root/Development/ray/src/common/tcos.c
Fri Jul 12 05:16:02 2013 UTC (12 years, 3 months ago) by greg
CVS Tags: HEAD, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 3.9: +4 -2 lines
Diff to previous 3.9
Took out definiton of tcos() when __FAST_MATH__ is defined
Fri Feb 8 16:39:01 2013 UTC (12 years, 8 months ago) by greg
Changes since 3.8: +2 -2 lines
Diff to previous 3.8
Goof
Fri Feb 8 16:10:07 2013 UTC (12 years, 8 months ago) by greg
Changes since 3.7: +2 -2 lines
Diff to previous 3.7
Renamed new fast arctangent call to atan2a()
Thu Feb 7 20:19:52 2013 UTC (12 years, 8 months ago) by greg
Changes since 3.6: +21 -1 lines
Diff to previous 3.6
Added fast atan2(y,x) approximation
Thu Jan 17 22:48:21 2013 UTC (12 years, 9 months ago) by greg
Diff to previous 3.5
Increased table size from 256 to 1024
Fri Feb 11 00:35:14 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.4: +5 -12 lines
Diff to previous 3.4
Minor changes and improvements
Thu Jul 17 09:21:29 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.3: +3 -1 lines
Diff to previous 3.3
Tue Feb 25 02:47:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.2: +1 -56 lines
Diff to previous 3.2
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.1: +60 -4 lines
Diff to previous 3.1
Wed Dec 16 18:15:07 1998 UTC (26 years, 10 months ago) by gwlarson
