX2 50722 /* &XYZ->reference color space + transformation matrix 2 */ +#define TIFFTAG_CAMERACALIBRATION1 50723 /* &calibration matrix 1 */ +#define TIFFTAG_CAMERACALIBRATION2 50724 /* &calibration matrix 2 */ +#define TIFFTAG_REDUCTIONMATRIX1 50725 /* &dimensionality reduction + matrix 1 */ +#define TIFFTAG_REDUCTIONMATRIX2 50726 /* &dimensionality reduction + matrix 2 */ +#define TIFFTAG_ANALOGBALANCE 50727 /* &gain applied the stored raw + values*/ +#define TIFFTAG_ASSHOTNEUTRAL 50728 /* &selected white balance in + linear reference space */ +#define TIFFTAG_ASSHOTWHITEXY 50729 /* &selected white balance in + x-y chromaticity + coordinates */ +#define TIFFTAG_BASELINEEXPOSURE 50730 /* &how much to move the zero + point */ +#define TIFFTAG_BASELINENOISE 50731 /* &relative noise level */ +#define TIFFTAG_BASELINESHARPNESS 50732 /* &relative amount of + sharpening */ +#define TIFFTAG_BAYERGREENSPLIT 50733 /* &how closely the values of + the green pixels in the + blue/green rows track the + values of the green pixels + in the red/green rows */ +#define TIFFTAG_LINEARRESPONSELIMIT 50734 /* &non-linear encoding range */ +#define TIFFTAG_CAMERASERIALNUMBER 50735 /* &camera's serial number */ +#define TIFFTAG_LENSINFO 50736 /* info about the lens */ +#define TIFFTAG_CHROMABLURRADIUS 50737 /* &chroma blur radius */ +#define TIFFTAG_ANTIALIASSTRENGTH 50738 /* &relative strength of the + camera's anti-alias filter */ +#define TIFFTAG_SHADOWSCALE 50739 /* &used by Adobe Camera Raw */ +#define TIFFTAG_DNGPRIVATEDATA 50740 /* &manufacturer's private data */ +#define TIFFTAG_MAKERNOTESAFETY 50741 /* &whether the EXIF MakerNote + tag is safe to preserve + along with the rest of the + EXIF data */ +#define TIFFTAG_CALIBRATIONILLUMINANT1 50778 /* &illuminant 1 */ +#define TIFFTAG_CALIBRATIONILLUMINANT2 50779 /* &illuminant 2 */ +#define TIFFTAG_BESTQUALITYSCALE 50780 /* &best quality multiplier */ +#define TIFFTAG_RAWDATAUNIQUEID 50781 /* &unique identifier for + the raw image data */ +#define TIFFTAG_ORIGINALRAWFILENAME 50827 /* &file name of the original + raw file */ +#define TIFFTAG_ORIGINALRAWFILEDATA 50828 /* &contents of the original + raw file */ +#define TIFFTAG_ACTIVEAREA 50829 /* &active (non-masked) pixels + of the sensor */ +#define TIFFTAG_MASKEDAREAS 50830 /* &list of coordinates + of fully masked pixels */ +#define TIFFTAG_ASSHOTICCPROFILE 50831 /* &these two tags used to */ +#define TIFFTAG_ASSHOTPREPROFILEMATRIX 50832 /* map cameras's color space + into ICC profile space */ +#define TIFFTAG_CURRENTICCPROFILE 50833 /* & */ +#define TIFFTAG_CURRENTPREPROFILEMATRIX 50834 /* & */ /* tag 65535 is an undefined tag used by Eastman Kodak */ #define TIFFTAG_DCSHUESHIFTVALUES 65535 /* hue shift correction data */ /* - * The following are ``pseudo tags'' that can be - * used to control codec-specific functionality. - * These tags are not written to file. Note that - * these values start at 0xffff+1 so that they'll - * never collide with Aldus-assigned tags. + * The following are ``pseudo tags'' that can be used to control + * codec-specific functionality. These tags are not written to file. + * Note that these values start at 0xffff+1 so that they'll never + * collide with Aldus-assigned tags. * - * If you want your private pseudo tags ``registered'' - * (i.e. added to this file), send mail to sam@sgi.com - * with the appropriate C definitions to add. + * If you want your private pseudo tags ``registered'' (i.e. added to + * this file), please post a bug report via the tracking system at + * http://www.remotesensing.org/libtiff/bugs.html with the appropriate + * C definitions to add. */ #define TIFFTAG_FAXMODE 65536 /* Group 3/4 format control */ #define FAXMODE_CLASSIC 0x0000 /* default, include RTC */ @@ -438,7 +583,9 @@ typedef enum { #define SGILOGDATAFMT_16BIT 1 /* 16-bit samples */ #define SGILOGDATAFMT_RAW 2 /* uninterpreted data */ #define SGILOGDATAFMT_8BIT 3 /* 8-bit RGB monitor values */ -#define TIFFTAG_SGILOGENCODE 65561 /* SGILog data encoding control */ -#define SGILOGENCODE_NODITHER 0 /* do not dither encoded values */ -#define SGILOGENCODE_RANDITHER 1 /* randomly dither encoded values */ +#define TIFFTAG_SGILOGENCODE 65561 /* SGILog data encoding control*/ +#define SGILOGENCODE_NODITHER 0 /* do not dither encoded values*/ +#define SGILOGENCODE_RANDITHER 1 /* randomly dither encd values */ #endif /* _TIFF_ */ + +/* vim: set ts=8 sts=8 sw=8 noet: */
