1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* Miscellaneous definitions required by many routines. |
7 |
8 |
9 |
#include <stdio.h> |
10 |
11 |
#include <sys/types.h> |
12 |
13 |
#include <fcntl.h> |
14 |
15 |
#include <math.h> |
16 |
17 |
#include <errno.h> |
18 |
19 |
#include "mat4.h" |
20 |
/* regular transformation */ |
21 |
typedef struct { |
22 |
MAT4 xfm; /* transform matrix */ |
23 |
FLOAT sca; /* scalefactor */ |
24 |
} XF; |
25 |
/* complemetary tranformation */ |
26 |
typedef struct { |
27 |
XF f; /* forward */ |
28 |
XF b; /* backward */ |
29 |
} FULLXF; |
30 |
31 |
#ifndef PI |
32 |
#ifdef M_PI |
33 |
#define PI ((double)M_PI) |
34 |
#else |
35 |
#define PI 3.14159265358979323846 |
36 |
#endif |
37 |
#endif |
38 |
39 |
#ifndef F_OK /* mode bits for access(2) call */ |
40 |
#define R_OK 4 /* readable */ |
41 |
#define W_OK 2 /* writable */ |
42 |
#define X_OK 1 /* executable */ |
43 |
#define F_OK 0 /* exists */ |
44 |
#endif |
45 |
46 |
#ifndef int2 |
47 |
#define int2 short /* two-byte integer */ |
48 |
#endif |
49 |
#ifndef int4 |
50 |
#define int4 int /* four-byte integer */ |
51 |
#endif |
52 |
53 |
extern int eputs(), wputs(); /* standard error output functions */ |
54 |
55 |
/* error codes */ |
56 |
#define WARNING 0 /* non-fatal error */ |
57 |
#define USER 1 /* fatal user-caused error */ |
58 |
#define SYSTEM 2 /* fatal system-related error */ |
59 |
#define INTERNAL 3 /* fatal program-related error */ |
60 |
#define CONSISTENCY 4 /* bad consistency check, abort */ |
61 |
#define COMMAND 5 /* interactive error */ |
62 |
#define NERRS 6 |
63 |
/* error struct */ |
64 |
extern struct erract { |
65 |
char pre[16]; /* prefix message */ |
66 |
int (*pf)(); /* put function (resettable) */ |
67 |
int ec; /* exit code (0 means non-fatal) */ |
68 |
} erract[NERRS]; /* list of error actions */ |
69 |
70 |
#define ERRACT_INIT { {"warning - ", wputs, 0}, \ |
71 |
{"fatal - ", eputs, 1}, \ |
72 |
{"system - ", eputs, 2}, \ |
73 |
{"internal - ", eputs, 1}, \ |
74 |
{"consistency - ", eputs, -1}, \ |
75 |
{"", NULL, 0} } |
76 |
77 |
extern char errmsg[]; /* global buffer for error messages */ |
78 |
79 |
#ifdef FASTMATH |
80 |
#define tcos cos |
81 |
#define tsin sin |
82 |
#define ttan tan |
83 |
#else |
84 |
extern double tcos(); /* table-based cosine approximation */ |
85 |
#define tsin(x) tcos((x)-(PI/2.)) |
86 |
#define ttan(x) (tsin(x)/tcos(x)) |
87 |
#endif |
88 |
/* custom version of assert(3) */ |
89 |
#define CHECK(be,et,em) ((be) ? error(et,em) : 0) |
90 |
#ifdef DEBUG |
91 |
#define DCHECK CHECK |
92 |
#else |
93 |
#define DCHECK(be,et,em) 0 |
94 |
#endif |
95 |
/* memory operations */ |
96 |
#ifdef NOSTRUCTASS |
97 |
#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) |
98 |
#else |
99 |
#define copystruct(d,s) (*(d) = *(s)) |
100 |
#endif |
101 |
102 |
#ifdef BSD |
103 |
extern long lseek(); |
104 |
#else |
105 |
#define bcopy(s,d,n) (void)memcpy(d,s,n) |
106 |
#define bzero(d,n) (void)memset(d,0,n) |
107 |
#define bcmp(b1,b2,n) memcmp(b1,b2,n) |
108 |
#define index strchr |
109 |
#define rindex strrchr |
110 |
extern off_t lseek(); |
111 |
#endif |
112 |
extern long ftell(); |
113 |
114 |
extern char *nextword(), *sskip(), *sskip2(); |
115 |
extern char *getpath(), *getenv(); |
116 |
#ifndef malloc |
117 |
extern char *malloc(), *calloc(), *realloc(); |
118 |
#endif |
119 |
extern char *bmalloc(), *savestr(), *savqstr(); |
120 |
121 |
#ifdef DCL_ATOF |
122 |
extern double atof(); |
123 |
#endif |
124 |
125 |
#ifdef MSDOS |
126 |
#define NIX 1 |
127 |
#endif |
128 |
#ifdef AMIGA |
129 |
#define NIX 1 |
130 |
#endif |
131 |
