root/Development/ray/src/common/testBSDF.c
Revision: 1.8
Committed: Thu Feb 2 00:34:55 2017 UTC (8 years, 9 months ago) by greg
Changes since 1.7: +13 -13 lines
Eliminated comparisons to NULL
2 static const char RCSid[] = "$Id: testBSDF.c,v 1.7 2017/02/02 00:30:16 greg Exp $";
5 * Simple test program to demonstrate BSDF operation.
6 *
7 * G. Ward June 2015
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include <ctype.h>
15 #include "rtio.h"
16 #include "bsdf.h"
17
18 static void
19 Usage(const char *prog)
20 {
21 printf("Usage: %s [bsdf_directory]\n", prog);
22 printf("Input commands:\n");
23 printf(" L bsdf.xml\t\t\t Load (make active) given BSDF input file\n");
24 printf(" i\t\t\t\t Report general information (metadata)\n");
25 printf(" c\t\t\t\t Report diffuse and specular components\n");
26 printf(" q theta_i phi_i theta_o phi_o\t Query BSDF for given path (CIE-XYZ)\n");
27 printf(" s N theta phi\t\t\t Generate N ray directions at given incidence\n");
28 printf(" h theta phi\t\t\t Report hemispherical total at given incidence\n");
29 printf(" r theta phi\t\t\t Report hemispherical reflection at given incidence\n");
30 printf(" t theta phi\t\t\t Report hemispherical transmission at given incidence\n");
31 printf(" a theta phi [t2 p2]\t\t Report resolution (in proj. steradians) for given direction(s)\n");
32 printf(" ^D\t\t\t\t Quit program\n");
33 }
34
35 static void
36 vec_from_deg(FVECT v, double theta, double phi)
37 {
38 const double DEG = M_PI/180.;
39
40 theta *= DEG; phi *= DEG;
41 v[0] = v[1] = sin(theta);
42 v[0] *= cos(phi);
43 v[1] *= sin(phi);
44 v[2] = cos(theta);
45 }
46
47 static void
48 printXYZ(const char *intro, const SDValue *vp)
49 {
50 printf("%s%.3e %.3e %.3e\n", intro,
51 vp->spec.cx/vp->spec.cy*vp->cieY,
52 vp->cieY,
53 (1.-vp->spec.cx-vp->spec.cy)/
54 vp->spec.cy*vp->cieY);
55 }
56
57 int
58 main(int argc, char *argv[])
59 {
60 const char *directory = NULL;
61 char inp[512], path[512];
62 const SDData *bsdf = NULL;
63
64 if (argc > 2 || (argc == 2 && argv[1][0] == '-')) {
65 Usage(argv[0]);
66 return 1;
67 }
68 if (argc == 2)
69 directory = argv[1];
70
71 SDretainSet = SDretainBSDFs; /* keep BSDFs in memory */
72
73 /* loop on command */
74 while (fgets(inp, sizeof(inp), stdin)) {
75 int sflags = SDsampAll;
76 char *cp = inp;
77 char *cp2;
78 FVECT vin, vout;
79 double proja[2];
80 int n;
81 SDValue val;
82
83 while (isspace(*cp)) cp++;
84
85 switch (toupper(*cp)) {
86 case 'L': /* load/activate BSDF input */
87 cp2 = cp = sskip2(cp, 1);
88 if (!*cp)
89 break;
90 while (*cp) cp++;
91 while (isspace(*--cp)) *cp = '\0';
92 if (directory)
93 sprintf(path, "%s/%s", directory, cp2);
94 else
95 strcpy(path, cp2);
96 if (bsdf)
97 SDfreeCache(bsdf);
98 bsdf = SDcacheFile(path);
99 continue;
100 case 'I': /* report general info. */
101 if (!bsdf)
102 goto noBSDFerr;
103 printf("Material: '%s'\n", bsdf->matn);
104 printf("Manufacturer: '%s'\n", bsdf->makr);
105 printf("Width, Height, Thickness (m): %.4e, %.4e, %.4e\n",
106 bsdf->dim[0], bsdf->dim[1], bsdf->dim[2]);
107 printf("Has geometry: %s\n", bsdf->mgf ? "yes" : "no");
108 continue;
109 case 'C': /* report constant values */
110 if (!bsdf)
111 goto noBSDFerr;
112 if (bsdf->rf)
113 printf("Peak front hemispherical reflectance: %.3e\n",
114 bsdf->rLambFront.cieY +
115 bsdf->rf->maxHemi);
116 if (bsdf->rb)
117 printf("Peak back hemispherical reflectance: %.3e\n",
118 bsdf->rLambBack.cieY +
119 bsdf->rb->maxHemi);
120 if (bsdf->tf)
121 printf("Peak front hemispherical transmittance: %.3e\n",
122 bsdf->tLamb.cieY + bsdf->tf->maxHemi);
123 if (bsdf->tb)
124 printf("Peak back hemispherical transmittance: %.3e\n",
125 bsdf->tLamb.cieY + bsdf->tb->maxHemi);
126 printXYZ("Diffuse Front Reflectance: ", &bsdf->rLambFront);
127 printXYZ("Diffuse Back Reflectance: ", &bsdf->rLambBack);
128 printXYZ("Diffuse Transmittance: ", &bsdf->tLamb);
129 continue;
130 case 'Q': /* query BSDF value */
131 if (!bsdf)
132 goto noBSDFerr;
133 if (!*sskip2(cp,4))
134 break;
135 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
136 vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4)));
137 if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr))
138 printXYZ("", &val);
139 continue;
140 case 'S': /* sample BSDF */
141 if (!bsdf)
142 goto noBSDFerr;
143 if (!*sskip2(cp,3))
144 break;
145 n = atoi(sskip2(cp,1));
146 vec_from_deg(vin, atof(sskip2(cp,2)), atof(sskip2(cp,3)));
147 while (n-- > 0) {
148 if (SDreportError(SDsampBSDF(&val, vin,
149 rand()*(1./(RAND_MAX+.5)),
150 sflags, bsdf), stderr))
151 break;
152 printf("%.8f %.8f %.8f\n", vin[0], vin[1], vin[2]);
153 }
154 continue;
155 case 'H': /* hemispherical totals */
156 case 'R':
157 case 'T':
158 if (!bsdf)
159 goto noBSDFerr;
160 if (!*sskip2(cp,2))
161 break;
162 if (tolower(*cp) == 'r')
163 sflags &= ~SDsampT;
164 else if (tolower(*cp) == 't')
165 sflags &= ~SDsampR;
166 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
167 printf("%.4e\n", SDdirectHemi(vin, sflags, bsdf));
168 continue;
169 case 'A': /* resolution in proj. steradians */
170 if (!bsdf)
171 goto noBSDFerr;
172 if (!*sskip2(cp,2))
173 break;
174 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
175 if (*sskip2(cp,4)) {
176 vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4)));
177 if (SDreportError(SDsizeBSDF(proja, vin, vout,
178 SDqueryMin+SDqueryMax, bsdf), stderr))
179 continue;
180 } else if (SDreportError(SDsizeBSDF(proja, vin, NULL,
181 SDqueryMin+SDqueryMax, bsdf), stderr))
182 continue;
183 printf("%.4e %.4e\n", proja[0], proja[1]);
184 continue;
185 }
186 Usage(argv[0]);
187 continue;
188 noBSDFerr:
189 fprintf(stderr, "%s: First, use 'L' command to load BSDF\n", argv[0]);
190 }
191 return 0;
192 }
