root/radiance/ray/src/common/testBSDF.c
Revision: 1.14
Committed: Tue Jun 11 14:26:29 2019 UTC (6 years, 1 month ago) by greg
Changes since 1.13: +11 -8 lines
Added output flushing for remote operation
2 static const char RCSid[] = "$Id: testBSDF.c,v 1.13 2018/05/10 01:41:33 greg Exp $";
5 * Simple test program to demonstrate BSDF operation.
6 *
7 * G. Ward June 2015
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include <ctype.h>
15 #include "rtio.h"
16 #include "bsdf.h"
17
18 static void
19 Usage(const char *prog)
20 {
21 printf("Usage: %s [bsdf_directory]\n", prog);
22 printf("Input commands:\n");
23 printf(" L bsdf.xml\t\t\t Load (make active) given BSDF input file\n");
24 printf(" i\t\t\t\t Report general information (metadata)\n");
25 printf(" c\t\t\t\t Report diffuse and specular components\n");
26 printf(" q theta_i phi_i theta_o phi_o\t Query BSDF for given path (CIE-XYZ)\n");
27 printf(" s[r|t][s|d] N theta phi\t Generate N ray directions & colors at given incidence\n");
28 printf(" h[s|d] theta phi\t\t Report hemispherical scattering at given incidence\n");
29 printf(" r[s|d] theta phi\t\t Report hemispherical reflection at given incidence\n");
30 printf(" t[s|d] theta phi\t\t Report hemispherical transmission at given incidence\n");
31 printf(" a theta phi [t2 p2]\t\t Report resolution (in proj. steradians) for given direction(s)\n");
32 printf(" ^D\t\t\t\t Quit program\n");
33 }
34
35 static void
36 vec_from_deg(FVECT v, double theta, double phi)
37 {
38 const double DEG = M_PI/180.;
39
40 theta *= DEG; phi *= DEG;
41 v[0] = v[1] = sin(theta);
42 v[0] *= cos(phi);
43 v[1] *= sin(phi);
44 v[2] = cos(theta);
45 }
46
47 static void
48 printXYZ(const char *intro, const SDValue *vp)
49 {
50 if (vp->cieY <= 1e-9) {
51 printf("%s0 0 0\n", intro);
52 return;
53 }
54 printf("%s%.3e %.3e %.3e\n", intro,
55 vp->spec.cx/vp->spec.cy*vp->cieY,
56 vp->cieY,
57 (1.-vp->spec.cx-vp->spec.cy)/
58 vp->spec.cy*vp->cieY);
59 }
60
61 int
62 main(int argc, char *argv[])
63 {
64 const char *directory = NULL;
65 char inp[512], path[512];
66 const SDData *bsdf = NULL;
67
68 if (argc > 2 || (argc == 2 && argv[1][0] == '-')) {
69 Usage(argv[0]);
70 return 1;
71 }
72 if (argc == 2)
73 directory = argv[1];
74
75 SDretainSet = SDretainBSDFs; /* keep BSDFs in memory */
76
77 /* loop on command */
78 while (fgets(inp, sizeof(inp), stdin)) {
79 int sflags = SDsampAll;
80 char *cp = inp;
81 char *cp2;
82 FVECT vin, vout;
83 double proja[2];
84 int n, i;
85 SDValue val;
86
87 while (isspace(*cp)) cp++;
88
89 switch (toupper(*cp)) {
90 case 'L': /* load/activate BSDF input */
91 cp2 = cp = sskip2(cp, 1);
92 if (!*cp)
93 break;
94 while (*cp) cp++;
95 while (isspace(*--cp)) *cp = '\0';
96 if (directory)
97 sprintf(path, "%s/%s", directory, cp2);
98 else
99 strcpy(path, cp2);
100 if (bsdf)
101 SDfreeCache(bsdf);
102 bsdf = SDcacheFile(path);
103 continue;
104 case 'I': /* report general info. */
105 if (!bsdf)
106 goto noBSDFerr;
107 printf("Material: '%s'\n", bsdf->matn);
108 printf("Manufacturer: '%s'\n", bsdf->makr);
109 printf("Width, Height, Thickness (m): %.4e, %.4e, %.4e\n",
110 bsdf->dim[0], bsdf->dim[1], bsdf->dim[2]);
111 if (bsdf->mgf)
112 printf("Has geometry: %lu bytes\n",
113 (unsigned long)strlen(bsdf->mgf));
114 else
115 printf("Has geometry: no\n");
116 break;
117 case 'C': /* report constant values */
118 if (!bsdf)
119 goto noBSDFerr;
120 if (bsdf->rf)
121 printf("Peak front hemispherical reflectance: %.3e\n",
122 bsdf->rLambFront.cieY +
123 bsdf->rf->maxHemi);
124 if (bsdf->rb)
125 printf("Peak back hemispherical reflectance: %.3e\n",
126 bsdf->rLambBack.cieY +
127 bsdf->rb->maxHemi);
128 if (bsdf->tf)
129 printf("Peak front hemispherical transmittance: %.3e\n",
130 bsdf->tLamb.cieY + bsdf->tf->maxHemi);
131 if (bsdf->tb)
132 printf("Peak back hemispherical transmittance: %.3e\n",
133 bsdf->tLamb.cieY + bsdf->tb->maxHemi);
134 printXYZ("Diffuse Front Reflectance: ", &bsdf->rLambFront);
135 printXYZ("Diffuse Back Reflectance: ", &bsdf->rLambBack);
136 printXYZ("Diffuse Transmittance: ", &bsdf->tLamb);
137 break;
138 case 'Q': /* query BSDF value */
139 if (!bsdf)
140 goto noBSDFerr;
141 if (!*sskip2(cp,4))
142 break;
143 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
144 vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4)));
145 if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr))
146 printXYZ("", &val);
147 break;
148 case 'S': /* sample BSDF */
149 if (!bsdf)
150 goto noBSDFerr;
151 if (!*sskip2(cp,3))
152 break;
153 if (toupper(cp[1]) == 'R') {
154 sflags &= ~SDsampT;
155 ++cp;
156 } else if (toupper(cp[1]) == 'T') {
157 sflags &= ~SDsampR;
158 ++cp;
159 }
160 if (toupper(cp[1]) == 'S')
161 sflags &= ~SDsampDf;
162 else if (toupper(cp[1]) == 'D')
163 sflags &= ~SDsampSp;
164 i = n = atoi(sskip2(cp,1));
165 vec_from_deg(vin, atof(sskip2(cp,2)), atof(sskip2(cp,3)));
166 while (i-- > 0) {
167 VCOPY(vout, vin);
168 if (SDreportError(SDsampBSDF(&val, vout,
169 (i+rand()*(1./(RAND_MAX+.5)))/(double)n,
170 sflags, bsdf), stderr))
171 break;
172 printf("%.8f %.8f %.8f ", vout[0], vout[1], vout[2]);
173 printXYZ("", &val);
174 }
175 break;
176 case 'H': /* hemispherical values */
177 case 'R':
178 case 'T':
179 if (!bsdf)
180 goto noBSDFerr;
181 if (!*sskip2(cp,2))
182 break;
183 if (toupper(cp[0]) == 'R')
184 sflags &= ~SDsampT;
185 else if (toupper(cp[0]) == 'T')
186 sflags &= ~SDsampR;
187 if (toupper(cp[1]) == 'S')
188 sflags &= ~SDsampDf;
189 else if (toupper(cp[1]) == 'D')
190 sflags &= ~SDsampSp;
191 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
192 printf("%.4e\n", SDdirectHemi(vin, sflags, bsdf));
193 break;
194 case 'A': /* resolution in proj. steradians */
195 if (!bsdf)
196 goto noBSDFerr;
197 if (!*sskip2(cp,2))
198 break;
199 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
200 if (*sskip2(cp,4)) {
201 vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4)));
202 if (SDreportError(SDsizeBSDF(proja, vout, vin,
203 SDqueryMin+SDqueryMax, bsdf), stderr))
204 continue;
205 } else if (SDreportError(SDsizeBSDF(proja, vin, NULL,
206 SDqueryMin+SDqueryMax, bsdf), stderr))
207 continue;
208 printf("%.4e %.4e\n", proja[0], proja[1]);
209 break;
210 default:
211 Usage(argv[0]);
212 break;
213 }
214 fflush(stdout); /* in case we're on remote */
215 continue;
216 noBSDFerr:
217 fprintf(stderr, "%s: First, use 'L' command to load BSDF\n", argv[0]);
218 }
219 return 0;
220 }
