root/radiance/ray/src/common/tcos.c
Revision: 3.10
Committed: Fri Jul 12 05:16:02 2013 UTC (11 years, 9 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Changes since 3.9: +4 -2 lines
Took out definiton of tcos() when __FAST_MATH__ is defined
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.10 static const char RCSid[] = "$Id: tcos.c,v 3.9 2013/02/08 16:39:01 greg Exp $";
3 gwlarson 3.1 #endif
4     /*
5     * Table-based cosine approximation.
6     *
7     * Use doubles in table even though we're not nearly that accurate just
8     * to avoid conversion and guarantee that tsin(x)^2 + tcos(x)^2 == 1.
9     *
10     * No interpolation in this version.
11 greg 3.2 *
12 greg 3.5 * External symbols declared in rtmath.h
13 greg 3.2 */
14
15 greg 3.3 #include "copyright.h"
16 gwlarson 3.1
17     #include <math.h>
18 schorsch 3.4
19     #include "rtmath.h"
20 gwlarson 3.1
21 greg 3.10 #ifndef __FAST_MATH__
22
23 gwlarson 3.1 #ifndef NCOSENTRY
24 greg 3.6 #define NCOSENTRY 1024
25 gwlarson 3.1 #endif
26
27     double
28 greg 3.5 tcos(double x) /* approximate cosine */
29 gwlarson 3.1 {
30     static double costab[NCOSENTRY+1];
31     register int i;
32
33     if (costab[0] < 0.5) /* initialize table */
34     for (i = 0; i <= NCOSENTRY; i++)
35     costab[i] = cos((PI/2./NCOSENTRY)*i);
36     /* normalize angle */
37     if (x < 0.)
38     x = -x;
39     i = (NCOSENTRY*2./PI) * x + 0.5;
40 greg 3.5 while (i >= 4*NCOSENTRY)
41     i -= 4*NCOSENTRY;
42 gwlarson 3.1 switch (i / NCOSENTRY) {
43     case 0:
44     return(costab[i]);
45     case 1:
46     return(-costab[(2*NCOSENTRY)-i]);
47     case 2:
48     return(-costab[i-(2*NCOSENTRY)]);
49     case 3:
50     return(costab[(4*NCOSENTRY)-i]);
51     }
52     return(0.); /* should never be reached */
53     }
54 greg 3.7
55 greg 3.10 #endif
56 greg 3.7
57     /* Fast arctangent approximation due to Rajan et al. 2006 */
58     double
59 greg 3.8 atan2a(double y, double x)
60 greg 3.7 {
61     double ratio, aratio, val;
62
63     if (x == 0)
64     return (y > 0) ? PI/2. : 3./2.*PI;
65
66     aratio = (ratio = y/x) >= 0 ? ratio : -ratio;
67
68     if (aratio > 1.01)
69 greg 3.9 return PI/2. - atan2a(x, y);
70 greg 3.7
71     val = PI/4.*ratio - ratio*(aratio - 1.)*(0.2447 + 0.0663*aratio);
72
73     return val + PI*(x < 0);
74     }
