root/radiance/ray/src/common/testBSDF.c
Revision: 1.15
Committed: Sat Dec 28 18:05:14 2019 UTC (4 years, 5 months ago) by greg
Changes since 1.14: +1 -2 lines
2 static const char RCSid[] = "$Id: testBSDF.c,v 1.14 2019/06/11 14:26:29 greg Exp $";
5 * Simple test program to demonstrate BSDF operation.
6 *
7 * G. Ward June 2015
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdlib.h>
12 #include <math.h>
13 #include <ctype.h>
14 #include "rtio.h"
15 #include "bsdf.h"
16
17 static void
18 Usage(const char *prog)
19 {
20 printf("Usage: %s [bsdf_directory]\n", prog);
21 printf("Input commands:\n");
22 printf(" L bsdf.xml\t\t\t Load (make active) given BSDF input file\n");
23 printf(" i\t\t\t\t Report general information (metadata)\n");
24 printf(" c\t\t\t\t Report diffuse and specular components\n");
25 printf(" q theta_i phi_i theta_o phi_o\t Query BSDF for given path (CIE-XYZ)\n");
26 printf(" s[r|t][s|d] N theta phi\t Generate N ray directions & colors at given incidence\n");
27 printf(" h[s|d] theta phi\t\t Report hemispherical scattering at given incidence\n");
28 printf(" r[s|d] theta phi\t\t Report hemispherical reflection at given incidence\n");
29 printf(" t[s|d] theta phi\t\t Report hemispherical transmission at given incidence\n");
30 printf(" a theta phi [t2 p2]\t\t Report resolution (in proj. steradians) for given direction(s)\n");
31 printf(" ^D\t\t\t\t Quit program\n");
32 }
33
34 static void
35 vec_from_deg(FVECT v, double theta, double phi)
36 {
37 const double DEG = M_PI/180.;
38
39 theta *= DEG; phi *= DEG;
40 v[0] = v[1] = sin(theta);
41 v[0] *= cos(phi);
42 v[1] *= sin(phi);
43 v[2] = cos(theta);
44 }
45
46 static void
47 printXYZ(const char *intro, const SDValue *vp)
48 {
49 if (vp->cieY <= 1e-9) {
50 printf("%s0 0 0\n", intro);
51 return;
52 }
53 printf("%s%.3e %.3e %.3e\n", intro,
54 vp->spec.cx/vp->spec.cy*vp->cieY,
55 vp->cieY,
56 (1.-vp->spec.cx-vp->spec.cy)/
57 vp->spec.cy*vp->cieY);
58 }
59
60 int
61 main(int argc, char *argv[])
62 {
63 const char *directory = NULL;
64 char inp[512], path[512];
65 const SDData *bsdf = NULL;
66
67 if (argc > 2 || (argc == 2 && argv[1][0] == '-')) {
68 Usage(argv[0]);
69 return 1;
70 }
71 if (argc == 2)
72 directory = argv[1];
73
74 SDretainSet = SDretainBSDFs; /* keep BSDFs in memory */
75
76 /* loop on command */
77 while (fgets(inp, sizeof(inp), stdin)) {
78 int sflags = SDsampAll;
79 char *cp = inp;
80 char *cp2;
81 FVECT vin, vout;
82 double proja[2];
83 int n, i;
84 SDValue val;
85
86 while (isspace(*cp)) cp++;
87
88 switch (toupper(*cp)) {
89 case 'L': /* load/activate BSDF input */
90 cp2 = cp = sskip2(cp, 1);
91 if (!*cp)
92 break;
93 while (*cp) cp++;
94 while (isspace(*--cp)) *cp = '\0';
95 if (directory)
96 sprintf(path, "%s/%s", directory, cp2);
97 else
98 strcpy(path, cp2);
99 if (bsdf)
100 SDfreeCache(bsdf);
101 bsdf = SDcacheFile(path);
102 continue;
103 case 'I': /* report general info. */
104 if (!bsdf)
105 goto noBSDFerr;
106 printf("Material: '%s'\n", bsdf->matn);
107 printf("Manufacturer: '%s'\n", bsdf->makr);
108 printf("Width, Height, Thickness (m): %.4e, %.4e, %.4e\n",
109 bsdf->dim[0], bsdf->dim[1], bsdf->dim[2]);
110 if (bsdf->mgf)
111 printf("Has geometry: %lu bytes\n",
112 (unsigned long)strlen(bsdf->mgf));
113 else
114 printf("Has geometry: no\n");
115 break;
116 case 'C': /* report constant values */
117 if (!bsdf)
118 goto noBSDFerr;
119 if (bsdf->rf)
120 printf("Peak front hemispherical reflectance: %.3e\n",
121 bsdf->rLambFront.cieY +
122 bsdf->rf->maxHemi);
123 if (bsdf->rb)
124 printf("Peak back hemispherical reflectance: %.3e\n",
125 bsdf->rLambBack.cieY +
126 bsdf->rb->maxHemi);
127 if (bsdf->tf)
128 printf("Peak front hemispherical transmittance: %.3e\n",
129 bsdf->tLamb.cieY + bsdf->tf->maxHemi);
130 if (bsdf->tb)
131 printf("Peak back hemispherical transmittance: %.3e\n",
132 bsdf->tLamb.cieY + bsdf->tb->maxHemi);
133 printXYZ("Diffuse Front Reflectance: ", &bsdf->rLambFront);
134 printXYZ("Diffuse Back Reflectance: ", &bsdf->rLambBack);
135 printXYZ("Diffuse Transmittance: ", &bsdf->tLamb);
136 break;
137 case 'Q': /* query BSDF value */
138 if (!bsdf)
139 goto noBSDFerr;
140 if (!*sskip2(cp,4))
141 break;
142 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
143 vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4)));
144 if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr))
145 printXYZ("", &val);
146 break;
147 case 'S': /* sample BSDF */
148 if (!bsdf)
149 goto noBSDFerr;
150 if (!*sskip2(cp,3))
151 break;
152 if (toupper(cp[1]) == 'R') {
153 sflags &= ~SDsampT;
154 ++cp;
155 } else if (toupper(cp[1]) == 'T') {
156 sflags &= ~SDsampR;
157 ++cp;
158 }
159 if (toupper(cp[1]) == 'S')
160 sflags &= ~SDsampDf;
161 else if (toupper(cp[1]) == 'D')
162 sflags &= ~SDsampSp;
163 i = n = atoi(sskip2(cp,1));
164 vec_from_deg(vin, atof(sskip2(cp,2)), atof(sskip2(cp,3)));
165 while (i-- > 0) {
166 VCOPY(vout, vin);
167 if (SDreportError(SDsampBSDF(&val, vout,
168 (i+rand()*(1./(RAND_MAX+.5)))/(double)n,
169 sflags, bsdf), stderr))
170 break;
171 printf("%.8f %.8f %.8f ", vout[0], vout[1], vout[2]);
172 printXYZ("", &val);
173 }
174 break;
175 case 'H': /* hemispherical values */
176 case 'R':
177 case 'T':
178 if (!bsdf)
179 goto noBSDFerr;
180 if (!*sskip2(cp,2))
181 break;
182 if (toupper(cp[0]) == 'R')
183 sflags &= ~SDsampT;
184 else if (toupper(cp[0]) == 'T')
185 sflags &= ~SDsampR;
186 if (toupper(cp[1]) == 'S')
187 sflags &= ~SDsampDf;
188 else if (toupper(cp[1]) == 'D')
189 sflags &= ~SDsampSp;
190 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
191 printf("%.4e\n", SDdirectHemi(vin, sflags, bsdf));
192 break;
193 case 'A': /* resolution in proj. steradians */
194 if (!bsdf)
195 goto noBSDFerr;
196 if (!*sskip2(cp,2))
197 break;
198 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
199 if (*sskip2(cp,4)) {
200 vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4)));
201 if (SDreportError(SDsizeBSDF(proja, vout, vin,
202 SDqueryMin+SDqueryMax, bsdf), stderr))
203 continue;
204 } else if (SDreportError(SDsizeBSDF(proja, vin, NULL,
205 SDqueryMin+SDqueryMax, bsdf), stderr))
206 continue;
207 printf("%.4e %.4e\n", proja[0], proja[1]);
208 break;
209 default:
210 Usage(argv[0]);
211 break;
212 }
213 fflush(stdout); /* in case we're on remote */
214 continue;
215 noBSDFerr:
216 fprintf(stderr, "%s: First, use 'L' command to load BSDF\n", argv[0]);
217 }
218 return 0;
219 }
