root/Development/ray/src/common/standard.h
Revision: 2.23
Committed: Thu Jun 5 19:29:34 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.22: +8 -70 lines
1 /* RCSid $Id: standard.h,v 2.22 2003/05/13 17:58:32 greg Exp $ */
2 /*
3 * Miscellaneous definitions required by many routines.
4 */
5
6 #ifndef _RAD_STANDARD_H_
7 #define _RAD_STANDARD_H_
8
9 #include "copyright.h"
10
11 #include <stdio.h>
12 #include <sys/types.h>
13 #include <fcntl.h>
14 #include <math.h>
15 #include <errno.h>
16 #include <stdlib.h>
17 #include <string.h>
18
19 #include "platform.h"
20 #include "mat4.h"
21
22 /* regular transformation */
23 typedef struct {
24 MAT4 xfm; /* transform matrix */
25 FLOAT sca; /* scalefactor */
26 } XF;
27 /* complemetary tranformation */
28 typedef struct {
29 XF f; /* forward */
30 XF b; /* backward */
31 } FULLXF;
32
33 #ifndef PI
34 #ifdef M_PI
35 #define PI ((double)M_PI)
36 #else
37 #define PI 3.14159265358979323846
38 #endif
39 #endif
40
41 #ifndef F_OK /* mode bits for access(2) call */
42 #define R_OK 4 /* readable */
43 #define W_OK 2 /* writable */
44 #define X_OK 1 /* executable */
45 #define F_OK 0 /* exists */
46 #endif
47
48 #ifndef int2
49 #define int2 short /* two-byte integer */
50 #endif
51 #ifndef int4
52 #define int4 int /* four-byte integer */
53 #endif
54
55 /* error codes */
56 #define WARNING 0 /* non-fatal error */
57 #define USER 1 /* fatal user-caused error */
58 #define SYSTEM 2 /* fatal system-related error */
59 #define INTERNAL 3 /* fatal program-related error */
60 #define CONSISTENCY 4 /* bad consistency check, abort */
61 #define COMMAND 5 /* interactive error */
62 #define NERRS 6
63 /* error struct */
64 extern struct erract {
65 char pre[16]; /* prefix message */
66 void (*pf)(); /* put function (resettable) */
67 int ec; /* exit code (0 means non-fatal) */
68 } erract[NERRS]; /* list of error actions */
69
70 #define ERRACT_INIT { {"warning - ", wputs, 0}, \
71 {"fatal - ", eputs, 1}, \
72 {"system - ", eputs, 2}, \
73 {"internal - ", eputs, 3}, \
74 {"consistency - ", eputs, -1}, \
75 {"", NULL, 0} }
76
77 extern char errmsg[]; /* global buffer for error messages */
78
79 #ifdef FASTMATH
80 #define tcos cos
81 #define tsin sin
82 #define ttan tan
83 #else
84 extern double tcos(); /* table-based cosine approximation */
85 #define tsin(x) tcos((x)-(PI/2.))
86 #define ttan(x) (tsin(x)/tcos(x))
87 #endif
88 /* custom version of assert(3) */
89 #define CHECK(be,et,em) if (be) error(et,em); else
90 #ifdef DEBUG
91 #define DCHECK CHECK
92 #else
93 #define DCHECK(be,et,em) (void)0
94 #endif
95 /* memory operations */
96 #ifdef NOSTRUCTASS
97 #define copystruct(d,s) bcopy((void *)(s),(void *)(d),sizeof(*(d)))
98 #else
99 #define copystruct(d,s) (*(d) = *(s))
100 #endif
101
102 #ifndef BSD
103 #define bcopy(s,d,n) (void)memcpy(d,s,n)
104 #define bzero(d,n) (void)memset(d,0,n)
105 #define bcmp(b1,b2,n) memcmp(b1,b2,n)
106 #define index strchr
107 #define rindex strrchr
108 #endif
109 extern off_t lseek();
110
111 #ifdef MSDOS
112 #define NIX 1
113 #endif
114 #ifdef AMIGA
115 #define NIX 1
116 #endif
117
118
119 /* defined in badarg.c */
120 extern int badarg(int ac, char **av, char *fl);
121 /* defined in bmalloc.c */
122 extern char *bmalloc(unsigned int n);
123 extern void bfree(char *p, unsigned int n);
124 /* defined in error.c */
125 extern void error(int etype, char *emsg);
126 /* defined in expandarg.c */
127 extern int expandarg(int *acp, char ***avp, int n);
128 /* defined in fdate.c */
129 extern time_t fdate(char *fname);
130 extern int setfdate(char *fname, long ftim);
131 /* defined in fgetline.c */
132 extern char *fgetline(char *s, int n, FILE *fp);
133 /* defined in fgetval.c */
134 extern int fgetval(FILE *fp, int ty, char *vp);
135 /* defined in fgetword.c */
136 extern char *fgetword(char *s, int n, FILE *fp);
137 /* defined in fputword.c */
138 extern void fputword(char *s, FILE *fp);
139 /* defined in fixargv0.c */
140 extern char *fixargv0(char *av0);
141 /* defined in fropen.c */
142 extern FILE *frlibopen(char *fname);
143 /* defined in getlibpath.c */
144 extern char *getrlibpath(void);
145 /* defined in getpath.c */
146 extern char *getpath(char *fname, char *searchpath, int mode);
147 /* defined in portio.c */
148 extern void putstr(char *s, FILE *fp);
149 extern void putint(long i, int siz, FILE *fp);
150 extern void putflt(double f, FILE *fp);
151 extern char *getstr(char *s, FILE *fp);
152 extern long getint(int siz, FILE *fp);
153 extern double getflt(FILE *fp);
154 /* defined in process.c */
155 extern int open_process(int pd[3], char *av[]);
156 extern int process(int pd[3], char *recvbuf, char *sendbuf,
157 int nbr, int nbs);
158 extern int close_process(int pd[3]);
159 extern int readbuf(int fd, char *bpos, int siz);
160 extern int writebuf(int fd, char *bpos, int siz);
161 /* defined in rexpr.c */
162 extern int ecompile(char *sp, int iflg, int wflag);
163 extern char *expsave(void);
164 extern void expset(char *ep);
165 extern char *eindex(char *sp);
166 /* defined in savestr.c */
167 extern char *savestr(char *str);
168 extern void freestr(char *s);
169 extern int shash(char *s);
170 /* defined in savqstr.c */
171 extern char *savqstr(char *s);
172 extern void freeqstr(char *s);
173 /* defined in tcos.c */
174 extern double tcos(double x);
175 /* defined in wordfile.c */
176 extern int wordfile(char **words, char *fname);
177 extern int wordstring(char **avl, char *str);
178 /* defined in words.c */
179 extern char *atos(char *rs, int nb, char *s);
180 extern char *nextword(char *cp, int nb, char *s);
181 extern char *sskip(char *s);
182 extern char *sskip2(char *s, int n);
183 extern char *iskip(char *s);
184 extern char *fskip(char *s);
185 extern int isint(char *s);
186 extern int isintd(char *s, char *ds);
187 extern int isflt(char *s);
188 extern int isfltd(char *s, char *ds);
189 /* defined in xf.c */
190 extern int xf(XF *ret, int ac, char *av[]);
191 extern int invxf(XF *ret, int ac, char *av[]);
192 extern int fullxf(FULLXF *fx, int ac, char *av[]);
193 /* defined in zeroes.c */
194 extern int quadtratic(double *r, double a, double b, double c);
195 /* defined in dircode.c */
196 extern int4 encodedir(FVECT dv);
197 extern void decodedir(FVECT dv, int4 dc);
198 extern double dir2diff(int4 dc1, int4 dc2);
199 extern double fdir2diff(int4 dc1, FVECT v2);
200 /* miscellaneous */
201 extern void eputs(char *s);
202 extern void wputs(char *s);
203 extern void quit(int code);
204
205
206 #endif /* _RAD_STANDARD_H_ */
