root/radiance/ray/src/common/tcos.c
Revision: 3.9
Committed: Fri Feb 8 16:39:01 2013 UTC (11 years, 4 months ago) by greg
Changes since 3.8: +2 -2 lines
Goof
2 static const char RCSid[] = "$Id: tcos.c,v 3.8 2013/02/08 16:10:07 greg Exp $";
5 * Table-based cosine approximation.
6 *
7 * Use doubles in table even though we're not nearly that accurate just
8 * to avoid conversion and guarantee that tsin(x)^2 + tcos(x)^2 == 1.
9 *
10 * No interpolation in this version.
11 *
12 * External symbols declared in rtmath.h
13 */
14
15 #include "copyright.h"
16
17 #include <math.h>
18
19 #include "rtmath.h"
20
21 #ifndef NCOSENTRY
22 #define NCOSENTRY 1024
23 #endif
24
25
26 double
27 tcos(double x) /* approximate cosine */
28 {
29 static double costab[NCOSENTRY+1];
30 register int i;
31
32 if (costab[0] < 0.5) /* initialize table */
33 for (i = 0; i <= NCOSENTRY; i++)
34 costab[i] = cos((PI/2./NCOSENTRY)*i);
35 /* normalize angle */
36 if (x < 0.)
37 x = -x;
38 i = (NCOSENTRY*2./PI) * x + 0.5;
39 while (i >= 4*NCOSENTRY)
40 i -= 4*NCOSENTRY;
41 switch (i / NCOSENTRY) {
42 case 0:
43 return(costab[i]);
44 case 1:
45 return(-costab[(2*NCOSENTRY)-i]);
46 case 2:
47 return(-costab[i-(2*NCOSENTRY)]);
48 case 3:
49 return(costab[(4*NCOSENTRY)-i]);
50 }
51 return(0.); /* should never be reached */
52 }
53
54
55 /* Fast arctangent approximation due to Rajan et al. 2006 */
56 double
57 atan2a(double y, double x)
58 {
59 double ratio, aratio, val;
60
61 if (x == 0)
62 return (y > 0) ? PI/2. : 3./2.*PI;
63
64 aratio = (ratio = y/x) >= 0 ? ratio : -ratio;
65
66 if (aratio > 1.01)
67 return PI/2. - atan2a(x, y);
68
69 val = PI/4.*ratio - ratio*(aratio - 1.)*(0.2447 + 0.0663*aratio);
70
71 return val + PI*(x < 0);
72 }
