--- ray/src/common/testBSDF.c 2016/02/03 18:33:18 1.5 +++ ray/src/common/testBSDF.c 2017/05/15 22:15:40 1.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: testBSDF.c,v 1.5 2016/02/03 18:33:18 greg Exp $"; +static const char RCSid[] = "$Id: testBSDF.c,v 1.12 2017/05/15 22:15:40 greg Exp $"; #endif /* * Simple test program to demonstrate BSDF operation. @@ -21,11 +21,13 @@ Usage(const char *prog) printf("Usage: %s [bsdf_directory]\n", prog); printf("Input commands:\n"); printf(" L bsdf.xml\t\t\t Load (make active) given BSDF input file\n"); + printf(" i\t\t\t\t Report general information (metadata)\n"); + printf(" c\t\t\t\t Report diffuse and specular components\n"); printf(" q theta_i phi_i theta_o phi_o\t Query BSDF for given path (CIE-XYZ)\n"); - printf(" s N theta phi\t\t\t Generate N ray directions at given incidence\n"); - printf(" h theta phi\t\t\t Report hemispherical total at given incidence\n"); - printf(" r theta phi\t\t\t Report hemispherical reflection at given incidence\n"); - printf(" t theta phi\t\t\t Report hemispherical transmission at given incidence\n"); + printf(" s[r|t][s|d] N theta phi\t Generate N ray directions & colors at given incidence\n"); + printf(" h[s|d] theta phi\t\t Report hemispherical scattering at given incidence\n"); + printf(" r[s|d] theta phi\t\t Report hemispherical reflection at given incidence\n"); + printf(" t[s|d] theta phi\t\t Report hemispherical transmission at given incidence\n"); printf(" a theta phi [t2 p2]\t\t Report resolution (in proj. steradians) for given direction(s)\n"); printf(" ^D\t\t\t\t Quit program\n"); } @@ -42,6 +44,20 @@ vec_from_deg(FVECT v, double theta, double phi) v[2] = cos(theta); } +static void +printXYZ(const char *intro, const SDValue *vp) +{ + if (vp->cieY <= 1e-9) { + printf("%s0 0 0\n", intro); + return; + } + printf("%s%.3e %.3e %.3e\n", intro, + vp->spec.cx/vp->spec.cy*vp->cieY, + vp->cieY, + (1.-vp->spec.cx-vp->spec.cy)/ + vp->spec.cy*vp->cieY); +} + int main(int argc, char *argv[]) { @@ -59,13 +75,13 @@ main(int argc, char *argv[]) SDretainSet = SDretainBSDFs; /* keep BSDFs in memory */ /* loop on command */ - while (fgets(inp, sizeof(inp), stdin) != NULL) { + while (fgets(inp, sizeof(inp), stdin)) { int sflags = SDsampAll; char *cp = inp; char *cp2; FVECT vin, vout; double proja[2]; - int n; + int n, i; SDValue val; while (isspace(*cp)) cp++; @@ -85,60 +101,101 @@ main(int argc, char *argv[]) SDfreeCache(bsdf); bsdf = SDcacheFile(path); continue; + case 'I': /* report general info. */ + if (!bsdf) + goto noBSDFerr; + printf("Material: '%s'\n", bsdf->matn); + printf("Manufacturer: '%s'\n", bsdf->makr); + printf("Width, Height, Thickness (m): %.4e, %.4e, %.4e\n", + bsdf->dim[0], bsdf->dim[1], bsdf->dim[2]); + printf("Has geometry: %s\n", bsdf->mgf ? "yes" : "no"); + continue; + case 'C': /* report constant values */ + if (!bsdf) + goto noBSDFerr; + if (bsdf->rf) + printf("Peak front hemispherical reflectance: %.3e\n", + bsdf->rLambFront.cieY + + bsdf->rf->maxHemi); + if (bsdf->rb) + printf("Peak back hemispherical reflectance: %.3e\n", + bsdf->rLambBack.cieY + + bsdf->rb->maxHemi); + if (bsdf->tf) + printf("Peak front hemispherical transmittance: %.3e\n", + bsdf->tLamb.cieY + bsdf->tf->maxHemi); + if (bsdf->tb) + printf("Peak back hemispherical transmittance: %.3e\n", + bsdf->tLamb.cieY + bsdf->tb->maxHemi); + printXYZ("Diffuse Front Reflectance: ", &bsdf->rLambFront); + printXYZ("Diffuse Back Reflectance: ", &bsdf->rLambBack); + printXYZ("Diffuse Transmittance: ", &bsdf->tLamb); + continue; case 'Q': /* query BSDF value */ - if (bsdf == NULL) + if (!bsdf) goto noBSDFerr; if (!*sskip2(cp,4)) break; vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2))); vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4))); - if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr)) { - c_ccvt(&val.spec, C_CSXY); - printf("%.3e %.3e %.3e\n", - val.spec.cx/val.spec.cy*val.cieY, - val.cieY, - (1.-val.spec.cx-val.spec.cy)/ - val.spec.cy*val.cieY); - } + if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr)) + printXYZ("", &val); continue; case 'S': /* sample BSDF */ - if (bsdf == NULL) + if (!bsdf) goto noBSDFerr; if (!*sskip2(cp,3)) break; - n = atoi(sskip2(cp,1)); + if (toupper(cp[1]) == 'R') { + sflags &= ~SDsampT; + ++cp; + } else if (toupper(cp[1]) == 'T') { + sflags &= ~SDsampR; + ++cp; + } + if (toupper(cp[1]) == 'S') + sflags &= ~SDsampDf; + else if (toupper(cp[1]) == 'D') + sflags &= ~SDsampSp; + i = n = atoi(sskip2(cp,1)); vec_from_deg(vin, atof(sskip2(cp,2)), atof(sskip2(cp,3))); - while (n-- > 0) { - if (SDreportError(SDsampBSDF(&val, vin, - rand()*(1./(RAND_MAX+.5)), + while (i-- > 0) { + VCOPY(vout, vin); + if (SDreportError(SDsampBSDF(&val, vout, + (i+rand()*(1./(RAND_MAX+.5)))/(double)n, sflags, bsdf), stderr)) break; - printf("%.8f %.8f %.8f\n", vin[0], vin[1], vin[2]); + printf("%.8f %.8f %.8f ", vout[0], vout[1], vout[2]); + printXYZ("", &val); } continue; - case 'H': /* hemispherical totals */ + case 'H': /* hemispherical values */ case 'R': case 'T': - if (bsdf == NULL) + if (!bsdf) goto noBSDFerr; if (!*sskip2(cp,2)) break; - if (tolower(*cp) == 'r') + if (toupper(cp[0]) == 'R') sflags &= ~SDsampT; - else if (tolower(*cp) == 't') + else if (toupper(cp[0]) == 'T') sflags &= ~SDsampR; + if (toupper(cp[1]) == 'S') + sflags &= ~SDsampDf; + else if (toupper(cp[1]) == 'D') + sflags &= ~SDsampSp; vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2))); printf("%.4e\n", SDdirectHemi(vin, sflags, bsdf)); continue; case 'A': /* resolution in proj. steradians */ - if (bsdf == NULL) + if (!bsdf) goto noBSDFerr; if (!*sskip2(cp,2)) break; vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2))); if (*sskip2(cp,4)) { vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4))); - if (SDreportError(SDsizeBSDF(proja, vin, vout, + if (SDreportError(SDsizeBSDF(proja, vout, vin, SDqueryMin+SDqueryMax, bsdf), stderr)) continue; } else if (SDreportError(SDsizeBSDF(proja, vin, NULL, @@ -150,7 +207,7 @@ main(int argc, char *argv[]) Usage(argv[0]); continue; noBSDFerr: - fprintf(stderr, "%s: need to use 'L' command to load BSDF\n", argv[0]); + fprintf(stderr, "%s: First, use 'L' command to load BSDF\n", argv[0]); } return 0; }
