root/Development/ray/src/common/testBSDF.c
Tue Dec 7 23:49:50 2021 UTC (4 years ago) by greg
Diff to previous 1.16
Revision 1.16 - (view) (download) (annotate) - [selected]
Sat Mar 27 17:50:18 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.15: +5 -4 lines
Diff to previous 1.15
Sat Dec 28 18:05:14 2019 UTC (6 years ago) by greg
Changes since 1.14: +1 -2 lines
Diff to previous 1.14 , to selected 1.16
Tue Jun 11 14:26:29 2019 UTC (6 years, 6 months ago) by greg
Changes since 1.13: +11 -8 lines
Diff to previous 1.13 , to selected 1.16
Added output flushing for remote operation
Thu May 10 01:41:33 2018 UTC (7 years, 7 months ago) by greg
Changes since 1.12: +6 -2 lines
Diff to previous 1.12 , to selected 1.16
Added report of length of MGF geometry
Mon May 15 22:15:40 2017 UTC (8 years, 7 months ago) by greg
Diff to previous 1.11 , to selected 1.16
Reversed ordering of in/out vectors for consistency between "A" and "Q" commands
Tue Apr 11 16:14:05 2017 UTC (8 years, 8 months ago) by greg
Changes since 1.10: +5 -1 lines
Diff to previous 1.10 , to selected 1.16
Fixed issue with reporting zero XYZ values
Thu Feb 2 04:52:46 2017 UTC (8 years, 11 months ago) by greg
Changes since 1.9: +5 -5 lines
Diff to previous 1.9 , to selected 1.16
Corrected menu
Thu Feb 2 04:46:38 2017 UTC (8 years, 11 months ago) by greg
Changes since 1.8: +31 -14 lines
Diff to previous 1.8 , to selected 1.16
Bug fixes and improvements -- sampling was not working, now reports color
Thu Feb 2 00:34:55 2017 UTC (8 years, 11 months ago) by greg
Changes since 1.7: +13 -13 lines
Diff to previous 1.7 , to selected 1.16
Eliminated comparisons to NULL
Thu Feb 2 00:30:16 2017 UTC (8 years, 11 months ago) by greg
Diff to previous 1.6 , to selected 1.16
Slight change in order of metadata output
Thu Feb 2 00:27:55 2017 UTC (8 years, 11 months ago) by greg
Changes since 1.5: +46 -10 lines
Diff to previous 1.5 , to selected 1.16
Added 'i' and 'c' commands for printing metadata and constant values, resp.
Wed Feb 3 18:33:18 2016 UTC (9 years, 11 months ago) by greg
Changes since 1.4: +12 -6 lines
Diff to previous 1.4 , to selected 1.16
Added testBSDF build and provided for color (XYZ) output
Fri Jun 26 22:07:53 2015 UTC (10 years, 6 months ago) by greg
Changes since 1.3: +2 -9 lines
Diff to previous 1.3 , to selected 1.16
Simplified switch statement
Sat Jun 6 16:30:26 2015 UTC (10 years, 7 months ago) by greg
Changes since 1.2: +8 -8 lines
Diff to previous 1.2 , to selected 1.16
Minor fixes
Fri Jun 5 18:58:37 2015 UTC (10 years, 7 months ago) by greg
Diff to previous 1.1 , to selected 1.16
Added freeing of cached data
Fri Jun 5 17:55:18 2015 UTC (10 years, 7 months ago) by greg
Diff to selected 1.16
Created testBSDF main module to demonstrate BSDF library
