root/Development/ray/src/common/testBSDF.c
Mon May 15 22:15:40 2017 UTC (8 years, 7 months ago) by greg
Diff to previous 1.11 , to selected 1.4
Reversed ordering of in/out vectors for consistency between "A" and "Q" commands
Tue Apr 11 16:14:05 2017 UTC (8 years, 8 months ago) by greg
Changes since 1.10: +5 -1 lines
Diff to previous 1.10 , to selected 1.4
Fixed issue with reporting zero XYZ values
Thu Feb 2 04:52:46 2017 UTC (8 years, 10 months ago) by greg
Changes since 1.9: +5 -5 lines
Diff to previous 1.9 , to selected 1.4
Corrected menu
Thu Feb 2 04:46:38 2017 UTC (8 years, 10 months ago) by greg
Changes since 1.8: +31 -14 lines
Diff to previous 1.8 , to selected 1.4
Bug fixes and improvements -- sampling was not working, now reports color
Thu Feb 2 00:34:55 2017 UTC (8 years, 10 months ago) by greg
Changes since 1.7: +13 -13 lines
Diff to previous 1.7 , to selected 1.4
Eliminated comparisons to NULL
Thu Feb 2 00:30:16 2017 UTC (8 years, 10 months ago) by greg
Diff to previous 1.6 , to selected 1.4
Slight change in order of metadata output
Thu Feb 2 00:27:55 2017 UTC (8 years, 10 months ago) by greg
Changes since 1.5: +46 -10 lines
Diff to previous 1.5 , to selected 1.4
Added 'i' and 'c' commands for printing metadata and constant values, resp.
Wed Feb 3 18:33:18 2016 UTC (9 years, 10 months ago) by greg
Changes since 1.4: +12 -6 lines
Diff to previous 1.4
Added testBSDF build and provided for color (XYZ) output
Revision 1.4 - (view) (download) (annotate) - [selected]
Fri Jun 26 22:07:53 2015 UTC (10 years, 5 months ago) by greg
Changes since 1.3: +2 -9 lines
Diff to previous 1.3
Simplified switch statement
Sat Jun 6 16:30:26 2015 UTC (10 years, 6 months ago) by greg
Changes since 1.2: +8 -8 lines
Diff to previous 1.2 , to selected 1.4
Minor fixes
Fri Jun 5 18:58:37 2015 UTC (10 years, 6 months ago) by greg
Diff to previous 1.1 , to selected 1.4
Added freeing of cached data
Fri Jun 5 17:55:18 2015 UTC (10 years, 6 months ago) by greg
Diff to selected 1.4
Created testBSDF main module to demonstrate BSDF library
