--- ray/src/common/testBSDF.c 2017/05/15 22:15:40 1.12 +++ ray/src/common/testBSDF.c 2021/12/07 23:49:50 1.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: testBSDF.c,v 1.12 2017/05/15 22:15:40 greg Exp $"; +static const char RCSid[] = "$Id: testBSDF.c,v 1.17 2021/12/07 23:49:50 greg Exp $"; #endif /* * Simple test program to demonstrate BSDF operation. @@ -8,7 +8,6 @@ static const char RCSid[] = "$Id: testBSDF.c,v 1.12 20 */ #define _USE_MATH_DEFINES -#include #include #include #include @@ -108,8 +107,12 @@ main(int argc, char *argv[]) printf("Manufacturer: '%s'\n", bsdf->makr); printf("Width, Height, Thickness (m): %.4e, %.4e, %.4e\n", bsdf->dim[0], bsdf->dim[1], bsdf->dim[2]); - printf("Has geometry: %s\n", bsdf->mgf ? "yes" : "no"); - continue; + if (bsdf->mgf) + printf("Has geometry: %lu bytes\n", + (unsigned long)strlen(bsdf->mgf)); + else + printf("Has geometry: no\n"); + break; case 'C': /* report constant values */ if (!bsdf) goto noBSDFerr; @@ -123,14 +126,15 @@ main(int argc, char *argv[]) bsdf->rb->maxHemi); if (bsdf->tf) printf("Peak front hemispherical transmittance: %.3e\n", - bsdf->tLamb.cieY + bsdf->tf->maxHemi); + bsdf->tLambFront.cieY + bsdf->tf->maxHemi); if (bsdf->tb) printf("Peak back hemispherical transmittance: %.3e\n", - bsdf->tLamb.cieY + bsdf->tb->maxHemi); + bsdf->tLambBack.cieY + bsdf->tb->maxHemi); printXYZ("Diffuse Front Reflectance: ", &bsdf->rLambFront); printXYZ("Diffuse Back Reflectance: ", &bsdf->rLambBack); - printXYZ("Diffuse Transmittance: ", &bsdf->tLamb); - continue; + printXYZ("Diffuse Front Transmittance: ", &bsdf->tLambFront); + printXYZ("Diffuse Back Transmittance: ", &bsdf->tLambBack); + break; case 'Q': /* query BSDF value */ if (!bsdf) goto noBSDFerr; @@ -138,9 +142,9 @@ main(int argc, char *argv[]) break; vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2))); vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4))); - if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr)) + if (!SDreportError(SDevalBSDF(&val, vin, vout, bsdf), stderr)) printXYZ("", &val); - continue; + break; case 'S': /* sample BSDF */ if (!bsdf) goto noBSDFerr; @@ -168,7 +172,7 @@ main(int argc, char *argv[]) printf("%.8f %.8f %.8f ", vout[0], vout[1], vout[2]); printXYZ("", &val); } - continue; + break; case 'H': /* hemispherical values */ case 'R': case 'T': @@ -186,7 +190,7 @@ main(int argc, char *argv[]) sflags &= ~SDsampSp; vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2))); printf("%.4e\n", SDdirectHemi(vin, sflags, bsdf)); - continue; + break; case 'A': /* resolution in proj. steradians */ if (!bsdf) goto noBSDFerr; @@ -202,9 +206,12 @@ main(int argc, char *argv[]) SDqueryMin+SDqueryMax, bsdf), stderr)) continue; printf("%.4e %.4e\n", proja[0], proja[1]); - continue; + break; + default: + Usage(argv[0]); + break; } - Usage(argv[0]); + fflush(stdout); /* in case we're on remote */ continue; noBSDFerr: fprintf(stderr, "%s: First, use 'L' command to load BSDF\n", argv[0]);
