1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: testBSDF.c,v 1.2 2015/06/05 18:58:37 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Simple test program to demonstrate BSDF operation. |
6 |
7 |
* G. Ward June 2015 |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdio.h> |
12 |
#include <stdlib.h> |
13 |
#include <math.h> |
14 |
#include <ctype.h> |
15 |
#include "rtio.h" |
16 |
#include "bsdf.h" |
17 |
18 |
static void |
19 |
Usage(const char *prog) |
20 |
21 |
printf("Usage: %s [bsdf_directory]\n", prog); |
22 |
printf("Input commands:\n"); |
23 |
printf(" l bsdf.xml\t\t\t Load (make active) given BSDF input file\n"); |
24 |
printf(" q theta_i phi_i theta_o phi_o\t Query BSDF for given path\n"); |
25 |
printf(" s N theta phi\t\t\t Generate N ray directions at given incidence\n"); |
26 |
printf(" h theta phi\t\t\t Report hemispherical total at given incidence\n"); |
27 |
printf(" r theta phi\t\t\t Report hemispherical reflection at given incidence\n"); |
28 |
printf(" t theta phi\t\t\t Report hemispherical transmission at given incidence\n"); |
29 |
printf(" a theta phi [t2 p2]\t\t Report resolution (in proj. steradians) for given direction(s)\n"); |
30 |
printf(" ^D\t\t\t\t Quit program\n"); |
31 |
32 |
33 |
static void |
34 |
vec_from_deg(FVECT v, double theta, double phi) |
35 |
36 |
const double DEG = M_PI/180.; |
37 |
38 |
theta *= DEG; phi *= DEG; |
39 |
v[0] = v[1] = sin(theta); |
40 |
v[0] *= cos(phi); |
41 |
v[1] *= sin(phi); |
42 |
v[2] = cos(theta); |
43 |
44 |
45 |
int |
46 |
main(int argc, char *argv[]) |
47 |
48 |
const char *directory = NULL; |
49 |
char inp[512], path[512]; |
50 |
const SDData *bsdf = NULL; |
51 |
52 |
if (argc > 2 || (argc == 2 && argv[1][0] == '-')) { |
53 |
Usage(argv[0]); |
54 |
return 1; |
55 |
56 |
if (argc == 2) |
57 |
directory = argv[1]; |
58 |
59 |
SDretainSet = SDretainBSDFs; /* keep BSDFs in memory */ |
60 |
61 |
/* loop on command */ |
62 |
while (fgets(inp, sizeof(inp), stdin) != NULL) { |
63 |
int sflags = SDsampAll; |
64 |
char *cp = inp; |
65 |
char *cp2; |
66 |
FVECT vin, vout; |
67 |
double proja[2]; |
68 |
int n; |
69 |
SDValue val; |
70 |
71 |
while (isspace(*cp)) cp++; |
72 |
73 |
switch (*cp) { |
74 |
case 'l': |
75 |
case 'L': /* load/activate BSDF input */ |
76 |
cp2 = cp = sskip2(cp, 1); |
77 |
if (!*cp) |
78 |
break; |
79 |
while (*cp) cp++; |
80 |
while (isspace(*--cp)) *cp = '\0'; |
81 |
if (directory) |
82 |
sprintf(path, "%s/%s", directory, cp2); |
83 |
else |
84 |
strcpy(path, cp2); |
85 |
if (bsdf) |
86 |
SDfreeCache(bsdf); |
87 |
bsdf = SDcacheFile(path); |
88 |
continue; |
89 |
case 'q': |
90 |
case 'Q': /* query BSDF value */ |
91 |
if (bsdf == NULL) |
92 |
goto noBSDFerr; |
93 |
if (!*sskip2(cp,4)) |
94 |
break; |
95 |
vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2))); |
96 |
vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4))); |
97 |
if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr)) |
98 |
printf("%.3e\n", val.cieY); |
99 |
continue; |
100 |
case 's': |
101 |
case 'S': /* sample BSDF */ |
102 |
if (bsdf == NULL) |
103 |
goto noBSDFerr; |
104 |
if (!*sskip2(cp,3)) |
105 |
break; |
106 |
n = atoi(sskip2(cp,1)); |
107 |
vec_from_deg(vin, atof(sskip2(cp,2)), atof(sskip2(cp,3))); |
108 |
while (n-- > 0) { |
109 |
if (SDreportError(SDsampBSDF(&val, vin, |
110 |
rand()*(1./(RAND_MAX+.5)), |
111 |
sflags, bsdf), stderr)) |
112 |
break; |
113 |
printf("%.8f %.8f %.8f\n", vin[0], vin[1], vin[2]); |
114 |
115 |
continue; |
116 |
case 'h': |
117 |
case 'H': /* hemispherical totals */ |
118 |
case 'r': |
119 |
case 'R': |
120 |
case 't': |
121 |
case 'T': |
122 |
if (bsdf == NULL) |
123 |
goto noBSDFerr; |
124 |
if (!*sskip2(cp,2)) |
125 |
break; |
126 |
if (tolower(*cp) == 'r') |
127 |
sflags &= ~SDsampT; |
128 |
else if (tolower(*cp) == 't') |
129 |
sflags &= ~SDsampR; |
130 |
131 |
printf("%.4e\n", SDdirectHemi(vin, sflags, bsdf)); |
132 |
continue; |
133 |
case 'a': |
134 |
case 'A': /* resolution in proj. steradians */ |
135 |
if (bsdf == NULL) |
136 |
goto noBSDFerr; |
137 |
138 |
break; |
139 |
140 |
if (*sskip2(cp,4)) { |
141 |
142 |
if (SDreportError(SDsizeBSDF(proja, vin, vout, |
143 |
SDqueryMin+SDqueryMax, bsdf), stderr)) |
144 |
continue; |
145 |
} else if (SDreportError(SDsizeBSDF(proja, vin, NULL, |
146 |
147 |
continue; |
148 |
printf("%.4e %.4e\n", proja[0], proja[1]); |
149 |
continue; |
150 |
151 |
Usage(argv[0]); |
152 |
continue; |
153 |
noBSDFerr: |
154 |
fprintf(stderr, "%s: need to use 'l' command to load BSDF\n", argv[0]); |
155 |
156 |
return 0; |
157 |
