| 1 |
/* $Header: /cvsroot/osrs/libtiff/libtiff/tiff.h,v 1.10 2001/11/02 17:25:52 warmerda Exp $ */
| 2 |
| 3 |
| 4 |
* Copyright (c) 1988-1997 Sam Leffler
| 5 |
* Copyright (c) 1991-1997 Silicon Graphics, Inc.
| 6 |
| 7 |
* Permission to use, copy, modify, distribute, and sell this software and
| 8 |
* its documentation for any purpose is hereby granted without fee, provided
| 9 |
* that (i) the above copyright notices and this permission notice appear in
| 10 |
* all copies of the software and related documentation, and (ii) the names of
| 11 |
* Sam Leffler and Silicon Graphics may not be used in any advertising or
| 12 |
* publicity relating to the software without the specific, prior written
| 13 |
* permission of Sam Leffler and Silicon Graphics.
| 14 |
| 15 |
* THE SOFTWARE IS PROVIDED "AS-IS" AND WITHOUT WARRANTY OF ANY KIND,
| 16 |
* EXPRESS, IMPLIED OR OTHERWISE, INCLUDING WITHOUT LIMITATION, ANY
| 17 |
* WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
| 18 |
| 19 |
* IN NO EVENT SHALL SAM LEFFLER OR SILICON GRAPHICS BE LIABLE FOR
| 20 |
* ANY SPECIAL, INCIDENTAL, INDIRECT OR CONSEQUENTIAL DAMAGES OF ANY KIND,
| 21 |
* OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
| 22 |
* WHETHER OR NOT ADVISED OF THE POSSIBILITY OF DAMAGE, AND ON ANY THEORY OF
| 23 |
* LIABILITY, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE
| 24 |
* OF THIS SOFTWARE.
| 25 |
| 26 |
| 27 |
#ifndef _TIFF_
| 28 |
#define _TIFF_
| 29 |
| 30 |
* Tag Image File Format (TIFF)
| 31 |
| 32 |
* Based on Rev 6.0 from:
| 33 |
* Developer's Desk
| 34 |
* Aldus Corporation
| 35 |
* 411 First Ave. South
| 36 |
* Suite 200
| 37 |
* Seattle, WA 98104
| 38 |
* 206-622-5500
| 39 |
| 40 |
#define TIFF_VERSION 42
| 41 |
| 42 |
#define TIFF_BIGENDIAN 0x4d4d
| 43 |
#define TIFF_LITTLEENDIAN 0x4949
| 44 |
| 45 |
| 46 |
* The so called TIFF types conflict with definitions from inttypes.h
| 47 |
* included from sys/types.h on AIX (at least using VisualAge compiler).
| 48 |
* We try to work around this by detecting this case. Defining
| 49 |
* _TIFF_DATA_TYPEDEFS_ short circuits the later definitions in tiff.h, and
| 50 |
* we will in the holes not provided for by inttypes.h.
| 51 |
| 52 |
* See http://bugzilla.remotesensing.org/show_bug.cgi?id=39
| 53 |
| 54 |
#if defined(_H_INTTYPES) && defined(_ALL_SOURCE)
| 55 |
| 56 |
#ifndef _TIFF_DATA_TYPEDEFS_
| 57 |
#define _TIFF_DATA_TYPEDEFS_
| 58 |
typedef unsigned char uint8;
| 59 |
typedef unsigned short uint16;
| 60 |
typedef unsigned int uint32;
| 61 |
#endif
| 62 |
| 63 |
#endif
| 64 |
| 65 |
| 66 |
* Intrinsic data types required by the file format:
| 67 |
| 68 |
* 8-bit quantities int8/uint8
| 69 |
* 16-bit quantities int16/uint16
| 70 |
* 32-bit quantities int32/uint32
| 71 |
* strings unsigned char*
| 72 |
| 73 |
| 74 |
| 75 |
| 76 |
#ifdef __STDC__
| 77 |
typedef signed char int8; /* NB: non-ANSI compilers may not grok */
| 78 |
#else
| 79 |
typedef char int8;
| 80 |
#endif
| 81 |
| 82 |
typedef short int16;
| 83 |
typedef unsigned short uint16; /* sizeof (uint16) must == 2 */
| 84 |
#if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) || defined(__LP64__)
| 85 |
typedef int int32;
| 86 |
typedef unsigned int uint32; /* sizeof (uint32) must == 4 */
| 87 |
#else
| 88 |
typedef long int32;
| 89 |
typedef unsigned long uint32; /* sizeof (uint32) must == 4 */
| 90 |
#endif
| 91 |
#endif /* _TIFF_DATA_TYPEDEFS_ */
| 92 |
| 93 |
/* For TIFFReassignTagToIgnore */
| 94 |
enum TIFFIgnoreSense /* IGNORE tag table */
| 95 |
| 96 |
TIS_STORE,
| 97 |
TIS_EXTRACT,
| 98 |
TIS_EMPTY
| 99 |
| 100 |
| 101 |
typedef struct {
| 102 |
uint16 tiff_magic; /* magic number (defines byte order) */
| 103 |
uint16 tiff_version; /* TIFF version number */
| 104 |
uint32 tiff_diroff; /* byte offset to first directory */
| 105 |
} TIFFHeader;
| 106 |
| 107 |
| 108 |
* TIFF Image File Directories are comprised of
| 109 |
* a table of field descriptors of the form shown
| 110 |
* below. The table is sorted in ascending order
| 111 |
* by tag. The values associated with each entry
| 112 |
* are disjoint and may appear anywhere in the file
| 113 |
* (so long as they are placed on a word boundary).
| 114 |
| 115 |
* If the value is 4 bytes or less, then it is placed
| 116 |
* in the offset field to save space. If the value
| 117 |
* is less than 4 bytes, it is left-justified in the
| 118 |
* offset field.
| 119 |
| 120 |
typedef struct {
| 121 |
uint16 tdir_tag; /* see below */
| 122 |
uint16 tdir_type; /* data type; see below */
| 123 |
uint32 tdir_count; /* number of items; length in spec */
| 124 |
uint32 tdir_offset; /* byte offset to field data */
| 125 |
} TIFFDirEntry;
| 126 |
| 127 |
| 128 |
* NB: In the comments below,
| 129 |
* - items marked with a + are obsoleted by revision 5.0,
| 130 |
* - items marked with a ! are introduced in revision 6.0.
| 131 |
* - items marked with a % are introduced post revision 6.0.
| 132 |
* - items marked with a $ are obsoleted by revision 6.0.
| 133 |
| 134 |
| 135 |
| 136 |
* Tag data type information.
| 137 |
| 138 |
* Note: RATIONALs are the ratio of two 32-bit integer values.
| 139 |
| 140 |
typedef enum {
| 141 |
TIFF_NOTYPE = 0, /* placeholder */
| 142 |
TIFF_BYTE = 1, /* 8-bit unsigned integer */
| 143 |
TIFF_ASCII = 2, /* 8-bit bytes w/ last byte null */
| 144 |
TIFF_SHORT = 3, /* 16-bit unsigned integer */
| 145 |
TIFF_LONG = 4, /* 32-bit unsigned integer */
| 146 |
TIFF_RATIONAL = 5, /* 64-bit unsigned fraction */
| 147 |
TIFF_SBYTE = 6, /* !8-bit signed integer */
| 148 |
TIFF_UNDEFINED = 7, /* !8-bit untyped data */
| 149 |
TIFF_SSHORT = 8, /* !16-bit signed integer */
| 150 |
TIFF_SLONG = 9, /* !32-bit signed integer */
| 151 |
TIFF_SRATIONAL = 10, /* !64-bit signed fraction */
| 152 |
TIFF_FLOAT = 11, /* !32-bit IEEE floating point */
| 153 |
TIFF_DOUBLE = 12 /* !64-bit IEEE floating point */
| 154 |
} TIFFDataType;
| 155 |
| 156 |
| 157 |
* TIFF Tag Definitions.
| 158 |
| 159 |
#define TIFFTAG_SUBFILETYPE 254 /* subfile data descriptor */
| 160 |
#define FILETYPE_REDUCEDIMAGE 0x1 /* reduced resolution version */
| 161 |
#define FILETYPE_PAGE 0x2 /* one page of many */
| 162 |
#define FILETYPE_MASK 0x4 /* transparency mask */
| 163 |
#define TIFFTAG_OSUBFILETYPE 255 /* +kind of data in subfile */
| 164 |
#define OFILETYPE_IMAGE 1 /* full resolution image data */
| 165 |
#define OFILETYPE_REDUCEDIMAGE 2 /* reduced size image data */
| 166 |
#define OFILETYPE_PAGE 3 /* one page of many */
| 167 |
#define TIFFTAG_IMAGEWIDTH 256 /* image width in pixels */
| 168 |
#define TIFFTAG_IMAGELENGTH 257 /* image height in pixels */
| 169 |
#define TIFFTAG_BITSPERSAMPLE 258 /* bits per channel (sample) */
| 170 |
#define TIFFTAG_COMPRESSION 259 /* data compression technique */
| 171 |
#define COMPRESSION_NONE 1 /* dump mode */
| 172 |
#define COMPRESSION_CCITTRLE 2 /* CCITT modified Huffman RLE */
| 173 |
#define COMPRESSION_CCITTFAX3 3 /* CCITT Group 3 fax encoding */
| 174 |
#define COMPRESSION_CCITT_T4 3 /* CCITT T.4 (TIFF 6 name) */
| 175 |
#define COMPRESSION_CCITTFAX4 4 /* CCITT Group 4 fax encoding */
| 176 |
#define COMPRESSION_CCITT_T6 4 /* CCITT T.6 (TIFF 6 name) */
| 177 |
#define COMPRESSION_LZW 5 /* Lempel-Ziv & Welch */
| 178 |
#define COMPRESSION_OJPEG 6 /* !6.0 JPEG */
| 179 |
#define COMPRESSION_JPEG 7 /* %JPEG DCT compression */
| 180 |
#define COMPRESSION_NEXT 32766 /* NeXT 2-bit RLE */
| 181 |
#define COMPRESSION_CCITTRLEW 32771 /* #1 w/ word alignment */
| 182 |
#define COMPRESSION_PACKBITS 32773 /* Macintosh RLE */
| 183 |
#define COMPRESSION_THUNDERSCAN 32809 /* ThunderScan RLE */
| 184 |
/* codes 32895-32898 are reserved for ANSI IT8 TIFF/IT <[email protected]) */
| 185 |
#define COMPRESSION_IT8CTPAD 32895 /* IT8 CT w/padding */
| 186 |
#define COMPRESSION_IT8LW 32896 /* IT8 Linework RLE */
| 187 |
#define COMPRESSION_IT8MP 32897 /* IT8 Monochrome picture */
| 188 |
#define COMPRESSION_IT8BL 32898 /* IT8 Binary line art */
| 189 |
/* compression codes 32908-32911 are reserved for Pixar */
| 190 |
#define COMPRESSION_PIXARFILM 32908 /* Pixar companded 10bit LZW */
| 191 |
#define COMPRESSION_PIXARLOG 32909 /* Pixar companded 11bit ZIP */
| 192 |
#define COMPRESSION_DEFLATE 32946 /* Deflate compression */
| 193 |
#define COMPRESSION_ADOBE_DEFLATE 8 /* Deflate compression, as recognized by Adobe */
| 194 |
/* compression code 32947 is reserved for Oceana Matrix <[email protected]> */
| 195 |
#define COMPRESSION_DCS 32947 /* Kodak DCS encoding */
| 196 |
#define COMPRESSION_JBIG 34661 /* ISO JBIG */
| 197 |
#define COMPRESSION_SGILOG 34676 /* SGI Log Luminance RLE */
| 198 |
#define COMPRESSION_SGILOG24 34677 /* SGI Log 24-bit packed */
| 199 |
#define TIFFTAG_PHOTOMETRIC 262 /* photometric interpretation */
| 200 |
#define PHOTOMETRIC_MINISWHITE 0 /* min value is white */
| 201 |
#define PHOTOMETRIC_MINISBLACK 1 /* min value is black */
| 202 |
#define PHOTOMETRIC_RGB 2 /* RGB color model */
| 203 |
#define PHOTOMETRIC_PALETTE 3 /* color map indexed */
| 204 |
#define PHOTOMETRIC_MASK 4 /* $holdout mask */
| 205 |
#define PHOTOMETRIC_SEPARATED 5 /* !color separations */
| 206 |
#define PHOTOMETRIC_YCBCR 6 /* !CCIR 601 */
| 207 |
#define PHOTOMETRIC_CIELAB 8 /* !1976 CIE L*a*b* */
| 208 |
#define PHOTOMETRIC_ITULAB 10 /* ITU L*a*b* */
| 209 |
#define PHOTOMETRIC_LOGL 32844 /* CIE Log2(L) */
| 210 |
#define PHOTOMETRIC_LOGLUV 32845 /* CIE Log2(L) (u',v') */
| 211 |
#define TIFFTAG_THRESHHOLDING 263 /* +thresholding used on data */
| 212 |
#define THRESHHOLD_BILEVEL 1 /* b&w art scan */
| 213 |
#define THRESHHOLD_HALFTONE 2 /* or dithered scan */
| 214 |
#define THRESHHOLD_ERRORDIFFUSE 3 /* usually floyd-steinberg */
| 215 |
#define TIFFTAG_CELLWIDTH 264 /* +dithering matrix width */
| 216 |
#define TIFFTAG_CELLLENGTH 265 /* +dithering matrix height */
| 217 |
#define TIFFTAG_FILLORDER 266 /* data order within a byte */
| 218 |
#define FILLORDER_MSB2LSB 1 /* most significant -> least */
| 219 |
#define FILLORDER_LSB2MSB 2 /* least significant -> most */
| 220 |
#define TIFFTAG_DOCUMENTNAME 269 /* name of doc. image is from */
| 221 |
#define TIFFTAG_IMAGEDESCRIPTION 270 /* info about image */
| 222 |
#define TIFFTAG_MAKE 271 /* scanner manufacturer name */
| 223 |
#define TIFFTAG_MODEL 272 /* scanner model name/number */
| 224 |
#define TIFFTAG_STRIPOFFSETS 273 /* offsets to data strips */
| 225 |
#define TIFFTAG_ORIENTATION 274 /* +image orientation */
| 226 |
#define ORIENTATION_TOPLEFT 1 /* row 0 top, col 0 lhs */
| 227 |
#define ORIENTATION_TOPRIGHT 2 /* row 0 top, col 0 rhs */
| 228 |
#define ORIENTATION_BOTRIGHT 3 /* row 0 bottom, col 0 rhs */
| 229 |
#define ORIENTATION_BOTLEFT 4 /* row 0 bottom, col 0 lhs */
| 230 |
#define ORIENTATION_LEFTTOP 5 /* row 0 lhs, col 0 top */
| 231 |
#define ORIENTATION_RIGHTTOP 6 /* row 0 rhs, col 0 top */
| 232 |
#define ORIENTATION_RIGHTBOT 7 /* row 0 rhs, col 0 bottom */
| 233 |
#define ORIENTATION_LEFTBOT 8 /* row 0 lhs, col 0 bottom */
| 234 |
#define TIFFTAG_SAMPLESPERPIXEL 277 /* samples per pixel */
| 235 |
#define TIFFTAG_ROWSPERSTRIP 278 /* rows per strip of data */
| 236 |
#define TIFFTAG_STRIPBYTECOUNTS 279 /* bytes counts for strips */
| 237 |
#define TIFFTAG_MINSAMPLEVALUE 280 /* +minimum sample value */
| 238 |
#define TIFFTAG_MAXSAMPLEVALUE 281 /* +maximum sample value */
| 239 |
#define TIFFTAG_XRESOLUTION 282 /* pixels/resolution in x */
| 240 |
#define TIFFTAG_YRESOLUTION 283 /* pixels/resolution in y */
| 241 |
#define TIFFTAG_PLANARCONFIG 284 /* storage organization */
| 242 |
#define PLANARCONFIG_CONTIG 1 /* single image plane */
| 243 |
#define PLANARCONFIG_SEPARATE 2 /* separate planes of data */
| 244 |
#define TIFFTAG_PAGENAME 285 /* page name image is from */
| 245 |
#define TIFFTAG_XPOSITION 286 /* x page offset of image lhs */
| 246 |
#define TIFFTAG_YPOSITION 287 /* y page offset of image lhs */
| 247 |
#define TIFFTAG_FREEOFFSETS 288 /* +byte offset to free block */
| 248 |
#define TIFFTAG_FREEBYTECOUNTS 289 /* +sizes of free blocks */
| 249 |
#define TIFFTAG_GRAYRESPONSEUNIT 290 /* $gray scale curve accuracy */
| 250 |
#define GRAYRESPONSEUNIT_10S 1 /* tenths of a unit */
| 251 |
#define GRAYRESPONSEUNIT_100S 2 /* hundredths of a unit */
| 252 |
#define GRAYRESPONSEUNIT_1000S 3 /* thousandths of a unit */
| 253 |
#define GRAYRESPONSEUNIT_10000S 4 /* ten-thousandths of a unit */
| 254 |
#define GRAYRESPONSEUNIT_100000S 5 /* hundred-thousandths */
| 255 |
#define TIFFTAG_GRAYRESPONSECURVE 291 /* $gray scale response curve */
| 256 |
#define TIFFTAG_GROUP3OPTIONS 292 /* 32 flag bits */
| 257 |
#define TIFFTAG_T4OPTIONS 292 /* TIFF 6.0 proper name alias */
| 258 |
#define GROUP3OPT_2DENCODING 0x1 /* 2-dimensional coding */
| 259 |
#define GROUP3OPT_UNCOMPRESSED 0x2 /* data not compressed */
| 260 |
#define GROUP3OPT_FILLBITS 0x4 /* fill to byte boundary */
| 261 |
#define TIFFTAG_GROUP4OPTIONS 293 /* 32 flag bits */
| 262 |
#define TIFFTAG_T6OPTIONS 293 /* TIFF 6.0 proper name */
| 263 |
#define GROUP4OPT_UNCOMPRESSED 0x2 /* data not compressed */
| 264 |
#define TIFFTAG_RESOLUTIONUNIT 296 /* units of resolutions */
| 265 |
#define RESUNIT_NONE 1 /* no meaningful units */
| 266 |
#define RESUNIT_INCH 2 /* english */
| 267 |
#define RESUNIT_CENTIMETER 3 /* metric */
| 268 |
#define TIFFTAG_PAGENUMBER 297 /* page numbers of multi-page */
| 269 |
#define TIFFTAG_COLORRESPONSEUNIT 300 /* $color curve accuracy */
| 270 |
#define COLORRESPONSEUNIT_10S 1 /* tenths of a unit */
| 271 |
#define COLORRESPONSEUNIT_100S 2 /* hundredths of a unit */
| 272 |
#define COLORRESPONSEUNIT_1000S 3 /* thousandths of a unit */
| 273 |
#define COLORRESPONSEUNIT_10000S 4 /* ten-thousandths of a unit */
| 274 |
#define COLORRESPONSEUNIT_100000S 5 /* hundred-thousandths */
| 275 |
#define TIFFTAG_TRANSFERFUNCTION 301 /* !colorimetry info */
| 276 |
#define TIFFTAG_SOFTWARE 305 /* name & release */
| 277 |
#define TIFFTAG_DATETIME 306 /* creation date and time */
| 278 |
#define TIFFTAG_ARTIST 315 /* creator of image */
| 279 |
#define TIFFTAG_HOSTCOMPUTER 316 /* machine where created */
| 280 |
#define TIFFTAG_PREDICTOR 317 /* prediction scheme w/ LZW */
| 281 |
#define TIFFTAG_WHITEPOINT 318 /* image white point */
| 282 |
#define TIFFTAG_PRIMARYCHROMATICITIES 319 /* !primary chromaticities */
| 283 |
#define TIFFTAG_COLORMAP 320 /* RGB map for pallette image */
| 284 |
#define TIFFTAG_HALFTONEHINTS 321 /* !highlight+shadow info */
| 285 |
#define TIFFTAG_TILEWIDTH 322 /* !rows/data tile */
| 286 |
#define TIFFTAG_TILELENGTH 323 /* !cols/data tile */
| 287 |
#define TIFFTAG_TILEOFFSETS 324 /* !offsets to data tiles */
| 288 |
#define TIFFTAG_TILEBYTECOUNTS 325 /* !byte counts for tiles */
| 289 |
#define TIFFTAG_BADFAXLINES 326 /* lines w/ wrong pixel count */
| 290 |
#define TIFFTAG_CLEANFAXDATA 327 /* regenerated line info */
| 291 |
#define CLEANFAXDATA_CLEAN 0 /* no errors detected */
| 292 |
#define CLEANFAXDATA_REGENERATED 1 /* receiver regenerated lines */
| 293 |
#define CLEANFAXDATA_UNCLEAN 2 /* uncorrected errors exist */
| 294 |
#define TIFFTAG_CONSECUTIVEBADFAXLINES 328 /* max consecutive bad lines */
| 295 |
#define TIFFTAG_SUBIFD 330 /* subimage descriptors */
| 296 |
#define TIFFTAG_INKSET 332 /* !inks in separated image */
| 297 |
#define INKSET_CMYK 1 /* !cyan-magenta-yellow-black */
| 298 |
#define TIFFTAG_INKNAMES 333 /* !ascii names of inks */
| 299 |
#define TIFFTAG_NUMBEROFINKS 334 /* !number of inks */
| 300 |
#define TIFFTAG_DOTRANGE 336 /* !0% and 100% dot codes */
| 301 |
#define TIFFTAG_TARGETPRINTER 337 /* !separation target */
| 302 |
#define TIFFTAG_EXTRASAMPLES 338 /* !info about extra samples */
| 303 |
#define EXTRASAMPLE_UNSPECIFIED 0 /* !unspecified data */
| 304 |
#define EXTRASAMPLE_ASSOCALPHA 1 /* !associated alpha data */
| 305 |
#define EXTRASAMPLE_UNASSALPHA 2 /* !unassociated alpha data */
| 306 |
#define TIFFTAG_SAMPLEFORMAT 339 /* !data sample format */
| 307 |
#define SAMPLEFORMAT_UINT 1 /* !unsigned integer data */
| 308 |
#define SAMPLEFORMAT_INT 2 /* !signed integer data */
| 309 |
#define SAMPLEFORMAT_IEEEFP 3 /* !IEEE floating point data */
| 310 |
#define SAMPLEFORMAT_VOID 4 /* !untyped data */
| 311 |
#define SAMPLEFORMAT_COMPLEXINT 5 /* !complex signed int */
| 312 |
#define SAMPLEFORMAT_COMPLEXIEEEFP 6 /* !complex ieee floating */
| 313 |
#define TIFFTAG_SMINSAMPLEVALUE 340 /* !variable MinSampleValue */
| 314 |
#define TIFFTAG_SMAXSAMPLEVALUE 341 /* !variable MaxSampleValue */
| 315 |
#define TIFFTAG_JPEGTABLES 347 /* %JPEG table stream */
| 316 |
| 317 |
* Tags 512-521 are obsoleted by Technical Note #2
| 318 |
* which specifies a revised JPEG-in-TIFF scheme.
| 319 |
| 320 |
#define TIFFTAG_JPEGPROC 512 /* !JPEG processing algorithm */
| 321 |
#define JPEGPROC_BASELINE 1 /* !baseline sequential */
| 322 |
#define JPEGPROC_LOSSLESS 14 /* !Huffman coded lossless */
| 323 |
#define TIFFTAG_JPEGIFOFFSET 513 /* !pointer to SOI marker */
| 324 |
#define TIFFTAG_JPEGIFBYTECOUNT 514 /* !JFIF stream length */
| 325 |
#define TIFFTAG_JPEGRESTARTINTERVAL 515 /* !restart interval length */
| 326 |
#define TIFFTAG_JPEGLOSSLESSPREDICTORS 517 /* !lossless proc predictor */
| 327 |
#define TIFFTAG_JPEGPOINTTRANSFORM 518 /* !lossless point transform */
| 328 |
#define TIFFTAG_JPEGQTABLES 519 /* !Q matrice offsets */
| 329 |
#define TIFFTAG_JPEGDCTABLES 520 /* !DCT table offsets */
| 330 |
#define TIFFTAG_JPEGACTABLES 521 /* !AC coefficient offsets */
| 331 |
#define TIFFTAG_YCBCRCOEFFICIENTS 529 /* !RGB -> YCbCr transform */
| 332 |
#define TIFFTAG_YCBCRSUBSAMPLING 530 /* !YCbCr subsampling factors */
| 333 |
#define TIFFTAG_YCBCRPOSITIONING 531 /* !subsample positioning */
| 334 |
#define YCBCRPOSITION_CENTERED 1 /* !as in PostScript Level 2 */
| 335 |
#define YCBCRPOSITION_COSITED 2 /* !as in CCIR 601-1 */
| 336 |
#define TIFFTAG_REFERENCEBLACKWHITE 532 /* !colorimetry info */
| 337 |
/* tags 32952-32956 are private tags registered to Island Graphics */
| 338 |
#define TIFFTAG_REFPTS 32953 /* image reference points */
| 339 |
#define TIFFTAG_REGIONTACKPOINT 32954 /* region-xform tack point */
| 340 |
#define TIFFTAG_REGIONWARPCORNERS 32955 /* warp quadrilateral */
| 341 |
#define TIFFTAG_REGIONAFFINE 32956 /* affine transformation mat */
| 342 |
/* tags 32995-32999 are private tags registered to SGI */
| 343 |
#define TIFFTAG_MATTEING 32995 /* $use ExtraSamples */
| 344 |
#define TIFFTAG_DATATYPE 32996 /* $use SampleFormat */
| 345 |
#define TIFFTAG_IMAGEDEPTH 32997 /* z depth of image */
| 346 |
#define TIFFTAG_TILEDEPTH 32998 /* z depth/data tile */
| 347 |
/* tags 33300-33309 are private tags registered to Pixar */
| 348 |
| 349 |
* TIFFTAG_PIXAR_IMAGEFULLWIDTH and TIFFTAG_PIXAR_IMAGEFULLLENGTH
| 350 |
* are set when an image has been cropped out of a larger image.
| 351 |
* They reflect the size of the original uncropped image.
| 352 |
* The TIFFTAG_XPOSITION and TIFFTAG_YPOSITION can be used
| 353 |
* to determine the position of the smaller image in the larger one.
| 354 |
| 355 |
#define TIFFTAG_PIXAR_IMAGEFULLWIDTH 33300 /* full image size in x */
| 356 |
#define TIFFTAG_PIXAR_IMAGEFULLLENGTH 33301 /* full image size in y */
| 357 |
/* Tags 33302-33306 are used to identify special image modes and data
| 358 |
* used by Pixar's texture formats.
| 359 |
| 360 |
#define TIFFTAG_PIXAR_TEXTUREFORMAT 33302 /* texture map format */
| 361 |
#define TIFFTAG_PIXAR_WRAPMODES 33303 /* s & t wrap modes */
| 362 |
#define TIFFTAG_PIXAR_FOVCOT 33304 /* cotan(fov) for env. maps */
| 363 |
#define TIFFTAG_PIXAR_MATRIX_WORLDTOSCREEN 33305
| 364 |
#define TIFFTAG_PIXAR_MATRIX_WORLDTOCAMERA 33306
| 365 |
/* tag 33405 is a private tag registered to Eastman Kodak */
| 366 |
#define TIFFTAG_WRITERSERIALNUMBER 33405 /* device serial number */
| 367 |
/* tag 33432 is listed in the 6.0 spec w/ unknown ownership */
| 368 |
#define TIFFTAG_COPYRIGHT 33432 /* copyright string */
| 369 |
/* IPTC TAG from RichTIFF specifications */
| 370 |
#define TIFFTAG_RICHTIFFIPTC 33723
| 371 |
/* 34016-34029 are reserved for ANSI IT8 TIFF/IT <[email protected]) */
| 372 |
#define TIFFTAG_IT8SITE 34016 /* site name */
| 373 |
#define TIFFTAG_IT8COLORSEQUENCE 34017 /* color seq. [RGB,CMYK,etc] */
| 374 |
#define TIFFTAG_IT8HEADER 34018 /* DDES Header */
| 375 |
#define TIFFTAG_IT8RASTERPADDING 34019 /* raster scanline padding */
| 376 |
#define TIFFTAG_IT8BITSPERRUNLENGTH 34020 /* # of bits in short run */
| 377 |
#define TIFFTAG_IT8BITSPEREXTENDEDRUNLENGTH 34021/* # of bits in long run */
| 378 |
#define TIFFTAG_IT8COLORTABLE 34022 /* LW colortable */
| 379 |
#define TIFFTAG_IT8IMAGECOLORINDICATOR 34023 /* BP/BL image color switch */
| 380 |
#define TIFFTAG_IT8BKGCOLORINDICATOR 34024 /* BP/BL bg color switch */
| 381 |
#define TIFFTAG_IT8IMAGECOLORVALUE 34025 /* BP/BL image color value */
| 382 |
#define TIFFTAG_IT8BKGCOLORVALUE 34026 /* BP/BL bg color value */
| 383 |
#define TIFFTAG_IT8PIXELINTENSITYRANGE 34027 /* MP pixel intensity value */
| 384 |
#define TIFFTAG_IT8TRANSPARENCYINDICATOR 34028 /* HC transparency switch */
| 385 |
#define TIFFTAG_IT8COLORCHARACTERIZATION 34029 /* color character. table */
| 386 |
/* tags 34232-34236 are private tags registered to Texas Instruments */
| 387 |
#define TIFFTAG_FRAMECOUNT 34232 /* Sequence Frame Count */
| 388 |
/* tag 34750 is a private tag registered to Adobe? */
| 389 |
#define TIFFTAG_ICCPROFILE 34675 /* ICC profile data */
| 390 |
/* tag 34377 is private tag registered to Adobe for PhotoShop */
| 391 |
#define TIFFTAG_PHOTOSHOP 34377
| 392 |
/* tag 34750 is a private tag registered to Pixel Magic */
| 393 |
#define TIFFTAG_JBIGOPTIONS 34750 /* JBIG options */
| 394 |
/* tags 34908-34914 are private tags registered to SGI */
| 395 |
#define TIFFTAG_FAXRECVPARAMS 34908 /* encoded Class 2 ses. parms */
| 396 |
#define TIFFTAG_FAXSUBADDRESS 34909 /* received SubAddr string */
| 397 |
#define TIFFTAG_FAXRECVTIME 34910 /* receive time (secs) */
| 398 |
/* tags 37439-37443 are registered to SGI <[email protected]> */
| 399 |
#define TIFFTAG_STONITS 37439 /* Sample value to Nits */
| 400 |
/* tag 34929 is a private tag registered to FedEx */
| 401 |
#define TIFFTAG_FEDEX_EDR 34929 /* unknown use */
| 402 |
/* tag 65535 is an undefined tag used by Eastman Kodak */
| 403 |
#define TIFFTAG_DCSHUESHIFTVALUES 65535 /* hue shift correction data */
| 404 |
| 405 |
| 406 |
* The following are ``pseudo tags'' that can be
| 407 |
* used to control codec-specific functionality.
| 408 |
* These tags are not written to file. Note that
| 409 |
* these values start at 0xffff+1 so that they'll
| 410 |
* never collide with Aldus-assigned tags.
| 411 |
| 412 |
* If you want your private pseudo tags ``registered''
| 413 |
* (i.e. added to this file), send mail to [email protected]
| 414 |
* with the appropriate C definitions to add.
| 415 |
| 416 |
#define TIFFTAG_FAXMODE 65536 /* Group 3/4 format control */
| 417 |
#define FAXMODE_CLASSIC 0x0000 /* default, include RTC */
| 418 |
#define FAXMODE_NORTC 0x0001 /* no RTC at end of data */
| 419 |
#define FAXMODE_NOEOL 0x0002 /* no EOL code at end of row */
| 420 |
#define FAXMODE_BYTEALIGN 0x0004 /* byte align row */
| 421 |
#define FAXMODE_WORDALIGN 0x0008 /* word align row */
| 422 |
#define FAXMODE_CLASSF FAXMODE_NORTC /* TIFF Class F */
| 423 |
#define TIFFTAG_JPEGQUALITY 65537 /* Compression quality level */
| 424 |
/* Note: quality level is on the IJG 0-100 scale. Default value is 75 */
| 425 |
#define TIFFTAG_JPEGCOLORMODE 65538 /* Auto RGB<=>YCbCr convert? */
| 426 |
#define JPEGCOLORMODE_RAW 0x0000 /* no conversion (default) */
| 427 |
#define JPEGCOLORMODE_RGB 0x0001 /* do auto conversion */
| 428 |
#define TIFFTAG_JPEGTABLESMODE 65539 /* What to put in JPEGTables */
| 429 |
#define JPEGTABLESMODE_QUANT 0x0001 /* include quantization tbls */
| 430 |
#define JPEGTABLESMODE_HUFF 0x0002 /* include Huffman tbls */
| 431 |
/* Note: default is JPEGTABLESMODE_QUANT | JPEGTABLESMODE_HUFF */
| 432 |
#define TIFFTAG_FAXFILLFUNC 65540 /* G3/G4 fill function */
| 433 |
#define TIFFTAG_PIXARLOGDATAFMT 65549 /* PixarLogCodec I/O data sz */
| 434 |
#define PIXARLOGDATAFMT_8BIT 0 /* regular u_char samples */
| 435 |
#define PIXARLOGDATAFMT_8BITABGR 1 /* ABGR-order u_chars */
| 436 |
#define PIXARLOGDATAFMT_11BITLOG 2 /* 11-bit log-encoded (raw) */
| 437 |
#define PIXARLOGDATAFMT_12BITPICIO 3 /* as per PICIO (1.0==2048) */
| 438 |
#define PIXARLOGDATAFMT_16BIT 4 /* signed short samples */
| 439 |
#define PIXARLOGDATAFMT_FLOAT 5 /* IEEE float samples */
| 440 |
/* 65550-65556 are allocated to Oceana Matrix <[email protected]> */
| 441 |
#define TIFFTAG_DCSIMAGERTYPE 65550 /* imager model & filter */
| 442 |
#define DCSIMAGERMODEL_M3 0 /* M3 chip (1280 x 1024) */
| 443 |
#define DCSIMAGERMODEL_M5 1 /* M5 chip (1536 x 1024) */
| 444 |
#define DCSIMAGERMODEL_M6 2 /* M6 chip (3072 x 2048) */
| 445 |
#define DCSIMAGERFILTER_IR 0 /* infrared filter */
| 446 |
#define DCSIMAGERFILTER_MONO 1 /* monochrome filter */
| 447 |
#define DCSIMAGERFILTER_CFA 2 /* color filter array */
| 448 |
#define DCSIMAGERFILTER_OTHER 3 /* other filter */
| 449 |
#define TIFFTAG_DCSINTERPMODE 65551 /* interpolation mode */
| 450 |
#define DCSINTERPMODE_NORMAL 0x0 /* whole image, default */
| 451 |
#define DCSINTERPMODE_PREVIEW 0x1 /* preview of image (384x256) */
| 452 |
#define TIFFTAG_DCSBALANCEARRAY 65552 /* color balance values */
| 453 |
#define TIFFTAG_DCSCORRECTMATRIX 65553 /* color correction values */
| 454 |
#define TIFFTAG_DCSGAMMA 65554 /* gamma value */
| 455 |
#define TIFFTAG_DCSTOESHOULDERPTS 65555 /* toe & shoulder points */
| 456 |
#define TIFFTAG_DCSCALIBRATIONFD 65556 /* calibration file desc */
| 457 |
/* Note: quality level is on the ZLIB 1-9 scale. Default value is -1 */
| 458 |
#define TIFFTAG_ZIPQUALITY 65557 /* compression quality level */
| 459 |
#define TIFFTAG_PIXARLOGQUALITY 65558 /* PixarLog uses same scale */
| 460 |
/* 65559 is allocated to Oceana Matrix <[email protected]> */
| 461 |
#define TIFFTAG_DCSCLIPRECTANGLE 65559 /* area of image to acquire */
| 462 |
#define TIFFTAG_SGILOGDATAFMT 65560 /* SGILog user data format */
| 463 |
#define SGILOGDATAFMT_FLOAT 0 /* IEEE float samples */
| 464 |
#define SGILOGDATAFMT_16BIT 1 /* 16-bit samples */
| 465 |
#define SGILOGDATAFMT_RAW 2 /* uninterpreted data */
| 466 |
#define SGILOGDATAFMT_8BIT 3 /* 8-bit RGB monitor values */
| 467 |
#define TIFFTAG_SGILOGENCODE 65561 /* SGILog data encoding control*/
| 468 |
#define SGILOGENCODE_NODITHER 0 /* do not dither encoded values*/
| 469 |
#define SGILOGENCODE_RANDITHER 1 /* randomly dither encd values */
| 470 |
#endif /* _TIFF_ */
