--- ray/src/common/tcos.c 2003/02/22 02:07:22 3.2 +++ ray/src/common/tcos.c 2013/02/07 20:19:52 3.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tcos.c,v 3.2 2003/02/22 02:07:22 greg Exp $"; +static const char RCSid[] = "$Id: tcos.c,v 3.7 2013/02/07 20:19:52 greg Exp $"; #endif /* * Table-based cosine approximation. @@ -9,82 +9,22 @@ static const char RCSid[] = "$Id: tcos.c,v 3.2 2003/02 * * No interpolation in this version. * - * External symbols declared in standard.h + * External symbols declared in rtmath.h */ -/* ==================================================================== - * The Radiance Software License, Version 1.0 - * - * Copyright (c) 1990 - 2002 The Regents of the University of California, - * through Lawrence Berkeley National Laboratory. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * - * 3. The end-user documentation included with the redistribution, - * if any, must include the following acknowledgment: - * "This product includes Radiance software - * (http://radsite.lbl.gov/) - * developed by the Lawrence Berkeley National Laboratory - * (http://www.lbl.gov/)." - * Alternately, this acknowledgment may appear in the software itself, - * if and wherever such third-party acknowledgments normally appear. - * - * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" - * and "The Regents of the University of California" must - * not be used to endorse or promote products derived from this - * software without prior written permission. For written - * permission, please contact radiance@radsite.lbl.gov. - * - * 5. Products derived from this software may not be called "Radiance", - * nor may "Radiance" appear in their name, without prior written - * permission of Lawrence Berkeley National Laboratory. - * - * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED - * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR - * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF - * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT - * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - * ==================================================================== - * - * This software consists of voluntary contributions made by many - * individuals on behalf of Lawrence Berkeley National Laboratory. For more - * information on Lawrence Berkeley National Laboratory, please see - * . - */ +#include "copyright.h" #include +#include "rtmath.h" + #ifndef NCOSENTRY -#define NCOSENTRY 256 +#define NCOSENTRY 1024 #endif -#ifdef M_PI -#define PI ((double)M_PI) -#else -#define PI 3.14159265358979323846 -#endif - double -tcos(x) /* approximate cosine */ -register double x; +tcos(double x) /* approximate cosine */ { static double costab[NCOSENTRY+1]; register int i; @@ -96,8 +36,8 @@ register double x; if (x < 0.) x = -x; i = (NCOSENTRY*2./PI) * x + 0.5; - if (i >= 4*NCOSENTRY) - i %= 4*NCOSENTRY; + while (i >= 4*NCOSENTRY) + i -= 4*NCOSENTRY; switch (i / NCOSENTRY) { case 0: return(costab[i]); @@ -109,4 +49,24 @@ register double x; return(costab[(4*NCOSENTRY)-i]); } return(0.); /* should never be reached */ +} + + +/* Fast arctangent approximation due to Rajan et al. 2006 */ +double +aatan2(double y, double x) +{ + double ratio, aratio, val; + + if (x == 0) + return (y > 0) ? PI/2. : 3./2.*PI; + + aratio = (ratio = y/x) >= 0 ? ratio : -ratio; + + if (aratio > 1.01) + return PI/2. - aatan2(x, y); + + val = PI/4.*ratio - ratio*(aratio - 1.)*(0.2447 + 0.0663*aratio); + + return val + PI*(x < 0); }
