root/radiance/ray/src/common/tcos.c
Fri Jul 12 05:16:02 2013 UTC (10 years, 10 months ago) by greg
Changes since 3.9: +4 -2 lines
Diff to previous 3.9
Took out definiton of tcos() when __FAST_MATH__ is defined
Fri Feb 8 16:39:01 2013 UTC (11 years, 3 months ago) by greg
Changes since 3.8: +2 -2 lines
Diff to previous 3.8
Goof
Fri Feb 8 16:10:07 2013 UTC (11 years, 3 months ago) by greg
Changes since 3.7: +2 -2 lines
Diff to previous 3.7
Renamed new fast arctangent call to atan2a()
Thu Feb 7 20:19:52 2013 UTC (11 years, 3 months ago) by greg
Changes since 3.6: +21 -1 lines
Diff to previous 3.6
Added fast atan2(y,x) approximation
Thu Jan 17 22:48:21 2013 UTC (11 years, 3 months ago) by greg
Diff to previous 3.5
Increased table size from 256 to 1024
Fri Feb 11 00:35:14 2011 UTC (13 years, 3 months ago) by greg
Changes since 3.4: +5 -12 lines
Diff to previous 3.4
Minor changes and improvements
Changes since 3.3: +3 -1 lines
Diff to previous 3.3
Changes since 3.2: +1 -56 lines
Diff to previous 3.2
Changes since 3.1: +60 -4 lines
Diff to previous 3.1
Wed Dec 16 18:15:07 1998 UTC (25 years, 5 months ago) by gwlarson
