root/radiance/ray/src/common/tiff.h
Revision: 3.13
Committed: Sun Jul 24 19:53:07 2005 UTC (20 years ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
Changes since 3.12: +2 -1 lines
1 /* $Id: tiff.h,v 1.37 2005/06/23 11:01:55 dron Exp $ */
2
3 /*
4 * Copyright (c) 1988-1997 Sam Leffler
5 * Copyright (c) 1991-1997 Silicon Graphics, Inc.
6 *
7 * Permission to use, copy, modify, distribute, and sell this software and
8 * its documentation for any purpose is hereby granted without fee, provided
9 * that (i) the above copyright notices and this permission notice appear in
10 * all copies of the software and related documentation, and (ii) the names of
11 * Sam Leffler and Silicon Graphics may not be used in any advertising or
12 * publicity relating to the software without the specific, prior written
13 * permission of Sam Leffler and Silicon Graphics.
14 *
15 * THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
16 * EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
17 * WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
18 *
19 * IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
20 * ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
21 * OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
22 * WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
23 * LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
24 * OF THIS SOFTWARE.
25 */
26
27 #ifndef _TIFF_
28 #define _TIFF_
29 /*
30 * Tag Image File Format (TIFF)
31 *
32 * Based on Rev 6.0 from:
33 * Developer's Desk
34 * Aldus Corporation
35 * 411 First Ave. South
36 * Suite 200
37 * Seattle, WA 98104
38 * 206-622-5500
39 *
40 * (http://partners.adobe.com/asn/developer/PDFS/TN/TIFF6.pdf)
41 *
42 * For Big TIFF design notes see the following link
43 * http://gdal.maptools.org/twiki/bin/view/libtiff/BigTIFFDesign
44 */
45 #define TIFF_VERSION 42
46 #define TIFF_BIGTIFF_VERSION 43
47
48 #define TIFF_BIGENDIAN 0x4d4d
49 #define TIFF_LITTLEENDIAN 0x4949
50
51 /*
52 * The so called TIFF types conflict with definitions from inttypes.h
53 * included from sys/types.h on AIX (at least using VisualAge compiler).
54 * We try to work around this by detecting this case. Defining
55 * _TIFF_DATA_TYPEDEFS_ short circuits the later definitions in tiff.h, and
56 * we will in the holes not provided for by inttypes.h.
57 *
58 * See http://bugzilla.remotesensing.org/show_bug.cgi?id=39
59 */
60 #if defined(_H_INTTYPES) && defined(_ALL_SOURCE) && defined(USING_VISUALAGE)
61
62 #define _TIFF_DATA_TYPEDEFS_
63 typedef unsigned char uint8;
64 typedef unsigned short uint16;
65 typedef unsigned int uint32;
66
67 #endif
68
69 /*
70 * Intrinsic data types required by the file format:
71 *
72 * 8-bit quantities int8/uint8
73 * 16-bit quantities int16/uint16
74 * 32-bit quantities int32/uint32
75 * strings unsigned char*
76 */
77 #ifndef _TIFF_DATA_TYPEDEFS_
78 #define _TIFF_DATA_TYPEDEFS_
79
80 typedef signed char int8; /* NB: non-ANSI compilers may not grok */
81 typedef unsigned char uint8;
82 typedef short int16;
83 typedef unsigned short uint16; /* sizeof (uint16) must == 2 */
84 #if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) || defined(__LP64__) || defined(__arch64__) || defined(__sparcv9)
85 typedef int int32;
86 typedef unsigned int uint32; /* sizeof (uint32) must == 4 */
87 #else
88 typedef long int32;
89 typedef unsigned long uint32; /* sizeof (uint32) must == 4 */
90 #endif
91
92 #endif /* _TIFF_DATA_TYPEDEFS_ */
93
94 /* For TIFFReassignTagToIgnore */
95 enum TIFFIgnoreSense /* IGNORE tag table */
96 {
97 TIS_STORE,
98 TIS_EXTRACT,
99 TIS_EMPTY
100 };
101
102 /*
103 * TIFF header.
104 */
105 typedef struct {
106 uint16 tiff_magic; /* magic number (defines byte order) */
107 #define TIFF_MAGIC_SIZE 2
108 uint16 tiff_version; /* TIFF version number */
109 #define TIFF_VERSION_SIZE 2
110 uint32 tiff_diroff; /* byte offset to first directory */
111 #define TIFF_DIROFFSET_SIZE 4
112 } TIFFHeader;
113
114
115 /*
116 * TIFF Image File Directories are comprised of a table of field
117 * descriptors of the form shown below. The table is sorted in
118 * ascending order by tag. The values associated with each entry are
119 * disjoint and may appear anywhere in the file (so long as they are
120 * placed on a word boundary).
121 *
122 * If the value is 4 bytes or less, then it is placed in the offset
123 * field to save space. If the value is less than 4 bytes, it is
124 * left-justified in the offset field.
125 */
126 typedef struct {
127 uint16 tdir_tag; /* see below */
128 uint16 tdir_type; /* data type; see below */
129 uint32 tdir_count; /* number of items; length in spec */
130 uint32 tdir_offset; /* byte offset to field data */
131 } TIFFDirEntry;
132
133 /*
134 * NB: In the comments below,
135 * - items marked with a + are obsoleted by revision 5.0,
136 * - items marked with a ! are introduced in revision 6.0.
137 * - items marked with a % are introduced post revision 6.0.
138 * - items marked with a $ are obsoleted by revision 6.0.
139 * - items marked with a & are introduced by Adobe DNG specification.
140 */
141
142 /*
143 * Tag data type information.
144 *
145 * Note: RATIONALs are the ratio of two 32-bit integer values.
146 */
147 typedef enum {
148 TIFF_NOTYPE = 0, /* placeholder */
149 TIFF_BYTE = 1, /* 8-bit unsigned integer */
150 TIFF_ASCII = 2, /* 8-bit bytes w/ last byte null */
151 TIFF_SHORT = 3, /* 16-bit unsigned integer */
152 TIFF_LONG = 4, /* 32-bit unsigned integer */
153 TIFF_RATIONAL = 5, /* 64-bit unsigned fraction */
154 TIFF_SBYTE = 6, /* !8-bit signed integer */
155 TIFF_UNDEFINED = 7, /* !8-bit untyped data */
156 TIFF_SSHORT = 8, /* !16-bit signed integer */
157 TIFF_SLONG = 9, /* !32-bit signed integer */
158 TIFF_SRATIONAL = 10, /* !64-bit signed fraction */
159 TIFF_FLOAT = 11, /* !32-bit IEEE floating point */
160 TIFF_DOUBLE = 12, /* !64-bit IEEE floating point */
161 TIFF_IFD = 13 /* %32-bit unsigned integer (offset) */
162 } TIFFDataType;
163
164 /*
165 * TIFF Tag Definitions.
166 */
167 #define TIFFTAG_SUBFILETYPE 254 /* subfile data descriptor */
168 #define FILETYPE_REDUCEDIMAGE 0x1 /* reduced resolution version */
169 #define FILETYPE_PAGE 0x2 /* one page of many */
170 #define FILETYPE_MASK 0x4 /* transparency mask */
171 #define TIFFTAG_OSUBFILETYPE 255 /* +kind of data in subfile */
172 #define OFILETYPE_IMAGE 1 /* full resolution image data */
173 #define OFILETYPE_REDUCEDIMAGE 2 /* reduced size image data */
174 #define OFILETYPE_PAGE 3 /* one page of many */
175 #define TIFFTAG_IMAGEWIDTH 256 /* image width in pixels */
176 #define TIFFTAG_IMAGELENGTH 257 /* image height in pixels */
177 #define TIFFTAG_BITSPERSAMPLE 258 /* bits per channel (sample) */
178 #define TIFFTAG_COMPRESSION 259 /* data compression technique */
179 #define COMPRESSION_NONE 1 /* dump mode */
180 #define COMPRESSION_CCITTRLE 2 /* CCITT modified Huffman RLE */
181 #define COMPRESSION_CCITTFAX3 3 /* CCITT Group 3 fax encoding */
182 #define COMPRESSION_CCITT_T4 3 /* CCITT T.4 (TIFF 6 name) */
183 #define COMPRESSION_CCITTFAX4 4 /* CCITT Group 4 fax encoding */
184 #define COMPRESSION_CCITT_T6 4 /* CCITT T.6 (TIFF 6 name) */
185 #define COMPRESSION_LZW 5 /* Lempel-Ziv & Welch */
186 #define COMPRESSION_OJPEG 6 /* !6.0 JPEG */
187 #define COMPRESSION_JPEG 7 /* %JPEG DCT compression */
188 #define COMPRESSION_NEXT 32766 /* NeXT 2-bit RLE */
189 #define COMPRESSION_CCITTRLEW 32771 /* #1 w/ word alignment */
190 #define COMPRESSION_PACKBITS 32773 /* Macintosh RLE */
191 #define COMPRESSION_THUNDERSCAN 32809 /* ThunderScan RLE */
192 /* codes 32895-32898 are reserved for ANSI IT8 TIFF/IT <[email protected]) */
193 #define COMPRESSION_IT8CTPAD 32895 /* IT8 CT w/padding */
194 #define COMPRESSION_IT8LW 32896 /* IT8 Linework RLE */
195 #define COMPRESSION_IT8MP 32897 /* IT8 Monochrome picture */
196 #define COMPRESSION_IT8BL 32898 /* IT8 Binary line art */
197 /* compression codes 32908-32911 are reserved for Pixar */
198 #define COMPRESSION_PIXARFILM 32908 /* Pixar companded 10bit LZW */
199 #define COMPRESSION_PIXARLOG 32909 /* Pixar companded 11bit ZIP */
200 #define COMPRESSION_DEFLATE 32946 /* Deflate compression */
201 #define COMPRESSION_ADOBE_DEFLATE 8 /* Deflate compression,
202 as recognized by Adobe */
203 /* compression code 32947 is reserved for Oceana Matrix <[email protected]> */
204 #define COMPRESSION_DCS 32947 /* Kodak DCS encoding */
205 #define COMPRESSION_JBIG 34661 /* ISO JBIG */
206 #define COMPRESSION_SGILOG 34676 /* SGI Log Luminance RLE */
207 #define COMPRESSION_SGILOG24 34677 /* SGI Log 24-bit packed */
208 #define COMPRESSION_JP2000 34712 /* Leadtools JPEG2000 */
209 #define TIFFTAG_PHOTOMETRIC 262 /* photometric interpretation */
210 #define PHOTOMETRIC_MINISWHITE 0 /* min value is white */
211 #define PHOTOMETRIC_MINISBLACK 1 /* min value is black */
212 #define PHOTOMETRIC_RGB 2 /* RGB color model */
213 #define PHOTOMETRIC_PALETTE 3 /* color map indexed */
214 #define PHOTOMETRIC_MASK 4 /* $holdout mask */
215 #define PHOTOMETRIC_SEPARATED 5 /* !color separations */
216 #define PHOTOMETRIC_YCBCR 6 /* !CCIR 601 */
217 #define PHOTOMETRIC_CIELAB 8 /* !1976 CIE L*a*b* */
218 #define PHOTOMETRIC_ICCLAB 9 /* ICC L*a*b* [Adobe TIFF Technote 4] */
219 #define PHOTOMETRIC_ITULAB 10 /* ITU L*a*b* */
220 #define PHOTOMETRIC_LOGL 32844 /* CIE Log2(L) */
221 #define PHOTOMETRIC_LOGLUV 32845 /* CIE Log2(L) (u',v') */
222 #define TIFFTAG_THRESHHOLDING 263 /* +thresholding used on data */
223 #define THRESHHOLD_BILEVEL 1 /* b&w art scan */
224 #define THRESHHOLD_HALFTONE 2 /* or dithered scan */
225 #define THRESHHOLD_ERRORDIFFUSE 3 /* usually floyd-steinberg */
226 #define TIFFTAG_CELLWIDTH 264 /* +dithering matrix width */
227 #define TIFFTAG_CELLLENGTH 265 /* +dithering matrix height */
228 #define TIFFTAG_FILLORDER 266 /* data order within a byte */
229 #define FILLORDER_MSB2LSB 1 /* most significant -> least */
230 #define FILLORDER_LSB2MSB 2 /* least significant -> most */
231 #define TIFFTAG_DOCUMENTNAME 269 /* name of doc. image is from */
232 #define TIFFTAG_IMAGEDESCRIPTION 270 /* info about image */
233 #define TIFFTAG_MAKE 271 /* scanner manufacturer name */
234 #define TIFFTAG_MODEL 272 /* scanner model name/number */
235 #define TIFFTAG_STRIPOFFSETS 273 /* offsets to data strips */
236 #define TIFFTAG_ORIENTATION 274 /* +image orientation */
237 #define ORIENTATION_TOPLEFT 1 /* row 0 top, col 0 lhs */
238 #define ORIENTATION_TOPRIGHT 2 /* row 0 top, col 0 rhs */
239 #define ORIENTATION_BOTRIGHT 3 /* row 0 bottom, col 0 rhs */
240 #define ORIENTATION_BOTLEFT 4 /* row 0 bottom, col 0 lhs */
241 #define ORIENTATION_LEFTTOP 5 /* row 0 lhs, col 0 top */
242 #define ORIENTATION_RIGHTTOP 6 /* row 0 rhs, col 0 top */
243 #define ORIENTATION_RIGHTBOT 7 /* row 0 rhs, col 0 bottom */
244 #define ORIENTATION_LEFTBOT 8 /* row 0 lhs, col 0 bottom */
245 #define TIFFTAG_SAMPLESPERPIXEL 277 /* samples per pixel */
246 #define TIFFTAG_ROWSPERSTRIP 278 /* rows per strip of data */
247 #define TIFFTAG_STRIPBYTECOUNTS 279 /* bytes counts for strips */
248 #define TIFFTAG_MINSAMPLEVALUE 280 /* +minimum sample value */
249 #define TIFFTAG_MAXSAMPLEVALUE 281 /* +maximum sample value */
250 #define TIFFTAG_XRESOLUTION 282 /* pixels/resolution in x */
251 #define TIFFTAG_YRESOLUTION 283 /* pixels/resolution in y */
252 #define TIFFTAG_PLANARCONFIG 284 /* storage organization */
253 #define PLANARCONFIG_CONTIG 1 /* single image plane */
254 #define PLANARCONFIG_SEPARATE 2 /* separate planes of data */
255 #define TIFFTAG_PAGENAME 285 /* page name image is from */
256 #define TIFFTAG_XPOSITION 286 /* x page offset of image lhs */
257 #define TIFFTAG_YPOSITION 287 /* y page offset of image lhs */
258 #define TIFFTAG_FREEOFFSETS 288 /* +byte offset to free block */
259 #define TIFFTAG_FREEBYTECOUNTS 289 /* +sizes of free blocks */
260 #define TIFFTAG_GRAYRESPONSEUNIT 290 /* $gray scale curve accuracy */
261 #define GRAYRESPONSEUNIT_10S 1 /* tenths of a unit */
262 #define GRAYRESPONSEUNIT_100S 2 /* hundredths of a unit */
263 #define GRAYRESPONSEUNIT_1000S 3 /* thousandths of a unit */
264 #define GRAYRESPONSEUNIT_10000S 4 /* ten-thousandths of a unit */
265 #define GRAYRESPONSEUNIT_100000S 5 /* hundred-thousandths */
266 #define TIFFTAG_GRAYRESPONSECURVE 291 /* $gray scale response curve */
267 #define TIFFTAG_GROUP3OPTIONS 292 /* 32 flag bits */
268 #define TIFFTAG_T4OPTIONS 292 /* TIFF 6.0 proper name alias */
269 #define GROUP3OPT_2DENCODING 0x1 /* 2-dimensional coding */
270 #define GROUP3OPT_UNCOMPRESSED 0x2 /* data not compressed */
271 #define GROUP3OPT_FILLBITS 0x4 /* fill to byte boundary */
272 #define TIFFTAG_GROUP4OPTIONS 293 /* 32 flag bits */
273 #define TIFFTAG_T6OPTIONS 293 /* TIFF 6.0 proper name */
274 #define GROUP4OPT_UNCOMPRESSED 0x2 /* data not compressed */
275 #define TIFFTAG_RESOLUTIONUNIT 296 /* units of resolutions */
276 #define RESUNIT_NONE 1 /* no meaningful units */
277 #define RESUNIT_INCH 2 /* english */
278 #define RESUNIT_CENTIMETER 3 /* metric */
279 #define TIFFTAG_PAGENUMBER 297 /* page numbers of multi-page */
280 #define TIFFTAG_COLORRESPONSEUNIT 300 /* $color curve accuracy */
281 #define COLORRESPONSEUNIT_10S 1 /* tenths of a unit */
282 #define COLORRESPONSEUNIT_100S 2 /* hundredths of a unit */
283 #define COLORRESPONSEUNIT_1000S 3 /* thousandths of a unit */
284 #define COLORRESPONSEUNIT_10000S 4 /* ten-thousandths of a unit */
285 #define COLORRESPONSEUNIT_100000S 5 /* hundred-thousandths */
286 #define TIFFTAG_TRANSFERFUNCTION 301 /* !colorimetry info */
287 #define TIFFTAG_SOFTWARE 305 /* name & release */
288 #define TIFFTAG_DATETIME 306 /* creation date and time */
289 #define TIFFTAG_ARTIST 315 /* creator of image */
290 #define TIFFTAG_HOSTCOMPUTER 316 /* machine where created */
291 #define TIFFTAG_PREDICTOR 317 /* prediction scheme w/ LZW */
292 #define PREDICTOR_NONE 1 /* no prediction scheme used */
293 #define PREDICTOR_HORIZONTAL 2 /* horizontal differencing */
294 #define PREDICTOR_FLOATINGPOINT 3 /* floating point predictor */
295 #define TIFFTAG_WHITEPOINT 318 /* image white point */
296 #define TIFFTAG_PRIMARYCHROMATICITIES 319 /* !primary chromaticities */
297 #define TIFFTAG_COLORMAP 320 /* RGB map for pallette image */
298 #define TIFFTAG_HALFTONEHINTS 321 /* !highlight+shadow info */
299 #define TIFFTAG_TILEWIDTH 322 /* !tile width in pixels */
300 #define TIFFTAG_TILELENGTH 323 /* !tile height in pixels */
301 #define TIFFTAG_TILEOFFSETS 324 /* !offsets to data tiles */
302 #define TIFFTAG_TILEBYTECOUNTS 325 /* !byte counts for tiles */
303 #define TIFFTAG_BADFAXLINES 326 /* lines w/ wrong pixel count */
304 #define TIFFTAG_CLEANFAXDATA 327 /* regenerated line info */
305 #define CLEANFAXDATA_CLEAN 0 /* no errors detected */
306 #define CLEANFAXDATA_REGENERATED 1 /* receiver regenerated lines */
307 #define CLEANFAXDATA_UNCLEAN 2 /* uncorrected errors exist */
308 #define TIFFTAG_CONSECUTIVEBADFAXLINES 328 /* max consecutive bad lines */
309 #define TIFFTAG_SUBIFD 330 /* subimage descriptors */
310 #define TIFFTAG_INKSET 332 /* !inks in separated image */
311 #define INKSET_CMYK 1 /* !cyan-magenta-yellow-black color */
312 #define INKSET_MULTIINK 2 /* !multi-ink or hi-fi color */
313 #define TIFFTAG_INKNAMES 333 /* !ascii names of inks */
314 #define TIFFTAG_NUMBEROFINKS 334 /* !number of inks */
315 #define TIFFTAG_DOTRANGE 336 /* !0% and 100% dot codes */
316 #define TIFFTAG_TARGETPRINTER 337 /* !separation target */
317 #define TIFFTAG_EXTRASAMPLES 338 /* !info about extra samples */
318 #define EXTRASAMPLE_UNSPECIFIED 0 /* !unspecified data */
319 #define EXTRASAMPLE_ASSOCALPHA 1 /* !associated alpha data */
320 #define EXTRASAMPLE_UNASSALPHA 2 /* !unassociated alpha data */
321 #define TIFFTAG_SAMPLEFORMAT 339 /* !data sample format */
322 #define SAMPLEFORMAT_UINT 1 /* !unsigned integer data */
323 #define SAMPLEFORMAT_INT 2 /* !signed integer data */
324 #define SAMPLEFORMAT_IEEEFP 3 /* !IEEE floating point data */
325 #define SAMPLEFORMAT_VOID 4 /* !untyped data */
326 #define SAMPLEFORMAT_COMPLEXINT 5 /* !complex signed int */
327 #define SAMPLEFORMAT_COMPLEXIEEEFP 6 /* !complex ieee floating */
328 #define TIFFTAG_SMINSAMPLEVALUE 340 /* !variable MinSampleValue */
329 #define TIFFTAG_SMAXSAMPLEVALUE 341 /* !variable MaxSampleValue */
330 #define TIFFTAG_CLIPPATH 343 /* %ClipPath
331 [Adobe TIFF technote 2] */
332 #define TIFFTAG_XCLIPPATHUNITS 344 /* %XClipPathUnits
333 [Adobe TIFF technote 2] */
334 #define TIFFTAG_YCLIPPATHUNITS 345 /* %YClipPathUnits
335 [Adobe TIFF technote 2] */
336 #define TIFFTAG_INDEXED 346 /* %Indexed
337 [Adobe TIFF Technote 3] */
338 #define TIFFTAG_JPEGTABLES 347 /* %JPEG table stream */
339 #define TIFFTAG_OPIPROXY 351 /* %OPI Proxy [Adobe TIFF technote] */
340 /*
341 * Tags 512-521 are obsoleted by Technical Note #2 which specifies a
342 * revised JPEG-in-TIFF scheme.
343 */
344 #define TIFFTAG_JPEGPROC 512 /* !JPEG processing algorithm */
345 #define JPEGPROC_BASELINE 1 /* !baseline sequential */
346 #define JPEGPROC_LOSSLESS 14 /* !Huffman coded lossless */
347 #define TIFFTAG_JPEGIFOFFSET 513 /* !pointer to SOI marker */
348 #define TIFFTAG_JPEGIFBYTECOUNT 514 /* !JFIF stream length */
349 #define TIFFTAG_JPEGRESTARTINTERVAL 515 /* !restart interval length */
350 #define TIFFTAG_JPEGLOSSLESSPREDICTORS 517 /* !lossless proc predictor */
351 #define TIFFTAG_JPEGPOINTTRANSFORM 518 /* !lossless point transform */
352 #define TIFFTAG_JPEGQTABLES 519 /* !Q matrice offsets */
353 #define TIFFTAG_JPEGDCTABLES 520 /* !DCT table offsets */
354 #define TIFFTAG_JPEGACTABLES 521 /* !AC coefficient offsets */
355 #define TIFFTAG_YCBCRCOEFFICIENTS 529 /* !RGB -> YCbCr transform */
356 #define TIFFTAG_YCBCRSUBSAMPLING 530 /* !YCbCr subsampling factors */
357 #define TIFFTAG_YCBCRPOSITIONING 531 /* !subsample positioning */
358 #define YCBCRPOSITION_CENTERED 1 /* !as in PostScript Level 2 */
359 #define YCBCRPOSITION_COSITED 2 /* !as in CCIR 601-1 */
360 #define TIFFTAG_REFERENCEBLACKWHITE 532 /* !colorimetry info */
361 #define TIFFTAG_XMLPACKET 700 /* %XML packet
362 [Adobe XMP Specification,
363 January 2004 */
364 #define TIFFTAG_OPIIMAGEID 32781 /* %OPI ImageID
365 [Adobe TIFF technote] */
366 /* tags 32952-32956 are private tags registered to Island Graphics */
367 #define TIFFTAG_REFPTS 32953 /* image reference points */
368 #define TIFFTAG_REGIONTACKPOINT 32954 /* region-xform tack point */
369 #define TIFFTAG_REGIONWARPCORNERS 32955 /* warp quadrilateral */
370 #define TIFFTAG_REGIONAFFINE 32956 /* affine transformation mat */
371 /* tags 32995-32999 are private tags registered to SGI */
372 #define TIFFTAG_MATTEING 32995 /* $use ExtraSamples */
373 #define TIFFTAG_DATATYPE 32996 /* $use SampleFormat */
374 #define TIFFTAG_IMAGEDEPTH 32997 /* z depth of image */
375 #define TIFFTAG_TILEDEPTH 32998 /* z depth/data tile */
376 /* tags 33300-33309 are private tags registered to Pixar */
377 /*
378 * TIFFTAG_PIXAR_IMAGEFULLWIDTH and TIFFTAG_PIXAR_IMAGEFULLLENGTH
379 * are set when an image has been cropped out of a larger image.
380 * They reflect the size of the original uncropped image.
381 * The TIFFTAG_XPOSITION and TIFFTAG_YPOSITION can be used
382 * to determine the position of the smaller image in the larger one.
383 */
384 #define TIFFTAG_PIXAR_IMAGEFULLWIDTH 33300 /* full image size in x */
385 #define TIFFTAG_PIXAR_IMAGEFULLLENGTH 33301 /* full image size in y */
386 /* Tags 33302-33306 are used to identify special image modes and data
387 * used by Pixar's texture formats.
388 */
389 #define TIFFTAG_PIXAR_TEXTUREFORMAT 33302 /* texture map format */
390 #define TIFFTAG_PIXAR_WRAPMODES 33303 /* s & t wrap modes */
391 #define TIFFTAG_PIXAR_FOVCOT 33304 /* cotan(fov) for env. maps */
392 #define TIFFTAG_PIXAR_MATRIX_WORLDTOSCREEN 33305
393 #define TIFFTAG_PIXAR_MATRIX_WORLDTOCAMERA 33306
394 /* tag 33405 is a private tag registered to Eastman Kodak */
395 #define TIFFTAG_WRITERSERIALNUMBER 33405 /* device serial number */
396 /* tag 33432 is listed in the 6.0 spec w/ unknown ownership */
397 #define TIFFTAG_COPYRIGHT 33432 /* copyright string */
398 /* IPTC TAG from RichTIFF specifications */
399 #define TIFFTAG_RICHTIFFIPTC 33723
400 /* 34016-34029 are reserved for ANSI IT8 TIFF/IT <[email protected]) */
401 #define TIFFTAG_IT8SITE 34016 /* site name */
402 #define TIFFTAG_IT8COLORSEQUENCE 34017 /* color seq. [RGB,CMYK,etc] */
403 #define TIFFTAG_IT8HEADER 34018 /* DDES Header */
404 #define TIFFTAG_IT8RASTERPADDING 34019 /* raster scanline padding */
405 #define TIFFTAG_IT8BITSPERRUNLENGTH 34020 /* # of bits in short run */
406 #define TIFFTAG_IT8BITSPEREXTENDEDRUNLENGTH 34021/* # of bits in long run */
407 #define TIFFTAG_IT8COLORTABLE 34022 /* LW colortable */
408 #define TIFFTAG_IT8IMAGECOLORINDICATOR 34023 /* BP/BL image color switch */
409 #define TIFFTAG_IT8BKGCOLORINDICATOR 34024 /* BP/BL bg color switch */
410 #define TIFFTAG_IT8IMAGECOLORVALUE 34025 /* BP/BL image color value */
411 #define TIFFTAG_IT8BKGCOLORVALUE 34026 /* BP/BL bg color value */
412 #define TIFFTAG_IT8PIXELINTENSITYRANGE 34027 /* MP pixel intensity value */
413 #define TIFFTAG_IT8TRANSPARENCYINDICATOR 34028 /* HC transparency switch */
414 #define TIFFTAG_IT8COLORCHARACTERIZATION 34029 /* color character. table */
415 #define TIFFTAG_IT8HCUSAGE 34030 /* HC usage indicator */
416 #define TIFFTAG_IT8TRAPINDICATOR 34031 /* Trapping indicator
417 (untrapped=0, trapped=1) */
418 #define TIFFTAG_IT8CMYKEQUIVALENT 34032 /* CMYK color equivalents */
419 /* tags 34232-34236 are private tags registered to Texas Instruments */
420 #define TIFFTAG_FRAMECOUNT 34232 /* Sequence Frame Count */
421 /* tag 34377 is private tag registered to Adobe for PhotoShop */
422 #define TIFFTAG_PHOTOSHOP 34377
423 /* tags 34665, 34853 and 40965 are documented in EXIF specification */
424 #define TIFFTAG_EXIFIFD 34665 /* Pointer to EXIF private directory */
425 /* tag 34750 is a private tag registered to Adobe? */
426 #define TIFFTAG_ICCPROFILE 34675 /* ICC profile data */
427 /* tag 34750 is a private tag registered to Pixel Magic */
428 #define TIFFTAG_JBIGOPTIONS 34750 /* JBIG options */
429 #define TIFFTAG_GPSIFD 34853 /* Pointer to GPS private directory */
430 /* tags 34908-34914 are private tags registered to SGI */
431 #define TIFFTAG_FAXRECVPARAMS 34908 /* encoded Class 2 ses. parms */
432 #define TIFFTAG_FAXSUBADDRESS 34909 /* received SubAddr string */
433 #define TIFFTAG_FAXRECVTIME 34910 /* receive time (secs) */
434 #define TIFFTAG_FAXDCS 34911 /* encoded fax ses. params, Table 2/T.30 */
435 /* tags 37439-37443 are registered to SGI <[email protected]> */
436 #define TIFFTAG_STONITS 37439 /* Sample value to Nits */
437 /* tag 34929 is a private tag registered to FedEx */
438 #define TIFFTAG_FEDEX_EDR 34929 /* unknown use */
439 #define TIFFTAG_INTEROPERABILITYIFD 40965 /* Pointer to Interoperability private directory */
440 /* Adobe Digital Negative (DNG) format tags */
441 #define TIFFTAG_DNGVERSION 50706 /* &DNG version number */
442 #define TIFFTAG_DNGBACKWARDVERSION 50707 /* &DNG compatibility version */
443 #define TIFFTAG_UNIQUECAMERAMODEL 50708 /* &name for the camera model */
444 #define TIFFTAG_LOCALIZEDCAMERAMODEL 50709 /* &localized camera model
445 name */
446 #define TIFFTAG_CFAPLANECOLOR 50710 /* &CFAPattern->LinearRaw space
447 mapping */
448 #define TIFFTAG_CFALAYOUT 50711 /* &spatial layout of the CFA */
449 #define TIFFTAG_LINEARIZATIONTABLE 50712 /* &lookup table description */
450 #define TIFFTAG_BLACKLEVELREPEATDIM 50713 /* &repeat pattern size for
451 the BlackLevel tag */
452 #define TIFFTAG_BLACKLEVEL 50714 /* &zero light encoding level */
453 #define TIFFTAG_BLACKLEVELDELTAH 50715 /* &zero light encoding level
454 differences (columns) */
455 #define TIFFTAG_BLACKLEVELDELTAV 50716 /* &zero light encoding level
456 differences (rows) */
457 #define TIFFTAG_WHITELEVEL 50717 /* &fully saturated encoding
458 level */
459 #define TIFFTAG_DEFAULTSCALE 50718 /* &default scale factors */
460 #define TIFFTAG_DEFAULTCROPORIGIN 50719 /* &origin of the final image
461 area */
462 #define TIFFTAG_DEFAULTCROPSIZE 50720 /* &size of the final image
463 area */
464 #define TIFFTAG_COLORMATRIX1 50721 /* &XYZ->reference color space
465 transformation matrix 1 */
466 #define TIFFTAG_COLORMATRIX2 50722 /* &XYZ->reference color space
467 transformation matrix 2 */
468 #define TIFFTAG_CAMERACALIBRATION1 50723 /* &calibration matrix 1 */
469 #define TIFFTAG_CAMERACALIBRATION2 50724 /* &calibration matrix 2 */
470 #define TIFFTAG_REDUCTIONMATRIX1 50725 /* &dimensionality reduction
471 matrix 1 */
472 #define TIFFTAG_REDUCTIONMATRIX2 50726 /* &dimensionality reduction
473 matrix 2 */
474 #define TIFFTAG_ANALOGBALANCE 50727 /* &gain applied the stored raw
475 values*/
476 #define TIFFTAG_ASSHOTNEUTRAL 50728 /* &selected white balance in
477 linear reference space */
478 #define TIFFTAG_ASSHOTWHITEXY 50729 /* &selected white balance in
479 x-y chromaticity
480 coordinates */
481 #define TIFFTAG_BASELINEEXPOSURE 50730 /* &how much to move the zero
482 point */
483 #define TIFFTAG_BASELINENOISE 50731 /* &relative noise level */
484 #define TIFFTAG_BASELINESHARPNESS 50732 /* &relative amount of
485 sharpening */
486 #define TIFFTAG_BAYERGREENSPLIT 50733 /* &how closely the values of
487 the green pixels in the
488 blue/green rows track the
489 values of the green pixels
490 in the red/green rows */
491 #define TIFFTAG_LINEARRESPONSELIMIT 50734 /* &non-linear encoding range */
492 #define TIFFTAG_CAMERASERIALNUMBER 50735 /* &camera's serial number */
493 #define TIFFTAG_LENSINFO 50736 /* info about the lens */
494 #define TIFFTAG_CHROMABLURRADIUS 50737 /* &chroma blur radius */
495 #define TIFFTAG_ANTIALIASSTRENGTH 50738 /* &relative strength of the
496 camera's anti-alias filter */
497 #define TIFFTAG_SHADOWSCALE 50739 /* &used by Adobe Camera Raw */
498 #define TIFFTAG_DNGPRIVATEDATA 50740 /* &manufacturer's private data */
499 #define TIFFTAG_MAKERNOTESAFETY 50741 /* &whether the EXIF MakerNote
500 tag is safe to preserve
501 along with the rest of the
502 EXIF data */
503 #define TIFFTAG_CALIBRATIONILLUMINANT1 50778 /* &illuminant 1 */
504 #define TIFFTAG_CALIBRATIONILLUMINANT2 50779 /* &illuminant 2 */
505 #define TIFFTAG_BESTQUALITYSCALE 50780 /* &best quality multiplier */
506 #define TIFFTAG_RAWDATAUNIQUEID 50781 /* &unique identifier for
507 the raw image data */
508 #define TIFFTAG_ORIGINALRAWFILENAME 50827 /* &file name of the original
509 raw file */
510 #define TIFFTAG_ORIGINALRAWFILEDATA 50828 /* &contents of the original
511 raw file */
512 #define TIFFTAG_ACTIVEAREA 50829 /* &active (non-masked) pixels
513 of the sensor */
514 #define TIFFTAG_MASKEDAREAS 50830 /* &list of coordinates
515 of fully masked pixels */
516 #define TIFFTAG_ASSHOTICCPROFILE 50831 /* &these two tags used to */
517 #define TIFFTAG_ASSHOTPREPROFILEMATRIX 50832 /* map cameras's color space
518 into ICC profile space */
519 #define TIFFTAG_CURRENTICCPROFILE 50833 /* & */
520 #define TIFFTAG_CURRENTPREPROFILEMATRIX 50834 /* & */
521 /* tag 65535 is an undefined tag used by Eastman Kodak */
522 #define TIFFTAG_DCSHUESHIFTVALUES 65535 /* hue shift correction data */
523
524 /*
525 * The following are ``pseudo tags'' that can be used to control
526 * codec-specific functionality. These tags are not written to file.
527 * Note that these values start at 0xffff+1 so that they'll never
528 * collide with Aldus-assigned tags.
529 *
530 * If you want your private pseudo tags ``registered'' (i.e. added to
531 * this file), please post a bug report via the tracking system at
532 * http://www.remotesensing.org/libtiff/bugs.html with the appropriate
533 * C definitions to add.
534 */
535 #define TIFFTAG_FAXMODE 65536 /* Group 3/4 format control */
536 #define FAXMODE_CLASSIC 0x0000 /* default, include RTC */
537 #define FAXMODE_NORTC 0x0001 /* no RTC at end of data */
538 #define FAXMODE_NOEOL 0x0002 /* no EOL code at end of row */
539 #define FAXMODE_BYTEALIGN 0x0004 /* byte align row */
540 #define FAXMODE_WORDALIGN 0x0008 /* word align row */
541 #define FAXMODE_CLASSF FAXMODE_NORTC /* TIFF Class F */
542 #define TIFFTAG_JPEGQUALITY 65537 /* Compression quality level */
543 /* Note: quality level is on the IJG 0-100 scale. Default value is 75 */
544 #define TIFFTAG_JPEGCOLORMODE 65538 /* Auto RGB<=>YCbCr convert? */
545 #define JPEGCOLORMODE_RAW 0x0000 /* no conversion (default) */
546 #define JPEGCOLORMODE_RGB 0x0001 /* do auto conversion */
547 #define TIFFTAG_JPEGTABLESMODE 65539 /* What to put in JPEGTables */
548 #define JPEGTABLESMODE_QUANT 0x0001 /* include quantization tbls */
549 #define JPEGTABLESMODE_HUFF 0x0002 /* include Huffman tbls */
550 /* Note: default is JPEGTABLESMODE_QUANT | JPEGTABLESMODE_HUFF */
551 #define TIFFTAG_FAXFILLFUNC 65540 /* G3/G4 fill function */
552 #define TIFFTAG_PIXARLOGDATAFMT 65549 /* PixarLogCodec I/O data sz */
553 #define PIXARLOGDATAFMT_8BIT 0 /* regular u_char samples */
554 #define PIXARLOGDATAFMT_8BITABGR 1 /* ABGR-order u_chars */
555 #define PIXARLOGDATAFMT_11BITLOG 2 /* 11-bit log-encoded (raw) */
556 #define PIXARLOGDATAFMT_12BITPICIO 3 /* as per PICIO (1.0==2048) */
557 #define PIXARLOGDATAFMT_16BIT 4 /* signed short samples */
558 #define PIXARLOGDATAFMT_FLOAT 5 /* IEEE float samples */
559 /* 65550-65556 are allocated to Oceana Matrix <[email protected]> */
560 #define TIFFTAG_DCSIMAGERTYPE 65550 /* imager model & filter */
561 #define DCSIMAGERMODEL_M3 0 /* M3 chip (1280 x 1024) */
562 #define DCSIMAGERMODEL_M5 1 /* M5 chip (1536 x 1024) */
563 #define DCSIMAGERMODEL_M6 2 /* M6 chip (3072 x 2048) */
564 #define DCSIMAGERFILTER_IR 0 /* infrared filter */
565 #define DCSIMAGERFILTER_MONO 1 /* monochrome filter */
566 #define DCSIMAGERFILTER_CFA 2 /* color filter array */
567 #define DCSIMAGERFILTER_OTHER 3 /* other filter */
568 #define TIFFTAG_DCSINTERPMODE 65551 /* interpolation mode */
569 #define DCSINTERPMODE_NORMAL 0x0 /* whole image, default */
570 #define DCSINTERPMODE_PREVIEW 0x1 /* preview of image (384x256) */
571 #define TIFFTAG_DCSBALANCEARRAY 65552 /* color balance values */
572 #define TIFFTAG_DCSCORRECTMATRIX 65553 /* color correction values */
573 #define TIFFTAG_DCSGAMMA 65554 /* gamma value */
574 #define TIFFTAG_DCSTOESHOULDERPTS 65555 /* toe & shoulder points */
575 #define TIFFTAG_DCSCALIBRATIONFD 65556 /* calibration file desc */
576 /* Note: quality level is on the ZLIB 1-9 scale. Default value is -1 */
577 #define TIFFTAG_ZIPQUALITY 65557 /* compression quality level */
578 #define TIFFTAG_PIXARLOGQUALITY 65558 /* PixarLog uses same scale */
579 /* 65559 is allocated to Oceana Matrix <[email protected]> */
580 #define TIFFTAG_DCSCLIPRECTANGLE 65559 /* area of image to acquire */
581 #define TIFFTAG_SGILOGDATAFMT 65560 /* SGILog user data format */
582 #define SGILOGDATAFMT_FLOAT 0 /* IEEE float samples */
583 #define SGILOGDATAFMT_16BIT 1 /* 16-bit samples */
584 #define SGILOGDATAFMT_RAW 2 /* uninterpreted data */
585 #define SGILOGDATAFMT_8BIT 3 /* 8-bit RGB monitor values */
586 #define TIFFTAG_SGILOGENCODE 65561 /* SGILog data encoding control*/
587 #define SGILOGENCODE_NODITHER 0 /* do not dither encoded values*/
588 #define SGILOGENCODE_RANDITHER 1 /* randomly dither encd values */
589 #endif /* _TIFF_ */
590
591 /* vim: set ts=8 sts=8 sw=8 noet: */
