root/radiance/ray/src/common/testBSDF.c
Revision: 1.5
Committed: Wed Feb 3 18:33:18 2016 UTC (8 years, 4 months ago) by greg
Changes since 1.4: +12 -6 lines
Added testBSDF build and provided for color (XYZ) output
2 static const char RCSid[] = "$Id: testBSDF.c,v 1.4 2015/06/26 22:07:53 greg Exp $";
5 * Simple test program to demonstrate BSDF operation.
6 *
7 * G. Ward June 2015
8 */
9
10 #define _USE_MATH_DEFINES
11 #include <stdio.h>
12 #include <stdlib.h>
13 #include <math.h>
14 #include <ctype.h>
15 #include "rtio.h"
16 #include "bsdf.h"
17
18 static void
19 Usage(const char *prog)
20 {
21 printf("Usage: %s [bsdf_directory]\n", prog);
22 printf("Input commands:\n");
23 printf(" L bsdf.xml\t\t\t Load (make active) given BSDF input file\n");
24 printf(" q theta_i phi_i theta_o phi_o\t Query BSDF for given path (CIE-XYZ)\n");
25 printf(" s N theta phi\t\t\t Generate N ray directions at given incidence\n");
26 printf(" h theta phi\t\t\t Report hemispherical total at given incidence\n");
27 printf(" r theta phi\t\t\t Report hemispherical reflection at given incidence\n");
28 printf(" t theta phi\t\t\t Report hemispherical transmission at given incidence\n");
29 printf(" a theta phi [t2 p2]\t\t Report resolution (in proj. steradians) for given direction(s)\n");
30 printf(" ^D\t\t\t\t Quit program\n");
31 }
32
33 static void
34 vec_from_deg(FVECT v, double theta, double phi)
35 {
36 const double DEG = M_PI/180.;
37
38 theta *= DEG; phi *= DEG;
39 v[0] = v[1] = sin(theta);
40 v[0] *= cos(phi);
41 v[1] *= sin(phi);
42 v[2] = cos(theta);
43 }
44
45 int
46 main(int argc, char *argv[])
47 {
48 const char *directory = NULL;
49 char inp[512], path[512];
50 const SDData *bsdf = NULL;
51
52 if (argc > 2 || (argc == 2 && argv[1][0] == '-')) {
53 Usage(argv[0]);
54 return 1;
55 }
56 if (argc == 2)
57 directory = argv[1];
58
59 SDretainSet = SDretainBSDFs; /* keep BSDFs in memory */
60
61 /* loop on command */
62 while (fgets(inp, sizeof(inp), stdin) != NULL) {
63 int sflags = SDsampAll;
64 char *cp = inp;
65 char *cp2;
66 FVECT vin, vout;
67 double proja[2];
68 int n;
69 SDValue val;
70
71 while (isspace(*cp)) cp++;
72
73 switch (toupper(*cp)) {
74 case 'L': /* load/activate BSDF input */
75 cp2 = cp = sskip2(cp, 1);
76 if (!*cp)
77 break;
78 while (*cp) cp++;
79 while (isspace(*--cp)) *cp = '\0';
80 if (directory)
81 sprintf(path, "%s/%s", directory, cp2);
82 else
83 strcpy(path, cp2);
84 if (bsdf)
85 SDfreeCache(bsdf);
86 bsdf = SDcacheFile(path);
87 continue;
88 case 'Q': /* query BSDF value */
89 if (bsdf == NULL)
90 goto noBSDFerr;
91 if (!*sskip2(cp,4))
92 break;
93 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
94 vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4)));
95 if (!SDreportError(SDevalBSDF(&val, vout, vin, bsdf), stderr)) {
96 c_ccvt(&val.spec, C_CSXY);
97 printf("%.3e %.3e %.3e\n",
98 val.spec.cx/val.spec.cy*val.cieY,
99 val.cieY,
100 (1.-val.spec.cx-val.spec.cy)/
101 val.spec.cy*val.cieY);
102 }
103 continue;
104 case 'S': /* sample BSDF */
105 if (bsdf == NULL)
106 goto noBSDFerr;
107 if (!*sskip2(cp,3))
108 break;
109 n = atoi(sskip2(cp,1));
110 vec_from_deg(vin, atof(sskip2(cp,2)), atof(sskip2(cp,3)));
111 while (n-- > 0) {
112 if (SDreportError(SDsampBSDF(&val, vin,
113 rand()*(1./(RAND_MAX+.5)),
114 sflags, bsdf), stderr))
115 break;
116 printf("%.8f %.8f %.8f\n", vin[0], vin[1], vin[2]);
117 }
118 continue;
119 case 'H': /* hemispherical totals */
120 case 'R':
121 case 'T':
122 if (bsdf == NULL)
123 goto noBSDFerr;
124 if (!*sskip2(cp,2))
125 break;
126 if (tolower(*cp) == 'r')
127 sflags &= ~SDsampT;
128 else if (tolower(*cp) == 't')
129 sflags &= ~SDsampR;
130 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
131 printf("%.4e\n", SDdirectHemi(vin, sflags, bsdf));
132 continue;
133 case 'A': /* resolution in proj. steradians */
134 if (bsdf == NULL)
135 goto noBSDFerr;
136 if (!*sskip2(cp,2))
137 break;
138 vec_from_deg(vin, atof(sskip2(cp,1)), atof(sskip2(cp,2)));
139 if (*sskip2(cp,4)) {
140 vec_from_deg(vout, atof(sskip2(cp,3)), atof(sskip2(cp,4)));
141 if (SDreportError(SDsizeBSDF(proja, vin, vout,
142 SDqueryMin+SDqueryMax, bsdf), stderr))
143 continue;
144 } else if (SDreportError(SDsizeBSDF(proja, vin, NULL,
145 SDqueryMin+SDqueryMax, bsdf), stderr))
146 continue;
147 printf("%.4e %.4e\n", proja[0], proja[1]);
148 continue;
149 }
150 Usage(argv[0]);
151 continue;
152 noBSDFerr:
153 fprintf(stderr, "%s: need to use 'L' command to load BSDF\n", argv[0]);
154 }
155 return 0;
156 }
