--- ray/src/common/tiff.h 2003/06/05 19:29:34 3.2 +++ ray/src/common/tiff.h 2003/09/09 15:01:22 3.11 @@ -1,4 +1,4 @@ -/* $Header: /usr/local/cvs/radiance/ray/src/common/tiff.h,v 3.2 2003/06/05 19:29:34 schorsch Exp $ */ +/* $Header: /usr/local/cvs/radiance/ray/src/common/tiff.h,v 3.11 2003/09/09 15:01:22 greg Exp $ */ /* * Copyright (c) 1988-1997 Sam Leffler @@ -42,8 +42,26 @@ #define TIFF_BIGENDIAN 0x4d4d #define TIFF_LITTLEENDIAN 0x4949 +/* + * The so called TIFF types conflict with definitions from inttypes.h + * included from sys/types.h on AIX (at least using VisualAge compiler). + * We try to work around this by detecting this case. Defining + * _TIFF_DATA_TYPEDEFS_ short circuits the later definitions in tiff.h, and + * we will in the holes not provided for by inttypes.h. + * + * See http://bugzilla.remotesensing.org/show_bug.cgi?id=39 + */ +#if defined(_H_INTTYPES) && defined(_ALL_SOURCE) + #ifndef _TIFF_DATA_TYPEDEFS_ #define _TIFF_DATA_TYPEDEFS_ +typedef unsigned char uint8; +typedef unsigned short uint16; +typedef unsigned int uint32; +#endif + +#endif + /* * Intrinsic data types required by the file format: * @@ -52,6 +70,9 @@ * 32-bit quantities int32/uint32 * strings unsigned char* */ +#ifndef _TIFF_DATA_TYPEDEFS_ +#define _TIFF_DATA_TYPEDEFS_ + #ifdef __STDC__ typedef signed char int8; /* NB: non-ANSI compilers may not grok */ #else @@ -60,7 +81,7 @@ typedef char int8; typedef unsigned char uint8; typedef short int16; typedef unsigned short uint16; /* sizeof (uint16) must == 2 */ -#if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) +#if defined(__alpha) || (defined(_MIPS_SZLONG) && _MIPS_SZLONG == 64) || defined(__LP64__) typedef int int32; typedef unsigned int uint32; /* sizeof (uint32) must == 4 */ #else @@ -150,7 +171,9 @@ typedef enum { #define COMPRESSION_NONE 1 /* dump mode */ #define COMPRESSION_CCITTRLE 2 /* CCITT modified Huffman RLE */ #define COMPRESSION_CCITTFAX3 3 /* CCITT Group 3 fax encoding */ +#define COMPRESSION_CCITT_T4 3 /* CCITT T.4 (TIFF 6 name) */ #define COMPRESSION_CCITTFAX4 4 /* CCITT Group 4 fax encoding */ +#define COMPRESSION_CCITT_T6 4 /* CCITT T.6 (TIFF 6 name) */ #define COMPRESSION_LZW 5 /* Lempel-Ziv & Welch */ #define COMPRESSION_OJPEG 6 /* !6.0 JPEG */ #define COMPRESSION_JPEG 7 /* %JPEG DCT compression */ @@ -182,6 +205,7 @@ typedef enum { #define PHOTOMETRIC_SEPARATED 5 /* !color separations */ #define PHOTOMETRIC_YCBCR 6 /* !CCIR 601 */ #define PHOTOMETRIC_CIELAB 8 /* !1976 CIE L*a*b* */ +#define PHOTOMETRIC_ITULAB 10 /* ITU L*a*b* */ #define PHOTOMETRIC_LOGL 32844 /* CIE Log2(L) */ #define PHOTOMETRIC_LOGLUV 32845 /* CIE Log2(L) (u',v') */ #define TIFFTAG_THRESHHOLDING 263 /* +thresholding used on data */ @@ -230,10 +254,12 @@ typedef enum { #define GRAYRESPONSEUNIT_100000S 5 /* hundred-thousandths */ #define TIFFTAG_GRAYRESPONSECURVE 291 /* $gray scale response curve */ #define TIFFTAG_GROUP3OPTIONS 292 /* 32 flag bits */ +#define TIFFTAG_T4OPTIONS 292 /* TIFF 6.0 proper name alias */ #define GROUP3OPT_2DENCODING 0x1 /* 2-dimensional coding */ #define GROUP3OPT_UNCOMPRESSED 0x2 /* data not compressed */ #define GROUP3OPT_FILLBITS 0x4 /* fill to byte boundary */ #define TIFFTAG_GROUP4OPTIONS 293 /* 32 flag bits */ +#define TIFFTAG_T6OPTIONS 293 /* TIFF 6.0 proper name */ #define GROUP4OPT_UNCOMPRESSED 0x2 /* data not compressed */ #define TIFFTAG_RESOLUTIONUNIT 296 /* units of resolutions */ #define RESUNIT_NONE 1 /* no meaningful units */ @@ -369,10 +395,10 @@ typedef enum { #define TIFFTAG_FAXRECVPARAMS 34908 /* encoded Class 2 ses. parms */ #define TIFFTAG_FAXSUBADDRESS 34909 /* received SubAddr string */ #define TIFFTAG_FAXRECVTIME 34910 /* receive time (secs) */ -/* tag 34929 is a private tag registered to FedEx */ -#define TIFFTAG_FEDEX_EDR 34929 /* unknown use */ /* tags 37439-37443 are registered to SGI */ #define TIFFTAG_STONITS 37439 /* Sample value to Nits */ +/* tag 34929 is a private tag registered to FedEx */ +#define TIFFTAG_FEDEX_EDR 34929 /* unknown use */ /* tag 65535 is an undefined tag used by Eastman Kodak */ #define TIFFTAG_DCSHUESHIFTVALUES 65535 /* hue shift correction data */ @@ -438,7 +464,7 @@ typedef enum { #define SGILOGDATAFMT_16BIT 1 /* 16-bit samples */ #define SGILOGDATAFMT_RAW 2 /* uninterpreted data */ #define SGILOGDATAFMT_8BIT 3 /* 8-bit RGB monitor values */ -#define TIFFTAG_SGILOGENCODE 65561 /* SGILog data encoding control */ -#define SGILOGENCODE_NODITHER 0 /* do not dither encoded values */ -#define SGILOGENCODE_RANDITHER 1 /* randomly dither encoded values */ +#define TIFFTAG_SGILOGENCODE 65561 /* SGILog data encoding control*/ +#define SGILOGENCODE_NODITHER 0 /* do not dither encoded values*/ +#define SGILOGENCODE_RANDITHER 1 /* randomly dither encd values */ #endif /* _TIFF_ */
