root/radiance/ray/src/common/tcos.c
Revision: 3.10
Committed: Fri Jul 12 05:16:02 2013 UTC (11 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Changes since 3.9: +4 -2 lines
Took out definiton of tcos() when __FAST_MATH__ is defined
2 static const char RCSid[] = "$Id: tcos.c,v 3.9 2013/02/08 16:39:01 greg Exp $";
5 * Table-based cosine approximation.
6 *
7 * Use doubles in table even though we're not nearly that accurate just
8 * to avoid conversion and guarantee that tsin(x)^2 + tcos(x)^2 == 1.
9 *
10 * No interpolation in this version.
11 *
12 * External symbols declared in rtmath.h
13 */
14
15 #include "copyright.h"
16
17 #include <math.h>
18
19 #include "rtmath.h"
20
21 #ifndef __FAST_MATH__
22
23 #ifndef NCOSENTRY
24 #define NCOSENTRY 1024
25 #endif
26
27 double
28 tcos(double x) /* approximate cosine */
29 {
30 static double costab[NCOSENTRY+1];
31 register int i;
32
33 if (costab[0] < 0.5) /* initialize table */
34 for (i = 0; i <= NCOSENTRY; i++)
35 costab[i] = cos((PI/2./NCOSENTRY)*i);
36 /* normalize angle */
37 if (x < 0.)
38 x = -x;
39 i = (NCOSENTRY*2./PI) * x + 0.5;
40 while (i >= 4*NCOSENTRY)
41 i -= 4*NCOSENTRY;
42 switch (i / NCOSENTRY) {
43 case 0:
44 return(costab[i]);
45 case 1:
46 return(-costab[(2*NCOSENTRY)-i]);
47 case 2:
48 return(-costab[i-(2*NCOSENTRY)]);
49 case 3:
50 return(costab[(4*NCOSENTRY)-i]);
51 }
52 return(0.); /* should never be reached */
53 }
54
55 #endif
56
57 /* Fast arctangent approximation due to Rajan et al. 2006 */
58 double
59 atan2a(double y, double x)
60 {
61 double ratio, aratio, val;
62
63 if (x == 0)
64 return (y > 0) ? PI/2. : 3./2.*PI;
65
66 aratio = (ratio = y/x) >= 0 ? ratio : -ratio;
67
68 if (aratio > 1.01)
69 return PI/2. - atan2a(x, y);
70
71 val = PI/4.*ratio - ratio*(aratio - 1.)*(0.2447 + 0.0663*aratio);
72
73 return val + PI*(x < 0);
74 }
