1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: testBSDF.c,v 1.13 2018/05/10 01:41:33 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Simple test program to demonstrate BSDF operation. |
6 |
7 |
* G. Ward June 2015 |
8 |
9 |
10 |
#define _USE_MATH_DEFINES |
11 |
#include <stdio.h> |
12 |
#include <stdlib.h> |
13 |
#include <math.h> |
14 |
#include <ctype.h> |
15 |
#include "rtio.h" |
16 |
#include "bsdf.h" |
17 |
18 |
static void |
19 |
Usage(const char *prog) |
20 |
21 |
printf("Usage: %s [bsdf_directory]\n", prog); |
22 |
printf("Input commands:\n"); |
23 |
printf(" L bsdf.xml\t\t\t Load (make active) given BSDF input file\n"); |
24 |
printf(" i\t\t\t\t Report general information (metadata)\n"); |
25 |
printf(" c\t\t\t\t Report diffuse and specular components\n"); |
26 |
printf(" q theta_i phi_i theta_o phi_o\t Query BSDF for given path (CIE-XYZ)\n"); |
27 |
printf(" s[r|t][s|d] N theta phi\t Generate N ray directions & colors at given incidence\n"); |
28 |
printf(" h[s|d] theta phi\t\t Report hemispherical scattering at given incidence\n"); |
29 |
printf(" r[s|d] theta phi\t\t Report hemispherical reflection at given incidence\n"); |
30 |
printf(" t[s|d] theta phi\t\t Report hemispherical transmission at given incidence\n"); |
31 |
printf(" a theta phi [t2 p2]\t\t Report resolution (in proj. steradians) for given direction(s)\n"); |
32 |
printf(" ^D\t\t\t\t Quit program\n"); |
33 |
34 |
35 |
static void |
36 |
vec_from_deg(FVECT v, double theta, double phi) |
37 |
38 |
const double DEG = M_PI/180.; |
39 |
40 |
theta *= DEG; phi *= DEG; |
41 |
v[0] = v[1] = sin(theta); |
42 |
v[0] *= cos(phi); |
43 |
v[1] *= sin(phi); |
44 |
v[2] = cos(theta); |
45 |
46 |
47 |
static void |
48 |
printXYZ(const char *intro, const SDValue *vp) |
49 |
50 |
if (vp->cieY <= 1e-9) { |
51 |
printf("%s0 0 0\n", intro); |
52 |
return; |
53 |
54 |
printf("%s%.3e %.3e %.3e\n", intro, |
55 |
vp->spec.cx/vp->spec.cy*vp->cieY, |
56 |
vp->cieY, |
57 |
(1.-vp->spec.cx-vp->spec.cy)/ |
58 |
vp->spec.cy*vp->cieY); |
59 |
60 |
61 |
int |
62 |
main(int argc, char *argv[]) |
63 |
64 |
const char *directory = NULL; |
65 |
char inp[512], path[512]; |
66 |
const SDData *bsdf = NULL; |
67 |
68 |
if (argc > 2 || (argc == 2 && argv[1][0] == '-')) { |
69 |
Usage(argv[0]); |
70 |
return 1; |
71 |
72 |
if (argc == 2) |
73 |
directory = argv[1]; |
74 |
75 |
SDretainSet = SDretainBSDFs; /* keep BSDFs in memory */ |
76 |
77 |
/* loop on command */ |
78 |
while (fgets(inp, sizeof(inp), stdin)) { |
79 |
int sflags = SDsampAll; |
80 |
char *cp = inp; |
81 |
char *cp2; |
82 |
FVECT vin, vout; |
83 |
double proja[2]; |
84 |
int n, i; |
85 |
SDValue val; |
86 |
87 |
while (isspace(*cp)) cp++; |
88 |
89 |
switch (toupper(*cp)) { |
90 |
case 'L': /* load/activate BSDF input */ |
91 |
cp2 = cp = sskip2(cp, 1); |
92 |
if (!*cp) |
93 |
break; |
94 |
while (*cp) cp++; |
95 |
while (isspace(*--cp)) *cp = '\0'; |
96 |
if (directory) |
97 |
sprintf(path, "%s/%s", directory, cp2); |
98 |
else |
99 |
strcpy(path, cp2); |
100 |
if (bsdf) |
101 |
SDfreeCache(bsdf); |
102 |
bsdf = SDcacheFile(path); |
103 |
continue; |
104 |
case 'I': /* report general info. */ |
105 |
if (!bsdf) |
106 |
goto noBSDFerr; |
107 |
printf("Material: '%s'\n", bsdf->matn); |
108 |
printf("Manufacturer: '%s'\n", bsdf->makr); |
109 |
printf("Width, Height, Thickness (m): %.4e, %.4e, %.4e\n", |
110 |
bsdf->dim[0], bsdf->dim[1], bsdf->dim[2]); |
111 |
if (bsdf->mgf) |
112 |
printf("Has geometry: %lu bytes\n", |
113 |
(unsigned long)strlen(bsdf->mgf)); |
114 |
else |
115 |
printf("Has geometry: no\n"); |
116 |
break; |
117 |
case 'C': /* report constant values */ |
118 |
if (!bsdf) |
119 |
goto noBSDFerr; |
120 |
if (bsdf->rf) |
121 |
printf("Peak front hemispherical reflectance: %.3e\n", |
122 |
bsdf->rLambFront.cieY + |
123 |
bsdf->rf->maxHemi); |
124 |
if (bsdf->rb) |
125 |
printf("Peak back hemispherical reflectance: %.3e\n", |
126 |
bsdf->rLambBack.cieY + |
127 |
bsdf->rb->maxHemi); |
128 |
if (bsdf->tf) |
129 |
printf("Peak front hemispherical transmittance: %.3e\n", |
130 |
bsdf->tLamb.cieY + bsdf->tf->maxHemi); |
131 |
if (bsdf->tb) |
132 |
printf("Peak back hemispherical transmittance: %.3e\n", |
133 |
bsdf->tLamb.cieY + bsdf->tb->maxHemi); |
134 |
printXYZ("Diffuse Front Reflectance: ", &bsdf->rLambFront); |
135 |
printXYZ("Diffuse Back Reflectance: ", &bsdf->rLambBack); |
136 |
printXYZ("Diffuse Transmittance: ", &bsdf->tLamb); |
137 |
break; |
138 |
case 'Q': /* query BSDF value */ |
139 |
if (!bsdf) |
140 |
goto noBSDFerr; |
141 |
if (!*sskip2(cp,4)) |
142 |
break; |
143 |
vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2))); |
144 |
vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4))); |
145 |
if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr)) |
146 |
printXYZ("", &val); |
147 |
break; |
148 |
case 'S': /* sample BSDF */ |
149 |
if (!bsdf) |
150 |
goto noBSDFerr; |
151 |
if (!*sskip2(cp,3)) |
152 |
break; |
153 |
if (toupper(cp[1]) == 'R') { |
154 |
sflags &= ~SDsampT; |
155 |
++cp; |
156 |
} else if (toupper(cp[1]) == 'T') { |
157 |
sflags &= ~SDsampR; |
158 |
++cp; |
159 |
160 |
if (toupper(cp[1]) == 'S') |
161 |
sflags &= ~SDsampDf; |
162 |
else if (toupper(cp[1]) == 'D') |
163 |
sflags &= ~SDsampSp; |
164 |
i = n = atoi(sskip2(cp,1)); |
165 |
vec_from_deg(vin, atof(sskip2(cp,2)), atof(sskip2(cp,3))); |
166 |
while (i-- > 0) { |
167 |
VCOPY(vout, vin); |
168 |
if (SDreportError(SDsampBSDF(&val, vout, |
169 |
(i+rand()*(1./(RAND_MAX+.5)))/(double)n, |
170 |
sflags, bsdf), stderr)) |
171 |
break; |
172 |
printf("%.8f %.8f %.8f ", vout[0], vout[1], vout[2]); |
173 |
174 |
175 |
break; |
176 |
case 'H': /* hemispherical values */ |
177 |
case 'R': |
178 |
case 'T': |
179 |
if (!bsdf) |
180 |
goto noBSDFerr; |
181 |
if (!*sskip2(cp,2)) |
182 |
break; |
183 |
if (toupper(cp[0]) == 'R') |
184 |
185 |
else if (toupper(cp[0]) == 'T') |
186 |
187 |
188 |
189 |
190 |
191 |
192 |
printf("%.4e\n", SDdirectHemi(vin, sflags, bsdf)); |
193 |
break; |
194 |
case 'A': /* resolution in proj. steradians */ |
195 |
if (!bsdf) |
196 |
goto noBSDFerr; |
197 |
198 |
break; |
199 |
200 |
if (*sskip2(cp,4)) { |
201 |
202 |
if (SDreportError(SDsizeBSDF(proja, vout, vin, |
203 |
SDqueryMin+SDqueryMax, bsdf), stderr)) |
204 |
continue; |
205 |
} else if (SDreportError(SDsizeBSDF(proja, vin, NULL, |
206 |
207 |
continue; |
208 |
printf("%.4e %.4e\n", proja[0], proja[1]); |
209 |
break; |
210 |
default: |
211 |
Usage(argv[0]); |
212 |
break; |
213 |
214 |
fflush(stdout); /* in case we're on remote */ |
215 |
continue; |
216 |
noBSDFerr: |
217 |
fprintf(stderr, "%s: First, use 'L' command to load BSDF\n", argv[0]); |
218 |
219 |
return 0; |
220 |
