1 |
/* RCSid $Id$ */ |
2 |
3 |
* Miscellaneous definitions required by many routines. |
4 |
5 |
6 |
#include "copyright.h" |
7 |
8 |
#include <stdio.h> |
9 |
10 |
#include <sys/types.h> |
11 |
12 |
#include <fcntl.h> |
13 |
14 |
#include <math.h> |
15 |
16 |
#include <errno.h> |
17 |
18 |
#include <stdlib.h> |
19 |
20 |
#include <string.h> |
21 |
22 |
#include "mat4.h" |
23 |
/* regular transformation */ |
24 |
typedef struct { |
25 |
MAT4 xfm; /* transform matrix */ |
26 |
FLOAT sca; /* scalefactor */ |
27 |
} XF; |
28 |
/* complemetary tranformation */ |
29 |
typedef struct { |
30 |
XF f; /* forward */ |
31 |
XF b; /* backward */ |
32 |
} FULLXF; |
33 |
34 |
#ifndef PI |
35 |
#ifdef M_PI |
36 |
#define PI ((double)M_PI) |
37 |
#else |
38 |
#define PI 3.14159265358979323846 |
39 |
#endif |
40 |
#endif |
41 |
42 |
#ifndef F_OK /* mode bits for access(2) call */ |
43 |
#define R_OK 4 /* readable */ |
44 |
#define W_OK 2 /* writable */ |
45 |
#define X_OK 1 /* executable */ |
46 |
#define F_OK 0 /* exists */ |
47 |
#endif |
48 |
49 |
#ifndef int2 |
50 |
#define int2 short /* two-byte integer */ |
51 |
#endif |
52 |
#ifndef int4 |
53 |
#define int4 int /* four-byte integer */ |
54 |
#endif |
55 |
56 |
/* error codes */ |
57 |
#define WARNING 0 /* non-fatal error */ |
58 |
#define USER 1 /* fatal user-caused error */ |
59 |
#define SYSTEM 2 /* fatal system-related error */ |
60 |
#define INTERNAL 3 /* fatal program-related error */ |
61 |
#define CONSISTENCY 4 /* bad consistency check, abort */ |
62 |
#define COMMAND 5 /* interactive error */ |
63 |
#define NERRS 6 |
64 |
/* error struct */ |
65 |
extern struct erract { |
66 |
char pre[16]; /* prefix message */ |
67 |
void (*pf)(); /* put function (resettable) */ |
68 |
int ec; /* exit code (0 means non-fatal) */ |
69 |
} erract[NERRS]; /* list of error actions */ |
70 |
71 |
#define ERRACT_INIT { {"warning - ", wputs, 0}, \ |
72 |
{"fatal - ", eputs, 1}, \ |
73 |
{"system - ", eputs, 2}, \ |
74 |
{"internal - ", eputs, 3}, \ |
75 |
{"consistency - ", eputs, -1}, \ |
76 |
{"", NULL, 0} } |
77 |
78 |
extern char errmsg[]; /* global buffer for error messages */ |
79 |
80 |
#ifdef FASTMATH |
81 |
#define tcos cos |
82 |
#define tsin sin |
83 |
#define ttan tan |
84 |
#else |
85 |
extern double tcos(); /* table-based cosine approximation */ |
86 |
#define tsin(x) tcos((x)-(PI/2.)) |
87 |
#define ttan(x) (tsin(x)/tcos(x)) |
88 |
#endif |
89 |
/* custom version of assert(3) */ |
90 |
#define CHECK(be,et,em) ((be) ? error(et,em) : 0) |
91 |
#ifdef DEBUG |
92 |
#define DCHECK CHECK |
93 |
#else |
94 |
#define DCHECK(be,et,em) 0 |
95 |
#endif |
96 |
/* memory operations */ |
97 |
#ifdef NOSTRUCTASS |
98 |
#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) |
99 |
#else |
100 |
#define copystruct(d,s) (*(d) = *(s)) |
101 |
#endif |
102 |
103 |
#ifndef BSD |
104 |
#define bcopy(s,d,n) (void)memcpy(d,s,n) |
105 |
#define bzero(d,n) (void)memset(d,0,n) |
106 |
#define bcmp(b1,b2,n) memcmp(b1,b2,n) |
107 |
#define index strchr |
108 |
#define rindex strrchr |
109 |
#endif |
110 |
extern off_t lseek(); |
111 |
112 |
#ifdef MSDOS |
113 |
#define NIX 1 |
114 |
#endif |
115 |
#ifdef AMIGA |
116 |
#define NIX 1 |
117 |
#endif |
118 |
119 |
#ifdef NOPROTO |
120 |
121 |
extern int badarg(); |
122 |
extern char *bmalloc(); |
123 |
extern void bfree(); |
124 |
extern void error(); |
125 |
extern int expandarg(); |
126 |
extern time_t fdate(); |
127 |
extern int setfdate(); |
128 |
extern char *fgetline(); |
129 |
extern int fgetval(); |
130 |
extern char *fgetword(); |
131 |
extern void fputword(); |
132 |
extern char *fixargv0(); |
133 |
extern FILE *frlibopen(); |
134 |
extern char *getlibpath(); |
135 |
extern char *getpath(); |
136 |
extern void putstr(); |
137 |
extern void putint(); |
138 |
extern void putflt(); |
139 |
extern char *getstr(); |
140 |
extern long getint(); |
141 |
extern double getflt(); |
142 |
extern int open_process(); |
143 |
extern int process(); |
144 |
extern int close_process(); |
145 |
extern int readbuf(); |
146 |
extern int writebuf(); |
147 |
extern int ecompile(); |
148 |
extern char *expsave(); |
149 |
extern void expset(); |
150 |
extern char *eindex(); |
151 |
extern char *savestr(); |
152 |
extern void freestr(); |
153 |
extern int shash(); |
154 |
extern char *savqstr(); |
155 |
extern void freeqstr(); |
156 |
extern double tcos(); |
157 |
extern int wordfile(); |
158 |
extern int wordstring(); |
159 |
extern char *atos(); |
160 |
extern char *nextword(); |
161 |
extern char *sskip(); |
162 |
extern char *sskip2(); |
163 |
extern char *iskip(); |
164 |
extern char *fskip(); |
165 |
extern int isint(); |
166 |
extern int isintd(); |
167 |
extern int isflt(); |
168 |
extern int isfltd(); |
169 |
extern int xf(); |
170 |
extern int invxf(); |
171 |
extern int fullxf(); |
172 |
extern int quadtratic(); |
173 |
extern void eputs(); |
174 |
extern void wputs(); |
175 |
extern void quit(); |
176 |
177 |
#else |
178 |
/* defined in badarg.c */ |
179 |
extern int badarg(int ac, char **av, char *fl); |
180 |
/* defined in bmalloc.c */ |
181 |
extern char *bmalloc(unsigned int n); |
182 |
extern void bfree(char *p, unsigned int n); |
183 |
/* defined in error.c */ |
184 |
extern void error(int etype, char *emsg); |
185 |
/* defined in expandarg.c */ |
186 |
extern int expandarg(int *acp, char ***avp, int n); |
187 |
/* defined in fdate.c */ |
188 |
extern time_t fdate(char *fname); |
189 |
extern int setfdate(char *fname, long ftim); |
190 |
/* defined in fgetline.c */ |
191 |
extern char *fgetline(char *s, int n, FILE *fp); |
192 |
/* defined in fgetval.c */ |
193 |
extern int fgetval(FILE *fp, int ty, char *vp); |
194 |
/* defined in fgetword.c */ |
195 |
extern char *fgetword(char *s, int n, FILE *fp); |
196 |
/* defined in fputword.c */ |
197 |
extern void fputword(char *s, FILE *fp); |
198 |
/* defined in fixargv0.c */ |
199 |
extern char *fixargv0(char *av0); |
200 |
/* defined in fropen.c */ |
201 |
extern FILE *frlibopen(char *fname); |
202 |
/* defined in getlibpath.c */ |
203 |
extern char *getlibpath(void); |
204 |
/* defined in getpath.c */ |
205 |
extern char *getpath(char *fname, char *searchpath, int mode); |
206 |
/* defined in portio.c */ |
207 |
extern void putstr(char *s, FILE *fp); |
208 |
extern void putint(long i, int siz, FILE *fp); |
209 |
extern void putflt(double f, FILE *fp); |
210 |
extern char *getstr(char *s, FILE *fp); |
211 |
extern long getint(int siz, FILE *fp); |
212 |
extern double getflt(FILE *fp); |
213 |
/* defined in process.c */ |
214 |
extern int open_process(int pd[3], char *av[]); |
215 |
extern int process(int pd[3], char *recvbuf, char *sendbuf, |
216 |
int nbr, int nbs); |
217 |
extern int close_process(int pd[3]); |
218 |
extern int readbuf(int fd, char *bpos, int siz); |
219 |
extern int writebuf(int fd, char *bpos, int siz); |
220 |
/* defined in rexpr.c */ |
221 |
extern int ecompile(char *sp, int iflg, int wflag); |
222 |
223 |
extern void expset(char *ep); |
224 |
extern char *eindex(char *sp); |
225 |
/* defined in savestr.c */ |
226 |
extern char *savestr(char *str); |
227 |
extern void freestr(char *s); |
228 |
extern int shash(char *s); |
229 |
/* defined in savqstr.c */ |
230 |
extern char *savqstr(char *s); |
231 |
extern void freeqstr(char *s); |
232 |
/* defined in tcos.c */ |
233 |
extern double tcos(double x); |
234 |
/* defined in wordfile.c */ |
235 |
extern int wordfile(char **words, char *fname); |
236 |
extern int wordstring(char **avl, char *str); |
237 |
/* defined in words.c */ |
238 |
extern char *atos(char *rs, int nb, char *s); |
239 |
extern char *nextword(char *cp, int nb, char *s); |
240 |
extern char *sskip(char *s); |
241 |
extern char *sskip2(char *s, int n); |
242 |
extern char *iskip(char *s); |
243 |
extern char *fskip(char *s); |
244 |
extern int isint(char *s); |
245 |
extern int isintd(char *s, char *ds); |
246 |
extern int isflt(char *s); |
247 |
extern int isfltd(char *s, char *ds); |
248 |
/* defined in xf.c */ |
249 |
extern int xf(XF *ret, int ac, char *av[]); |
250 |
extern int invxf(XF *ret, int ac, char *av[]); |
251 |
extern int fullxf(FULLXF *fx, int ac, char *av[]); |
252 |
/* defined in zeroes.c */ |
253 |
extern int quadtratic(double *r, double a, double b, double c); |
254 |
/* miscellaneous */ |
255 |
extern void eputs(char *s); |
256 |
extern void wputs(char *s); |
257 |
extern void quit(int code); |
258 |
259 |
#endif |
